View Full Version : Windstar
- a/c problems
- leaking radiator fluid
- 98 windstar stalls when coming to a stop
- 2000 Windstar po171/174 Finally Fixed
- Radiator Fan Relay Number & Location
- 2000 front drive axle joint seal/ lip?
- Coolant, temp, heater issue
- Reset the Computer to shut off idiot lights
- Battery Replacement on a 2003 Windstar
- Won't turn over
- Front End Issue
- 2001 Winny - No front brakes
- Fuel delivery problem solved
- Bad coil pack symptoms
- noise when stopping
- Gas Mileage mpg city hwy fuel economy
- Power Sliding Door Adjustment
- Help solve a mystery. . . .
- 02 Windstar Battery Dead Intermittently
- Use the right spark plug cap tool
- Going after the BUMP isuue..
- 2001 Windstar blending door vacuum line
- why the brake/abs light on with 2002 windstar?
- 2000 windstar stalls; how to check IAC
- intake manifold gaskets
- Help with cruise control
- 00 windstar chugs and bucks fixed!!!
- 2002 Windstar 3.8, P0171
- Upper Intake torque sequence/specs?
- ABS Light On
- Radiator Fan Always On
- Timing Upgrade
- Timing upgrade
- Going in for Trans replacement today
- Windstar rpms going up and down at idle
- grille question
- Tranny (Neutral Slams)
- Need Headlight Assy. 2003 Windstar
- B1
- Rear wiper won't work. 1998 Windstar.
- Fixed power seat, and electric mirrors 1998 Windstar.
- Trying to fix criuse control, 1998 Windstar.
- Ultimate Windstar
- does valve cover have defect on 2002 windstars?
- 2000 Windstar Issues
- How to know defective EGR Valve Windstar 99 3.8
- 2002 windstar probs
- How to use Compression Tester on my Ford Windstar 88
- No spark/no start condition
- Anyone else getting downshift clunk? 99 LX
- 2000 Windstar LX, how to know if equiped with load levelling
- Location of DRL
- Lower Intake Manifold Gaskets Failure Question
- P0174 - Replaced isolater bolts, port seals, "U" shaped vacuum hose, still cant pass
- Windstar Oil viscosity
- Bad Tie-rod Ends & Ball Joint
- Strut Mount Noise
- codes p171&174 and also p0401
- 01 windstar won't start or Jump
- 2003 windstar 1131?
- One Issue or Two ???
- Engine Vibration at 2000 RPM WINDSTAR 99 3.8
- Camshaft Synchronizer Brand - Opinion
- Rear Brakes - Drums & Pads
- Location of REM (Rear Electronic Module) on '98 LX Northwood
- gasline antifreeze in windshield washer fluid?
- MT 2500 scanner info fyi
- Battery Died, now speedometer and odometer aren't working
- 2002 Windstar Rough Idle, Spark Plugs, Coil Pack?
- Infamous heater blend door
- ABS Light On. Are codes in computer?
- '99 Driver's Power Window Not working
- 96 ford windstar instrument panel and headlights flashing
- Serious starting problem/no code info
- windstar 96 3.8 how to clear coodes
- If you lose 3rd gear and no back-up lights
- Rear Brakes Squeak - solution?
- tranny games
- 1995 windstar 3.8L loses power after 1.5 miles of driving, restart solves problem
- P code 1450
- 1995 Ford Windstar 3.0 Liter
- power sliding door adjustment?
- 99 windstar OD light flashing?
- rough idle after restart
- cruise control & abs problem
- cruise control@abs problem
- Key issue - 99 Windstar
- Ford Windstar 1998
- Spark Knock
- door keypad code
- Rear Window Washer
- same problem new info quitting while driving
- battery light flickers and car shuts off 99 windstar
- air bag light
- How do you change PS fluid?
- Uninstalling upper intake manifold for FPR?
- Our 3.8L Throttle Bodies
- Just replaced lower intake gaskets.
- Clunk Over Bumps (Not same scenario as other posts)
- parking aid sensor in bumper
- Where is my cooling leak? 3.8L 2000 WS
- 2000 Windstar not responsive when first started
- 2000 ford windstar brake pressure switch
- Headlight problem
- 99' tranny gone with no warning!
- Windstar Interior Disco Lights
- 03 LX 3.8 L; Drain Coolant Advice
- Spark Plugs
- flex pipe question 2000 3.8
- '99-'03 Windstar Headlight Adjust Tools?
- Smell Radiator Fluid inside & outside when using Heater
- 98 Windstar coolant dirty, cel flashing, rough running...
- Pass window and rear wiper do not work Related? 98 SEL
- po 300
- 2001 sel died while driving
- 1998 Ford Windstar Clock Spring???????
- Rpm Drop When Hot
- Blend Door Jerry Rig?
- Windstar Massive Chugging
- 2001 Ford Windstar
- Front end vibration at highway speeds
- Headlight Oxidation
- 1999 (3.8) Windstar Hesitation When Cold
- tranny cooler
- Changed every thing but cam shaft sensor is still
- Billy Beckman
- Rear Liftgate Strut Support Pins
- Power Steering flush works GREAT!!!
- Rough working engine
- '02 loud clicking/rattle on high rpm
- Parking brake light
- the dreaded PO304 code
- 01 Windstar Intake Manifold
- 01 Windstar Rough Idle
- help...random misfire detected ?
- 99 windstar still chugging really bad.. Help please
- 2001 Windstar blows #14 fuse shifting into/through reverse
- egr...camshaft sensor problem
- %%%**poll**%%%
- Lower intake gaskets...OEM vers aftermarket
- 99 Windstar misfiring -will that make it fail etest?
- 95 Winnie 3.8L Tranny Problem
- RPM limited to 4k
- Worked on the 98 today CEL gone for now
- steering wheel hard to turn
- 96 windstar LFC 41
- steering wheel repair/restoration?
- Stuttering 99 Windstar
- Front right tire wobble- cause ideas?
- Blend Door Actuator issue
- Odd P0171 & P0302
- speedometer cable lubricant
- Hubcaps falling off
- Cruise Control Problems
- Help - Engine light flashing, chugging - 99 Windstar
- 2001 Windstar SEL
- Electrical?
- NOW is the time to prepare for winter
- 2000 Windstar p1151, cant pass emissions
- 01 Winstar with studder at idle
- Ignition coil replacement?
- Help w/ changing ABS module on '03 windstar
- 2002 Windstar Code P1450
- will a transport key work?99 ford windstar
- 99 ford windstar i tried something & it didn't work.wet key problem!HELP
- 99 windstar erratic gauges door lock/unlock
- Opinions on Ordering a FSM From Helm Inc?
- 98 windstar front wiper not stopping
- oil changing time....
- Windstar with codes P0171 and P0174
- key got wet won't start 99 ford windstar van
- poor fuel mileage help
- Sliding Door adjustment
- Non Flat Line Headlights available?
- 99 Windstar - door in heat/AC box flapping. What's up w/ that?
- Windstar 13.1 miles per gallon and smell like gas
- 99 Windstar Lock Actuator question
- Is That A Pump I Hear at Engine Start??
- 1999 Windstar Alarm Question
- 2003 windstar transmission has no gears but Park.
- What I thought was trans issue was IMRC
- How to put the 96 Windstar3.6 head gasket?
- ac clutch problem
- 2003 windstar ABS & Brake light on
- 98 windstar EGR issues, bogs down, P0401 P0301 P1780 P1408
- Windstar Transmission Support
- bg fuel service
- '99 Windstar - Brake Problem
- Sway bar bushing replacement
- ping
- dropped pan, only go 4.5 liters fluid?
- 2000 no start
- Windstar Real Gas Mileage?
- Power steering fluid overflow
- FYI - Transmission Chatter
- 2001 Windstar P0401 EGR Insufficient Flow
- 03 windstar electrical problem
- 99' AC question
- Rear view mirror question
- good oil
- bucket seats?
- No speedo, A/C, Ometer, ABS light on etc. etc.
- about miss at idle or low speed on 2001 3.8L windstar
- Munching sway bar bushings like peanuts
- 99 Windstar Lean
- Fading Break Pedal
- Signing out
- Engine Oil Stop Leak - Good or Bad Idea?
- 2000 Windstar - Timing Belt or Chain?
- 2000 Windstar w 3.8L
- Overfilling oil while away due to Gustav
- Front end problems.
- HELP Please Power Steering Pump 99 Windstar 3.8L
- no dash bord lights help plzs
- miss at idle or low speed on 2001 3.8L windstar
- sheet metal parts supplier?
- quaker state multi vehicle atf ok for 2000 windstar
- Changing brake pads in my moms 99 3.8 windstar
- Brake Drum Question
- 99 windstar oil light, light assembly you name it
- TSS sensor
- 1999 3.8L Windstar knock/ratrle under load
- My WIndstar drain plug thread stripped
- 2000 Windstar electronic transmission issue
- Windstar 1998 Service Engine Light Code
- 1996 Trans Problems???
- 99 Windstar SEL Brake Questions (Maybe too simple)
- question about quick strut problem
- 2000 Coolant Leak from under throttle body ??
- 96 ford windstar trans problem
- no power
- AC refrigerant crimper/joiner tool
- Rear AC Hose Leak
- Rough idle/stalls when put into gear
- Replacing Catalytic Converter
- 2003 Ford Windstar Right Turn Signal out
- Changing out Compressor for AC
- fuel pump turns, but not pumping
- Steering, and bucking?? HELP
- Motor & Transmission Mounts
- 98 Ford Windstar issue
- Can this be true.???....................LOL
- What is your Fuel Pressure in PSI?
- 02 Windstar torque convereter
- Front door actuators
- 2002 Winstar Sport Edition. Hoses wet - REAREND - (Driverside) are those for the AC?
- '96 3.8L Misfire / Engine Sputters when Fan Turns On
