View Full Version : Windstar
- code p0430
- Sigh.... hard 1-2 shift on 2001
- Steam coming from oil dipstick?
- Vacum lines
- Speedometer vs wheel sensor ????
- Help With Lights Dimming and Instarmental Panel
- 2002 Windstar - noise everytime gas pedal is pressed.
- FI Cleaner - To Add Or Not To Add?
- heater hoses
- 99 passenger window motor/regulator
- Multifunction Switch Replacement
- 02 Windstar pings when hot
- Loose thread-inserts in intake manifold.
- Rear Wiper Not Working - Motor or Fuse?
- A/C problems
- cruise control on my ford 2000 windstar stopped working
- 96 Windstar 2 Month Wheel Bearing??
- 96 Windstar ignition switch Rod
- Won't start...maybe fuel pump??
- AC System ... new problem identified!
- Cowling Hold-Down Clips ... part numbers.
- Suspension Clunk!, 98 Windstar, 120k
- Gas spewing into front exhaust manifold pipe
- Windstar Coolant Bypass Hose replacement questions
- windstar/freestar and towing package
- Idle Problems At My Wits End
- odometer speedometer abs light
- Coolant amount in 99 WS 3.8L`
- 99 Windstar ticking
- Power steering pump?
- 02 Windstar-mechanic says transmission is about to blow........
- blend door
- 2003 winstar gl 3.8l coolant leak
- Is the chamber adjustable on a '96
- 99 Windstar Flashing OD Light
- 2003 WStar Battery drain
- 96 Windstar 3.8L Coolant in Throttle Body
- Windstar electrical problem
- Trans cooler... tow lights..... door lock actuator
- Engine noise-'99 3.8
- breather tube missing
- A/C, Transmission, & Misfire
- Front Lower Bumper
- Gear selector hard to shift
- 3.8 #6 misfire
- I did it...2000 water pump.
- 96 Windstar Exhaust Leak
- Doing a Tranny Flush...99 Windstar
- 01 Windstar ABS Light & Brake Light On
- spark plugs
- vacuum leak
- 98 3.8L GL Transmission Leak
- Head Gasket Scare! ... '99 3.8l
- Help changing Water pump ??
- Special tool needed for removing fuel lines?
- '02 How do you remove the rear bumper cover?
- Can I access/replace the fuel pump from inside the van?
- 2001 Ford Windstar - No start, no crank
- 2002 power door lock relay location?
- regarding prevous post: "Wiring for 99 Windstar universal actuator / keyless remote
- 99 Windstar - wiring for universal actuator/remote ket
- Trans Rebuild and Lucas Trans Fix
- 00 windstar, od switch not working
- Power steering rack failure ... 99 3.8l
- 2000 windstar trans trbl
- 1998 Transmission Failed
- Antifreeze smell coming in through vents???
- Transmission Not Shifting Into 4th Gear
- 01 turn the key nothing happens
- 02 winstar misfire cylinder 5
- 03- Front speakers cutting out
- 97 Windstar- Fuel pump/filter/something!?
- Power seat 2002
- cooling help needed 95 windstar
- Ccrm
- Headlight Mounting Plate
- Pimping my 2000 windstar with new front speakers
- is it hard to change a starter
- 1999 Windstar 3.8 P0136 & P0141 - Help?
- Blend Door
- Weird Oil Leak
- 98 3.8 Winstar service eng lite
- 02 Windstar - turn signal problem
- '99 Windstar Air Conditioning
- Electric power/battery problem
- 99 Windstar Coolant Smell w/ heat on
- Driver Side Sliding Door Problem
- 02 windstar lx - programmable key questions
- 1999 windstar
- 01 Ford Windstar knocking sound from enginge compartment
- 03 Windstar chugging on hills
- Windstar with a distributor?
- 1996 windstar lock actuator
- # 1 coil will not fire?
- 98 Windstar - popping when turning
- '02 Windstar chugging on accel - no CEL (yet) - Where to start
- Holes in Oil Dipstick Tube
- IMCR problem code 1538
- 96 and 01 what's interchangable?
- 98 winstar
- lose power steering when drive through puddle
- PCM fault, turns on injector when shouldn't
- New Problem?
- Voltage specs at DPFE on 2002 3.8
- 2000 sel windstar: Front speaker install
- Just Finished Isolator Bolts Have Questions
- EGR Valve Solenoid
- Question About AutoLight plugs APP 765 VS APP105
- power sliding door fix
- Data Link Connector information
- Lower Intake Gaskets
- Setting up the EPC Trany presure Windstar 96
- 95 windstar engine knock
- Van chokes at 4000-4500rpm at idle
- Muffler on sale
- RPM surge at exactly 19mph, 2000 SE
- Power Sliding Doors
- 2000 Windstar SEL won't start
- 2003 SEL steering sways from acceleration
- helpful youtube video re: TRS - neutral safety switch
- 171 174 codes
- help, brake pressure switch wiring
- 2003 windstar high ide when hot
- windstar 2000 repair manual
- OBD does not communicate with safety inspection computer
- 95 WINDSTAR, 3.8 blend door actuator removal
- 96 Windstar CEL Codes p0161 & p0174
- 2000 Water pump
- Cause of P0171 & P0174 Codes 1996 Ford Windstar
- Front Brakes ....Help
- transmission change
- Passenger Side Slider Doesn't Unlock
- air bag light
- Ashtray lamp replacement
- Steering/Heating/Cooling Problem
- 171/174 on 2000 Windstar
- Wheel Bearing '98, how difficult?
- PCV Catch Can Install
- can i put wheel adopters on my 03 windstar?
- Anyone running NGK iridium plugs
- TRS Removal Problems
- 2000 windstar power window issue
- windshield washer doesnt work on 03 windstar
- feeing a sudden "push" when driving '03 windstar
- are there any bodykits available for windstars?
- Ford's Brake Deactivation Switch Kit
- 2000 windstar intake oil leak,should I replace head gaskets while Im at it?
- 18" universal 5 lug fwd rims wont fit '03 windstar
- 1998 3.8l Windstar
- Just made some repairs and now won't start!!
- 2002 Windstar 3.8L crankcase
- 03 Windstar - suggestions on a remote starter
- Castrol LMA Brake Fluid
- 2000 Windstar slow to heat-up
- p1409 iSSUE in 1996 windstar
- 1996 3.8 liter windstar engine removal
- interior light come on when driving
- 02 F150 5.4L V8 Triton Plug Problems
- ABS light
- O/D light bliking, no trans codes from autozone?
- Van will not go above 40 mph without shuddering- help!
- 95 WS abs problems
- Overhead dvd installation
- 1998 Windstar -- Losing Coolant
- Squawk on startup, '02 Windstar
- Fuel Injector Spray End Cap fell into Bore/Spark chamber
- windstar won't start - sometimes
- Lock Jammed, Sliding Door, '02 Windstar
- Freestars??
- 2000 windstar 3.8 engine out of balance
- Well she's dead.
- Windstar stalling/light problems?
- 00 windstar misfires need help!!!
- '03 Windstar Surging Idle at Cold
- 2000 winstar van stalls
- Oil smells like gas
- '96 Wndstar internal coolant leak
- 99 windstar 3.8L Rough idle & accel misfire
- Transmission Fluid Question ..
- '96 Windstar coolant loss & cylinder miss
- oil leak on the passanger side
- erg flow insufficient 2001 ford windstar
- Bad battery/starter/???????
- 98 windstar 3.0 will not keep running
- mifire on #5
- brake shoe de-lamination - 2nd time
- 2000 windstar tranny leak
- Hot soak start rough idle
- Overdrive off light flashing in Park
- MPGuino Fuel Consumption Computer?
- '99 WS; Trans bucking on 4th to 3rd downshift; anyone?
- 1998 3.0L Windstar transmission failure? possible damage?
- doing the tranny flush on a different make
- automatic tranny fluid
- IMRC stuck open 1998 3.8
- Coolant temperature issue
- Fuel pressure leak down rate: acceptable or not
- Engine Calibration
- Cold engine knock
- Does my Windstar have 2 PCV valves?
- 03 windstar fuel problem
- AX$S Schemas?
- Trany oil type
- Radiator fan assembly removal procedure
- squeel when steering
- Help me find this ground cable 95 3.8L
- 2000 windstar need door weatherstripping
- Fuel pressure lower after new fuel pump installed
- IAC Questions: Voltage and Knob
- Lubing Caliper Sliders 1999 Windstar
- 96 Windstar Fan Module change
- 2000 Windstar 171/174 then more codes/issues
- Design Flaw in Transmission??
- 2002 Windstar Spark plug replacement
- 2002 Windstar. Where is pcm? Anyone do remote starter?
- Coolant "Y" Pipe to the Heater
- Alternator and A/C clutch
- Cam Synchro/Sensor: Clicking, rattling, metal tapping or clanking
- Misfire on cylinder 1
- Another Intermittent ABS Light
- 18" Mustang Wheels on my Windstar
- '01 PATS key in steering column
- Brake Deactivation Switch Replacement Procedure
- 98 Windstar, drivetrain vibration solved.
- Stablizer Bar Issues Windstar 1999 SEL
- Help With Front Brake Job 1999 Windstar SEL
- Missing Brake Fluid
- coolant leak 95 windstar
- abs and traction control
- 1998 Windstar transmission
- No heat - 97 windstar 3.0L
- 01 Complete rear brake job, now brake warning light is on.
- Blend door removal?
- Wagner Thermoquiet Ceramics on Front '99 SEL
- Engine won't crank, why?
- Does your Windstar do this after fans turn off?
- 96 windstar 3.8 lights flickering and stalling at idle
- 97 windstar 3.0 IMRC stuck open
- 2000 Windstar died, thank you Ford.
- Valve cover replacement
- 2001 Windstar Won't Start
- Intermittent ABS & T/C warning light Indication
- Engine Lt. on
- Engines Stalls Shortly After Starting
- new engine & transmission install
- Light on Bumper Cover Windstar 2000 SEL
- Tsb 03-16-01 (p0171, P0174)
- alternator
