Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Ford
> Explorer/Explorer Sport Trac |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
99 Epxl Sport -- Low Gas Mileage
Engine Problem
tranny
97 Explorer Sport 4x4 Blinks 6 times
skip
What did I do to my trany!?!?
1998 Ford Explorer Idle Problems
Tonneau cover trouble
1998 Explorer - High idle, rough automatic shifting, running hot - Water pump??
U-Haul WTF?
'95 Ford Explorer Humming
Cruise Control Lights on Steering Wheel
HP on a 97 SOHC 4.0L?
Check engine light and codes
1994 Ford Explorer Keyless Entry
CD Player Problems!!!
Electric Side Mirror switch wiring.
Headlights plastic is cloudy: Any fixes?
engine stalls after warm start
97 XLT Explorer auto start Location ?
transmission question
Rear wheel and Diff bearings on 94 trac-lock
93 explorer rear door problems
Starter interrupt
billet grill question
Fuse - Drivers seat 1996 explorer
remote starter
99 explorer with Rear window wiper problem
New 04 XLS in NEED of CD changer - help!
sound from the rear end
Broken Gas Pedal
alarm doesnt disengage from drivers side
4x4
99 explorer idles rough at startup
Need help replacing lower ball joints!!!
97 Check Engine Light/Rough Idle - HELP PLEASE!
vacuum lines for 4x4
97 Explorer XLT: Installing Reverse Gauges
Power steering air purge
wiring diagram for a ford explorer 4.0L
headlamps and foglamps do not work
94 Explorer heater works only on high
91-94 Which tranny is worse?
Power door locks keep re-locking (intermittent)
Engine Lifter Problem?
Check Oil Light wont go...can anyone help?
Automatic Hubs going bad again?
4x4 problems
vibration on acceleration
push button 4x4 problems
was I taken for a ride?
Dashboard icons & warning lights on a 1997 Ford Explorer
#3 cylender mis firing..why
1997 Explorer XLT Erratic Alarm!!
2001 Expolrer-Check Gauge Light/Temp Gauge
Grinding sound from the front end
Subwoofer Wiring Harness???
Are Explorers Not Supposed To Start
Oil in Anti-Freeze
Door won't open. Can I take panel off/elec. latch not working?
alarm stopped working??
Help with automatic hubs
Spraying raw gas out of exhaust, a lot?
Anyone know where the factory amp is on a 1997 Ford Explorer?
fuses
2002 Explorer Idle Troubles
brakes replacement 1993 exlporer
Adding a Message Center...
Chirping noise in 2002 Ford Explorer
interior and exterior lights "pulsating" while idling...
interior light staying lit.
Heat only after 45 minutes
Back Doors will not open from the inside!!!
1997 ford explorer console cd changer
clock goes dim, not the battery?
Check engine light on
Check Engine light on
91 Explorer Valve lifter noise.
raido
Engine Temp/Loss of Power
Alarming Noise
4 wheel drive does not engage
rear wiper problems
engine/oil gage problems
Fuse Help
96 Explorer XLt Engine Dies when cold
Help!!! Temp Guage???
93 to 98 OEM wheel swap
1993 4 wheel drive won't engage
Lack of heat in a '93
reading color code from my explorer
Help with coolant leak
Blinking lights problem
I need a parts Explorer
air suspension system
Radio/CD Display
Alarm Going Crazy!
what is the value of a 98 4x2 sport?
automatic to manual trans
2001 Sport Trac Question
problems with 94 Expl 4 wheel drive
Transmission or ?
Replacing hinge pins
Engine dies after ride when I shift into park?
Heat 1996 Explorer
2002 Explorer gauges not working
Multifunction switch
woman question
Chirping Sound new Explorer
Bad subwoofer??
Intermittent wipers on a 97 Ford Explorer XLT
Keyless entry
Dashboard Lighting - 96 explorer
96 explorer indicator light
1996 Explorer dome lights & rear wiper
won't idle at cold start
93 Sport Door Handles
Knocking at noramal operating temp
Sport ride quality upgrade
Clutch problem 98 exp sp
Odometer/Trip Odometer Inop
Grinding/Metal Screech sound when accelerating...
Reset check engine light
I'm Stupid
2002 Sound System
1994 EXP tranny ?
Explorer or DUrango
Explorer - TWO solenoids?!? No start!
FS: 96 sport very sharp
no start after hot soak
Tranny question
96 explorer subwoofer
ABS Idiot Light
96 Explorer "hesitating" steering in park
Ticking with acceleration
Dumb fuse blowing question
easy to install keyless entry system?
93 explorer 5 spd
93 explorer starting
1996 Ford Explorer Billet Grill
2003 Explorer Wiring....HELP!!!
2002 front door seals leaking at 16,000 miles
Rides worse than a lumber wagon
96 radio upgrade
99 Explorer Sport Rough Starting
94 5 speed
2000 Ford Explorer alarm gone psychotic!!
94 Overdrive. When to use?
Explorer 5.0 Headers
Rough Idle in 2002 Explorer
98 explorer eratic idle no w/no engine light
Check Engine Light on '92 Explorer
98 Explorer Wiring Schematic
OBD2 Scanner Needed Or Not?
Location of vehicle alarm for 1994 Ford Explorer
96 XLT Keyless Remot Programming
96 Air Vents
Ceck Engine Light
93 explorer Overdrive
Explorer 4.0 ohc block/pan ladder girdle?
wiring diagram for center console heater
1992 Eddie Bauer power window problem
Removing overhead console
95 Explorer Blinking Overdrive Light
1997 V8 Egr sensor?
temperature control problems
center floor cosole wiring
how easy?
Problem with VSS?
'95 Transmission - to where?
Largest possible tires
Rear seal leakage
Starter Problems on 93 FordExp
1997 Explorer lift and fog lights
94 Ford Explorer 4 Wheel Drive Problems
looking to buy 93 explorer
98 Explorer shock absorbers
explorer auto locking in Drive
99 Explorer knocking
Scan Tool for 95 XLT
wiring 94 explorer
98 check engine light...
Woman question here.
6 cd changer
what is this?????
Keyless Entry Code
Odd Engine Sounds, Please Help!
Xenon Lights and Dome Bulbs
2001 Explorer Limited - Rear Defroster, Backup Sensor, Overdrive button, Auto Lock
HELP O2 Sensor!
99 Explorer Overdrive Light Blinking
Wheres the amp
Grinding/clicking noise from the front end
Heat!!!!!
2001 Sport Trac Starting Problems (Fuel Related?)
18" Detata Profiler 6LUG Wheels On Pirelli Tires FOR SALE!
4.0 5 speed 4 wheel drive question?
truck overheating but gauges do not indicate overheating
Motor Madness 10/18/03
94 Explorer - Replacing Factory Speakers
1993 Ford Explorer gas gauge question
Rough & Noisey ride???? I am thinking of buying a Explorer
Travelling problems
92 Explorer trans problem
Minor Paint flaws
92 Ford Explorer power window
Explorer 2003 woes
'92 Explorer Heater Core Replacement
check gauge light
Idlie problems 97'
93 explorer loosing transmission fluid
1997 loweing springs?
97 Explorer - Check Engine P0153 code
hitch wiring for 95 Explorer
1992 Explorer head gasket replacement
Engine Light on after Oil change
gauge lights going out one by one
PCV Valve location on 96' Ford Explorer
I Can't open my 1997 Explorer with my keyless remote but it open with a tahoe remote
spinning rims
2000 XLT door entry programming
2002 woes
Ford Remote Keyless entry module
hoping for a quick fix on my tail light!
Programming a 94 Explorer Key Fob
2000 Explorer Overheating
ford keyless remote alarm programming
Air Ride System
All Interior lights to blue
body kits
Interior light color change
differential seals leaking
Explorer sport mods
94 Ford Explorer Eddie Bauer model Trans problems
332 and 538 error codes on 95 exp
02-03 explorer trannys
93 explorer compression test
Mods to 2000 Explorer?...
check engine test readings....
2002 Drive shaft question
1997 Ford Explorer alarm issues
2003 Transmission Problems!!!!
explorer keyless entry
1996 Explorer Remote Needs Programming
how long will an explorer last!
2k engine sputtered and died
Loud sound from my '97 Explorer
Web
AF
