View Full Version : Explorer | Explorer Sport Trac
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19
  1. 98 Explorer Sport Horn
  2. Diagnosing Oxygen Sensor
  3. Thinking of buying a 2000 explorer sport...Transmission though..
  4. 98 explorer audio problems/possible dead or fried speakers/wires
  5. Front left speaker cutting out
  6. 94 headlight lom issue?
  7. 1993 Ford Explorer XLT Rear Wiper not moving
  8. How do you check fuel pressure on 1993 4.0
  9. 91 Explorer Starts Sometimes
  10. 93 Explorer 4.0 Coolant Leak
  11. 2004 Explorer spooling like turbo
  12. rear main seal
  13. 2001 Explorer Sport rear turn and brake light issue.
  14. remote entry and check engine
  15. 02 Explorer cold seats?
  16. 97 Explorer Head Gasket..?
  17. 99 explorer washer pump fuse keeps blowing?
  18. 1996 Explorer, lost power when driving
  19. 92 explorer not charging/replaced alternator
  20. insufficient airflow from vents
  21. 94 Ford Explorer vacuum tubes
  22. transfer case 1996 Explorer Sport
  23. 99 Explorer 4x4 mileage drop off
  24. Good news to explorer owner
  25. Rough idle and stalling
  26. 96 explorer hatch problem + a few other things
  27. 1994 For Sale
  28. 2000 Exp brake lights out
  29. Explorer 99 XLT - Rough Cold Start, Semi Rough Idle
  30. Check engine light and clunking engine `96 Limited
  31. clear coat 02 problems
  32. door locks broken
  33. installing security systems
  34. 1992 Explorer idles good and takes off like a turtle
  35. strange noises don't know the cause
  36. 92 explorer 4x4 not working
  37. is my 98 xlt 4.0 blown
  38. NEED Fuse Panel Diagram 99 Explorer XLT
  39. Metallic buzzing sound??
  40. 2000 Transmission Delay From Stop
  41. Driver side Power Lock
  42. 99 explorer Noise/Thump from RF tire area, need assistance
  43. 92 Explorer GUAGES NOT WORKING, 4WD not working
  44. jump start....wrong???
  45. '95 Explorer Power Windows
  46. 2003 Explorer owners manual
  47. 1994 Explorer Limited - Towing/Rear Lighting info.
  48. Help Help Help
  49. 97 Explorer - Fast Idle
  50. 97 Explorer High Idle
  51. explorer surging
  52. 1991 Explorer Check Engine Light
  53. 94 Explorer Sport stuck in 4 low
  54. 97 Explorer Shocks?
  55. voltage gauge
  56. 95 explorer lower ball joints
  57. Where is the EGR located on a 2000 Exp
  58. Rear Differential
  59. Misfire on cylinder xx
  60. Wiper Relay
  61. car wont start
  62. Labor for waterpump change $255 too high?
  63. Is it a Lemon or a 2002 Explorer Sport? Rear End & Belt PLEASE HELP
  64. High miles '95 w/Power Steering Issue
  65. lights stopped flashing
  66. Check Engine
  67. 96 Explorer XLT Power windows/wipers/int. lights not working
  68. 95 ford explorer replacing the heater core
  69. interior light on 95/96 Explorer
  70. trouble codes
  71. Keyless entry reset????
  72. Can I replace only 2 Tires on 1999 4wd Exporer?
  73. 1997 Differential
  74. Rear Diff Problem- Please Help!!!!!!
  75. Are codes wrong?
  76. Rough idle ,,,various other problems
  77. Safety(?) switch on tranny
  78. Check Engine Light!!! 91 Explorer
  79. 97 Explorer Heater Blend door
  80. Need help with power Window regulators
  81. 98 Explorer Tranny problem?
  82. 98 Ford Explorer P1762 code
  83. 1991 Explorer
  84. 97 oil guage freaks-out at low RPM
  85. Help My Hood Latch Is Broke
  86. How to remove center arm rest 2000 EXPLorer
  87. 1992 explorer 4x4
  88. 1997 Explorer Heat control
  89. 1993 Explorer - lots of heat, but gauge reads low
  90. 93 explorer noise
  91. 2002 Won"t Idle
  92. Is there any common 95 or 98 explorer problems
  93. 1994 - Excessive play in the steering
  94. 91 explorer clutch problem
  95. cd player
  96. Pioneer in Dash 6 Disk Changer/MP3 Player
  97. Dome light problem
  98. Fuel gauge problem
  99. HELP Pease! freeze plugs
  100. 2002 Explorer Seat belt alarm.
  101. Auto lighting on 1998 Ford Explorer quit working
  102. Help: 01 Explorer Sport won't shift into 4x4 Low
  103. Do You Need Your Radio Light Repaired?
  104. My Ford 96 drinks too much fuel and there is air coming from the tank
  105. 2002 Sport Trac Brakes
  106. stalling when shifting from reverse to drive
  107. wheres my keys
  108. Rear tailight problem 2001 Explorer Sport
  109. transmission hard to shift when cold?
  110. 1998 Exploere 4wd problems
  111. Blend Door Revisited (quick fix didn't take) 1996
  112. Trouble with slidding
  113. No Heat in 1993 Explorer
  114. 95 Explorer questions?
  115. Ford Explorer Parts!!!!!!!!!!!!!
  116. 94 Explorer Loud Vibrations
  117. Please help when I keep driving on speed above 120 km/h O/D on off starts alerting
  118. 91 ford explorer tranny problems
  119. O2 Sensor wire on top of transmission
  120. 92 Ford explorer: SPEEDOMETER
  121. Heater Blower Motor
  122. very little heat, temp gauge doesn't move- 99 Explorer
  123. rusted rocker
  124. Extended Warranty Info
  125. 99 tailgate keeps getting stuck shut
  126. Keyless Entry or Not?
  127. factory anti-theft
  128. 1996 Explorer
  129. 94 Explorer 4x4 doesn't work
  130. melted on/off cruise control switch
  131. 92 Ford Explorer will not start
  132. my explorer is growling
  133. Hydrolock--- Good site
  134. 95 chevy blazer 4x4 button sticking
  135. 91 explorer 4x4 not engauging
  136. HELP! Explorer rough idle, can't figure it out!
  137. 91 explorere no 4x4 doesnt light or try to shift into
  138. Can over torqued lug nuts affect brakes?
  139. Keyless Remote problem
  140. 99 brake issues
  141. 98 explorer tranny problems
  142. Grounds
  143. 93 exp power window problem
  144. Problem with Lights
  145. '94 Explorer electrical Q
  146. wipers
  147. 97 Explorer Heater Valve
  148. 92 explorer turn signals
  149. Fuel gauge problem
  150. 2001 keyless entry problem
  151. 94 hood release button?
  152. new subwoofer question
  153. Wiring diagram for 92 ford explorer
  154. '99 Explorer Front end noise
  155. 4x4 low: rear wheel not spinning
  156. Clutch Fan to Electric Radiator fan help?
  157. 92 Explorer will not go into overdrive
  158. Burned out lights in steering wheel cruise control buttons
  159. rear hatch glass
  160. 1993 Exp Electrical Problem?
  161. Gas problems
  162. OEM Nerf Bars/Running Bars
  163. no display in radio
  164. 92 Explorer 12 mpg
  165. 96 explorer stuck in 4WD low
  166. Replacing battery cables
  167. 1998 Eddie Bauer won't start/new battery
  168. 91 Explorer pwr steering
  169. Can't open my hood!
  170. Remotes will not re-program
  171. 94 Explorer stock alarm
  172. Passanger foot rest right side panel?
  173. Thermastat location '94 Explorer
  174. running lights
  175. Insight on the Explorer
  176. '99 Explorer - ABS and Traction Control bugs
  177. AC Compressor will not engage on 92 Explorer
  178. Front brakes are not releasing
  179. 4 X 4 won't engage
  180. 1997 Ford Explorer XLT V8 EGR VAlve
  181. Electric 4x4
  182. AirBag Rediness Light & winding noise when accelerating
  183. washer nozzle freezes
  184. 1992 Explorer Clicks, but Won't Start
  185. 2002 explorer trans probs...
  186. Power?!?!
  187. Can I over ride the immobiliser?
  188. 99 Explorer, head gasket,heat,vacuum hose...
  189. 97 explorer 5R55E OD light blinking
  190. help finding glass
  191. It passed
  192. oder from ducts
  193. 99 Explorer, "fluid" in spark plug
  194. 1997 transmission rebuilt but clunking and shifting hard
  195. Wirless Keypad Entry Installation
  196. Another transmission problem
  197. O2 sensor replacement help
  198. Rear Door Latch Problem, Please Help!
  199. change transmission fluid-yes or no?
  200. Keypad Code Location
  201. Electrical Problems Please Help
  202. Rich burn on 91
  203. 92 Explorer 10mpg
  204. Bypass filtration
  205. 95 Ford Explorer Alarm won't Shut off
  206. '97 Ford Explorer; water pump
  207. Will Not Start
  208. Still feels like it will stall...
  209. Explorer w\ a go cart clutch?
  210. Radio light display burned out
  211. Installing Sirius, want it to shut off with thte car
  212. 94 explorer engine layout
  213. ABS prob with 4X4 probs
  214. Temp gage dont work in 94
  215. 1994 Transmission - Advice
  216. Using air bags to lower an Explorer.
  217. Hard Shift 1-2 and TC Locking problems
  218. Synthetic oil vs. Standard? 02 sport trac
  219. 4WD Survey (Manual or Electric)
  220. where are door sencors located?
  221. ball joints 01 mountaineer/explorer
  222. 93 Explorer 4WD busted
  223. 2001 Sport Keypad Code Help
  224. 92' exploder experiencing unique tranny issues...please help!
  225. faulty defroster in 02 Explorer
  226. 91 explorer window problems
  227. CD PLAYER Light OUT. Don't wanna get ripped.
  228. 91 ford explorer eddie bauer edition
  229. 1995 Explorer Temp Gauge
  230. 1995 Explorer A/C problem
  231. 91 Explorer passenger power window motor
  232. and good 2002 Ford Exp.
  233. Torsion Bars
  234. 1991 Explorer Heater screeching
  235. 2001 Ford Explorer Console Wiring
  236. Changing the rear speakers
  237. Clips in fuel line for fuel filter
  238. 92 Failed Smog....again
  239. Engine (drone) noise @ idle
  240. 2002 Ford Explorer XLT(Left Door)
  241. Final Warranty Checklist for 2002
  242. Fuel filter replacement
  243. Replacing a Lock Nut Key
  244. Headlights
  245. 95 Explorer radio wiring question???
  246. 1991 Explorer
  247. explorer roof
  248. Cold Start Iddle Porblems
  249. A/C and Heat blow through the Deffoger only
  250. 1994 Explorer Shift Problem
