View Full Version : Windstar
- 96 Windstar GL won't start
- Dashlights
- disabling drl
- Passanger side power door
- relly puzzled
- Power Drivers Seat Install
- 1999 ws miss in bank one
- 96 Windstar hard to start when hot
- Rough Idle after repair work done
- Ford Windstar 1998 Brakes
- Windstar 2000 SEL lock button issue.
- traction control and abs light
- 95 Windstar LX, Shifter PROBLEMS
- Cranking but no start
- head gasket position
- Windstar 2000 SEL. No front hot air.
- Reset obd to check repair 2001 windstar
- 2003 Windstar front rotor removal
- 98 windstar...all kinds of elec probs
- HELP!! Brakes!!
- Pinging/knocking when accelerating
- ford windstar abs light and traction control light
- Engine Running Cool
- Any suggestions when replacing a PS rack on an '01?
- replacing air bags
- sticky lifter
- Need help/advice with Windstar 2000 rear brake lights
- Fan Temp Sensor 95 3.8L
- 95 3.8L vacuum hose issue
- Windstar codes
- 99 Windstar Instrument Panel Whacks Out!!
- Synthetic
- electric wiring diagram Ford Windstar 2001
- 98 winstar camshaft position sensor
- 1998 3.8L Starts but stalls
- problem with batteriwarning light
- Please Help 2000 LX 3.8 intermittant stall and jerk???
- 2002 Winstar radiator draincock
- No 3rd or 4th on my 98 Windstar
- 95 windstar injector problem
- 95 Winstar tail lights not working
- Do Non-Dealers Get TSBs & does driving 2000 Windstar "too lean" = long-term damage?
- How to bleed off fuel pressure?
- 1999 Windstar No Heat Blend door?
- Codes 1537 and 1538...
- 1999 WS owner, Poor Idle, acts in cycles
- ABS Codes - Set Points
- 2000 WS Stalling w/Rainy Weather
- 2000 Windstar Power Steering
- 1995 Windstar 3.8 Computer Problem?? Need Help
- Heater Core Problems, Please, Please Help
- reprogramming remote on "98 Windstar
- 96 blows cold air when stopped
- New driver
- Power Steering Flush
- Experience installing overhead LCD monitor?
- oil in coolant 1998 - head gasket?
- DPFE sensor?
- Rough Idle
- Gas Gauge
- Lights Won't Go Out
- 97 Windstar, No Heat, Its The Heater Core
- 97 Windstar No Heat, Where Is Thermostat
- How many miles on your original tranny?
- Ford Windstar 99 clicking noise
- same problem 99 wind as wiredcpa
- windstar 200 high gas consumption
- 2000 Windstar Stalling
- Cabin Air Filter Cover
- 99 Windstar ABS (I've got codes)
- Rod bearings
- Theft display light blinking
- CD Player Installation
- Windstar Running Great, Thanks to All
- engine light on - code P1518
- 99 Windstar Suddenly No Break
- 2000 running lean
- testing abs sensor
- 01 Temp Slider Control Causes Clicking
- codes 0171 and 0174
- 2000 windstar growling
- Windstar 95 trasmission jerk
- 99 windstar a/c, cruise, and now fan wont shut off
- 2001 windstar light problem
- windstar hesitation
- 1998 and 1999 Windstar sheared off lug nut studs
- looking for parts
- what is the rear electronic module on windstar 2000 located?
- power seat not working on 2001 windstar
- 2001 windstar keypad code
- fuse diagram
- Power Steering Return Hose Cooler
- Key in Ignition Chime!!!!
- Cold start problem
- Washer Fluid Spray
- ford windstar check engine light
- 2000 Windstar makes LOUD noise when backing up
- Replace Rear Wheel Stud?
- windstar 96 extensive external coolant leak
- help
- P401/p402
- Air not coming out of vents, only defrost vent
- ABS/Brake light comes on when I go over speed bumps
- Windstar 2000 check engine
- Best way to flush the coolant system?
- How to 95 windstar drivers window motor and regulator
- Radiator Coolant Change
- 97 Winstar speed sensor location
- Different Plugs
- Where is Oil Filter
- Brake upgrades for '03 model
- 2000 Windstar stalling/idle too low
- Cassette player
- Tie Rod Replacement
- it whines and stalls
- Spedometer goes to zero while driving
- 2000 Windstar Bleeding Brakes
- On Another Note, Check Engine Light On All The Time
- I Cant See!!! No Heat Out Front Defrosters
- '98 Windstar - Low air flow from vents, etc.
- 99 Windstar Guages freaking out. Electrical?
- Gas Smell
- Rattle from Right Rear on 99 Windstar
- keyless entry stoped working
- clicking behind raido heat not working
- White smoke from exhaust - 96
- 2000 Windstar Door Lock Actuator
- 1996 Windstar IMRC code 1537
- Plug Gap
- 01 drivers power windows relay/module??
- 2003 Windstar makes whining noise
- 99 windstar wont stay running?
- sensor, sinchro, and now head gasket!
- 98 windstar door adjared lights & beeps
- DPFE vs. EGR cleaning?
- P402
- Ticketa ticketa tick
- 2000 windstar hesitant on acceleration
- Tell me about 'anti-rattle clips' for front brakes
- Need Help in Another Forum
- Whining noise on a 1998 Windstar 3.8L
- 99 power side doors
- Roof rack wind resistance?
- 1995 Blower Motor Removal
- staling and battery light
- Windstar Options & Keyless Entry
- Getting Codes Read for Free
- Out of gear/Transmission until shutoff and then, restart the engine
- windstar 3.8 cooling sys
- Help 99 Windstar Electrical
- oxygen sensor code P0136
- Nisson sentra speedometer cable
- Resetting the change oil message on 99' SEL
- 2000 radio losing reception
- Windstar 96 - High NOx Emissions
- Idle Surge
- fuse panel cover
- Yet another question, A/C smell.
- 2k Winnie - Beeping Noise From Engine.
- heat from defrost only (success) 98 3.8l
- Wobble
- Air Conditioning..Check Engine
- Replacigng pwr windoe motor on a windstar
- keypad code?
- Cycling Air Conditioning
- Trouble With Passenger Sliding Door
- gear slips
- power windows
- ENGINE FIRE caused by speed control 96WS
- "clunks" when brakes applied first time after going in reverse
- 2000 Windstar Right Front Rattle
- Electrical Problem
- Check Engine light but no signes of problems
- significant loss or power
- Can a IAC valve this?
- Beeping noise???
- 99 windstar lx mystery cable/switch
- Blowing fule pump fuses
- Love my Windstar but...
- brakes pusate every time
- Windstar 96 wreckw
- air conditioning
- Hi guys! How to take the head off
- Bought my 96 Ford Windstar To find out- A Thousand of Problems! MUST READ MY STORY
- eectric window drivers side
- Need HELP Again. The Outside Turn signal is on in the Mirror w/lights on
- 2000 3.8 cylinder 2 misfire
- IMRC codes P1538 and P1537
- Windstar ABS and Brake light always on!
- rpm gets stuck
- rain water leaking into passenger floor
- using oil
- '99 Windstar trans
- 98 WStar-Intense Vibration at 60rpm
- no brakes
- 98 windstar remote door locks
- 98 windstar trac light & alb light
- How to disable 75Mph. Speed alarm on 99 Windstar
- Transmission problems
- Liftgate power lock
- 1996 Drivers side rear vent window problem
- where is the cam position sensor on a 1998 windstar 3.8?
- Desperately need your help!!!
- misfire
- Fuse box diagrams
- 2000 windstar stalls when put AC on high
- Add-On Transmission Cooler?
- Transmission shifting with A/C on?
- 2000 whinning while steering
- Knock or Pinging Noise
- Non Starts and Electrical Spikes
- Remote Keyless Entry
- lift door sensor problem
- Fuel Pump gone Bad?
- 1998 Windstar Sluggish Starting
- driver door speaker noise on 2002 Windstar
- sherm42, where are you?
- overheating
- I put the wrong power stering fluid in my 98
- Speedo Never Worked
- updated maint to do 99 w/109k
- '96 Serpentine Belt Question.
- Water pump's in - something else now!
- need help with fuel economy
- anti theft: how to disable?
- 98 Windstar cruise, horn, A/B problem
- removing door lock actuator in 2000 windstar
- How to remove the powersteering pump
- How to install plugs/plug wires
- tRANNY COOLER
- 2001 windstar transmission
- outside temp gauge
- 95 Windstar water pump-what a nightmare!!
- Clicking at Shifting
- 2000 windstar-cv shaft trans seal
- Problem With Vents On 94 Blazer
- Transmission whining when coasting?
- 96 Windstar problem...
- Intake Accuators Windstar
- 1995 windstar engine surge
- Windstart AC woe's, need help.
- Gettin ready for cold
- 99 rapid clicking relay
- can't unlock tailgate on 96 windstar
- Lost all gears while driving
- Trailer harness kit includes mysterious plug
- Replacing A/C Low Pressure Switch?
- .....95 Windstar STARTER problems.....
- '00 Limited -rapid battery drain while driving
