View Full Version : Windstar
- power outlet off when car is off?
- Shuttering
- lighting problems
- 14mpg with windstar in the city?
- Trans jerks
- How easy is it to change the serpentine belt?
- Drop-pan method only got 4.x Qt of transmission fluid?
- front end noise cannot diagnose
- rattling noise upon acceleration
- Squealing BELT - Which pulley
- '98 Windstar transmission shift hesitation between 2nd and 3rd gears
- 98 ABS kicks in
- code P0156 HO2S
- '98 Pulls to the right
- ABS sensor
- 2000 Ford Windstar Driver side seat not workin
- Rack and Pinion Replacement 98 Windstar
- 1996 Windstar
- Squeaking noise when turning right
- Transmission slipping in 1st and 2nd
- no power to whiper motor, power windows, dome light
- Ford Winstar Battery Dash Light On Runs New Bat Help
- 99 windstar throttle cable broken Help !
- Proper coolant temperature gauge operation?
- Brake bleeder bolt stuck, now what?
- 99 Ford Windstar LX
- No Heat Thx Wiswind
- '98 Windstar - Brake Shake - Help
- Disconneted Vacuum Line
- Front blower does not work
- 2000 windstar code 1518 - any help?
- trans cooler
- heater water outlet tube
- 1998 Ford Windstar Won't Start
- Routine Transmission Flush
- Lug nuts (class action Law-Suit)
- 98 windstar engine rpm
- Is your clear coat peeling on your door trim?
- 1996 Windstar stalls at stops when warm
- winstar knock
- '96 3.8L Windstar Idles too fast.....
- Running Rough no CEL code
- 99' interior fuse cover
- 98 Windstar Transmission Jerking
- 1999 windstar
- '96 Windstar misfires when warms up....
- Front End Electronic Control Module
- Tranny fluid sucker
- air bag light blinks then stays on?( 2001
- Does power steering pump pulley have to be removed before removing bracket on 98 3.8
- 1996 ford windstar trembles.........
- EGR wisdom please anybody?
- Power Booster Delay Causes me to hit dog on highway.
- Sufficient Seafoaming process for 95 3.8L?
- engin lihgt on code 1517
- 2000 stabilizer bushings
- 2000 ford windstar-clicking noise
- 98 Windstar strange finding
- A/C, Odometer, Speedometer not Working, O/D Light Flashing
- What do you call the clips that attach the window to the power window regulator
- 96 Windstar died suddenly
- Correct Fluids for 96 Windstar
- The thing is possessed!
- Oil pouring into exh. need rec. on long block supplier
- compatiable replacement alternator for 95 Winstar 3.8L?
- Transmission Range Sensor REMOVAL HELP!!
- 02 Windstar codes 172 & 175?? anybody know?
- 97 Windstar idling problems
- Tune up help
- 99 Ford Windstar, Rack & Pinon
- Rear AC in 96 Windstar
- Battery or alternator?
- Urgent vss sensor not the same??
- 2001 Windstar window Question
- Vacuum Bleed off
- Oil everywhere
- Rear shocks/Springs?
- oil pump, cat conv, and oil pan replacement
- 96 Windstar, Power Train Roughness Cruising
- 2000 plenum help
- Field report: DIY strut replacement
- Need advice - tanny shudder not fixed by fluid change
- Windstar ignition switch actuator
- 99' engine problems
- '98 3.8 new battery dead, coolant level seems low in radiator, engine hot...?!?!?!?!!
- removing EGR valve
- speed sensor loaction
- HELP.. tune up
- any help would be helpful
- Evaporative monitor won't clear
- 95 3.8 water pump replacement
- 03 Windstar transmission - slip/shudder
- 2000 windstar misfire
- 2000 windstar EGR
- 98 Windstar IMRC Vacuum
- After fixing 99 WindStat Power Window (Driver Side)
- Max Air Not Blowing/working Help
- 99 Windstar code P0181 Fuel Temp Sensor
- max blower now blowing
- Runs rough in the rain
- 2003 SEL Advise Please
- 1999 Ford Windstar
- What might cause rough 1st-2nd tranny shift other than low&intermediate servo gaskets
- Help: Can't slide the flex pipe out from the muffler! (photo)
- Can a fuse just pop?
- Help! scary brakes - 96 Windstar GL
- ABS light on sometimes
- 96 Ford Windstar A/C Problems
- Brake Pressure switch failure
- Front brake rotors
- Air not blowing through the front vents
- ABS and Brake warning light.
- 2002 windstar adjust strut towers ??
- 98 Windstar GL DRL
- Right headlight low beam stopped working
- Isolators intake plenum 96 3.8
- engine stalls
- Help, still clunking after bushing were changed
- Blowing Fuse #14
- Trans trouble far from home
- which new tire to buy
- oil change type
- Transmission Flush and Cooler installation
- A/C oil leaking from the A/C compressor and its hose in 2003 Windstar
- 98 windstar tranny
- 99 Windstar tach quit
- Resonating / Vibration Highway Speeds
- air conditioning
- Battery light?
- Engine stalls at idle--clueless!
- Codes 171/174 Returned after TSB fix - Windstar stalls when hot
- Is it the Alternator
- Workshop manual for 2003 Windstar
- "Clever" way I plan to my change Transmission Fluid
- Will P0171/174 affect the state inspection?
- VCP - no display, and audio panel lights, but does not work
- What type of oil do you use?
- 1995 windstar 3.8 eno. passenger side powr. wndw
- Halfshaft removal
- open door beeping and light
- Tranny Problem
- ABS Control Module SOFTWARE download
- ABS Light
- 99 Windstar problems after isolator bolt fixes
- 96 Windstar starter grrrrrrrr
- Brake switch recall
- Horrible Smell coming from ac vents HELP PLEASE :)
- 1998 Windstar's OD light is flashing
- 98 WS Overdrive button broke - Help!
- EGR Vacume Solenoid Question
- 2003 Windstar parking brake adjustment
- Transmission/AC problem???
- O/D Blinks but no CEL - How do I read Trans codes?
- A Tip for Stalling/Bucking (own a 2000 Windstar)
- Transmission Adjustment Shift Cable Yellow Clip, How? Help?
- AC vacuum line help
- What's wrong????
- 1999 Ford Windstar Broken Power Sliding Door Actuator (Motor)
- Front end Noise/Vibration
- No AC, compressor clicking
- 2000 Windstar Pulls out in Second
- Transmission Fluid Change from Ford Shop Manual
- 1995 wdstar 3.8 pass. side pwr wndw.
- Transmission Range Sensor Adjustment
- Transmission Shudder - fixed!!
- 2003 Windstar Eletrical Problems
- Opinions please....
- Caliper Anchor Plate Bolts/Spark Plugs
- Belt and Belt tensioner installed 95 Windstar 3.8L; battery light?
- Help !!!!!!!
- Inoperative outside mirrors
- 96 windstar 3.8 stumbling / stalling - hesitate
- Looking for a Tranny in Michigan!
- error p1537 98 windstar
- IAC missing cap or plug 96 windstar 3.8
- 01 Windstar Trans Lever, Thump Question.....
- Cleaning spray for throttle body/intake
- CMP setup on 95 3.8L
- tranny dead???
- Dual Transmission coolers
- Transmission trouble?
- 2001 Windstar Limited Stalls w/no warning or reason
- Gauges Gone Wild!
- Plug wire question.
- Dropping resistor
- Rusty Exhaust System for '98 3.8L
- intake mannifold runner control
- 98 Ford Windstar GL
- 2001 power steering leaks at pressure hose fitting
- sticking at ful throttle?
- Wire question
- EGR ports cleaning
- Not your average Fuse#10 problem
- Engine shudder / hesitation
- power locks all doors not functioning
- 98 windstar headlight vs DRL modual
- 1999 3.8 trany leak questions
- Upgrade Time
- Glove box cannot be opened.
- 1998 Windstar -Transmission help
- Very Rare Windstar Transmission Problem
- 95 3.8 surge with a/c
- '96 exhaust question
- Hesitation EGR
- ac problem on 99 windstar
- Interior light question
- Monroe QuickStruts
- Some More Questions
- Removing the cowling on 2000 Windstar?
- 98 windstar no. 2 cyl. misfire?
- idle issue and lower intake manifold
- 98 3.8 Stalling at Stops
- A few general maintenance questions...
- 2001 SEL with power window issues!
- 2000 Windstar SEL - adding a sunroof
- Valve Cover Replacement For 171 & 174 Codes
- Help identify part
- A/C fine in town, No engagement on highway?
- 2001 Windstar- no codes but shudders
- Paint codes
- brake light staying on
- 96 windstar has miss in the engine
- Did Power Steering Flush on my 03 WS
- 2003 Windstar oil pressure switch
- Plenum Bolt Replacement Help
- Brake light on (intermittent) 2001 Windstar LX
- 1996 Windstar - Need Help Solving Passenger Power Window Problem
- 1998 windstar air conditioning not working
- 1998, GL 3.8L: How to take off front hub?
- 2001 Windstar - no rear a/c
- 2001 Windstar do not blow AC/Hot air from rear vents.
- Disable the stock alarm?
- tranny return line???
- Oily fouled plugs only on one side of engine
- Rear drum brake ceasing wheel
- Overdrive switch does not work
- 2000 3.8 Dying when comming to stop Please help OBI WAN
- Flex pipe broke on '98 Windstar 3.8l
- Strut Replacement??
- 99 Ford windstar brakes
- Cruise Control - Replacing Resume/Set/Accel/Coast Switch
- AC drain line
- Stripped O2 Sensor
- What's the difference between TSS & VSS on a 98?
- 2000 Windstar Stall/Hesitation
- Name that fault - squeaky wheel
- 98 vacuum hose routing and Greta ran out of bread crumbs.
- lower control arm how to get it off
