View Full Version : Windstar
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23
  1. Burning too much gas
  2. 99 radio and heat concerns
  3. '00 Windstar Brake Squeal
  4. 96 windstar door unlock problem
  5. Fuse box diagram
  6. 2000 Windstar 3.8 rough idle mystery
  7. 2000 windstar tranny trashed
  8. 2004 freestar-crackling noise on acceleration
  9. third row DOES fit
  10. 99 Windstar Brake Lights...
  11. coolant line connected to the lower intake manifold
  12. Front Wheel Wobble
  13. A few 96 windstar questions
  14. Vehicle Speed Sensor (VSS)
  15. 98 trans issue
  16. ABS Light
  17. Where's the Lower Intake Manifold?
  18. 2001 windstar cut off while driving
  19. Steering Column Lock stuck on !
  20. 96 Windstar rough idle after warm up
  21. Anti Freeze Rail underneath the upper intake manifold
  22. dtc U2500
  23. Windstar Pet Peeves
  24. 99 WINDSTAR CODE 171 & 174 LEAN FIX
  25. 96 windstar misfire no 5 cylinder
  26. Damn it
  27. 1995 Oil Pump Installation?
  28. SRS Airbag questions
  29. 2000 SEL Check Engine but no codes
  30. Anti-Freeze Leak
  31. windstar door wont lock
  32. 95 windstar radio trouble
  33. Interior lights stay on
  34. Suspension Help
  35. high crankcase pressure
  36. ‘96 Windstar Check Engine Light
  37. Speedometer limit Windstar 2003
  38. ABS rear wheel speed sensors- bad??
  39. No electrical power...
  40. Code 300 Windstar97.3.0
  41. 1999 Ford Windstar No Rear Heat
  42. 96 windstar (wont start)
  43. Heater problem
  44. Windstar versus Caravan Tranny problems
  45. 1996 Windy Knocking
  46. Damn rear heat/air
  47. 1996 3.8 intake manifold runner control stuck open
  48. 98 Winstar Shifting
  49. 96 Windstar electrical
  50. Steering noise
  51. What is the cheapest most funtional obd2
  52. TSB 3-16-1 or not?
  53. is mercon ok for powerstearing fluid
  54. 1995 With shift problem when cold.
  55. 2000 Windstar - No Heat in Roof Vents
  56. OBD II Code Reading Error
  57. 98 windstar weird transmission problem??
  58. Best Year Of Windstar?
  59. intermittent engine idle
  60. Does your engine require difrent oil as it gets older
  61. Coolent, Oil, Power stering fluid recomendations
  62. valve cover replacement
  63. PCV Oil Seperator
  64. Question ? (o/d off light) on all the time
  65. To possible fix ABS problem (Activation before stopping)
  66. Fixed charging problem
  67. Windstar transmission-RPM sensor
  68. CEL No power to OBD
  69. 96 GL Vacuum Leak
  70. 98 WS Rear Hatch Door Ajar
  71. Can you swap a ford 3.8 with something reliable
  72. 2001 Windstar Oil In Throttle Body
  73. My 96 Windstar is Weird! Please Help!
  74. 98' ford windstar
  75. flashing o/d off light-1999 WS
  76. 2000 Windstar Automatic sliding doors keeps opening/closing
  77. Noise in steering
  78. Busted Oil Pump?
  79. 2001 Keyless entry Code location??
  80. the radio and keyless entry fuse blows again
  81. 98 Windstar- Cruise control stopped working
  82. AIR VENTS & FRONT END NOISE
  83. WINDSTAR CODE 171&174 FIX
  84. 1998 Windstar Interior Light Control
  85. All about the ford alternater (pretty good)
  86. 2004 Sales
  87. Swapping bench for captain's chairs in the second row...
  88. Preventing head gasket failer
  89. Block Heater Plug
  90. replacing wiper,washer, signal switch (stalk)
  91. alternator not charging but good ?
  92. LATCH safety system
  93. Rear HVAC
  94. Tire pressure light on on console
  95. 1999 Windstar - manifold
  96. Leak or Blown? - Coolant of cat
  97. Transmission problem 97
  98. 00 SEL Air Bag Light Blinking
  99. Greasing Type for "Sealed" Joints
  100. 00 SEL Sliding door switch
  101. blowing fuel pump fuse Ford Windstar
  102. no heat
  103. 99 windstar anti-theft
  104. 96 windstar No heat from vents
  105. right signal works on/off
  106. front end noise
  107. gas guage
  108. reviving up
  109. Tranny Leak?
  110. Need 97Windstar Fuse Map
  111. transmission
  112. Engine replacement
  113. Windstar bucks, need help identifying problem
  114. Heater continues after key out of ignition
  115. timing cover gasket questions
  116. Blown Head gasket
  117. 2000 Windstar Tie Rod
  118. cartrackers.com windstar forum???
  119. 95 Ford Windstar Computer Question
  120. In need of help with 99 Windstar
  121. A/C Clutch Clunking??
  122. engine noise
  123. gasket installation
  124. All new steering parts, steering stiff
  125. 96 Windstar Tachometer Wire
  126. Digital Compass seems to be off by 90 degrees
  127. 3.8L Anyone else have bad lifter guides?
  128. info for anyone wanting to rebuild their ford 3.8
  129. engine light on Ford Windstar 2000
  130. 1996 Windstar Gl From Hell
  131. Codes 171 & 174 TSB # 03-16-1 update
  132. Lock-Down
  133. Still Running Rough
  134. Power Steering Fluid leaking
  135. Remove Radio panel 98 Windstar
  136. check engine light 96 windstar
  137. 2000 Windstar-side power doors retracting
  138. 98 Windstar Heat Problems
  139. a/c switch
  140. Front Bumper Assembly
  141. 2000 WStar SEL outdoor temp sensor
  142. 98 Limited: air suspension bag leak
  143. 1996 Ford Windstar 3.8L
  144. Bad Idle on '96 3.8L
  145. OBD II Code P1517
  146. code 1350 or1450 translate please
  147. Check engine
  148. 99 windstar..won't start in cold weather
  149. Fuel Filter
  150. Newbie with tranny problems on 1999 WS
  151. I wanna buy a WS,BUT....
  152. Traction control clicking and startup noise
  153. Steering Noise Greasing
  154. Lower Intake Manifold Gasket Leak
  155. lip kits or body kits???
  156. weird smell from exhaust
  157. fuel pressure loss when car is off
  158. head gasket project
  159. Replacement Fluid Caps??
  160. Buying a 98 Windstar - What to watch for?
  161. CHarging Problems
  162. 1995 EGR on windstar
  163. Problem with subwoofer on 98 Windstar
  164. '99 LX 3.8L Bad Engine Noise UPDATE!!
  165. Check Engine light code P1131 & P0135
  166. 2001 WIndatar idle surge
  167. 1995 Acceleration problem
  168. '98 Windstar Serpentine Belt Question
  169. Brake Lights Stay On
  170. wheels sticking in cold weather
  171. up/down engine idle, Battery light on/off
  172. Broken blend door
  173. power steering out
  174. 2000 Windstar Knock ??
  175. 1999 transmission
  176. Check Engine Light
  177. ABS after rotor replacement - 95 windstar
  178. Brake Light Problem 97 Windstar
  179. 99 winstar engine ping
  180. 2003 windstar rear heat not working
  181. Mercon V or Mercon??? 96 Winstar
  182. 2000 Ford Windstar
  183. bottom piece of upper intake manifold
  184. AX4S Trans Swap - 1997 WindStar
  185. 99 ford windstar
  186. bet you cant guess what wrong...electrical
  187. 95 tranny disengaging after stop
  188. bank 1&2 too lean
  189. Killing the Door Chime?
  190. Dome Light Problem
  191. Where are the ignition switch wires???
  192. CV Joint Noise
  193. 95 Windstar Temp Gage Fluctuating
  194. 1999 Windstar RSS (reverse sensor system) help needed
  195. Antenna
  196. RTV for Inner Plastic Manifold Plenum
  197. ford windstar for sale
  198. '99 LX 3.8L Bad Engine Noise Identified!
  199. Cruise control problem identified!
  200. 2 New Issues
  201. Dome light stays on
  202. chilton windstar manual
  203. zero pressure at compression #5?
  204. Front Engine Cover Leak 97 3.8L
  205. Check Engine
  206. key replacement
  207. driver side door lock messed up
  208. Brake rotor removal
  209. Passenger side rear door won't shut.
  210. Windstar seat swapping
  211. chirping noise when cold
  212. replacing burnt out bulbs behind cluster
  213. sliding door panel removal
  214. '99 LX 3.8 Bad Engine noise
  215. o2 senser location bank one
  216. 1998 windstar heater leaking
  217. Parking Brake Cable Help
  218. fuel filter
  219. fuel filter
  220. speedometer/abs
  221. Valve spring
  222. Tranmission cooler install?
  223. HELP! Battery light...interior lights dim
  224. resetting the computer on 2001 LX
  225. Check Engine Light
  226. 1995 windstar transmission pull
  227. '98 oil pan and trans gasket
  228. Obd Port
  229. 2000 Windstar OBD codes 171, 181
  230. question about a idiot light
  231. throttlebody
  232. Fuel Economy/Engine Perameters??
  233. 2001 Windstar sport
  234. 98 Windstar wipers front & rear wiers acting up
  235. Transmission, Power Steering and Cruise Control
  236. receiver of the remote key
  237. Starting While In Park
  238. Door chime and Rear Heat/AC
  239. 2000 Windstar Dead Battery
  240. As long as I'm pulling the engine. . . .
  241. need to warm up 98 Windstar; is this normal?
  242. side door wont unlock
  243. Power steering pressure switch
  244. inverter
  245. 1995 3.8 Windstar starter
  246. '99 Windstar Monitors "not ready"
  247. power steering hose leak
  248. No Airflow From Dash Vents???
  249. driver side window motor
  250. Isolator bolts
