View Full Version : Windstar
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. 98 vacuum hose routing and Greta ran out of bread crumbs.
  2. lower control arm how to get it off
  3. Lower Intake Gaskets 96 3.8
  4. 2001 A/C diagnosis - what does it mean?
  5. Some Questions
  6. AC top-up confiusion. R12A or R134A?
  7. 2000 Windstar SEL rear defroster clip broken
  8. Keyless entry question
  9. 2000 Windstar LX Starts but Stalls
  10. 01 Stalling Issue
  11. E85 mods- what will i need?
  12. Just one more question.......
  13. Noise when coasting from 40 & up
  14. 95 surging on start up...
  15. Toque Converter shudder is driving me crazy!!!
  16. 95 w'star tune up
  17. Repair Manual
  18. OBD II Problem
  19. Cruise control still not working - defective pressure switch
  20. Double Trouble: Air and start problems
  21. Windstar won't run properly
  22. How do you know whether your seat belt is working?
  23. Going to replace Transmission
  24. 98 3.8 stalls when put in gear
  25. 2001 Windstar SEL Rear Brakes Thumping
  26. 2002 Winstar..is it a negative or positive ground system?
  27. Overdrive switch not working
  28. Air conditioning problem in 98 Windstar
  29. Intake Air Temperature Circuit High Input
  30. Value Cover Repacement ?
  31. Crankshaft Position Sensor
  32. Half axle replacement how to?
  33. Radiator life span?
  34. Removal? - Quick disconnect coolant hose by thermostat
  35. Misfire on cylinder 1 and 5
  36. HELP (98 windstar) TCC won't lockup at hot???
  37. 97 Windstar Missing
  38. oil inside the air thortle rubber bellows
  39. Oxygen Sensor Green
  40. ABS kicking in, Dry road, not skidding
  41. AC bad smell
  42. Light miss/ shudder under light load
  43. Great News Tranny going I think..
  44. Traction Control Message
  45. airbag error
  46. Shop Manuals
  47. Access to transmission internals
  48. 98 winstar a/c
  49. Windstar Tranny Rebuild and Power Steering
  50. 2002 Tranny problem
  51. 95 w'star 3.8l dpfe
  52. Changing high-mount break light
  53. Uh oh! Coolant in oil.
  54. need help new windstar owner(couple issues)
  55. Codes 171 and 174
  56. Oil light and slight knock after 30min of driving
  57. Removing the transmission on windstar 1995 3.8L
  58. trans problem
  59. Is it an Axle (CV Joint), a Wheel Bearing or Tranny issue?
  60. Trans range sensor
  61. Horrible cooling system design flaw (rant)
  62. 97 Windstar 3.8 - not running - no pulse at injector
  63. 99 Windstar - Worth Fixing?
  64. 96 windstar turns over but will not stay started!!
  65. why the thing wont start again
  66. 2k Ford Windstar/auto door/won't idle
  67. Air Conditioning
  68. About the Intake Manifold Runner Control (IMRC)
  69. What transmission fluid to use for '98 3.8L?
  70. burning smell going uphill
  71. 99 fuel pump/fuel gauge
  72. Module on back of transmission?
  73. 97 Windstar Air Conditioning Unit is not spinning
  74. isolator bolt fix without the valve cover
  75. Wheels Seem to be Grabbing
  76. 1999 ford windstar lx
  77. 1999 windstar door locks
  78. 1999 ford windstar lx engine cuts out 4000rpm
  79. head gasket replacement cost??
  80. 01 Windstar No Left Low Beam
  81. update 2003 windstar
  82. 2001 Windstar ABS and Brake warning lights come on
  83. 95 ford windstar windows and locks won't work
  84. A/C Issues
  85. 2003 ford windstar
  86. 98 Windstar Brake Problem
  87. 2033 winstar wont do any thing
  88. 2001 Windstar 2001 EGR
  89. Windstar Towing Upgrade
  90. cam position sensor
  91. Door Adjar Switch Location Picture
  92. 1999 Windstar Lx Front Bumper
  93. transmission help
  94. Trany Problems 95' Windstar
  95. Tie rod lube?
  96. 96 Windstar...code 0351 issues....
  97. 95 windstar dpfe signal voltage
  98. ABS sensor location
  99. Fuel injector question 96 3.8
  100. transmission leak
  101. Urgent Question: accidentally pour brake fluid into crank case
  102. Air Conditioning Problem
  103. 1999 transmission leak
  104. Rear drum brakes
  105. 98 Windstar blowing hot air in rear a/c
  106. 2001 Ford Windstar Brake Leak
  107. Ecm I need help 99 windstar
  108. Ford Windstar
  109. looking for dash lights
  110. aftermarket radio
  111. excessive coolant usage-- '98, 3.8.
  112. flickering lights
  113. 99 windstar will not turn over
  114. 98 Windstar will not start
  115. Torque Coverter Clutch Stuck Code
  116. Having a bizarre problem
  117. front windshield washer pump quit OR how to rebuild cluster switch
  118. tough one
  119. 96 windstar transmission slippage
  120. 97 windstar a/c pronlem
  121. no headlights
  122. power steering total failure
  123. possible head gasket problem
  124. Relay and fuse help
  125. Is MERCON and MERCON V Compatible?
  126. Shutting off while driving......not cool
  127. 2000 WIndstar armrest
  128. Hot relay & draining battery
  129. A/C can't turn off?
  130. 96 Windstar - Code P1538
  131. 2000 Windstar SEL interior lights flickering
  132. 2000 Windstart Trac Action
  133. Changing Thermostat in 99 WS
  134. Is my tranny bad???
  135. Reverse sensing system acting up!
  136. ABS question
  137. Speedometer jumps between high and low states
  138. Power Window Motor Replacement
  139. 98 Windstar Transmission Quit while driving
  140. 99 Windstar LX Radiator ?
  141. 98 3.8ltr plastic against metal slapping sound / serpentine belt broke
  142. where to get OEM transmission pan gasket '98 3.0L
  143. Could this be the problem?
  144. 1999 3.8 Windstar CMP housing setting
  145. dont know what to do!!
  146. sale. 15x7 5 spokes w/225-60 tires
  147. 2000 Windstar Surging?
  148. Shudder, Shudder, what words to utter!!!
  149. 2001 windstar side speaker problem
  150. A/C Vent Contro;
  151. '03 windstar, trans bucks, lurches
  152. My vans not feeling right!!!?
  153. '02 Windstar compressor shot- compressor?
  154. 2001 windstar bumper cover repair?
  155. Fuel Pump Life
  156. wheres the guy w/fans running all the time?
  157. Berryman chemtool fuel system question
  158. Visteon VCR
  159. excessive wear on the driver side front brake pads
  160. Strut rod bushings
  161. torque converter switch
  162. 98 Windstar 3.0
  163. '99 Windstar Back-Up Sensors
  164. How to change solenoid?
  165. Is my tranny fluid low?
  166. 96'Ford Windstar Pump...Where?
  167. 98 3.8L Periodic Shudder
  168. Curious: Change from 3000 to 1500RPM for IMRC?
  169. Transmission leak
  170. 2001 Windstar Power Window problem
  171. Progress Thread for Repairing the Lower Intake Manifold Gaskets and related items
  172. headlights
  173. Ford windstar Squeaks then stalls
  174. Location of torque converter clutch solenoid?
  175. What else to do while doing the lower intake manifold gaskets?
  176. WS jerks real bad when put in gear
  177. 2000 Winstar Electrical Schematics? (Still fuse #6)
  178. Windstar Coolant Change
  179. Symptoms of torque converter failure?
  180. 1999 Windstar 3.8 Shutters .....
  181. It's not a processor....it's the transmission...HELP!
  182. Anyone know the name of this processor?
  183. DIY Accident Damage Repair
  184. How do I remove the A/C Clutch
  185. Strange Transmission problem
  186. Door Locks Relay
  187. Needing Help
  188. 2002 Windstar New Trasmission Failed
  189. Power Steering Issue!
  190. Water Pump question 2000 Windstar
  191. 98 3.8 Windstar bucking and rough idle
  192. More on 95 surging problem
  193. '96 Windstar stalling when put in reverse or drive
  194. OBD-II Scan Tool Communication Error
  195. computer flash?
  196. 99 windstar 3.8 tranny issues - again
  197. tuch up pait kit
  198. HVAC problem
  199. 03 power steering
  200. where to jack the front end using hydraulic jack?
  201. DEADLY Antilock Brake Operation: 2000 Windstar
  202. white smoke/flickering oil light/little heat through vents
  203. 1999 WS 3.8L white smoke
  204. 2001 battery light on, won't start in hot weather
  205. 2001 Windstar trans leak -- what should I look for?
  206. 97 Windstar - ABS problem?
  207. How do I find TDC on a 3.8 L 95 windstar?
  208. 2001 Windstar "Bucking" between 45-60 mph
  209. 2000 Winstar keeps blowing fuse #6
  210. Outside Temp displays ERR
  211. 2000 3.8 ABS Light at it again
  212. Ford Rattling from bottom
  213. 2000 Windstar fuse location info?
  214. 2001 Windstar - no cold air in front
  215. Went over a bump, now no radio or power sliding door
  216. 2001 Windstar CV Joints
  217. 96 sliding door
  218. Airbag
  219. Ford CDs request >>-need help-<<
  220. Clunking noise when coming to a stop
  221. 96 3.0 with code P0430
  222. Rear light issues
  223. 97 Windstar Power Window Problem
  224. DIY power steering system flush !@#$
  225. Trans trouble
  226. VSS vehicle speed sensor P0500 code
  227. P0500
  228. p1309
  229. Windstar Manuals
  230. Where to buy the Iso Bolts & Ports Gaskets
  231. Help
  232. WindStar Not Starting Up Unless
  233. 2001 Windstar Transmission Line Removal
  234. 2001 SE Fuel Mileage Drop
  235. 99 ford winstar light problem
  236. Cruise control & Abs
  237. winstar alternator?
  238. Loud electric lock buzz on sliding door
  239. Wrong fluid cause hard shift?
  240. 2001 Windstar hesitation
  241. Power steering fluid replacement '97 Wind 3.8L
  242. 2002 Windstar Door Key Lock Repair
  243. help sisters car taillights come on and stay on
  244. reverse alert, need help!!!
  245. clunk from park to drive or reverse
  246. Cylinder head replacement
  247. 2000 Windstar - Mass Airflow Sensor code & rough running
  248. Engine bogging down and trying to stall on startup
  249. Changing Front wheel bearing
  250. remote start...
