View Full Version : Explorer/Explorer Sport Trac
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17
  1. Cold Start Iddle Porblems
  2. A/C and Heat blow through the Deffoger only
  3. 1994 Explorer Shift Problem
  4. Horn wont work
  5. 1992 IAC Valve Question
  6. 94 explorer fuel gauge not working and sparkknocking
  7. 93 Ford Explorer No Power
  8. Better Breaks (I want 4 wheel Disc...)
  9. Spark Plug Recomendations...
  10. New Wheel Studs... (Longer?)
  11. Electric / Manual 4WD
  12. tune up explorer on regular basis
  13. What should I torque my lug nuts at?
  14. Rpm
  15. Fluids Mixing
  16. 1994 Major Oil Leak
  17. 92 Explorer 2WD Clutch Replacement
  18. 1995 explorer trans
  19. Overhead Console
  20. Newbie with a question
  21. 93 ticking
  22. 1997 Oxygen sensor replacement
  23. Clutch Master cylinder....
  24. Radio on 2003
  25. peddle to master cylinder connection
  26. Audio Help
  27. Pin Point Squeak in Front Pass Suspension
  28. 2001 Sport Trac Airbag Module Location
  29. torsion bars adjustment
  30. 92 with transmission issues
  31. 2002 4WD contoler
  32. 1997 explorer fuse list
  33. 97 explorer 4x4 flashing on dash
  34. 98 explorer tranny issues
  35. Clutch linkage
  36. Timing chain
  37. Oil Pressure Guage Problem
  38. 97 Explorer 4x4 engaging all the time
  39. 91 water pump removal and replacement
  40. 2003 Ford Explorer KeyPad Code??
  41. 1997 Ford Alarm Problems
  42. transmission filter
  43. rough idle on 99 ford explorer
  44. 1991 Explorer 4x4 issues
  45. 6 Disc CD Player Not Playing
  46. 2002 explorer start problems
  47. Camshaft Sensor
  48. Weird noise at 3000 rpm
  49. 1992 explorer with4.0
  50. 4 Speed or 5 Speed in 1998 XLT?
  51. "E"
  52. clutch adjustment,91 explorer
  53. Where is the Power Antenna Cable?!?!?
  54. Explorer Trans Shudder
  55. You guessed it TRANSMISSION trouble 91
  56. A few problems
  57. drain plug has a rubber gasket
  58. spark outside the engine,94 ford expl
  59. (97 Explorer Sport 4X4 Lower Ball Joints
  60. 2002 explorer
  61. 97 explorer installing streetglow LEDs
  62. it all started with the electric locks
  63. 98 Rear Axle/Pinion Gear Question
  64. 2002 explorer random steering vibration/shudder when turning from stop
  65. 92 explorer 4wd problems
  66. 97 Explorer Control Trac
  67. 98 explorer radio cd player
  68. 2002 Explorer Transmission Bad @ 55,000
  69. Montero vs Trooper vs Explorer-buying used
  70. 94 Explorer stalling in reverse after starting
  71. yet another problem with our explorer!!!help
  72. explorer 98 dash lights
  73. Looking to buy a 2002 Exporer Sport Trac
  74. Is there a site that lists ALL recalls?
  75. Starting
  76. 4 wheel drive possible probs code P1729
  77. 94 explorer auto trans shifting issues
  78. Air Suspension to Regular Suspension
  79. roaring noise under the hood
  80. PCV Valve
  81. 2000 explorer websites
  82. remote starter wiring diagrahm
  83. 94 Explorer XLT question
  84. cold engine idle problem
  85. Car Turns Off while Driving...Anyone Know?
  86. CD Player Lighted Display Out. How replace bulb?
  87. Missing cylinder
  88. Thermometer sensor
  89. 1996 Explorer wiring harness
  90. 98 explorer lamp out module????
  91. Amplifier location in a 1991 Explorer
  92. 99 Explorer Sport 4.0 SOHC IAC Replaced What Else is wrong?
  93. 1999 ford explorer 4.0 sohc
  94. 93 Explorer 4WD doesn't work
  95. 98 explorer lights???
  96. Rear Shocks on a 98' Sport, HELP PLEASE...
  97. Oil gauge 98 sport
  98. 97 Explorer 4wd Problem with front wheels
  99. '91 transmission problems?
  100. 96 Explorer Overhead console
  101. 1994 Transmission
  102. 92 explorer overdrive problems
  103. Interior lights out
  104. ticking when cold
  105. FS - Custom 2 10" Subwoofer Box for Explorer
  106. 99 side mirror lights???
  107. high beams on
  108. 98 explorer body lift kit???
  109. 97 Explorer v8 0455 large leak
  110. We came, We read, We tried******
  111. codealarm system
  112. 92 Explorer, Engine Plug Leak or gasket problem
  113. 1991 ford 4 door explorer rear window regulator cable
  114. 97 Explorer front hubs problem?
  115. Interior Light
  116. Audio Install
  117. 98 explorer- release gas pedal and engine stalls
  118. 1993 Explorer No dash lights
  119. A Lot Of Your Questions Can Be Answered
  120. New steering column problem
  121. 98 Exploder with NO HEAT!
  122. Blower motor
  123. 4wd not working help!!!!!!!!
  124. EGR code 1400 solution
  125. Any Video Footage
  126. Breaks Moaning
  127. programming remotes...anyone know how?
  128. 1998 ford explorer xlt turn signal problems
  129. '94 Pinging and Rattling
  130. Reprogram 1997 Keypad/ Touchpad
  131. Limited wheel needed
  132. Fs 91 Explorer parting out
  133. 98 explorer no dash lights
  134. 94 explorer starting and stalling problem
  135. 02 Explorer
  136. Transmission Shot??
  137. CODE WEBSITE again****************
  138. 1993 no start problem... help
  139. 1991 Explorer
  140. Sometimes Starts othert times NO Start 99
  141. egr
  142. Can't pull latch to hood, hood won't open
  143. Starts up when hot and then dies
  144. found a codes website, bookmark it
  145. passenger rear tire locks up when braking
  146. how do u set the timing
  147. 96 explorer 4.o liter hot start
  148. Code P0230-Please I need Help
  149. keycode
  150. Remote Starter Help
  151. changing the MAF (mass air flow sensor)
  152. 99 ford explorer hard to crank problem iac valve humming
  153. CLUNK when stopping - rear driveshaft u-joint?
  154. Grinding Noise Front Left Wheel, when Reverse to the Left
  155. FACTORY keypad code stolen
  156. 1999 Ford Explorer Fuel Filter Replacement
  157. Explorer Burnout
  158. 1996 Upper Brake Light Out--$250!?
  159. Help Changing AIC sensor
  160. just bought a sport 2001
  161. Let it be known I am not an expert mechanic
  162. mass air flow sensor replacement, does the...
  163. Whats wrong with my Explorer?
  164. Shock Absorbers
  165. Battery keeps going dead
  166. What if I did this to the MAF and....
  167. steering wheel fluid leaks out
  168. radio display repair
  169. 4wd
  170. Abs Light
  171. help changing rear break pads
  172. Radiator Leak
  173. 92 Navajo 2wd Torque converter prob.
  174. 98 Spt how to remove cowl panels
  175. hub bearing replacement
  176. Winter is hear but my 4WD is not...
  177. Warning on back brake lines
  178. MAP (manifold absolute pressure) sensor??
  179. Replacing and oxygen (0 2) sensor
  180. WTB: Have HUGE parts list
  181. 94 won't start
  182. 1991 Ford Explorer
  183. Ford Explorer Needs Help
  184. 2002 Alarm ..red light Question
  185. 98 Explorer Spt. - Brake Lights Out
  186. no LO Beams
  187. 97 Explorer Speedometer and odometer intermittently work
  188. reverse sensor
  189. Automate AM6 in 2001 Explorer
  190. '96 Explorer rear panel removal
  191. Explorer noob
  192. stuck on brake lights
  193. Brake wire
  194. 2002 O/D Light Flashing
  195. 91' sport....Won't start
  196. 2000 Explorer starting "stutter"
  197. I can't believe that
  198. EATC Retrofit
  199. 2002 Fuel Meetering Code
  200. system in my explorer
  201. Ford 4.0 OHV Engines
  202. Are Explorers Problem Prone?
  203. 94 explorer quits
  204. 2000 explorer wont run when started cold.
  205. inspection due
  206. 2002 Explorer Keyless Remote
  207. tow AWD?
  208. 1997 Explorer Limited Temperature COntrol
  209. 97 Ford Explorer Left Low Beam Problem
  210. Battery drain
  211. 1997 Ford Explorer XLT Generic Electronic Module
  212. rattle from moonroof
  213. sport trac remote keyless entry program
  214. Driver side mirror replacement
  215. 4x4 on a 2002 How does it work?
  216. problem with my 96
  217. Electric Problem With Swtich on Door
  218. 91 Explorer fuel pump stays on
  219. 1991 serpentine belt breakage
  220. 97 explorer awd (not working???)
  221. help with fuses!!!!
  222. Ford Explore 1993 fan only works on high speed where is the relay located
  223. Engine Block Drain on 4.0 SOHC ???
  224. My Explorer is haunted
  225. Common Transmission Issues Question?
  226. 97 and up BRAND NEW roof rack.
  227. 1993 xlt-abs pump going out
  228. Looking for advise ...
  229. Rear Wiper Problems on a 98' Explorer Sport
  230. 2001 Ford Explorer Sport 2wd
  231. 2000 Explorer starting problem
  232. Interior lights stay lit
  233. weird feeling when turning
  234. 2002 Explorer Sport Trac 4X4 Engagement Issues
  235. Trans Slipping HELP
  236. 1992 4x4 won't engage
  237. Disperate/tran Slipping
  238. 99 explorer overhead console
  239. 98 explorer heat/ac
  240. Turn Sig's Die when on the Brake
  241. ford explorer gas conversoin
  242. 98 Explorer vibrations
  243. 2002 keyless entry dead
  244. 1999 Ford Explorer Repair Manual
  245. Fule Gauge Not Working!
  246. Reprogramming a new key for 01 sport
  247. Cruise control
  248. Door Lovks
  249. used car warranty
  250. Suspension parts
