View Full Version : Windstar
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Dash door open indicator staying on
  2. 2000 Windstar Chugging at Idle
  3. About Neutral Safet Switch (TRS)
  4. Broken Bolt Extraction
  5. 3.8 engine compatability question
  6. Trying to find out what a part is called for a 99 Ford Windstar
  7. 1995 transmission flush
  8. Heating problems
  9. 95 3.8 occasional surging
  10. overheating when idling
  11. 96 Windstar Squeals
  12. P0171- did TSB - now misfire on 1 and knock
  13. 97 Winstar overheats while idling
  14. How to drop transmission for access?
  15. Is it tme to change coolant hoses
  16. clicking noise 2001 ford windstar
  17. P0304 misfire
  18. Bumping sound
  19. Bucking (misfire) while driving
  20. 2000 windstar
  21. lights went dim
  22. 2002 windstar making noise sounds like idler
  23. trailer brakes
  24. Front end clunk
  25. Brake On Off Switch
  26. 96 3.0 windstar burning rich on 87 octane
  27. IMRC question
  28. 98 Ford Windstar 3.8
  29. '99 Windstar
  30. Lower intake gasket leak Blackstone Labs
  31. Windstar 1997 stalls when cold
  32. Goodbye and thanks
  33. engine pings and dings
  34. ? about the Berrymans Chemtool Products
  35. 96 Windstar's bizarre starting problem
  36. 95 Windstar Van power windows
  37. remove retaining bolts wheel bearing hub assembly
  38. Strut bearings
  39. 1996 windstar 3.8 rattling noise
  40. 171and 174 codes affect gas mileage
  41. 98 win 2nd gear slam
  42. REALLY Dirty Intakes (was "won't accellerate"
  43. Is it Possible to replace struts and springs yourself?
  44. oil, oil everywhere
  45. Fuel Injectors
  46. help!!!!
  47. OBD 2 ABS scanner
  48. 2003 Windstar Radio Reception
  49. IMRC Codes/Cooling System Issues
  50. ABS activating no code.
  51. 3.8L Broke Serpentine; now no start
  52. Location of REM (Rear Electronic Module) in a `99?
  53. Ford Windstar Parts
  54. High Speed Shake
  55. Heater Blowing Cold Air
  56. Please help Jatpapa....
  57. Hot to bypass ABS on 95 windstar?
  58. PO741 and PO305 Codes..mind is spinning!
  59. UIM gaskets reusable?
  60. p0174/p0171 ...other possible causes?
  61. Bad head gasket or LIM gasket?
  62. 99 ford windstar keyless
  63. 97 windstar running rough
  64. 97 Windstar running sluggish
  65. 97 Windstar running sluggish
  66. How to find TDC? / Valve Springs & Pushrod Replacement
  67. 99 windstar stalls after warm starts randomly
  68. 99 Windstar battery draining
  69. P303 needs new engine?
  70. 96 windstar just turns off please help!!
  71. 1999 windstar windshield washer
  72. Replacing the seat foam
  73. 1999 door adjustment
  74. Just to be extra safe, please check your Brake Pressure Switch
  75. '98 Windstar 3.8 Won't accellerate past 40
  76. 1998 3.8L Windstar won't start. Please Help!
  77. Brake Greases for 99 Windstar
  78. 1996 Windstar Not Charge
  79. Power Steering Pump and Water Pump
  80. Transmission and Battery
  81. Fixed Intermittent ABS light and Brake light!
  82. Shop manual
  83. Power problems
  84. OBD II Scanner Recommendations
  85. DPFE on 01 windstar
  86. Tail lights staying on. . . .
  87. Castrol Mercon V -- Changed formula!!
  88. power door locks go crazy in the rain
  89. 98 windstar possible head gasket issue.
  90. Brakes On 3.8 Liter 1999 Windstar
  91. p0171 is back
  92. Interior Lights
  93. 99 windstar 3.8 stalling at lights
  94. Grade of Oil
  95. '98 3.8 codes PO171/174, rough idle, shaking steering wheel
  96. Windstar air bag sign
  97. 98 Ford Windstar GL Diagnostic Results - Need guidance
  98. Electrical Problem
  99. OBDII "P" Codes and What They Mean
  100. 96 windstar 3.8 Intermitemt P0402
  101. isolator bolt fix help
  102. 2000 SEL Lumbar problems
  103. 03 front end howling
  104. 2000 LX 3.8 problemafter Isolator bolt fix. Please help!
  105. 1999 Ford Windstar (Correct Gap) ?
  106. 2001 Vacuum related problem
  107. Misfire worse after changing plug
  108. 96 3.8L IMRC question
  109. 1999 ford windstar
  110. 1999 Ford Windstar (Brake Pressure Switch)
  111. Problems with Ford Service CD
  112. There's oil in my intake dear Martha, dear Martha....
  113. 1999 Ford Windstar 3.8 L (Fuse Keeps Blowing)
  114. Valve Cover
  115. Water pump hose or tube
  116. Quick one: need to raise car to drop transmission pan? Best location for jackstands?
  117. Wiswind
  118. rough idle
  119. 96 Windstar stalls when you...
  120. 98 On the Road Again - Transmission Advice
  121. 200 Windstar Rust
  122. windstar leaking coolant
  123. Another blown head gasket and some engine removal questions
  124. are they any good??????????
  125. Airbag Code B1942 HELP!
  126. 1999 Ford Windstar
  127. Thank you WISWIND!!!
  128. P1409???
  129. interior lights staying OFF, not On.
  130. Wiswind will be a Great Moderator
  131. Sqeaking on start up and turning steering wheel
  132. 2000 3.8 Turns over slow, but starts
  133. fuss box diagram 95 windstar
  134. 2000 Power steering fluid change
  135. Intermittent Turn Signal
  136. General Windstar Information
  137. Hey wiswind... let me be the first one!
  138. Please Read Before Posting
  139. CRC mass airflow cleaner
  140. 2003 windstar:blower works no heat, plus clicking noise
  141. 2001 windstar front bumper removal
  142. 01 Windstar: slide door won't unlock
  143. 2000 Windstar arm rest
  144. 2000 Windstar won't start
  145. 2000 Ford Windstar Tune-Up
  146. Mercon V – Trans issues/concerns
  147. The Lights On But Nobodys Home
  148. Smelly Heater Fogs Up Windows
  149. Heating Issue
  150. intermittent ABS warning light 2000
  151. All smells coming in
  152. Suspected Valve Noise
  153. 97 Windstar power locks problem
  154. 2001 Windstar power window question
  155. EGR Valve Dripping Oil
  156. 2001 Windstar Front Wheel Bearings
  157. My 99 3.8 windstar gone crazzzzzzzyyy
  158. fluctuating RPM
  159. 2001 Winstar Milky bubble ps fluid
  160. Power steering leak
  161. Rough Idle
  162. Replaced plugs, now wont start!!
  163. Trying to replace my spark plug wires and plugs
  164. 2000 3.8L H20 Pump Repair
  165. Transmission Info
  166. Now I've done it
  167. 2000 SEL with 171 but no 174?
  168. 2000 Windstar - keeps dying
  169. 95 Windstar- radiator back pressure?
  170. Air conditionet not working
  171. Intermittent start and kill problems
  172. Auto Locks
  173. 98 windstar, IMRC and coolant issues
  174. Front bumper cost??
  175. Blower not working
  176. alicia
  177. Good Bye Windstar!
  178. 98 Windstar GL Auto Trans not Switching Gears
  179. Front wheel bearing
  180. 2001 Windstar tranny filter change..
  181. Sliding Door Nylon Roller Broken - 2000
  182. New Design Valve cover on Ebay
  183. P0401 and P0402
  184. Windstar brake lights sticking on
  185. Backup lights off at (R) windstar 95, 3.8 lt
  186. Anyone to proofread my ’98 Windstar listing?
  187. Instructions to replace steering rack
  188. newbie here and to fords
  189. Persistent P0715
  190. blowing fuse turning left
  191. miss at idle
  192. Which is the rear wiper relay?
  193. Where to get part numbers and diagrams
  194. Hummm
  195. I need the location off VSS and TRS WIndstar 95
  196. Washer Fluid Low
  197. Temperature gauge acting strange
  198. 96 Windstar Code 301
  199. P0118 Engine Coolant Temperature Circuit High Input
  200. rusted brake lines
  201. POWER LOST 15 Ampere
  202. I did what I said I would NEVER do!!!!
  203. Intermitant CEL P1538 IMRC code. ’98 3.8L
  204. 98 Windstar 3.8L- IMRC actuator number??
  205. po172 & po175???????
  206. 2000 Windstar Stalls in Winter when Humid
  207. Possible starter going or false alarm?
  208. 98 Windstar P0171/174 Lean code won't run
  209. My 99 Windstar LX saga had ended...
  210. 97 Windstar using alot of gas
  211. '98 with PO171 and PO174
  212. wipers
  213. Remote Car Starter.....prostart anybody install one on your van?
  214. Which code scanner?
  215. Windstar SE 2003 clicking noise
  216. Silent Warranty on front coils
  217. Turn signal problems
  218. 2003 Winstar Heater blower motor
  219. blown fuse on cruise control
  220. 98 Windstar Jerk when Stopping
  221. Jerk when Stopping
  222. 1999 Windstar - Wet carpet
  223. 2000 Windstar ABS Pump Assembly Replacement
  224. Code P1506- '99 Windstar 3.8L Idle problem
  225. What will happen when the lower intake manifold leaks coolant?
  226. Liftgate Ajar
  227. Windstar 1999 Interior Lights Stay On-- Fixed
  228. Mercon 3
  229. 2001 Windstar Swaybar Links
  230. Transmissions in Winstar and Freestar
  231. Where is the Cabin Air Filter on my '98 Windstar GL?
  232. INFO needed on trailer hitch
  233. I can't find vibration!!
  234. Which cylinder is #6?
  235. How to remove right rear spark plug from the bottom? '98 3.8L
  236. Fashing Trac Off Light
  237. Problem with 1996 Ford Windstar Mini Van
  238. What is the proper spark plug gap for '98 3.8L?
  239. 98 windstar tranny gear sticking
  240. Transmission slipping, seems OK when not in O/D
  241. Broken stabilizer bar
  242. Vss Speed Sensor
  243. Coolant leak?
  244. po401 dpfe repalcement AGAIN!!!
  245. Persistant 171/174 Codes
  246. Code p0118 Heat Sensor
  247. How to shut off low tire pressure light?
  248. Windstar Transmissions
  249. 2001 upper engine knocking sound
  250. Any changes between 95 to 98 models?
