Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Ford
> Explorer/Explorer Sport Trac |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
98 Ford explorer check engine light
leans to one side
cid sensor?
Explorer '96 V8 "Stutters"
whirling noise
Door Locks and oil sensor
heat/ AC Fan stopped blowing
96 Expolrer Transmission
tires and alignment issues
2002 Ford Explorer Black Coating
Kyeless entry on 1996 Explorer
93 Transmission/engine problem.
tranny driving me nuts
AC Clutch Engages/Disengages
Trans gone south?
Take my ford to the dealership for maintenance and repairs or to any regular bodyshop
ALtenator
Explorer for sale
Transmission fluid
Oil change?
upper/lower ball joints on a 95 explorer
99 Explorer Sport
2003 Handling woes
Radio Display problem........
00-03 Explorer Sport (redesigned)
97 Explorer – shocks???
94 Explorer A/C blower
98 Explorer power window problem
2000 Explorer noise/vibration when turning from a stop
2000 for explorer lacks power
power window problems
94 ford explorer wont shift into overdrive.
Where is PCV on 94 Explorer V6 4.0?
96 engine replacement
02 Explorer trans went out - do this!
tranny problems on 97 explorer!
Turn signals don't work
small hole leaking engine coolant
98 OD light blinking
Anyone Know A 1992 Explorer Bolt Pattern?
fuel pump
what is your fuel milage??
Explorer Sport Brush Guards?
2002 explorer windshield wiper problem
Fuse Panel, 1996 Ford Explorer
please help! Explorer won't start
94 ford explorer eddie bauer fuel kill switch
fuel gauge
2000 Explorer Recalls
95 Explorer 4x4 Not Engaging
Piston issues
Explorer XLT 94' When turning from stop rear makes grinding noise
keypad entry disable or new code entry
Where is thermostat?
running boards-side step rails ford exp
1994 Ford Explorer 4x4 5 speed
Bumpy ride/stiff shocks
1998 Ford Explorer Transmission Problem..
Tachometer, fuel gauge, oil pressure gauge not working.
94 Explorer Transmission / Engine Problem
someone please help 1994 explorer loosing power
02 Explorer Suspension Squeaky
power window switches
keyless entry not working on drivers door
Keypad entry programming
02 vibration noise in drivetrain
97 explorer - tranny problem?
1994 Ford Explorer Losing Power
2004 explorer limited wont turn over
Has anyone used a K&N intake?
worth
94 Explorer
Rewiring Radio, som help needed please
getting at the gauges
Rear door
1994 4X4 not working
Dual Alternators
1997 Explore 4wd Low Light Blinks
grinding in the front end
1996 Explorer Sport clutch/transmission? not right! Any suggestions?
2001 Burning Smell
Can someone answer my questions about a Explorer?
Alternator/Total Amps on 1995 Explorer
Fog Light question
94 explorer has high beams but no low beams
Warning lights flash..Windows don't work
Explorer Questions
92 explorer transmission
No Start 92
1995 Explorer new sound system help
1997 Sport door chime
2002 transmission oil- thanks O.H.
OD light flashing....again.
Tire diameter question
1996 Explorer Sport Fuel Filter
1991 Explorer 4.0 blowing eec maxi fuse !
factory entry code for 1987 nissan maxima
2000 Explorer Transmission
Overheating after 2mi
Drivers door unlock switch inoperative
Plug Keeps Melting???
94 4*4 Ford Explorer Tranny problems!!
pulling to the right
Iac & mas sensors
Need transmission help please!!
2002 transmission oil change?
Overheating & alternator.
98 XLT - Check Engine Diagnostic Codes
Programming 2002 Keyless Remote
It does not start anytime ???? HELP
1993 Tran Problem?
98 Explorer Sport not spraying washer fluid
Rough idle
rough idle on hot start
92 Explorer Surges
92 Explorer trailer connection
intake noise when hot
Squeaking noise
1998 ford explorer keypad
No Heat (Burrr!)
91 Explorer Engine Shake when switching to overdrive
explorer trans problem
99 explorer rough ridle and ride
2001 explorer sport door entry programming
'94 Explorer Acceleration
99 Explorer Sport Engine Noise
Piece of junk explorer!
96 Explorer DTC P0154, Replace All 02 Sensors?
daytime running lights
FS: 1995 Explorer Service Manual
engine light
Jeep Cherokee vs Ford Explorer
02 hood moves a lot NORMAL?
98 Explorer XLT has sporadic idle then stalls+Engine light
2002 Explorer Limited V8 idle stall
Message center
96 Explorer, Check engine light on for 3rd time, help!
Found Source of engine noise
Engine Advice
2000 Explorer revs when clutch pedal depressed
96 exp. sport-manual trans shifting problems
96 ford explorer--call father marin-its possessed!!
2002 Keyless Entry Break-In
window trim removal
Help~Interior fan stays on all the time
Help!! Transmission powershifts
Right Tire Shakes
99 explorer stalling when driving and stopping
rough idle
Loud Noise
Keyless entry
2001 Clock radio set/program
Heated Seat problems
95-99 explorer mild lift?
Amplifier Location?
2000 Explorer tailgate problems
2001 Explorer Engine
1991 ford explorer
egr
351w in 92 explorer ?
Radio/Speaker Wiring Problems
98 Explorer Transfer Case
Adjusting 96 Explorer Parking Brake
2000 Ford Explorer O/D light flashing!!!
93 radio fuse location?
95 Explorer 4x4 auto tranny fluid capacity??
Dead Stereo Fuse Slot
Broken Antenna '96 Explorer
Wiring diagram 91explorier 4wd
Need help OPERA HOUSE ...if your around
98 sport trouble starting
Need transmission help !!!
2000 Explorer burning extreme amount of gas
Reprogramming Keyless Entry
Need '95 JBL subwoofer
99 explorer trouble starting when cold
96 Explorer shifting issue?
95 Explorer power steering pump replacement
1998 Ford Explorer Alarm
20" rims 4 sale
1998 explorer 4.0 ( spark knock?)
1995 Explorer Premium sound, PROBLEMS!
securilock/1key .no horn/alarm 1998
keyless entry on 1996 ford explorer
95 Explorer 4x4 stalling when coming to a stop
Loud squeak 1998 Explorer
96 Explorer break issue
Wiring Problems Engine keeps cranking without a key in ignition
Help with fuses to replace
brake liights and controller
99 Explorer 4.0 4R44 Trans Help
check engine light comes on
my 2000 explorer is driving me nuts!!!!
Problem Starting
02 Explorer High Pitched Whistle Sound
2000 Ford Explorer Transmission Trouble
2002 Ford Explorer front crank seal leaking
Desperate Transmission help
Changing instrument cluster on 2002 Explorer
(experts needed)costly mistake, but need help ASAP
'93 Explorer Check Engine Light
2000 Explorer - Where is IAT sensor
99 explorer
91 Explorer 4 Wheel Drive Grinding
Where is the PCV valve?
temp guage
1994 Explorer with engine knocking?
Front Suspension...please Help!!!
Explorer Trailer Wiring???
92 EB spark knock. Has new open air intake
99 explorer Lean Right, Left Bank code
Tranny problems
94 explorer with 4 wheel drive problems - should I buy car?
ford explorer overhead console wiring diagram
97 Acceleration/deceleration noise
93 4x4 problem
98 v8 engine noise
Purdue ME design course survay
Amp Wiring!!
Low Beam Headlights Gone, One at a time
AC modes control on 2002 Explorer
4x4 wont disengage
wiring diagram
Replacing Torn Leather Seats
Rear defrorst 95 Explorer Limited
95 Explorer Wiring Diagram JBL Antenna
Explorer not starting
'95 Exp. oil in my air filter?
99 Explorer Rear Wiper not working
Sports trac high pitch whistling sound?!
Daytime running lights.
Defroster/Heater Core
92 4 Wheel won't Engage/Whirring Sound
96 Heater Problem - Difficult?
2002 Explorer Sport Keyless Entry on the fritz
What's my problem??
Escorts Key Worked In '97 Explorer...!
Needed Help
no 4x4 lo
Shifting Problem
Keyless Entry System Module-Where is it?
i need a radio wiring diagram for a 97 explorer
Transmission Fluid change - mystery check valve?
Mysterious Explorer Starting Problems..
"clattering" 2000 explorer sport 4.0 ohv
just got 91 explorer and it has a starting problem
Extreme Power Loss
1996 Idle increase/decrease with possible hissing noise!
2002 Explorer Gas pedal vibration
1998 Explorer Keys
Web
AF
