View Full Version : Windstar
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28
  1. Changing Stereo?
  2. 98 transmission interchange
  3. 01 Windstar bucking in high gears
  4. 2002 windstar squeal without serpentine belt
  5. 2001 Cold Windstar
  6. 2000 windstar 3.8 van with a 01 motor installed vibrating
  7. 03 Windstar. Hazzards will not stop flashing
  8. aluminum valve cover for the rear of a 2000 3.8 ????
  9. 2000 3.8 #2 missfire and strange plenum noise and rattling noise possibly cured
  10. Excessive Oil Consumption '00 Windstar
  11. Heater Core Quick Disconnect Cracked
  12. Transmission Failing??
  13. Do you have to reset the brake service light?
  14. 2000 3.8-Neutral SftySw-Is this the shaft?
  15. Size of steering knuckle to strut bolt/nut?
  16. Multiple Unfixable Problems! charging/tranny/too lean/etc.
  17. 99 Windstar. Cold Start Problems / White Smoke
  18. What is this?
  19. Axel recall on ABC News
  20. Unable to pull codes on 2000 Windstar
  21. Reduced turning radius in 2000 from 2003
  22. Rear Axle Recall Question-worried!
  23. Obd
  24. Crossed power steering lines/98 3.8 Windy
  25. CV joint? Brakes rubbing? Steering rack? Bearing?
  26. 1998 Windstar power steering line routing...
  27. 95 3.8 coolant troubles
  28. 2001 Windstar (3.8) IMRC issues/questions
  29. no heater at idle/heat when driving
  30. 01 stalling at 45 mph
  31. Blend door actuator
  32. 99 Windstar Knocking
  33. Please Help!
  34. no gas
  35. Technique for aligning new strut?
  36. 2002 Windstar - Computer Issue?
  37. hose disconnected laying on engine???
  38. 2000 winstar problems
  39. 99 Windstar, different no heat problem...
  40. real head scratcher p171 and p174 codes
  41. 2001 Windstar PCM Power Relay
  42. low rpms and
  43. 2003 windstar runs rough when cold
  44. Misfire & EGR test
  45. Blank Odometer
  46. 2000 Windstar 3.8 engine
  47. Pinging Problem, Tracing it's cause
  48. 95 for w-star engine surging
  49. 96 3.8 Hard Starting/Rough Running Battery Light On
  50. 2001 Winstar wants to stall at stop lights
  51. Transmission not shifting
  52. Brake Lights not Coming On
  53. third brake light stays on
  54. 96 front wheel bearing
  55. IAC Question
  56. 98 Windstar Intermittent No Start
  57. unbelievable! fifth transmiision.
  58. Clockspring gone bad?
  59. po402 code Help?
  60. Im new to this and need helpppp! p 1516?
  61. 98 Windstar strats okay - rough idle after warm start on Humid day
  62. Synchronizer Sqeak Video
  63. 03 Ford Windstar SE frozen compressor...Is there an easy fix?
  64. 98 w/3.0 engine cranks but won't start?
  65. PO171 & PO174 Code, With A Twist
  66. 99 windstar P1518 idle speed/air control motor??
  67. vehicle road noise
  68. Axle OK but have a question
  69. Car wont start or dies/Code reader error/Bad ground?
  70. ABS/ brake problem
  71. Solution to A/C switching vents on its own under engine load.
  72. Engine stumbles under while in low torque
  73. P0500, P0401 and P1537, Windstar 96
  74. Power sliding door won't open
  75. 98 Windstar: Good Quality HID Conversion Kit
  76. Broken front seat bolts
  77. Misfiring - Spark Plug, Injector, or Coil Pack?
  78. 98 Windstar with Electric gremlins: Windows, Fan, Turn Signals and Interiors
  79. Do I replace head gasket on 96 3.9 Windstar?
  80. rear axles
  81. rear axle recall
  82. NOOB with '96 Windstar 3.8 IMRC and vacuum issues
  83. Dies while driving
  84. windstar Blend Door Actuator/Video
  85. Help!..its going to get chilly
  86. Rear AC line problem
  87. Airbag code help!
  88. A/C switches vents on its own
  89. Crappy Ceramic Pads
  90. Air sucking sound, unserviced transmission
  91. 2000 Windstar won't start
  92. Dashboard cluster
  93. sticky steering
  94. Windstar 98, 3.8 liter - whistles and missing power
  95. Park Assist Sensor Test
  96. To keep or not to keep
  97. Sway bar bushing/subframe
  98. car wont start after using ac
  99. IAC Valve makes Windstar die.
  100. Code P0001??? Please help ASAP!
  101. Windstar steering line fitting dilemma
  102. Ford Windstar dies please help
  103. will a 99 window switch console fit a 2001
  104. Weird Buzzing Noise from 98 Windstar
  105. 98 Windstar surging problem
  106. Octane shorting plug
  107. 96 A/C Problem
  108. new power window motor failed after 5 tries
  109. Air bag code 44, Windstar 96, 3.8l
  110. Rear view mirror installation
  111. Help: Relay Identification
  112. Remote lock unlock no horn & another thing
  113. Rear Coil Spring Replacement
  114. Overly responsive steering
  115. No air flow from vents, blower fan running
  116. Overdrive stoped working / Flashing O/D off light
  117. obd2 wont read computer
  118. Rear Axle RECALL.
  119. Brake Lights - safe to drive?
  120. Steering Gear issues
  121. ac clicking sound ( no cold air)
  122. Squealing sound coming from right side
  123. Lights / electrical problem
  124. Brake pressure switch, do they go by another name? trying to find one
  125. 2001 windstar quits while driving
  126. 99 cranks but won't start
  127. Windstar Motor swap
  128. Getting drive belt off 2002 Winstar
  129. 98 windstar fuel system help
  130. 99 Windstar clicking sound
  131. Instrument cluster issues
  132. 2000 Ford Windstar, Not a whole lot of knowledge
  133. 2000 Windstar- Engine/accessory squeak
  134. Windstar wheel bolt pattern
  135. Speedometer issues
  136. Question about Amsoil products
  137. ABS LIGHT Stays On
  138. Transmisson Failure
  139. 2k1 Windstar lost AC, Odom, Speedom & flash OD Off light all at once
  140. 02 Windstar transmission problems
  141. 2001 WS - thermostat or water pump problem?
  142. Rear Axle Crack
  143. 99 Windstar steering pinion seems to slip
  144. Front Right Vibration
  145. NHTSA expands Ford Windstar corrosion probe to front subframes
  146. Does anyone have the 2000 windstar repair DVD/CD ROM?
  147. Vacuum leak too??? 2000 windstar 3.8
  148. 2000 Windstar transmission fluid leak
  149. Leaky heater pipes!
  150. 2000 Windstar Air vents not working right
  151. P1518 COde
  152. 2000 Windstar Transmission Leak
  153. 2000 Ford Windstar Plenums
  154. Clock spring wiring for 99 Winnie
  155. P1744 Code Concern?
  156. P0171/0174 post recall
  157. Are XF2P-BB transmission compatible to XF2P-BA?
  158. 03 windstar.. A/C Issues... never seen before
  159. Can a bad bearing stop a running engine?
  160. 2000 windstar turbine speed sensor R&R
  161. 96 Windstar brake pedal went to floor
  162. 01 Windstar How to remove injectors/harness?
  163. 99 Windstar 3.8 Died Need your thoughts please
  164. aged windstar what to do
  165. Mystery Transmission Problem - '98 Windstar
  166. 2001 Ford Windstar airbag code #14?
  167. 2000 Windstar Idling
  168. Is It A Misfire or Problem With Engine Mounts?
  169. Windstar airbag codes
  170. time
  171. electrical problems
  172. No headlights??
  173. help on vacuum leak, hot soak rough idle
  174. self rebuild or new front calipers?
  175. GEM module repair 98 Windstar
  176. 2003 Ford Windstar A/C blowing cold air only on highway
  177. Transmission Took A Vacation.
  178. 2002 cargo cruise control OFF button doesn't work
  179. 2001 Ford Windstar Replaced Blend Door Actuator
  180. 98 Windstar 3.8. Tranny won't shift to 2nd gear.
  181. van stumbles when accelerating engine light flashes then goes away. ideas?
  182. 0171 0174 please read
  183. Lost one, gained another!
  184. burned DPFE
  185. Runs great ...then seems to "fuel starve"!
  186. 2000 Windstar not accelerating
  187. 2003 windstar transmission leak.
  188. wiring a stero
  189. tow bar - hide, dont seek
  190. Misfire and backfire
  191. watchmakers problem - what screws are left over?
  192. 2000 Windstar A/C question
  193. Anyone removed the injector harness without removing intake? 95 year or higher
  194. 150k 2000 Windstar: Tracking down ATF leak in cooler lines
  195. 98 windstar 3.8 liter - P0402 code problem
  196. 2000 Windstar Front Hub or Wheel Bearing Back ???
  197. Rear Coil Spring(s)
  198. 98 Electrical problem
  199. 1997 windstar mysterious brown sludge in cooling system
  200. '00 muffler heat shield shot
  201. Windstar rims interchangeable with Chevy?
  202. front air blower switch?
  203. 99 Windstar won't upshift in top gear
  204. 99 Windstart grinding at startup
  205. 2000 SEL 3.8l Battery Cable Hot !!
  206. 2000 SEL 3.8 air conditioning troubleshooting a/c
  207. Intermittent Engine Stalling '01 Windstar
  208. seat looking a bit worn, what to do
  209. Word of warning...!
  210. Transmission Leak - photo attached
  211. stalls after running AC 2003
  212. no ac in rear just recharged
  213. nide a trasmission
  214. 2002 200K+ kms stumbles while accelerating from approx. 40kmph. Airbag light...
  215. 02 sensors CEL but thats not problem
  216. P0172/174 and now p0301/303 TSB repair done yet no luck. HELP?
  217. Rear axle beam possible recall 1999 to 2003
  218. 3.8/96 camshaft position sensor - strange instructions?
  219. AC Coolant Lines - Routing diagram
  220. Pic of Winstar w/20" wheels, anyone have?
  221. R&I tranny 96 windstar
  222. front windshield washer
  223. 96 windstar turbine shaft speed sensor
  224. power steering unit & belt alignment
  225. clunking/resistance
  226. Tranny issues
  227. TCC solenoid inductive signature, etc.
  228. 95 Winstar Serpentine Belt Problem
  229. 2003 Windstar stumbles at idle
  230. 98 windstar rear aux cooling unit problem.
  231. Where is the EGR Vacuum solonoid located..
  232. I see misfires in ScanXL but...
  233. '03 Windstar AdvanceTrac problem
  234. Air intake baffle
  235. BIG trouble with my Windstar!!!
  236. '03 Windstar makes moaning sound...
  237. Ford windstar van won't start
  238. '98 Windstar died, would crank but not starting
  239. Fuel Trim banks
  240. Am I loosing the alternantor?
  241. 96 ford windstar problems
  242. General A/C troubleshooting advice
  243. '00 Window driver side window won't roll down, door won't lock
  244. 1995 Windstar Evap changeout
  245. 02 power steering leaking
  246. 98 intermidiate hiss
  247. 95 Trany do not shift after sopping
  248. windstar 1999 hood release
  249. Windstar sppedometer, odometer, air conditioning
  250. Broken CV Boot Cover
