View Full Version : Windstar
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. location of ecu
  2. Win 95 3.8 with 171/174 Codes Help
  3. 96 Windstar start problem
  4. funny "rubber" squeek sound at front end
  5. anyone done the front subframe welding?
  6. 2001 - No front A/C - Rear A/C Works
  7. oil filter
  8. rigid to flex brake line help needed!
  9. 2003 Rear Power Window Motor
  10. 2003 Hard Shifting after tranny Service
  11. 98 Windstar Electrical Diagram
  12. fuel system status
  13. Fuel Injectors
  14. Cold Start - Rough Idle
  15. Struts on 1999 Windstar 3.8L
  16. 97 WS - Both Power Windows Out (and Rear Wiper)
  17. Humming sound coming from front end?
  18. rear brake shoe - 2000 windstar
  19. Driver Side Electrical Pannel Cannot Move Both Front Power Windows.
  20. IMRC actuator, help
  21. Just making sure I'm not missing something
  22. windstar bad hesitation
  23. 2002 Windstar - Stalling when cold low spd
  24. 96 winnie 3.8L cel codes
  25. Radiator Fan Droping Resistor assistance.
  26. 99 windstar heater door problems
  27. Attempts stall, Idle Pulses 600-800 rpms, horrible MPG
  28. 98 Windstar Braking Problem
  29. Dash Lights
  30. 96 windstar cooling fan issues
  31. 98 Transmission
  32. 95 Posessed lock switches? FYI
  33. 96 Windstar
  34. Magnaflow Ypipe part# 23353 - Anyone installed?
  35. Won't start, nothing obvious wrong, any suggestions?
  36. WTF?? videi ADS????
  37. 95 with a busted sway bar
  38. Windstar 98-2000 Transmission?
  39. yellow shift cable terminal lock
  40. 2000 Windstar suspension still mushy
  41. slightly OT - tech tip
  42. If your shopping for a GPS
  43. 2000 windstar power mirrior switch
  44. bottom rad hose 2000 3.8
  45. weak start
  46. field report: quickstrut,LCA,inner/outer tie rods, sway bar links
  47. 01 windstar "howling" noise (air)
  48. Drives itself up to 20mph until warm
  49. no spark for my windstar
  50. Defrost airflow door/diverter
  51. time quote for full suspension renew?
  52. Tranny slipping, long trip tomorrow-help!
  53. My p0420 code
  54. Shuddering on '01 Winstar with 90K miles
  55. Speedometer cable noise. Help please
  56. Code 171/174 question
  57. Code scanners/readers
  58. Rear Air on 01
  59. doing quickstruts Thursday, camber plate needed??
  60. Need Help replacing oil pump 03 windstar
  61. 1999 Windstar Camber alignment
  62. Sorry if I missed this......
  63. 2002 windstar hesitation-solved
  64. Cooling System Question
  65. 98 windstar 3.8l upper intake
  66. vacuum reading at intake manifold??
  67. ABS Brake Issue
  68. 5% Rock Auto discount....
  69. another coolant question 3.8 l
  70. Windstar Upper Engine - Photo Labled
  71. Belt Routing 2000 3.8 v-6
  72. Horrible Squeek and Missing Coolant
  73. bad vibration/shudder on takeoffs
  74. can i patch a hole in my cooling system?
  75. How do I change the head gasket on my 3.8L
  76. defrost, vent and floor vents stuck on vent
  77. 2001 Windstar Sport Transmission Questions
  78. Tranny slipping
  79. Oil Leaks - Help Please...
  80. Time to part it out
  81. 2000 Windstar Window molding
  82. 95 Windstar Is tranny shot?
  83. 2001 O/D button issue
  84. trans scanner tool?
  85. Exhaust Options - Catalytic Converter Ypipe and Exhaust pipe/muffler etc..
  86. holy crap, ABS Codes...........
  87. Difference in F78 and F88 tranny's
  88. A new problem, leaking somewhere
  89. 2002 winstar taillight problem
  90. Cleaning Upper & Lower Intake manifolds
  91. Cleaning lower & upper intake manifolds
  92. Try beat the infamous gasket again
  93. Windstar noise when moving from cold.
  94. Emissions Return Tube Part #
  95. Basic P1518 IMRC Questions - 1999 Windstar
  96. field report - ps flush 2000 3.8
  97. 2000 squeek/squall and stall...
  98. 1998 Ford Windstar IMRC - how many?
  99. Intermitten passenger side power sliding door
  100. Windstar Brake, ABS, and Trac Off Warning Light
  101. P0743 on 98 Windstar
  102. Winstar Vacuum Hiss / IMRC Question
  103. 99 windstar Shifting 4th problem TCC Help
  104. Code 171 Repair - Parts Question
  105. Transmission getting replaced
  106. spark knock....
  107. 98 windstar SEL lamp HELP!!
  108. Why are the door labels missing?
  109. Hesitation/Loss of Power
  110. teflon on brake pressure switch?
  111. How many 1995 Windstar folks out there?
  112. 98 Windstar Loss of Power / Hesitation
  113. need clarification
  114. trasmission fluid change
  115. Replace Dashboard Lamps
  116. Power Socket Fuses 96 Windstar
  117. Tranny or torque converter issues
  118. 1996 Ford Taurus LX Sedan 4D
  119. diy temporary alignment?
  120. steering problem
  121. possible parasitic drain source?
  122. help with vacuum line please
  123. code 1405
  124. Bad cat or not?
  125. traction control on sharp right tuns
  126. Where is homologation number on 2001 Windstar?
  127. need help with front end noise
  128. dashboard light bulb in a 1996 Ford Windstar GL?
  129. Rough Idle on Restart
  130. Moving Temp Guage and other problem?? Need Help!
  131. P0102- Bad MAF?!?!
  132. Intermittent Problem Starting
  133. best ball joint lub grease?
  134. Oh Crap!
  135. 2000 front caliper pins
  136. Shattered back glass-driving down hwy!
  137. Won't start after car wash! Fuse?
  138. 2000 3.8 Crank Position Problem???
  139. code po720
  140. 1997 to 2000 Windstar tranny
  141. Rack and Pinion replacement
  142. 96 Windstar engine miss under load
  143. Brake Pressure switch recall
  144. Ford Windstar Blown head gasket
  145. Did the P171/174 fix now rough idle
  146. Winding down noise
  147. 1998 Wheel bearing removal
  148. Problem with reverse
  149. Replacing turn signal/highbeam/wiper stick or lever
  150. Bell Housing Dowel-Pins
  151. P0301 – hesitation during rain - 2001
  152. Reman tranny & Rebuilt Engine Replacement.
  153. Rear main seal leak
  154. Anyone know what code 403 means?
  155. Rack- pressure valve,fluid questions
  156. tie rod boot clamps
  157. 2002 windstar loosing oil
  158. anyone use this scan/pc tool?
  159. tranny slipping..............????
  160. fuel pump problem
  161. New head gasket install
  162. Engine tries to stall after cooling fan cuts off
  163. 1998 Windstar Oil/Water in Throttle Body and Air Duct Hose
  164. Coolant Leak above Thermostat
  165. OBDII and FSM
  166. 2001 intermittent front wipers
  167. 95 Windstar oil leak.
  168. 2000 Front wheel bearing & hub - My Experience
  169. another "new bolt" thread
  170. 2002 Windstar hesitation during load
  171. Trans problem
  172. Battery Light Flashing at times.
  173. 96' Ford Windstar help needed!
  174. 95 Windstar temp gauge help
  175. speedo ?
  176. Convert water into fuel
  177. ABS Sensor compatibility
  178. headlight problem
  179. P0161 Downstream Oxygen sensor bank 2 HEATER circuit malfuntion
  180. is this the brake pressure switch?
  181. Electric Blend Door Actuator replacement
  182. 2000 gear shifter problem
  183. tranny cooler
  184. lower control arm - is my thinking ok?
  185. alarm lights
  186. Lots of work on my 2003
  187. Clunking Noise ??
  188. something better than alldatadiy.com?
  189. Rear Windshield Wiper Problems
  190. 2000 windstar defrost problems
  191. Performance Chip for Windstar?
  192. Intermittent Horn Failure
  193. windstar drum brakes
  194. 95 windstar waterpump
  195. FORD TSB for Spark Knock on Light Load / Acceleration
  196. Is this a blend door issue?
  197. EGR and IMRC
  198. doesnt overheat but temperature fluctuates radically
  199. 1995 Windstar won`t start
  200. New bolts necessary on 2000 hub assembly replacement?
  201. 2000 Axle / Spindle nut size 30mm or 29mm or 1-1/8?
  202. anyone replaced an inner tie rod?
  203. 2000 Ford Windstar 157K miles - 2000 to 2003 engine swap!!!
  204. anyone got pictures of trans drain plug?
  205. Broken hood latch cable
  206. P0302 cylinde #2 miss fire?????
  207. Brake Pressure Switch, What Now?
  208. 2001 Windstar Blend Door Access
  209. P/S Hose Blows off on '98 Windstar
  210. 1995 windstar fan problems
  211. front suspension suggestions needed
  212. A/C Clutch coil
  213. Brake Lights
  214. left front hub bearing
  215. please help me diagnose the ABS+Traction Control problem
  216. 98 Windstar no horn no cruise control
  217. Roarrr!!!!
  218. Strange Transmission problem -98 3.0
  219. Windstar fuse #9 and #16
  220. P1518 IMRC open
  221. Rough Idle when Cold
  222. tie rod - lower ball joint testing
  223. 2003 windstar rear liftgate problem
  224. 2001 Windstar-cooling system freeze out plug leaking
  225. Car starts but stops itself
  226. jerky, hesitation
  227. replacing oil and trans pan
  228. tranny not grabbin?
  229. 97 3.8l blew fuse #21
  230. 97 front blower relay
  231. Wet Weather Rough Idle
  232. Please help 95 3.8 Windstar coolant leak
  233. ABS light
  234. Problem with Remote Programming...
  235. Need help programing the keyless entry number pad located on the driver door.
  236. 2001 Windstar steering wheel stops turning 1/2 way through a turn.
  237. Please Help! 2001 Windstar Makes Clunking Noise
  238. 2001 Windstar (Deathstar) Rear Windsheild Wiper problems
  239. 2001 Windstar (Deathstar) No Front Heat, Rear Heat Working
  240. Help me pin point this rought idle...!
  241. Please Help!! Replaced Transmission and won't shift into OD
  242. Is this a hole?
  243. Performed p171/p174 code TSB but broke cruise control
  244. Brake pressure switch - '01 Windstar
  245. Replacing the cats
  246. 2001 SE - Outside Temp Going Crazy
  247. Power steering pump bad???
  248. Would like to say goobye to my good bye
  249. 2000 windstar deep engine knock
  250. engine misses only when loaded down
