View Full Version : Explorer/Explorer Sport Trac
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17
  1. 4wd Won't DisEngage
  2. Crack in Liftgate
  3. 98 xlt 5 speed?
  4. stock speaker removal of 98 Explorer xlt
  5. 98 oil guage problem again!
  6. Replacing Headlight Capsule in '94 Exp
  7. cleaning alloy wheels
  8. 98 Explorer....many faults
  9. Very interesting FACT !!! (check engine light related)
  10. HI FROMOZ...and my Explorer
  11. 2001 ford explorer brakes
  12. 1997 explorer wont start
  13. 98 Explorer Sport Horn
  14. Diagnosing Oxygen Sensor
  15. Thinking of buying a 2000 explorer sport...Transmission though..
  16. 98 explorer audio problems/possible dead or fried speakers/wires
  17. Front left speaker cutting out
  18. 94 headlight lom issue?
  19. 1993 Ford Explorer XLT Rear Wiper not moving
  20. How do you check fuel pressure on 1993 4.0
  21. 91 Explorer Starts Sometimes
  22. 93 Explorer 4.0 Coolant Leak
  23. 2004 Explorer spooling like turbo
  24. rear main seal
  25. 2001 Explorer Sport rear turn and brake light issue.
  26. remote entry and check engine
  27. 02 Explorer cold seats?
  28. 97 Explorer Head Gasket..?
  29. 99 explorer washer pump fuse keeps blowing?
  30. 1996 Explorer, lost power when driving
  31. 92 explorer not charging/replaced alternator
  32. insufficient airflow from vents
  33. 94 Ford Explorer vacuum tubes
  34. transfer case 1996 Explorer Sport
  35. 99 Explorer 4x4 mileage drop off
  36. Good news to explorer owner
  37. Rough idle and stalling
  38. 96 explorer hatch problem + a few other things
  39. 1994 For Sale
  40. 2000 Exp brake lights out
  41. Explorer 99 XLT - Rough Cold Start, Semi Rough Idle
  42. Check engine light and clunking engine `96 Limited
  43. clear coat 02 problems
  44. door locks broken
  45. installing security systems
  46. 1992 Explorer idles good and takes off like a turtle
  47. strange noises don't know the cause
  48. 92 explorer 4x4 not working
  49. is my 98 xlt 4.0 blown
  50. NEED Fuse Panel Diagram 99 Explorer XLT
  51. Metallic buzzing sound??
  52. 2000 Transmission Delay From Stop
  53. Driver side Power Lock
  54. 99 explorer Noise/Thump from RF tire area, need assistance
  55. 92 Explorer GUAGES NOT WORKING, 4WD not working
  56. jump start....wrong???
  57. '95 Explorer Power Windows
  58. 2003 Explorer owners manual
  59. 1994 Explorer Limited - Towing/Rear Lighting info.
  60. Help Help Help
  61. 97 Explorer - Fast Idle
  62. 97 Explorer High Idle
  63. explorer surging
  64. 1991 Explorer Check Engine Light
  65. 94 Explorer Sport stuck in 4 low
  66. 97 Explorer Shocks?
  67. voltage gauge
  68. 95 explorer lower ball joints
  69. Where is the EGR located on a 2000 Exp
  70. Rear Differential
  71. Misfire on cylinder xx
  72. Wiper Relay
  73. car wont start
  74. Labor for waterpump change $255 too high?
  75. Is it a Lemon or a 2002 Explorer Sport? Rear End & Belt PLEASE HELP
  76. High miles '95 w/Power Steering Issue
  77. lights stopped flashing
  78. Check Engine
  79. 96 Explorer XLT Power windows/wipers/int. lights not working
  80. 95 ford explorer replacing the heater core
  81. interior light on 95/96 Explorer
  82. trouble codes
  83. Keyless entry reset????
  84. Can I replace only 2 Tires on 1999 4wd Exporer?
  85. 1997 Differential
  86. Rear Diff Problem- Please Help!!!!!!
  87. Are codes wrong?
  88. Rough idle ,,,various other problems
  89. Safety(?) switch on tranny
  90. Check Engine Light!!! 91 Explorer
  91. 97 Explorer Heater Blend door
  92. Need help with power Window regulators
  93. 98 Explorer Tranny problem?
  94. 98 Ford Explorer P1762 code
  95. 1991 Explorer
  96. 97 oil guage freaks-out at low RPM
  97. Help My Hood Latch Is Broke
  98. How to remove center arm rest 2000 EXPLorer
  99. 1992 explorer 4x4
  100. 1997 Explorer Heat control
  101. 1993 Explorer - lots of heat, but gauge reads low
  102. 93 explorer noise
  103. 2002 Won"t Idle
  104. Is there any common 95 or 98 explorer problems
  105. 1994 - Excessive play in the steering
  106. 91 explorer clutch problem
  107. cd player
  108. Pioneer in Dash 6 Disk Changer/MP3 Player
  109. Dome light problem
  110. Fuel gauge problem
  111. HELP Pease! freeze plugs
  112. 2002 Explorer Seat belt alarm.
  113. Auto lighting on 1998 Ford Explorer quit working
  114. Help: 01 Explorer Sport won't shift into 4x4 Low
  115. Do You Need Your Radio Light Repaired?
  116. My Ford 96 drinks too much fuel and there is air coming from the tank
  117. 2002 Sport Trac Brakes
  118. stalling when shifting from reverse to drive
  119. wheres my keys
  120. Rear tailight problem 2001 Explorer Sport
  121. transmission hard to shift when cold?
  122. 1998 Exploere 4wd problems
  123. Blend Door Revisited (quick fix didn't take) 1996
  124. Trouble with slidding
  125. No Heat in 1993 Explorer
  126. 95 Explorer questions?
  127. Ford Explorer Parts!!!!!!!!!!!!!
  128. 94 Explorer Loud Vibrations
  129. Please help when I keep driving on speed above 120 km/h O/D on off starts alerting
  130. 91 ford explorer tranny problems
  131. O2 Sensor wire on top of transmission
  132. 92 Ford explorer: SPEEDOMETER
  133. Heater Blower Motor
  134. very little heat, temp gauge doesn't move- 99 Explorer
  135. rusted rocker
  136. Extended Warranty Info
  137. 99 tailgate keeps getting stuck shut
  138. Keyless Entry or Not?
  139. factory anti-theft
  140. 1996 Explorer
  141. 94 Explorer 4x4 doesn't work
  142. melted on/off cruise control switch
  143. 92 Ford Explorer will not start
  144. my explorer is growling
  145. Hydrolock--- Good site
  146. 95 chevy blazer 4x4 button sticking
  147. 91 explorer 4x4 not engauging
  148. HELP! Explorer rough idle, can't figure it out!
  149. 91 explorere no 4x4 doesnt light or try to shift into
  150. Can over torqued lug nuts affect brakes?
  151. Keyless Remote problem
  152. 99 brake issues
  153. 98 explorer tranny problems
  154. Grounds
  155. 93 exp power window problem
  156. Problem with Lights
  157. '94 Explorer electrical Q
  158. wipers
  159. 97 Explorer Heater Valve
  160. 92 explorer turn signals
  161. Fuel gauge problem
  162. 2001 keyless entry problem
  163. 94 hood release button?
  164. new subwoofer question
  165. Wiring diagram for 92 ford explorer
  166. '99 Explorer Front end noise
  167. 4x4 low: rear wheel not spinning
  168. Clutch Fan to Electric Radiator fan help?
  169. 92 Explorer will not go into overdrive
  170. Burned out lights in steering wheel cruise control buttons
  171. rear hatch glass
  172. 1993 Exp Electrical Problem?
  173. Gas problems
  174. OEM Nerf Bars/Running Bars
  175. no display in radio
  176. 92 Explorer 12 mpg
  177. 96 explorer stuck in 4WD low
  178. Replacing battery cables
  179. 1998 Eddie Bauer won't start/new battery
  180. 91 Explorer pwr steering
  181. Can't open my hood!
  182. Remotes will not re-program
  183. 94 Explorer stock alarm
  184. Passanger foot rest right side panel?
  185. Thermastat location '94 Explorer
  186. running lights
  187. Insight on the Explorer
  188. '99 Explorer - ABS and Traction Control bugs
  189. AC Compressor will not engage on 92 Explorer
  190. Front brakes are not releasing
  191. 4 X 4 won't engage
  192. 1997 Ford Explorer XLT V8 EGR VAlve
  193. Electric 4x4
  194. AirBag Rediness Light & winding noise when accelerating
  195. washer nozzle freezes
  196. 1992 Explorer Clicks, but Won't Start
  197. 2002 explorer trans probs...
  198. Power?!?!
  199. Can I over ride the immobiliser?
  200. 99 Explorer, head gasket,heat,vacuum hose...
  201. 97 explorer 5R55E OD light blinking
  202. help finding glass
  203. It passed
  204. oder from ducts
  205. 99 Explorer, "fluid" in spark plug
  206. 1997 transmission rebuilt but clunking and shifting hard
  207. Wirless Keypad Entry Installation
  208. Another transmission problem
  209. O2 sensor replacement help
  210. Rear Door Latch Problem, Please Help!
  211. change transmission fluid-yes or no?
  212. Keypad Code Location
  213. Electrical Problems Please Help
  214. Rich burn on 91
  215. 92 Explorer 10mpg
  216. Bypass filtration
  217. 95 Ford Explorer Alarm won't Shut off
  218. '97 Ford Explorer; water pump
  219. Will Not Start
  220. Still feels like it will stall...
  221. Explorer w\ a go cart clutch?
  222. Radio light display burned out
  223. Installing Sirius, want it to shut off with thte car
  224. 94 explorer engine layout
  225. ABS prob with 4X4 probs
  226. Temp gage dont work in 94
  227. 1994 Transmission - Advice
  228. Using air bags to lower an Explorer.
  229. Hard Shift 1-2 and TC Locking problems
  230. Synthetic oil vs. Standard? 02 sport trac
  231. 4WD Survey (Manual or Electric)
  232. where are door sencors located?
  233. ball joints 01 mountaineer/explorer
  234. 93 Explorer 4WD busted
  235. 2001 Sport Keypad Code Help
  236. 92' exploder experiencing unique tranny issues...please help!
  237. faulty defroster in 02 Explorer
  238. 91 explorer window problems
  239. CD PLAYER Light OUT. Don't wanna get ripped.
  240. 91 ford explorer eddie bauer edition
  241. 1995 Explorer Temp Gauge
  242. 1995 Explorer A/C problem
  243. 91 Explorer passenger power window motor
  244. and good 2002 Ford Exp.
  245. Torsion Bars
  246. 1991 Explorer Heater screeching
  247. 2001 Ford Explorer Console Wiring
  248. Changing the rear speakers
  249. Clips in fuel line for fuel filter
  250. 92 Failed Smog....again
