Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Ford
> Explorer/Explorer Sport Trac |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
Cold start trouble
No sound?
over drive off light blinking...trannys acting funny
97 AWD AUTO TRANS hard swift into 2nd
Fuse Panel, 1998 Explorer
92 ford explorer (bad oil pump or pickup screen?)
4x4 light flashing+stays engauged
Vehicle falling apart
97 Ford Explorer - No Power
2002 explorer valve spring break
Fuel Problem
Gas Pedal Fell Off - 1997 Explorer
Reprogramming a keyless entry keypad on door
'95 Explorer problems
98 Explorer Transmission hard shifting
air ride suspension
Transmission hunt between 3rd and 4th
Transmission Swap? Is it Possible?
removing instrument cluster on 01 sport
2000 explorer idle air
auxiliary power point--- cigarett lighter ?
Please Help OBD code P0442
code reader wont work 91 explorer
door and rear speakers
Rough Idle on Cold Start
miss under a load
Thumping Sound Coming From Right Front
1993 Explorer vibration
Oil Change Problems
Help code P0153, but I get no readings from any of the o2...
Stalls
95 Explorer JBL subwoofer blown?? Help???
Idle Problem - 2001 Explorer
1993 Explorer remote entry program
Acceleration
AC Clicking noise 1997 EB
Engine oil change
99 explorer
custom turbo for a 92 4.0?
2000 Explorer XLT
02 Explorer Rear Brake problem
OverDrive Light
2004 explorer keypad code
O/D Light Flashes
Too much heat, 96 Explorer
Headrest
Want to replace my original tires
95 ford explorer over drive light wont shut off
93 Ford Explorer XLT - POS Alarm
97 Explorer, I hear the blower but no air
03 Explorer hard to shift from Drive to Park.
2000 Eddie Bauer front Stabilizer bushing
'93 Ford Explorer issues - help please
98 explorer headlight problem
2000 Ford Explorer Driver Seat
The thump thump heart beat
1998 Explorer, adding a Cd Changer
94 Explorer tail light
Radio display going out; CD won't work
need radio wire diagram
92 explorer
Problems Starting
ABS Faulty Wheel Sensor Replacement?
94 Explorer EGR valve
Weird problems with a 99 Explorer.
Park/running lamps wont turn off...
Front Suspension
automatic climate control
2001 Explorer Sport Computer Module location
1998 ford explorer alarm light flashing no start???
Installing Command Start and Keyless entry
shaking.. is this normal?
fuse panel
What tires are on your explorers?
Thermo control switch for electric fan?
explorer won't idle when cold
Transmission Problems 2004 Limited Explorer
92 Ex Clear Signal lenses
98 explorer - yet another one not starting
2002 Explorer
2002 Explorer in dash cd changer has 2 stuck cds
Bleed hydraulic system
Rim Job (heh)
locate tcs switch on 96 explorer.
Trans. Od. Problems!
1998 Ford Explorer No brakelights
91 Tranny Shudder
Where can I find the driver side computer?
Rear windshield wiper question
94 Explorer Xlt Rear 1/4 panel
96 explorer ltd
Outside temp. gauge not wkg
Ford Explorer Sprot Help
tranny question
4x4 hub conversion
shocks and knocking
1994 Ford Explorer
91 Explorer aftermarket remote keyless entry help
97 Explorer ABS Problem
air bag code 37
HELP!!Hose wont stay on EGR sensor 97Expl 4.0
1999 E/B explorer trans slipping 2nd to 3rd shift
2002 explorer auto 4w drv
Door lock number pad reset
Stuck CD Changer?
stearing wheel shakes?
02 explorer lock/start keyless entry
Desperate!! Need help with driver door handle!!!
02 Explorer - extended warranty recommendations?
2000 explorer radio lights and now the instrument light quit working and answers?
Ford Explorer EB '01 back doors won't open from inside
92 4x4 Explorer auto tranny prob
Electric 4x4 does not work?
decal for ford explorer
97 Eddie Bauer 4WD- many problems - Please help!
transmission noise
What's better?
power lost radio now quit work correctly
Couple of engine codes for your reading pleasure...
99 Explorer Sport not a lot of heat
my 96 explore sport make noise when accelerating
noise from brakes
drivers power lock
94 explorer
engine overheating - almost
wire harness
Bearing, Shocks easy really.
1994 explorer oil consumption
94 dome lights
horn/tuba sound in engine area also low rear end
Wont Start
1998 Front Brake Pad Replacement
Starter problem
93 sport lighting problems
Front end rattle/klunk
problem with moonroof in 1999 Explorer
1993 Explorer Door Lock Problem
Transmission problem - finally after 482,000 miles!!!
92' Explorer Transmission Question
Explorer Indicator (turn) tail light bulbs
98 Exp Sport starting problems
1996 Explorer Pwr Door Locks Wont Lock
RSS & FACTORY CODE
odd beep
Explorer alarm keeps going on
gas gauge question
Raw gasoline smell.....
Will not start......still
Tire pressure
Explorer wont start
1997 Explorer - Fast Idle
HELP - engine flooding/not idleing correctly
torque specs
93/99 Explorer Radio Swap
2000 Explorer XLS
horsepower question
will help alot of people out
94 MAP Sensor
Radio Problem - Please Help!
Air Conditioner squeling
aftermarket remote starter
Big Radio Problems
Headlight problem
2002 ford explorer
96 Explorer XLT for sale!!! Great Price!!!
96 rough idle
Ford Explorer Auto Locks
Saleen Explorer??
Head lights
IAC Valve
2000 Ford Explorer engine ticking noise
Explorer 98 power locks
Replacing 98 Engine with 2002
For Sale: Crystal clear corner lenses
98 Explorer problems - LOTS!!!
'97 Explorer 4x4 problem, ate front diff.
Access to Passenger plugs - 1997
blower stays on high, even when ignition switch is off
Tranny slipping And Exhaust Rattle
transfer case failure/jake brake sound
96 Rattle noise
Explorer tranny problem
2002 Sport Trans Problem
91 Auto Trans Question
96 explorer sport starting headache
FS: EXPLORER 2dr 4wd 5 speed
93 tranny problem
1994 Headlight Adjustment Screw
Explorer Anti-theft System
1998 Explorer fuel (gas) gauge issue
WHere is IAC valve??
blower directional switch
94 4x4 check engine light
95 Explorer Wipers
92 Explorer Deisels
'92 4x4 wont engage.....
oil specifications
power window
96 exp rough idle and cutting out
No idle on my Explorer
5.0 Exhaust Leak
ford explorer alarm removel
91 Explorer Speedometer Cable Replacement
98 Explorer Sport
idle air screw keeps backing out of the throttle body
Explorer wont start! What do we check next?
02-03 headrest different?
Who makes the 4WABS for Ford?
transmission gasket replacement
2002 Odometer problem
2002 Explorer Sun Roof
91 Explorer Trans- HELP!
98 explorer odd starting problem
Jammed locks
1992 explorer overheating
1993 Explorer Sport 4x4 Transmission
gas tank and manuel
exhuast upgrade
front end vibration
91 explorer trans trouble
1998 Explorer 4x4 problem
Do not flush Tranny
'92 Explorer 4 Dr Eddie Bauer for sale/parting out!
Humming sound from rear
04 XLT Hesitation / Accelerator Delay
how do i make my explorer burn out?
Is there a special tool to remove frt seat belt anchor (98 explorer)?
Check Gage. Low oil pressure
98 explorer hood release cable snapped
volume control on radio - 94 explorer sport
Ignition/Tumblers
squealing noise
2001 ford sport trac
rough Idle with a 94 explorer
What gear lube do I use-Front and Rear?
Windows, Radio, Some Interior Fixes are OUT
What are Settings for Timing Chain on 1997 Ford Explorer?!
1995 Limited Stuck Moon Roof
keyless entry pad on drivers door
94 Explorer Black sut smoke
Tranny Problem/ Transfer Case?
97 Explorer - overheating
98 Explorer - Brake Lights Out
Noise from engine believed to be timing chain
2000 5-speed auto Transmission
Replacing 93 Exp Control Arm Bushings
2002 Explorer Starting Trouble
2001 Exp Sprt Blower mtr replaced-works on hi only
91 eddie bauer 4x4
Won't hold idle
Web
AF
