Ford
> Explorer | Explorer Sport Trac
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
Changing the rear speakers
Clips in fuel line for fuel filter
92 Failed Smog....again
Engine (drone) noise @ idle
2002 Ford Explorer XLT(Left Door)
Final Warranty Checklist for 2002
Fuel filter replacement
Replacing a Lock Nut Key
Headlights
95 Explorer radio wiring question???
1991 Explorer
explorer roof
Cold Start Iddle Porblems
A/C and Heat blow through the Deffoger only
1994 Explorer Shift Problem
Horn wont work
1992 IAC Valve Question
94 explorer fuel gauge not working and sparkknocking
93 Ford Explorer No Power
Better Breaks (I want 4 wheel Disc...)
Spark Plug Recomendations...
New Wheel Studs... (Longer?)
Electric / Manual 4WD
tune up explorer on regular basis
What should I torque my lug nuts at?
Rpm
Fluids Mixing
1994 Major Oil Leak
92 Explorer 2WD Clutch Replacement
1995 explorer trans
Overhead Console
Newbie with a question
93 ticking
1997 Oxygen sensor replacement
Clutch Master cylinder....
Radio on 2003
peddle to master cylinder connection
Audio Help
Pin Point Squeak in Front Pass Suspension
2001 Sport Trac Airbag Module Location
torsion bars adjustment
92 with transmission issues
2002 4WD contoler
1997 explorer fuse list
97 explorer 4x4 flashing on dash
98 explorer tranny issues
Clutch linkage
Timing chain
Oil Pressure Guage Problem
97 Explorer 4x4 engaging all the time
91 water pump removal and replacement
2003 Ford Explorer KeyPad Code??
1997 Ford Alarm Problems
transmission filter
rough idle on 99 ford explorer
1991 Explorer 4x4 issues
6 Disc CD Player Not Playing
2002 explorer start problems
Camshaft Sensor
Weird noise at 3000 rpm
1992 explorer with4.0
4 Speed or 5 Speed in 1998 XLT?
"E"
clutch adjustment,91 explorer
Where is the Power Antenna Cable?!?!?
Explorer Trans Shudder
You guessed it TRANSMISSION trouble 91
A few problems
drain plug has a rubber gasket
spark outside the engine,94 ford expl
(97 Explorer Sport 4X4 Lower Ball Joints
2002 explorer
97 explorer installing streetglow LEDs
it all started with the electric locks
98 Rear Axle/Pinion Gear Question
2002 explorer random steering vibration/shudder when turning from stop
92 explorer 4wd problems
97 Explorer Control Trac
98 explorer radio cd player
2002 Explorer Transmission Bad @ 55,000
Montero vs Trooper vs Explorer-buying used
94 Explorer stalling in reverse after starting
yet another problem with our explorer!!!help
explorer 98 dash lights
Looking to buy a 2002 Exporer Sport Trac
Is there a site that lists ALL recalls?
Starting
4 wheel drive possible probs code P1729
94 explorer auto trans shifting issues
Air Suspension to Regular Suspension
roaring noise under the hood
PCV Valve
2000 explorer websites
remote starter wiring diagrahm
94 Explorer XLT question
cold engine idle problem
Car Turns Off while Driving...Anyone Know?
CD Player Lighted Display Out. How replace bulb?
Missing cylinder
Thermometer sensor
1996 Explorer wiring harness
98 explorer lamp out module????
Amplifier location in a 1991 Explorer
99 Explorer Sport 4.0 SOHC IAC Replaced What Else is wrong?
1999 ford explorer 4.0 sohc
93 Explorer 4WD doesn't work
98 explorer lights???
Rear Shocks on a 98' Sport, HELP PLEASE...
Oil gauge 98 sport
97 Explorer 4wd Problem with front wheels
'91 transmission problems?
96 Explorer Overhead console
1994 Transmission
92 explorer overdrive problems
Interior lights out
ticking when cold
FS - Custom 2 10" Subwoofer Box for Explorer
99 side mirror lights???
high beams on
98 explorer body lift kit???
97 Explorer v8 0455 large leak
We came, We read, We tried******
codealarm system
92 Explorer, Engine Plug Leak or gasket problem
1991 ford 4 door explorer rear window regulator cable
97 Explorer front hubs problem?
Interior Light
Audio Install
98 explorer- release gas pedal and engine stalls
1993 Explorer No dash lights
A Lot Of Your Questions Can Be Answered
New steering column problem
98 Exploder with NO HEAT!
Blower motor
4wd not working help!!!!!!!!
EGR code 1400 solution
Any Video Footage
Breaks Moaning
programming remotes...anyone know how?
1998 ford explorer xlt turn signal problems
'94 Pinging and Rattling
Reprogram 1997 Keypad/ Touchpad
Limited wheel needed
Fs 91 Explorer parting out
98 explorer no dash lights
94 explorer starting and stalling problem
02 Explorer
Transmission Shot??
CODE WEBSITE again****************
1993 no start problem... help
1991 Explorer
Sometimes Starts othert times NO Start 99
egr
Can't pull latch to hood, hood won't open
Starts up when hot and then dies
found a codes website, bookmark it
passenger rear tire locks up when braking
how do u set the timing
96 explorer 4.o liter hot start
Code P0230-Please I need Help
keycode
Remote Starter Help
changing the MAF (mass air flow sensor)
99 ford explorer hard to crank problem iac valve humming
CLUNK when stopping - rear driveshaft u-joint?
Grinding Noise Front Left Wheel, when Reverse to the Left
FACTORY keypad code stolen
1999 Ford Explorer Fuel Filter Replacement
Explorer Burnout
1996 Upper Brake Light Out--$250!?
Help Changing AIC sensor
just bought a sport 2001
Let it be known I am not an expert mechanic
mass air flow sensor replacement, does the...
Whats wrong with my Explorer?
Shock Absorbers
Battery keeps going dead
What if I did this to the MAF and....
steering wheel fluid leaks out
radio display repair
4wd
Abs Light
help changing rear break pads
Radiator Leak
92 Navajo 2wd Torque converter prob.
98 Spt how to remove cowl panels
hub bearing replacement
Winter is hear but my 4WD is not...
Warning on back brake lines
MAP (manifold absolute pressure) sensor??
Replacing and oxygen (0 2) sensor
WTB: Have HUGE parts list
94 won't start
1991 Ford Explorer
Ford Explorer Needs Help
2002 Alarm ..red light Question
98 Explorer Spt. - Brake Lights Out
no LO Beams
97 Explorer Speedometer and odometer intermittently work
reverse sensor
Automate AM6 in 2001 Explorer
'96 Explorer rear panel removal
Explorer noob
stuck on brake lights
Brake wire
2002 O/D Light Flashing
91' sport....Won't start
2000 Explorer starting "stutter"
I can't believe that
EATC Retrofit
2002 Fuel Meetering Code
system in my explorer
Ford 4.0 OHV Engines
Are Explorers Problem Prone?
94 explorer quits
2000 explorer wont run when started cold.
inspection due
2002 Explorer Keyless Remote
tow AWD?
1997 Explorer Limited Temperature COntrol
97 Ford Explorer Left Low Beam Problem
Battery drain
1997 Ford Explorer XLT Generic Electronic Module
rattle from moonroof
sport trac remote keyless entry program
Driver side mirror replacement
4x4 on a 2002 How does it work?
problem with my 96
Electric Problem With Swtich on Door
91 Explorer fuel pump stays on
1991 serpentine belt breakage
97 explorer awd (not working???)
help with fuses!!!!
Ford Explore 1993 fan only works on high speed where is the relay located
Engine Block Drain on 4.0 SOHC ???
My Explorer is haunted
Common Transmission Issues Question?
97 and up BRAND NEW roof rack.
1993 xlt-abs pump going out
Looking for advise ...
Rear Wiper Problems on a 98' Explorer Sport
2001 Ford Explorer Sport 2wd
2000 Explorer starting problem
Interior lights stay lit
weird feeling when turning
2002 Explorer Sport Trac 4X4 Engagement Issues
Trans Slipping HELP
1992 4x4 won't engage
Disperate/tran Slipping
99 explorer overhead console
