View Full Version : Explorer | Explorer Sport Trac
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19
  1. 97 AWD AUTO TRANS hard swift into 2nd
  2. Fuse Panel, 1998 Explorer
  3. 92 ford explorer (bad oil pump or pickup screen?)
  4. 4x4 light flashing+stays engauged
  5. Vehicle falling apart
  6. 97 Ford Explorer - No Power
  7. 2002 explorer valve spring break
  8. Fuel Problem
  9. Gas Pedal Fell Off - 1997 Explorer
  10. Reprogramming a keyless entry keypad on door
  11. '95 Explorer problems
  12. 98 Explorer Transmission hard shifting
  13. air ride suspension
  14. Transmission hunt between 3rd and 4th
  15. Transmission Swap? Is it Possible?
  16. removing instrument cluster on 01 sport
  17. 2000 explorer idle air
  18. auxiliary power point--- cigarett lighter ?
  19. Please Help OBD code P0442
  20. code reader wont work 91 explorer
  21. door and rear speakers
  22. Rough Idle on Cold Start
  23. miss under a load
  24. Thumping Sound Coming From Right Front
  25. 1993 Explorer vibration
  26. Oil Change Problems
  27. Help code P0153, but I get no readings from any of the o2...
  28. Stalls
  29. 95 Explorer JBL subwoofer blown?? Help???
  30. Idle Problem - 2001 Explorer
  31. 1993 Explorer remote entry program
  32. Acceleration
  33. AC Clicking noise 1997 EB
  34. Engine oil change
  35. 99 explorer
  36. custom turbo for a 92 4.0?
  37. 2000 Explorer XLT
  38. 02 Explorer Rear Brake problem
  39. OverDrive Light
  40. 2004 explorer keypad code
  41. O/D Light Flashes
  42. Too much heat, 96 Explorer
  43. Headrest
  44. Want to replace my original tires
  45. 95 ford explorer over drive light wont shut off
  46. 93 Ford Explorer XLT - POS Alarm
  47. 97 Explorer, I hear the blower but no air
  48. 03 Explorer hard to shift from Drive to Park.
  49. 2000 Eddie Bauer front Stabilizer bushing
  50. '93 Ford Explorer issues - help please
  51. 98 explorer headlight problem
  52. 2000 Ford Explorer Driver Seat
  53. The thump thump heart beat
  54. 1998 Explorer, adding a Cd Changer
  55. 94 Explorer tail light
  56. Radio display going out; CD won't work
  57. need radio wire diagram
  58. 92 explorer
  59. Problems Starting
  60. ABS Faulty Wheel Sensor Replacement?
  61. 94 Explorer EGR valve
  62. Weird problems with a 99 Explorer.
  63. Park/running lamps wont turn off...
  64. Front Suspension
  65. automatic climate control
  66. 2001 Explorer Sport Computer Module location
  67. 1998 ford explorer alarm light flashing no start???
  68. Installing Command Start and Keyless entry
  69. shaking.. is this normal?
  70. fuse panel
  71. What tires are on your explorers?
  72. Thermo control switch for electric fan?
  73. explorer won't idle when cold
  74. Transmission Problems 2004 Limited Explorer
  75. 92 Ex Clear Signal lenses
  76. 98 explorer - yet another one not starting
  77. 2002 Explorer
  78. 2002 Explorer in dash cd changer has 2 stuck cds
  79. Bleed hydraulic system
  80. Rim Job (heh)
  81. locate tcs switch on 96 explorer.
  82. Trans. Od. Problems!
  83. 1998 Ford Explorer No brakelights
  84. 91 Tranny Shudder
  85. Where can I find the driver side computer?
  86. Rear windshield wiper question
  87. 94 Explorer Xlt Rear 1/4 panel
  88. 96 explorer ltd
  89. Outside temp. gauge not wkg
  90. Ford Explorer Sprot Help
  91. tranny question
  92. 4x4 hub conversion
  93. shocks and knocking
  94. 1994 Ford Explorer
  95. 91 Explorer aftermarket remote keyless entry help
  96. 97 Explorer ABS Problem
  97. air bag code 37
  98. HELP!!Hose wont stay on EGR sensor 97Expl 4.0
  99. 1999 E/B explorer trans slipping 2nd to 3rd shift
  100. 2002 explorer auto 4w drv
  101. Door lock number pad reset
  102. Stuck CD Changer?
  103. stearing wheel shakes?
  104. 02 explorer lock/start keyless entry
  105. Desperate!! Need help with driver door handle!!!
  106. 02 Explorer - extended warranty recommendations?
  107. 2000 explorer radio lights and now the instrument light quit working and answers?
  108. Ford Explorer EB '01 back doors won't open from inside
  109. 92 4x4 Explorer auto tranny prob
  110. Electric 4x4 does not work?
  111. decal for ford explorer
  112. 97 Eddie Bauer 4WD- many problems - Please help!
  113. transmission noise
  114. What's better?
  115. power lost radio now quit work correctly
  116. Couple of engine codes for your reading pleasure...
  117. 99 Explorer Sport not a lot of heat
  118. my 96 explore sport make noise when accelerating
  119. noise from brakes
  120. drivers power lock
  121. 94 explorer
  122. engine overheating - almost
  123. wire harness
  124. Bearing, Shocks easy really.
  125. 1994 explorer oil consumption
  126. 94 dome lights
  127. horn/tuba sound in engine area also low rear end
  128. Wont Start
  129. 1998 Front Brake Pad Replacement
  130. Starter problem
  131. 93 sport lighting problems
  132. Front end rattle/klunk
  133. problem with moonroof in 1999 Explorer
  134. 1993 Explorer Door Lock Problem
  135. Transmission problem - finally after 482,000 miles!!!
  136. 92' Explorer Transmission Question
  137. Explorer Indicator (turn) tail light bulbs
  138. 98 Exp Sport starting problems
  139. 1996 Explorer Pwr Door Locks Wont Lock
  140. RSS & FACTORY CODE
  141. odd beep
  142. Explorer alarm keeps going on
  143. gas gauge question
  144. Raw gasoline smell.....
  145. Will not start......still
  146. Tire pressure
  147. Explorer wont start
  148. 1997 Explorer - Fast Idle
  149. HELP - engine flooding/not idleing correctly
  150. torque specs
  151. 93/99 Explorer Radio Swap
  152. 2000 Explorer XLS
  153. horsepower question
  154. will help alot of people out
  155. 94 MAP Sensor
  156. Radio Problem - Please Help!
  157. Air Conditioner squeling
  158. aftermarket remote starter
  159. Big Radio Problems
  160. Headlight problem
  161. 2002 ford explorer
  162. 96 Explorer XLT for sale!!! Great Price!!!
  163. 96 rough idle
  164. Ford Explorer Auto Locks
  165. Saleen Explorer??
  166. Head lights
  167. IAC Valve
  168. 2000 Ford Explorer engine ticking noise
  169. Explorer 98 power locks
  170. Replacing 98 Engine with 2002
  171. For Sale: Crystal clear corner lenses
  172. 98 Explorer problems - LOTS!!!
  173. '97 Explorer 4x4 problem, ate front diff.
  174. Access to Passenger plugs - 1997
  175. blower stays on high, even when ignition switch is off
  176. Tranny slipping And Exhaust Rattle
  177. transfer case failure/jake brake sound
  178. 96 Rattle noise
  179. Explorer tranny problem
  180. 2002 Sport Trans Problem
  181. 91 Auto Trans Question
  182. 96 explorer sport starting headache
  183. FS: EXPLORER 2dr 4wd 5 speed
  184. 93 tranny problem
  185. 1994 Headlight Adjustment Screw
  186. Explorer Anti-theft System
  187. 1998 Explorer fuel (gas) gauge issue
  188. WHere is IAC valve??
  189. blower directional switch
  190. 94 4x4 check engine light
  191. 95 Explorer Wipers
  192. 92 Explorer Deisels
  193. '92 4x4 wont engage.....
  194. oil specifications
  195. power window
  196. 96 exp rough idle and cutting out
  197. No idle on my Explorer
  198. 5.0 Exhaust Leak
  199. ford explorer alarm removel
  200. 91 Explorer Speedometer Cable Replacement
  201. 98 Explorer Sport
  202. idle air screw keeps backing out of the throttle body
  203. Explorer wont start! What do we check next?
  204. 02-03 headrest different?
  205. Who makes the 4WABS for Ford?
  206. transmission gasket replacement
  207. 2002 Odometer problem
  208. 2002 Explorer Sun Roof
  209. 91 Explorer Trans- HELP!
  210. 98 explorer odd starting problem
  211. Jammed locks
  212. 1992 explorer overheating
  213. 1993 Explorer Sport 4x4 Transmission
  214. gas tank and manuel
  215. exhuast upgrade
  216. front end vibration
  217. 91 explorer trans trouble
  218. 1998 Explorer 4x4 problem
  219. Do not flush Tranny
  220. '92 Explorer 4 Dr Eddie Bauer for sale/parting out!
  221. Humming sound from rear
  222. 04 XLT Hesitation / Accelerator Delay
  223. how do i make my explorer burn out?
  224. Is there a special tool to remove frt seat belt anchor (98 explorer)?
  225. Check Gage. Low oil pressure
  226. 98 explorer hood release cable snapped
  227. volume control on radio - 94 explorer sport
  228. Ignition/Tumblers
  229. squealing noise
  230. 2001 ford sport trac
  231. rough Idle with a 94 explorer
  232. What gear lube do I use-Front and Rear?
  233. Windows, Radio, Some Interior Fixes are OUT
  234. What are Settings for Timing Chain on 1997 Ford Explorer?!
  235. 1995 Limited Stuck Moon Roof
  236. keyless entry pad on drivers door
  237. 94 Explorer Black sut smoke
  238. Tranny Problem/ Transfer Case?
  239. 97 Explorer - overheating
  240. 98 Explorer - Brake Lights Out
  241. Noise from engine believed to be timing chain
  242. 2000 5-speed auto Transmission
  243. Replacing 93 Exp Control Arm Bushings
  244. 2002 Explorer Starting Trouble
  245. 2001 Exp Sprt Blower mtr replaced-works on hi only
  246. 91 eddie bauer 4x4
  247. Won't hold idle
  248. squeeking rear doors
  249. 95 explorer blend door!!
  250. Rear axle plate?
