View Full Version : Windstar
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Ford OD Transmission Maintenance & Auxiliary Cooler Installation
  2. Anyone rebuilt their 1999 or newer 3.8 Engine - Looking for a good rebuild kit
  3. 2002 Windstar Power Steering Switch
  4. 2001 windstar speedometer and abs light prob
  5. Finding heater core hoses on '98 windstar
  6. Code P0455 along with 171/174 Help please
  7. tire pressure
  8. 99 winstar tranny slippage
  9. Power steering leak 1997 windstar
  10. how to remove the vehicle speed sensor from a 2000 ford windstar
  11. clunk/jerk when shift the lever
  12. left head light
  13. Howling harmonic noise from right front
  14. Knock
  15. Electrical problems
  16. Clogged EGR ports
  17. Driver side armrest
  18. A different electrical problem, '03 Wind
  19. A different electrical problem, '03 Wind
  20. Camshaft synchronizer assembly removal problem - need advice
  21. trying to remove VCR
  22. Fuel Pump Question
  23. spark plug changing
  24. newbie ford owner here.
  25. Heater Problem, NOT actuator
  26. door lock acuator install
  27. H frame rotten
  28. H frame rotten
  29. Front brake rotor hold screws
  30. Alternator Bearings
  31. Removing headlight housing - am I being dim?
  32. Pinging - EGR question
  33. Has Anyone Used An Oil Pan Pad Heater?
  34. 2003 Rear Defroster cable disconnected
  35. Rear entertainment problems
  36. P0302 Misfire on cylinder 2 (rear bank middle)
  37. windstar question
  38. Flashing Check Engine Light
  39. 2002 Windstar keeless entry error codes
  40. my 1999 windstar se will not start
  41. 6 cd changer won't eject or play (2003 Windstar)
  42. 171-174 codes after tsb
  43. 98 Windstar ABS light on/ help
  44. 99 windstar trans replacement
  45. 95 Windstar/Head gasket failure/Short trips
  46. Engine won't fully rotate! HELP!
  47. Ford Reman Trannies and Engines
  48. 1996 Windstar 3.8 engine swap, what's compatable?
  49. Back-up alarm quit working
  50. 99 Windstar - rough idle at stop or at start
  51. ignition problems,wont start
  52. 2001 Windstar Coolant hose pipe leak Solved with Pictures
  53. Power Steering, Intake Manifolds, And Automatic 2 Step...wtf?!
  54. Low oil pressure on new engine install
  55. electrical component on plenum 2000 3.8
  56. Engine Sputtering while in Gear @ Stop
  57. My new engine is installed 1995 3.8L
  58. 2003 SEL Windstar Window Washers Problem
  59. vaccuum line unplugged
  60. VSS Replacement Question
  61. 2 extra gaskets 171/174 kit from 1A auto?
  62. oil question (did 171/174 repair last night)
  63. 1995 start\stall
  64. Name That Part (with Bonus Question)
  65. Tail lights
  66. worth buying
  67. adjustment of washer spray heads
  68. Pinging & Oil Consumption
  69. Another Windstar heater problem thread
  70. 2000 windstar strut advice needed
  71. directions/suggestions for installing drain in trans pan
  72. Code P0315- Help!
  73. changing alternator
  74. 99 windstar imrc bearins leaking
  75. Blinking parking lights and won't start
  76. '95 Winstar wouldn't shift into 3rd, then stopped completely
  77. ford code po442 and engine miss
  78. Intermittent Battery Light
  79. RPM fluctuates with steering, is this normal?
  80. po705 problem resolved (was need help badly)
  81. Pulsating the right front brakes
  82. Transmission Problems
  83. Gas tank backpressure 1999 Windstar.
  84. anyone changed the TRS without the alignment tool??
  85. Remote Starter
  86. Check engine light
  87. Temp Gauge Acting Weird
  88. 2001 DTC Code P0156
  89. tsr connector wire diagram?
  90. od light intermitent all the time- 3.8 1996
  91. Type F trans axle fluid for 2002 Winstar?
  92. 1995 Windstar won't shift after running a while.
  93. po705 help needed badly!
  94. Window Motor 2001 Ford Windstar
  95. another cruse ?
  96. 2002 Ford Windstar Bumper
  97. Power Steering
  98. automatic locks on 2001 windstar
  99. Check your printer ink and warm up your printer. THE LIST!!
  100. 2001 door frame sticker missing correct Tire psi
  101. OD off flashing with P0741 code
  102. Message Center Annoyance!!
  103. '99 Windstar gaining negative camber on drivers side only
  104. Am-FM Radio and Entertainment System Sound
  105. 98 Wndstar won't shift
  106. OD light flashes for first 5 min of driving
  107. Power Steering Pump Pump Noise
  108. Intermittent misfire
  109. '99 Windstar runs poorly cold until warm
  110. flasher rate
  111. wipers
  112. Failed Spare Tire Cable/Winch System
  113. Entertainment System on 2000 Windstar
  114. 1995 Windstar power steering hose/line
  115. Microfuse
  116. Hiss from engine, 171,74 DTCs
  117. engine quit running on interstate
  118. Socket Size For Factory Lug Nuts
  119. 95 Windstar hestates wont go over 60 mph
  120. 98 Windstar Stalling
  121. Owners manuals online - Windstar 1996 thru 2003
  122. stalling at idle
  123. Vehicle Speed Sensor and "General Info" sticky
  124. Injector cleaning
  125. New Engine Break In 1995 3.8L
  126. rocker arm / adjust valves
  127. Seatbelt buckle switch
  128. windstar transmission dead ?
  129. Headlight repair
  130. Biggest transmission cooler the 95-98 will allow
  131. 2001 Windstar Idiot lights
  132. Windstar 3.8 Water pump, Heater core and Master cylinder
  133. CV Joint Boots just starting to Crack/Leak
  134. oil in coolant!
  135. Autozone Ball Joint Wear Indicator Inspection
  136. '96 Windstar front end noise.
  137. Parts Prices - Feedback?
  138. 2000 Widstar mis-fire on cylinder 5 and tapping sound
  139. Intake manifold runner control linkage
  140. Can running lean cause damage?
  141. Please help with windstar problem - P1518 IMRC code
  142. 98 windstar door ajar alarm and light
  143. Transmission Speed Sensor Discrepency
  144. P0104 P0107 on 2000 windstar SE 3.8L...again? PLEASE HELP ME
  145. Shuttering in low RPM, all gears, intermitent blinking CEL
  146. Transmission line removal RAPID ANSWER NEEDED
  147. 1999 windstar lx rough idle
  148. 2000 windstar alternator woes
  149. Power Steering
  150. 2002 Doesnt have DPFE
  151. 2000 Windstar SEL Door Lock Problem?
  152. Doorlock light's
  153. windstar intake knock
  154. Pulling the tranny
  155. AC how to check relay 204
  156. What is the little white module on the top of my transmission?
  157. 95 Windstar uneven break pad wear
  158. Mysterious front end noise
  159. air bag light code 21
  160. 2003 Windstar Transmission Problems
  161. 2000 Windstar Transmission issue
  162. Bad slipping between 2nd &3rd, but only when TRS is plugged in.
  163. Body and subframe separation fix: Insulators WHERE?
  164. Cruise control no worky in 95 GL
  165. change spark plug wires-01 windstar
  166. Revving in PARK produces odd shutter/shake 3500 - 4000rpms
  167. The Fastest and Furious Windstars :)
  168. Captains chairs or Bucket Seats into 2nd row of 95 GL
  169. Choosing between a like new 2003 LX or 2000 SE Windstar
  170. 98 3.0 Emmisions codes and Stalling
  171. 01 Windstar (SEL): Cannot read Codes
  172. 2000 Windstar PATS key
  173. Does 95 water pump give pre-failure warning?
  174. Replacing Control Panel Lights
  175. Airbag Light On
  176. Public service: US govt auction for donor vehicle in FL
  177. change plugs and wires on 2001 windstar
  178. Splash Guard?
  179. Just so you know on a Freestar..
  180. 98 Windstar code 1461 and 1462
  181. Opinions of value for private sale after new tranny and engine - 1995 Windstar 3.8L
  182. Backup sensor theory
  183. Replacing plug wires
  184. Does 95 turn signal switch have safety issue, not finding any
  185. any trick to removing rotors on 01
  186. AX4S Transmission Interchangeability 1995 - 2000
  187. Pulling motor 96
  188. Fluid Leaking
  189. Now running rough when cold after working in intake - '96 3.8L
  190. 99 Windstar ignition problems
  191. Tie Rods: Do Both Inners or all 4?
  192. Throttle Body Stuck To Plenum
  193. Oil Leak, Oil Pan or Crankshaft seals? 2002 Windstar
  194. Lubricating sliding doors
  195. Front end work
  196. power steering questions?
  197. '95 trans issue's.
  198. Drive belt and spark plug wires. What RU running.
  199. How hard to change the cats on 96 3.8l
  200. egr problems
  201. My heater blows cold air in front and hot air in back
  202. JB Weld
  203. 1999 ford windstar se 3.8l wont start
  204. 99 windstar lx 3.8
  205. van stalls with right turn
  206. '98 Windstar Transmission Repair Results a Mystery
  207. Sound system info!
  208. Do I need to change my Crankshaft Position Sensor?
  209. Thermostat replacement with lower temp opening setting
  210. Brake Pressure Switch and Cruise Control
  211. 96-98 engine in a 95 with AX4S transmission
  212. 95 3.8L water pump replacement procedure?
  213. 2000 Winstar door ajar
  214. 2000 drivers side sliding door jams up
  215. 95 Windstar ABS light
  216. 2000 Windstar will not stay in overdrive
  217. Alternator and Rain
  218. Thread size in Shredder valve
  219. Codes 171 & 174 ligh back after 5k
  220. 2000 Windstar powersteering
  221. 2000 Inner Tie Rod - My Experience
  222. Rough Idle and No Fast Idle When Cold
  223. codes p1506,p1152
  224. Stick a fork in it, its done.
  225. Erratic speedometer reading
  226. '98 Windstar Idle 'Hiccup'
  227. '99 3.8 LX, weird ind. lights/loss of electrical
  228. 2001 Windstar Heater actuator
  229. Cruise not working and O/D off light flashes
  230. 98 Windstar rear brake job
  231. 95 windstar rough 1st shift
  232. windstar trouble code 1056
  233. remote fob program
  234. 1989 ford windstar tumbler replace
  235. Changing alternator on '98 Windstar, pulley come with alternator?
  236. 98 Windstar w/trac control soft break pedal
  237. Front Engine Cover Coolant Leak
  238. 2000 windstar driver side windows: help
  239. Transmission shop put Mercon instead of Mercon V in my tranny, now what?
  240. 98 Rear Hub Assembly
  241. Lower Intake Manifold Gasket Leaks on 2002 Windstar?
  242. Windstar info
  243. Stalling Cold Start
  244. Main seal squrting transmission fluid a few days after changing transmission oil
  245. o2 sensor
  246. power locks makes nosie
  247. Wiswind Filter change
  248. Power window don't work
  249. Grinding AC clutch engagement
  250. To what degree does it hurt the transmission with not sufficient transmission oil?
