View Full Version : Windstar
- Brake light
- 2002 spark plug gap?
- Engine Compartment Fuse Box ??
- New coil; still missing/bucking; '99 3.8L
- How do i adjust the handbrake??
- switching motors
- Interior light problem
- code p0304
- Windstar The dash shutts off !
- 2000 Windstar Power Window Problems
- No start after 171/174 code repair
- Rear Axle Break
- 1999 Windstar Heater Blend Door Actuator
- Door lock question
- 2001 windstar
- 2001 windstar transmission problem
- 2001 Windstar
- 2003 Windstar losing oil
- Radio Removal 99 Windstar SLE
- Water Pump check out
- replacing master cylinder -- '01, 3.8 L
- rough engine at very low speed
- 1999 Windstar LX Fog Lights
- '02 Windstar - P0305 - Deposits on plugs
- 95 Windstar 3.8 P0171 Code
- 00 Windstar wouldn't start
- 99 Windstar - how to replace struts & rear shocks?
- A/C Outside Air Door Going Bonkers?
- Odd electrical issues
- Is there a Relay for the blower fan?
- Posted this on the recall sticky above.
- van won't start
- Rough running and backfiring...looking for pointers
- Engine temp wont go up
- Windstar Cruise Control Recall
- Charging system issues
- squealing brakes
- How to clean engine coolant reservoir?
- 3.8L 95 windstar TRS Change... Any helpful hints?
- 2000 windstar headlight problem
- Bucking & missing revisited; '99 LX 3.8L
- Heat from Front
- Help
- Help
- 301 code
- How to put the drive belt back?
- 2003 Windstar Fuel Filter
- 2000windstar rear heat
- 2000 windstar, need help fast
- Finished the 171/174 fix, now idle problem?
- 99 Windstar- going through coolant
- Recall
- Cowl Removal - 2001 Windstar
- charging system HELP!
- Coolant on serpentine belt
- Torque Converter Groove
- 98 Tranny Problems Need Help Before The Snow Flys
- Fuel Tank - How to Clean?
- Problem with brakes.
- p171 p174 again!!
- 99 Windstar - Head Gasket??
- 2003 Windstar weird transmission shifting
- TSB Number:98E03 NHTSA Number:616509 TSB Date:December 1, 1998
- Windstar losing coolant
- Where is located the sliding door AJAR switch?
- How to disable a kill switch on a Windstar 98?
- 2003 Windstar Tranny Problems
- Rear Heater Core
- 2000 Windstar Armrest fell off
- 96 Windstar fuel line repair plus what?
- 1998 Windstar ground issue
- 1998 Windstar Luggage Cargo Carrier issue
- 2000 Winnie, Radiator Cap
- indicator lights
- Bad Engine Ping, no codes!
- 99 Water in oil, changed out lower intake
- fogstar
- 2000 Windstar P102 code question
- Part number for spare tire winch? 02 winnie.
- 98 windstar or 97 aerostar?
- 2001 Windstar - Weird Electrical issues draining battery
- 98 Windstar wheels & tires on 99 Cavalier
- How do I know if I have the factory tow package?
- Engine knocks oil pressure?
- 98 Windstar Limited 3.8: Codes 171 & 174 related to stalling?
- P1744 Code on 2001 Windstar
- Need help, 1998 Windstar
- Misfire Cyl 5
- ignition switch or something else?
- 98 Windstar ABS Trouble
- "Attaboy" for Ford reman tranny for Windstar ....
- Which Brake Fluid To Use?
- A little help ('99 3.8L Tranny trouble)
- My 98 windstar wont start after engine replacement
- '99 Windstar 3.8L
- 2000 Windstar slipping shift lever
- Replace air suspension with standard suspension
- alternator replacement, help please?
- Christmas tree dashboard
- 96 Windstar 3.8 Air Conditioning Charge
- 3.0 Aerostar engine block => Windstar
- Rich up your mixture
- 2000 Windstar - random failures all at once
- Holes in Windstar Muffler
- slight knocking in rear drums on 2002 windstar
- Windstar in trouble
- 98 windstar can't communicate with computer
- po715
- rear end vibration
- No odometer and abs/trac light on
- Fans
- Tie Rod mishap ??
- P0401 with massive oil consumption
- 1999 ford windstar pulls when I let off gas
- Codes 171 & 174 and 401 fixed
- So Long Old Friend
- '03 Rear Brakes anomaly
- 2001 Windstar needs replace computer ECM
- a/c problem need help
- Hard starting when cold and squeak
- 1999 Windstar - Anything Worth Scavenging?
- Crankshaft sensor ... engine stumbling. 1999 3.8
- inner cv joint wobble normal?
- 2000 Windstar Coolant Crossover Tube Leak
- P1517 Chugging engine w/ power loss
- Potentially dangerous situation need help asap
- Harbor Freight vacuum bleeder giving me trouble
- Odometer, Speedometer, AC , Cruise Control
- charging/starting/battery tester? slightly OT
- grinding sound
- 2003 FORD WINDSTAR Transmission issues, lots of codes.
- TPS at idle?
- suspension noise
- Thanks to All!!
- Windstar IMRC Clips: Ford F5RZ-9F955-AB -v- Dorman 47099
- Check engine light insanity
- won't shift to 2nd when cold
- 2000 Windstar IMRC intake runner control Removal (how to)
- Do you prefer to drive or to repair?
- Windstar A/C has a mind of it's own?????
- WARNING: Removing upper plenum on '99
- High Idle during Startup
- Holy smokes!?! I think I killed 'er!?! Please Help!!!
- Cash For Clunkers
- 2001 Windstar Transmission Overflow
- Quick question cleaning EGR ports on '99
- crazy door locks/horn where is door lock processor
- blown discharge line on ac
- 2000 SE starts then dies immediately when cold
- Window Motor/Regulator Windstar 1999
- Relay Problem?
- speedometer/ odometer fuse 10 keeps blowing
- Power steering! Help urgent!
- 1996 Windstar tie rod ends
- 1996 ford windstar sputters
- 2000 Windstar 3.8L poor gas mileage
- Cash for Clunkers/Windstars?
- van ford windstar 2000 ignition lights on but do not crank
- Cruise control stopped working on 96 Windstar
- 01 Windstar showing no improvement
- 95 windstar oil in coolant reservoir
- Rearend rattle
- Oxygen Sensor - Rear 2002 windstar
- 95 windstar sat for 2 years and now won't run
- 1998 3.8L transmission problems
- Power Steering Fluid & Chirping Noise
- gears disappear, ok after restart
- Temp. getting hot?
- Body Control Module
- P1518 IMRC stuck open: 2000 winnie, 3.8l
- Windstar A/C question
- Has anyone used this tool?
- Do I really need a shim on the Right Rear Wheel
- 1999 windstar electrical probably pats
- PS Teflon seal installer???
- Transmission codes 713 & 734
- Windstar Engine Blown
- Driver's door Lock
- Changed out my lower intake manifold gasket
- How much for rear plugs?
- Win 95 3.8 Speed signal to PCM missing
- Driver Side Window Doesn't Open- Clicks
- Weird Problem (transmission)
- 2002 Front Electronics Module
- "Speedometer Driven Gear" vs "New Drive Gear"
- Rear of van sitting slanted down to right
- Coolant Leak
- Bad Wheel Bearing Symptoms
- Cooling Fan Dropping Resistor
- Brake Pad Question
- Should the strut rod bushing be soft and rubbery?
- Link: Dealer shop manuals for cheap.
- Tightening slider door??
- door code on 2002 windstar...
- abs/brake light on 2002 windstar...whats it all about?
- Torn ball joint boot
- 1995 wont crank
- 1999 windstar oil in radiator resorvior
- Help! Where is the "EPA sticker" located on my '98 Windstar?
- Proper PAG oil for a/c system?
- 2000 Windstar 9 Years Later "Dream Van" or "Nightmare?"
- Driver side turn signal in mirror
- no 2nd gear or od
- ride hight
- Lamp indicator.
- Ohm Meter Settings?
- Ford OBDII Theory and Operation Manuals
- Battery light
- Coolant temp sensor?
- Why is the 1995 Windstar OBDII compliant?
- 97 Windstar intermittent clicking/no start condition
- 3 letter word searching on this forum
- What are symptoms of a bad ICM or one going bad?
- Thermostat 180 "V" 195 degree?
- 145 for a power steering hose.....
- Winstar under door sill replacement
- Check Engine Light On
- RH Door Window Dead
- Do all 3.8 engines idle fast?
- Ford Windstar Blower Does Not Work
- Where does this wire go?
- Hello first time post.
- Idler pulley
- 99 windstar codes now po401
- '98 A/C clutch not engaging
- 95' windstar.. How many LBS freon?
- 2000 Windstar A/C recharge
- Miss/bucking at low speed & on incline
- 2001 front passenger signal not working
- Intervals For Rear Brake Replacement?
- Mobil-1 Extended Performance 15K
- 1996 Keyless Entry Module
- 2001 - brakes - long pedal travel
- 99 windstar vacuum tube
- 96 Windstar-3.8 eng
- Locating Windstar VSS - Replacing Windstar VSS
- Trans fluid change- capacity??
- Mobil 1 ATF not available anymore at Wal-Mart?!?
- Transmission disengages between 1st and 2nd
- any thoughts on the ford flex?
- help with tran 2000 sel
- 02 Windstar Acceleration Stall (wiswind please have a look)
- Ide Speed Controller Reading On Service Engine Light
- Has anyone changed from 5W-20 to something else?
- Coolant Drips - Need Opinions.
- Help With Part Identification
- 95 windstar won't start
- 97/98 Windstar Rear Wheel Bearing Question
- P0171/4 code issue, tried to fix
