Ford
> Explorer | Explorer Sport Trac
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
03 Explorer Radio Question
coolant smell
Explorer Sportrac 2004 gauges
performance chips
Disabling 2002 Explorer chimes
WTB - Factory wheels
Explorer Running Cool
ceramic brake pads
Transmission Cooler
choosing new brake pads
Drvier side door and rear hatch won't unlock
keyless entry vs Security System????
2001 sport trac
Wiper Fuse???
Keyless Entry Pad
Codes?
1998 Ford Explorer
92 Xlt/ Is It Worth The Repairs???
What no pictures?
2004 Explorer RH Mirror
Hood latch is not working.
97 explorer code 1744
loud grinding noises in 4 wheel drive
Breaks (soft/low)
engine code
1992 Explorer Cold Tranny Engagement
No Power To Cd Player/radio
'92 transmission problem after other repairs
no power windows or wipers or interior lights
no start
Inspection this week and NO brake lights... HELP
93 explorer ignition fuse
truck wont start
2000 Ford Explorer No Heat
Ford Explorer Loud Screeching HELP!!
Power Locks
Headlights will not work
93 explorer pinging noise
92 explorer new cd player has dead air...need help!!!!
Keyless Entry
Idle Problem???????
O2 Sensor Service Engine Light
Help me change my air filter
Help with Stumbling RPM's??????
02 explorer facelift
Replacing Front ABS Sensors
shocks or struts
wheel making grinding noise
Rear Wiper Problem
Drove through big puddle - loud engine
explorer overdrive swtch
2000 explorer running lean
Rear View Mirror Question
Red Light
94 Explorer break pedal grinds
Cruise Control
94' Explorer 4X2 suspension squeeks
Spark Plug Replacement
no sound from rear speakers
speakers
1994 ford explorer no heat
1996 keypad
1996 accesory 12v lights
Ford Explorer Problems
Blinking O/D Off light,2003 Explorer
1991 ford explorer gas gauge
1999 XLS Suspension
1992 Explorer for sale
HELP!!!!!!!!! Can't find the MAP SENSOR!!!!
2002 Explorer start problem
dashboard light
A/C fan
"02 Explorer EGR Valve issues
96 4wd/4wd low flashing lights
Fuel gauge sticking
check engine light with codes p1507 & o0455
94 XLT chirping problem
changed drivebelt, but still squealing
1996 explorer tranny transmission
1996 door locks
idle drop..97 ford explorer sport
97 Xlt Front End Noise When Turning
cargo
Check engine light not coming on during start up or in test position.
O/D OFF flashing
clicking with no key
97 Explorer wheel bearings
Brake recommendations?
Shaking
(97 Fast Idle
Code P0743
heat in my 97 eddie baurer
96 explorer front end
keyless remote
1993 explorer problems
94 Explorer starting problem
02 sensor
replacing PCV valve
Heeelp!
OBD 2 Scan tools
my truck wont go in gear
96 Explorer 5.0L Excessive EGR Flow (P0402)
Vacuum tree 4.0 V-6
4x4 Problem
Which V6 is best in a 1999 Explorer?
Break light
Tires vibrate and shake
Reverse Sensor Disables
02 explorer sports trak keypad code?
shimmy & Shake!!
2000 Explorer Computer Module/Keyless Entry
Turn Signal
power windows relay switch
tires
grease points
power windows on 96 EB explorer w/flasher
Frt End Question
water in rear door 96 eddie bauer explorer
flasher on 96 eddie bauer explorer
help 2004 explore major problems need advice
Help! Problem with shift indicator
explorer transmission interchange
'96 Explorer possible transmission problem!
2003 Mountainer Rear Wheel Bearing
Shudder at full steering lock
Evaporative Emission Control System Vent Control Circuit Malfunction
Engagement Problem on 99 XLT
possible problem ?
97 explorer,electrical problems?
AC/Heater Problems
vacuum line
spark plugs
Turn signal
brake rotor???
intermittent starting on 98
gas mileage
Is it bad...
Adding AC refridgorant to 94 Explorer.
94 Explorer brakes Hiss
Door won't unlock or open by any method
Ford Explorer Rough Idle / Stalls / Sputters
1996 explorer....starts but have to push gas
'91 passenger-side door lock problem
93 Explorer Electrical Problem
98 Explorer Limited help
94 Explorer's Daytime Lights Won't Go Out!
96 explorer gear ratio
91 Explorer stalls/runs rough at idle
Camber and Caster 1997 Ford Explorer.
'94 Explorer EB Interior lights stay on, Alarm?
back door locks
2002 2WD Trans any good?
2002 ford explorer ses code p1401
KMC Stealth 20" for Sale
RearView Mirror AutoLight ?!?
94' Explorer Fuse Box location(s)
94 Explorer factory Amplifier
2005 Explorer Limited speakers
99- cruise contols buttons won't illuminate
95 Explorer, could popping be transmission?
2000 Explorer Sport keyless entry code location?
97 explorer for sale
1994 Ford Explorer Sport 4x4 5 speed "500"
Explorer Backfire
Rattling noise as I drive
1995 Explorer Starts and idles above 2k rpms and slowly drops
1993 ford explorer speedometer
2002 Rear Wiper Pump
door won't open
transmission slips in reverse
ford intake class action nears settlement.
Rear Window on sport trac
gas mileage& codes
1999 Rear Wiper not working
Rear Brakes weak
remote key pad lock/unlock intermittent
2003 Sport Trac Brake Light Problem
O/D Light Flashing
fwd low light
91 xlt with 128k miles.......trans
starter will not disengage
2001 Explorer Sport O/D light flashing...
Check Engine Light
2002 Explorer Aftermarket DVD Changer Help
Engine stalls w low rpm idle 2000m
5lt into 4lt
92 Explorer running rich Help please
'92 eddie bower edition tranny change?
low idle
Keys....
lambo doors
very weird trailer wiring problem
94 explorer that pings
AC Leak in High side valve
Fuel pump fuse blowing expl.ltd 94
1993 Explorer fuel pump
97 Explorer 5.0L Wont Hot Start, or multiple times cold start
1997 Explorer Won't Start
Explorer XLS options??
Owners manual
2005 Explorer Keypad
Oil Change mess
Factory manuals
2001 Explorer Sport Trac - 2 problems
subs with stock headunit
flashers
Affordable Explorer arm rest replacement .
air conditioner hot on one side
2002 Explorer Cigar lighter fuse ?
2002 explorer remote entry fuse
2002 Explorer Sport Rear Brakes
1992 ford explorer wont start/battery?
1992 Ford Explorer
97 Explorer Headlight problems
resetting blinking overdrive indicator
Seafoam and seatbelt
Center console on 2002 Explorer
door locks 96 explorer
98 Explorer sport air bags helpful or hurtful?
1998 Ford Explorer
AC only running on full or not at all
1992 explorer issues/ does not start
transmission
Orifice Tube Location
od light flashing
1997 driver side door lock and handle will not work
ABS light on but not all the time.
P0300 random misfire on 98 exploree V8
havng trouble starting 93 ford explorer
1998 Explorer Subwoofer
Transmission oil gets mixed in the engine
Front wheel/bearing noise
ABS Pump Failure? - 94 Ford Explorer XLT 4WD
trying to pull rear rotors
Keyless entry code on 03 Explorer
Explorer 01 Engine light and O/D light flashing
2003 Exploder Transmission/Rear end
Need help with A/C issues!
99 explorer ABS light, I have codes
Do I have bad front wheel bearings?
98 OHV melted the pfe sensor twice in 2 weeks
2002 Explorer Issue
Explorer Odometer
location of Computer module 96 explorer
2002 Explorer
need to replace drivers door 1993
2002 service engine soon light
4x4 lights not lighting/blinking
98 rear wiper
'98 Ford Explorer Radio lights out
