View Full Version : Windstar
- 2001 vs 2003 wheel dia.?
- Rough Idle on 2000 Windstar
- abs and trac light
- front Brake Rotors
- How to replace the power stering pump?
- P0171/174
- 2000 Windstar electrical problem
- A/C problem
- Front cover removal tips ?
- Green brake fluid?
- 2000 Windstar belt diagram
- 2001 Windstar Oil Usage
- '95 Engine Code P1407
- 2000 Windstar SE- Wiper Problem!
- How to Diagnose Tailgate Power Lock (and funny story)
- 1999 windstar power windows
- Freestar seats.... SUCK
- How many clunks when you shift?
- 1999 Windstar transmission
- LH valve cover replacement
- Wswind-Air-Comp-fixed
- Installing a 98 Windstar Hitch
- 98 Transmision problem code 1744
- Does intake maifold really need replaced?
- 2002, Shift lever doesn't work at all
- cel po171/174 windstar
- DIY 2000 Valve Cover TSB Modification
- Brakes are "clicking".
- 2000 Windstar driver window doesnt work.
- 95 jerked foward and now won't go
- 95 Windstar jerked and lurched forward, now won't go.
- cleaning lower intake mainfold ??
- When Defrost on, engine RPMS jumps
- 95 Windstar Tranny Problem. Help!!!!!!
- synchronizer tool
- 97 Windstar A/c Won't Work
- Fixing po171/174? BEWARE!!!!!
- P0401 DPFE Code
- error code Windstar air bags
- back to the project 96 3.8l rebuild
- CCRM and Radiator Fans
- 98 Windstar no horn, no cruise
- Internal or Electrical??
- clicking noise from right front tire(96 windstar)
- 96 Windstar lean code bank 1 and bank 2. Please Help
- ABS Activates for no reason when breaking
- disconnect ABS?
- 96 Windstar 3.8 Ltr. eng. codes 1537/1538
- 2000 Windstar 3.8 Ltr. code P0401
- input turbine speed
- 96 3.8 Windstar A/C problem
- Starting Problems 01 Windstar
- I'm tempted to eliminate the isolator bolts.
- Intermittent P0153 Code Question
- Removal of side door panel.
- Computer problem???
- 99 Transmission problem
- ABS dash light comes on then off
- windstar-battery
- Work Truck woes 99 Windstar LX
- Windstar died suddenly on the road
- Windstar ~ brake or tranny issue
- tranmission troubles
- Rough Running 2002 Windstar
- Replacing my Alternator (99) a few questions
- What are these engine codes?
- Dorman Kit for P0171 P0174 TSB Valve Cover and Isolator Bolts
- Help with a '96 with a 3.8L
- IMRC actuator issue
- Technical Service Bulletins
- 96 Windstar transaxle issues... HELP???
- front abs sensor stuck 95 3.8 178K miles
- 2001 Windstar ABS Codes
- windstar 96 engine shut off
- `01 Windstar 200,000 miles, Woo Hoo!!
- Stalling out
- what is this light on dash board??
- 1998 Ford WIndstar starting problem
- 96' windstar P0151,P1151 and P0304
- 2001 blowing fan fuse
- Suggestions changing O2's appreciated
- 2001 Windstar Fuel filter replacement
- Master Cylinder or just leaky pipes!
- Recalls
- need help please!!! Tranny/radiator
- speaker harness problems
- exciter ring !!!
- '96 Windstar issues (thinking of buying) - tranny, windows, and AC
- Strange rattle sound from rear of engine or tranny
- How do you replace power window on Windstar
- 98 windstar cyl. head.
- Any other year interchangeable with 99 Windstar Tranny?
- Chirp, chirp, stutter & die
- shoot me, just flipping shoot me! (96 3.8l)
- '95 Transmission Neutral Safety Switch
- Brakes or ?
- 2001 slow start sometimes/cranks too much
- 00' 3.8L Hissing (Vacuum) Noise when braking...
- 96 windstar problem
- Rear Heat and A/C fan control not working
- External Temperature Sensor Location?
- How hot can the frame be heated on a 98?
- engine codes
- '99 windstar o/d flashing and tranny not shifting right.
- 98 Winstar power seat rail alignment
- vibration during breaking
- '96 Windstar trans leak
- Anti-Rattle Clips
- Concern about '96 cig lighter wiring...
- Coolant Capacity
- Not Starting
- Radio-Battery Drain
- 98 Windstar Engine Problems...Please Help
- 96 Windstar door chime
- Changing Air Compressor?
- Beginners questions
- po171/174 save $
- Brake Drum Removal
- 2000 windstart P0171 & P0174
- Power lock module
- key light
- 97 Windstar, A/c Questions, Also Clock Settings
- P0302, P0304, P0174
- tranny vibrations/subtle jerks while on a complete stop...
- 97 ford windstal gl electrical issues
- 02 Windstar Not starting
- Noise coming from A/C clutch! Not Tensioner Pulley
- P0420 - Best method to fix this
- abs burnt connector
- ABS and TRAC OFF Lights
- code p1518
- Windstar pressure in fuel vent & tank
- 95 windstar tdc
- 95 Fuel pressure 3.8L
- fuel pump replaced(warranty)dealer 2001 still noisy?
- Steering concern....
- 2001 Wndstar altenator
- A tad confused but need some feedback..thxs
- Cleaning Your Carpet … Hardcore!
- 01 Overdrive Prblem
- RPMs and fan???
- 98 Windstar Transmission cooler
- Door open / interior light on? Here's a fix!
- '99 windstar tranny problem
- Windstar Headlights Important Read
- Jerking 99 Windstar
- Engine Coolant
- Lower Intake Manifold Gasket, 1996 3.8L
- Ventilation Problem
- FordCds
- 99 windstar theft light
- 98 windstar headlights
- SALE; 15x7 5 spoke silver wheels w/225-60x15 in KY
- 2001 windstart p0171 & p0174 wits end
- Power Locks - Rear Works - Front Doesn't
- Error codes P1537,P1538, and P0460
- 00 Windstar sel stuck in park
- '99 Windstar Parking Brake Cable
- 99 windstar
- spark plugs
- 2000 Windstar Steering Noise
- 2003 Directional Mirrors
- 99 windstar transponder key
- 2000 Windstar transmission TSB 99-16 sticker
- 2000 SEL odd noise at Idle
- 99 windstar oil filter location
- MOBIL1 syn ATF now = MerconV ...???
- 2002 Windstar with P0401
- danger engine damge may occur 3.8
- 98 windstar poor idle when warm
- '98 Windstar
- 98 Windstar won't start
- ABS Light
- RPMs 1996 Windstar GL 3.8L
- Tensioner pulley
- Front rotors stuck on, 2001 LX..
- EVAP problem
- Pressure test Cooling System
- Bad Fuel - Best method to clean and resolve
- 98 windstar 3.8 cam position sensor
- reset tire dash light
- Drip Drip Drip
- #1 and 2 banks lean??
- 2000 Keyless remote question
- 2000 Windstar fixed and fixed again?
- 98 windstar power window motor replacement
- fuel in oil
- Po171 Po174
- Replacement rear sliding door-1999 Winstar
- 2000 Windstar SEL...need ideas (IAC?)
- 2001 windstar tranny cooler??
- 2001 ford windstar lx abs light
- Replacing Windstar door switch- how to?
- Brake Problem please help
- 2000 3.8L Power Steering Pump
- strange noise 98 windstar...please HELP
- IMRC actuator linkage needed
- '97 Windstar transmission problems
- head gasket gone repair gone wrong??
- Rear drum brakes 2001
- Ticking under manifold
- Anti theft alarm trips for no reason
- 2001 windstar stalls when a/c is on and in drive position.
- Noise when making turn
- DPFE Sensor
- DPFE Sensor
- 2000 Windstar tranny problems
- 95 Windstar,brakes dragging
- 98 windstar window lift motor
- Passenger side airbag disable
- Changing Fuses on Ford Windstar
- 200 Ford Windstar - little light
- 2002 Windstar drivers window switch
- 95 Windstar radiator fan won't stop running
- '01 Windstar 171 & 174 Codes
- 98 windstar lights and door ajar lights stay on help with this piece
- Windstar 2001 fuel pump
- Engine hesitation under load
- Power seat not working
- 97 Windstar sometimes rough idle cold
- 2002 Windstar 12V accessory fuse?
- 96 with vac leak behind heater controls
- AX4S / AXODE Trouble...
- Cabin Filter for 2003 Windstar
- 96 windtar engine
- imrc replacement
- 95 Windstar - Changing Spark Plugs
- Need information around TSB 03-16-1
- lalalala
- 98 Ford Windstar (GL) Overdrive Problems
- 2000 Windstar Engine Light
- Unable to remove VCP from floor console
- Scan Tool
- 1999 hitch in steering
- 1999 po171 and po174
- Windstar tranny problem
- head gasket
- Rear Whining Noise 98 Windstar
- 00 Windstar Tranny issue
- Ford Windstar 2000 not auto shifting to higher gears/speeds
- Code 401
- Pictures of decarb process
- 1995 Windstar 3.8 air in coolent system
- 2000 Windstar Issues
- Sputters, shudders or stalls sometimes
- Brake lights
- 01 Windstar passenger side mirror
- 99 windstar won't start without keyless
