Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Ford
> Explorer/Explorer Sport Trac |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
99 Explorer Cylinder #4 ruins the Spark plug in 7 months?
Need 4.0 engine 97 Explorer which engines fit?
Head gasket leak-95 Explorer
Nice 02' ST for sale with a warranty
2001 Sport Trac Fog Lights
97 EB Exploer rear subwwofer
Power steering noise
Stuck In neutral!
2001 Explorer Transmission Issue
94 Explorer head gasket
97 Explorer makes a grinding sound only when turning
Rear wiper
1996 ford explorer jbl subwoofer removal
Trouble Code
2002 sealed rear bearings
98 explorer 6 cyl. 4L Oxygen Sensors
1996 Explorer
94 Explorer problems...
1997 Explorer Starting Problem
White smoke from exhaust
-98 explorer leaning left
more questions about tires, lift kits, and gas mileage
Explorer makes noise when driving
Clunking Heater
door locks
rear view mirrors not working
head gasket
92 explorer $250 NJ
trans. help
starting problems
tones when starting
1996 remote entry
Check engine light
Speaker problem
Need info
To crank or not to crank.............
2003 XLT Axle Howling
cannot find engine number
2000 5.0 Explorer EGR valve change (or clean)
1996 Explorer 4.0 egr valve location
klunking while driving
Intermittantly won't start
2000 Explorer 4x2 rear differential
2000 Explorer rusted freeze plugs
97 Eplorer - press brakes and dash lights come on
Transmission Issues.. plus voltmeter
Missing Under Power
Cargo cover application by year
1997 paint. help me please
2003 Explorer shudders at sharp turns
2002 Explorer Back-up Sensor
Can anyone help?
How much to sell 01 Xplorer Sport?????
AWD at the Beach?
99 Explorer horn problems.
91 explorer
'96 Radio Controls no Backlight
radio setup
94 Explorer has lost alot of power
cruise control
Will not turn over!!!
96 Explorer Stutters when warm
Explorer Fuel Problem
Tire noise, maybe not...
97 Explorer Steering Rack leaking & Noisy
exterior step light
Where is the PCV valve on a 2002 Sport Trac
A/C Problems!!!
my '92 explorer sounds like a diesel
Is the XLT capable? Need help
Change all oils at 60,000 miles
1994 explorer won't start
trouble getting at one spark plug
Battery/Charging Issue
A/C Problem..how difficult? Any advice?
2002 Ford Explorer V8 Transmission Problem
33" tires??
Airbag Problems! Worried!
NEED HELP BADLY.. SEVERE OIL Leak, Hitting Exuahest Manifold
Tornado to improve explorer gas milage
Fuel Gauge
A/C Comp???
just got a 94 explorer xlt and have a few questions
Engine noise
Randmonly will not start
97 explorer cd changer control
explorer ipod hookup
94 ford explorer help
97 electrical problem?
New to board, couple of questions-1993..
1996 Explorer A/C problems
hydraulic clutch line
Installed new starter and it's making noise...
1991 Automatic - Dumping massive amounts of fluid
Spark Plugs-How often do you change it?
Which would u choose?
2002 Sport Trac four wheel drive issue
Heater blowing cold air only
97 explorer- check guage lite
93 overhead console removal
Spindle thread problems
Weak spark during cranking: Strong spark when running.
Cold Air Intake
Squeeking noise from front-end
squealing noise
Trouble with shaking speedometer; and trans
stereo wiring diagram
selling a vehicle question
Fuel filter
91 Explorer catalytic converter questions
97 explorer shifting from rev to drive
Crackling sound at low speed
Unable to open hood
1994 Explorer in low range (stuck)
Can I reprogram auto door lock feature-97 Explorer
1998 explorer engine noise
turn signal fuse burns out
2000 Ford explorer will not start
wanted: boxextender for sporttrac
Faded Wheel Lip Moldings
97 Explore sport.
1996 Explorer Hood Won't Stay Up
Alarm System
Check Enging Light on 99
94 explorer makes noise and engine light
Tekonsha 2030 Mark 12 Brake Controller
Programing remote for 97
1993 Ford Explorer XLT - Winding then THUMP
1994 Explorer No Neutral Or Reverse
Possible to change shift points on 1998?
Miss in 97 Explorer 5.0 CYL 7
explorer 3rd row seat
Horn or cruise control dont work.
Buzzing noise when turn signal is activated
tire rotation
Still Wont Start..after all the repairs???
parking breaks
Another Check Engine light thread
'97 - Speedometer problems/battery light
is it any good?
Svt St?!
headlight problem, sooooo close to fix HELP!!!
Contemplating 98 V8 Explorer
fuel pump
Basic tune up
'96 Explorer trans shiftig problems
Check Engine Light Diagnostic help.
Chirping Noise
rear window sporttrac
4x4 High light on instead of 4x4 Low
00 explorer rear wiper stuck
Drivers door/ lock, elec. mirrors, int. lights, door ajar light
91 explorer over heats after going uphill
94 Ford Explorer FOB/Keyless Entry Reprogramming
Reverse problem
93 Explorer Remote Entry
Ford Explorer 94 Problems
'96 explorer limited 'air ride' problem
Ford GR-1
92 Explorer Parking Park Serious Problem!! Need Help!!
Car wash, Wax, Tire cleaner, etc.
Motor Oil Brands to Use
Rotor Thickness - Service Limit
Do i have an alarm? (explorer 1998)
2000 Ford Explorer No Heat Defrost Only
fuel kill switch
'98 Explorer sounds like rattling under valve covers
01 Explorer Sport Rear Turn / Brake signal
ford explorer for sale
rattling sound under valve case cover!!SOS
Ford explorer 2001 sport trac
Oil mixing in antifreeze? HELP!!!
Spedo problem, Electrical?
rebuilt transmission issues
1999 Explorer XLS Remote Programing ???
97 explorer radio
front end vibration at slow to 50mph. ok at 50+mph?
98 SOHC Ticking
Help!!!!!! rack pinion prob. S.O.S
95 explorer instrument cluster
blink,blink,blink
4X4 hubs
98 Explorer rough idle no codes
sounds like horn
99 Explorer washer pump
changing trasmission filter/fluid
Noise Source? - High pitched vaccum/damper sound.
How to remove? - rear passenger spark plug wire
The Last Resort Heater/AC Blend Door Fix
1993 Explorer turn signals not working
91 Explorer stalls when I step on accellerator
Defrost causing idle problems
2000 ford explorer bad vibrations after hitting bumps
Transmission fluid
Anyone Who Has A 92 Ford Explorer
Compressor problems?
Remote Control Programming keyless entry for a 2002 Explorer eddie bauer
Air compressor burnt out
TRanny Fluid Change
break noise
Hot start 96, Explorer
97 explorer hard pedal
Ford Explorer Compass
Another Transmition question (1997)
Steering Wheel Pulsating Help?
Please answer this question
1991 Explorer Air cond.
I know this is a dumb question but how do i take the spare off a 94 explorer sport?
lower intake manifold
dimming headlights/brights don't work
98 explorer trany filter
I will never buy a ford again!!!
Keyless door entry programming??
91 Ford Explorer Wiring Diagram
Help Rear Hatch
odometer dies
92 explorer no spark
2002 Fuse/Power issue?
97 Ford Explorer Rear Windshield wiper problem
1992 explorer leprosy questions. Please help....
airbag light stays on
factory cd changer
95 Exploder: Vibration/Hum from front end...
Loud humming at 35mph
96 Explorer, Loud Humming Noise
01 explorer 2 cluster lights out
2004 Explorer Break Job
1996 Explorer Air Suspension
Vacuum hoses.
Flasher Unit Location For 2001 Explorer
NEED Fuse Panel Information
what do you check if it's not getting fire?
engine swap 4.0 to a 351
abs light on
No 4X4 Engaging....
02 explorer lift kit
95 Explorer mis-shifting when towing in traffic
92 exploder- rotates but will not start
1999 Exploer XLS electric question
anti lock brake light on
1992 Water Pump replacement
98 explorer rough idle and stalling after long drives
4wd Won't DisEngage
Crack in Liftgate
98 xlt 5 speed?
stock speaker removal of 98 Explorer xlt
98 oil guage problem again!
Replacing Headlight Capsule in '94 Exp
cleaning alloy wheels
98 Explorer....many faults
Web
AF
