View Full Version : Explorer/Explorer Sport Trac
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17
  1. squeeking rear doors
  2. 95 explorer blend door!!
  3. Rear axle plate?
  4. 1993 explorer xlt 4x4 wont engage
  5. Leaking transmission fluid...gaining oil?
  6. 1998 power windows, sunroof & wipers don't work
  7. Rear Hatch, and passenger side door.
  8. adding a cd changer to explorer
  9. 2004 Explorer LTD chimes
  10. Help with a 1994
  11. Anyone know of any websites that sell ford mods?
  12. Speedo dances?
  13. how to replace broken lug bolts?
  14. Pulsating ABS brakes on 1996 explorer
  15. questions alarm system
  16. Too tight?
  17. 91 bad cold start, rough idle, underpowered
  18. Poor AM Reception
  19. ford hum
  20. removing inner door panel 99 xlt
  21. 92 Explorer AC clutch not engaging
  22. 2003 Explorer Engine Swap
  23. engine noise
  24. Need extra money for mods, etc. Go here to make some easy money
  25. 1993 Explorer Sport 4x4 Electrical Questions
  26. Speed/Cruise Control 1995 Explorer V6 4.0 ltr
  27. driver side power locks don't work
  28. Need Help With Billet Grille*
  29. Centennial Edition!!
  30. Explorer Disc Breaks Squeal
  31. Got a new aftermarket Radio and my factory 6 disc changer doesn't work
  32. neutral tow feature
  33. Where is IAC and how do I clean it?
  34. Car wont stay running and theft light blinks!
  35. Honking Remote
  36. 2001 Explorer Sport Electrical System
  37. replacing 96 eng with 2000 eng
  38. websites for selling?
  39. Rear Hatch won't open 92 explorer - Help!
  40. help - can't find pcv valve in 92 explorer
  41. Finding Error Codes on 93 Explorer..
  42. passenger side door lock not working
  43. Wheels
  44. 96 XL clunking when cold in 2wd ok in 4wd
  45. 2002 explorer tailgate cracking
  46. Another Name for IAC?
  47. Inner Door handle
  48. 98 EB Power door locks
  49. 93 Explorer problems
  50. 93 transmission overheating???
  51. 94 Explorer engine dies with no faults detected
  52. Rear Hatch won't open - Help!
  53. 2002 Ford Explorer Sport Keypad Code
  54. 2002 Ford Explorer Sport
  55. Check Engine Light 98 Explorer 5.L V8
  56. Replacing oil pressure switch and other questions
  57. 98 explorer sport rear wiper probs....
  58. 1998 Fuse Diagram - Help!
  59. Ignition Electrical Problem
  60. 2000 Explorer front end hum
  61. low Idle
  62. Fog Light Re-wiring on '98 Explorer
  63. How is your explorer holding up
  64. '00 explorer idling up and down when i start it up.
  65. CD eject noise
  66. 95 explorer od/off light blinking
  67. Explorer makes grinding noises
  68. Oil Leak
  69. bigger tires
  70. 1991 Explorer no 4th gear
  71. Front and rear drive axle-What lubricant do i use??
  72. new..94 Explorer headlight out
  73. 98 Explorer - Prob. w/Auto Door Locks & Rear Wiper
  74. Overheat/lack of power
  75. Gooey Steering Wheel
  76. 1996 explorer 4x4 transfer case problem
  77. oil reset on 2003 explorer eddie bauer
  78. 91 exp.starves for fuel when shifting gears
  79. 95 Ford Explorer Transmission
  80. Lowering your Explorer?
  81. replacing alternator on 94
  82. rough idle
  83. driver side door lock non functional
  84. Fuse ID guide for 1993 Explorer
  85. Rear Wiper Replacement
  86. 96 Explorer, Cranks but won't start
  87. Electrical Problems
  88. '99 Explorer, no turn signals
  89. 1997 Explorer ALL WHEEL DRIVE with Poping sound on left front side
  90. Driver's seat belt
  91. Power Steering
  92. sub problems with mach audio system
  93. clatter at start up
  94. Fs: Ford Explorer
  95. Horn on 95 Explorer
  96. rear wiper
  97. Air Induction
  98. Rear A/C unit clicking noise
  99. 2002 air vent changes under strain
  100. Explorer dies when making Right Turns
  101. 91 explorer bell housing
  102. cruise control
  103. ABS Light on 2000 XLT V8
  104. Tranny problem?
  105. 2002 Explorer message center
  106. More power...
  107. 99 Explorer 4x4 runs but won't idle...
  108. '01 XLT-a/c quit, warning light, overheat
  109. rear rotors 1996 explorer
  110. Drivers Window Works Intermittently...
  111. fuel kill switch
  112. need help antifreeze leak
  113. 1992 ford explorer cruise control
  114. 92 Transmission Swap
  115. Brake lights do not work!
  116. airbag code
  117. Master Repair Kit
  118. Explorer JBL Amp
  119. 2002 Explorer XL Vent
  120. back roll pan (bumper)
  121. just wondering
  122. no horn/air bag light on
  123. IAC and MAF valves. How do you clean?
  124. 97 explorer p0455 Cehck engine light
  125. 1992 Explorer for sale (parts)
  126. Panel Removal.
  127. Tool to remove Rotor Bolt?
  128. 94 EXPLORER was this a tune-up?
  129. 1997 explorer door lock problem
  130. Where ar door switches?
  131. 98 Explorer 4x4 lights flash no engage
  132. explorer sport alternator
  133. Explorer Lean
  134. 98 Explorer - Open door Chime Alarm
  135. Check Engine light
  136. Plastic trim paint code 96 eddie bauer
  137. HELP! 93 explorer fuel problems
  138. 2002 Explorer idle question (dealer is clueless)
  139. Explorer won't
  140. Windows can be pull down outside the vehicle!
  141. Drivers side door sags...bad lower hinge?
  142. Estimate For 1993 Ford Explorer 5 Speed Transmission
  143. automatic to 5 speed conversion
  144. Popping sound 2000 ford explorer xls
  145. 4L V6 engine swap
  146. 96 explorer fuel tank prob
  147. 96 ford explorer
  148. horn doesn't work
  149. Where is the fuel "kill switch" reset button
  150. Cranks but won't start-1998
  151. 99 explorer wont stay on!
  152. Power Windows
  153. Oil pressure guage
  154. 20 inch wheels on and 1992
  155. New to the board explorer niose Q's
  156. 2002, smoking 4.0 L
  157. Better fuel mileage
  158. No Brake lights
  159. Blowing white smoke..Strong Gas odor
  160. 96 4.0 engine screech
  161. 2002 Explorer Tailgate Problem
  162. 98 Explorer Sport Wiring Issues
  163. Problem with 4L
  164. 2000 explorer stalls when put into gear
  165. AC - 97 Explorer
  166. 95 Explorer cranks, won't start...for awhile
  167. 96 Expl. Cat bad or not?
  168. 94 explorer transmission
  169. alternater
  170. barely visible odometer display
  171. Crankshaft sprocket removal.
  172. AC compressor clutch doesn't engage
  173. mass air flow senser
  174. Fuel Leaking from top of gas tank
  175. 1997 Ford Explorer - AC Problem
  176. Body Kits
  177. squeaky pedal
  178. Cell Phone Kit?
  179. Explorer gets hot and gags under load!
  180. 96 eddie bauer- cd player trouble
  181. Vibration Under Driver's Floor
  182. 1994 explorer coolant/oil leak
  183. Problem w/locking mechanism...can anyone help?
  184. 94 Explorer won't start
  185. would anyone send me a schematic 91 explorer
  186. replacing front brake pads
  187. spark plug change 1995 exp. V6
  188. Building a real-life Jurassic Park Explorer
  189. for lamps
  190. what amp alternator is in
  191. 1996 explorer factory alarm starts for no reason and then car won't start
  192. 91 explorer speaker wiring
  193. 1997 Explorer 4.0l Efi Firing Order
  194. 1991 ford explorer shock absorbers
  195. '98 - where is the camshaft censor at? P0340
  196. chime sound
  197. 02 Explorer Tran Problem/ Please Help
  198. 2002 Explorer Fuel Filter
  199. mysterious noise - 96 Explorer xlt auto
  200. Left Turn Signal Is Possessed
  201. Interesting radio/cd problem and front wipers too!!!
  202. 93 Explorer
  203. 98 Explorer turn signal not working
  204. Look here for 2002 factory keypad code
  205. 2002 Engine Roar
  206. 92 Explorer Sport Rans Problem
  207. New to Explorer
  208. gas milage problem
  209. My Explorer is for sale "LOOK"
  210. Problems with 02 F.O.R.D.(fix or repair daily) Explorer
  211. Amp in Premium Sound
  212. Bull Guard for a 02+ Explorer?
  213. '04 Explorer XLT Sport Heat Whistling
  214. 97 SOHC Engine Help
  215. Keyless entry door code?
  216. 2000 explorer xlt wont start unless i hold the gas wide open
  217. Just bought a 92 Explorer 4X4
  218. 91 ford explorer for sale
  219. 96 Explorer 4WD Problem
  220. Explorer hood
  221. 1993 Explorer Transmission Problems Please Help
  222. 1992 Explorer Clutch replacement method
  223. Rotor needs turned
  224. I've LOST a few HORSES on my engine....
  225. fuel milage
  226. Door lock and switches 96
  227. 2003 XLT 4.0 engine noise driving me nuts!
  228. Engine Seized!
  229. Explorer fuel injector
  230. 94 explorer transmission
  231. OBD Code
  232. cps
  233. Replacing Alternator on 93'
  234. 92 Expl. Air Intake Heater?? Need help!
  235. '00 explorer front wheel noise
  236. Engine noise
  237. Check Engine, need advice!
  238. Hello, and Explorer stalling (desperate)
  239. air condition blowing hot air full of freon 98 explorer
  240. 2001 Explorer Sport for Sale. A Gem!!!
  241. Every 3000 miles or every 3 months?
  242. 98 Ford explorer check engine light
  243. leans to one side
  244. cid sensor?
  245. Explorer '96 V8 "Stutters"
  246. whirling noise
  247. Door Locks and oil sensor
  248. heat/ AC Fan stopped blowing
  249. 96 Expolrer Transmission
  250. tires and alignment issues
