View Full Version : Windstar
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23
  1. 2001 windstar Water leak under the intake
  2. Oxygen Sensor Diagnostics and Specific complaint.
  3. Master cylinder resevoir filler cap
  4. are areostar and windstar engines the same?
  5. 2000 Windstar Stalling
  6. Hello fellow Ford owners
  7. 2000 winstar no high idle does not wantto run
  8. 99 windstar inner tie rod replacement
  9. 98 Winny, traction control light flashes??
  10. ABS 95 Windstar
  11. Irritating Turn signal issue on my 2001 Windstar
  12. Help desperately needed on a 95 WS Tranny problem.
  13. Sea foam.............
  14. 96 windstar transmission
  15. Alarm Problems
  16. 2000 Windstar with no speedometer /odometer and problem codes
  17. Fuel Error
  18. 95 Transmission clicking noise?
  19. 96 Windstar won't quit running
  20. Intermittent ABS Light
  21. loud squealing/screeching noise 98 3.8L
  22. Power Door Lock Actuators
  23. Short grinding noise after startup
  24. Cruise control not working & Airbag 32 light
  25. 1999 windstar...should i buy?
  26. 95 windstar tranny
  27. 99 Windstar both pwr window switches don't work...
  28. Inner tierod ends 96 Windstar
  29. Subframe Bushing weld
  30. Airbag Light and Fuel Gauge
  31. '95 Windstar back window
  32. Accelerator Pedal Vibration / Buzz
  33. 96 windstar (front brakes)
  34. 99 Transmission work
  35. cam synchronizer
  36. 2002 Windstar radiator drain plug location
  37. 96 Windstar Loud Engine Knocking
  38. which repair manual is better?
  39. clearing codes for 00' windstar 3.8..mass air and egr
  40. O2 sensors in 3.0 litre engine
  41. P1405
  42. broke down...not literally
  43. rotor removal: need help
  44. 96 Windstar CO code
  45. Fuel Injection system cleaning
  46. 2002 windstar lx
  47. '01-ABS & Brake dash lights
  48. 96 Windstar stalling problem
  49. Windstar alignment
  50. IMRC valve needed
  51. 99 Windstar
  52. fuel filter surprise....
  53. P0172 and P0175 codes
  54. 99 windstar dash lights
  55. Which Plugs and wires to use for 2000 3.8l
  56. 98 check engine light on
  57. Idling issues and dying on Windstar
  58. Outside Tempature Reading
  59. 99 Windstar. Where does the plug go?
  60. Transmission Problem.
  61. Straining/Moaning noise between 4500-5500 rpm.
  62. anyone who has replaced there 98 synchro
  63. Confused about spark plugs for '99 3.8L
  64. $168 for new Key w/chip anyway to disable alarm
  65. Codes P1537 & P0172
  66. ABS - Sensor
  67. Strange Brake Pedal Noise
  68. 98 GL 3.8 - Brake light on dash appears for a few seconds then disappears
  69. Cabin Blower Fan Speed Dropping Resistor
  70. 02 Windstar power window/lock switch
  71. P0401/P0402 Codes - Help needed
  72. 1998 Windstar Cigarette Lighter / Power Outlets
  73. 98 Windstar IMRC ( manifold runner) $$$$$$
  74. Questions on Isolator Bolt Fix
  75. Windstar Codes?
  76. 99 Windstar, 02 sensor
  77. 01 Windstar Sport Driver's Power Seat
  78. Spark plug removal ruin heads?
  79. Poor fuel economy
  80. 2000 Windstar, burning smell, grinding!
  81. 2000 Ford Windstar 3.8L Serpetine Belt Routing
  82. Door locks don’t work??--I fixed mine!
  83. 2000 Ford Windstar Intermitent no start/theft flashing
  84. 95 Ford Windstar aux a/c blows warm air
  85. 1996 Windstar code P1151
  86. 99 Windstar is kaput, anyone seen this before?
  87. upsetinmo
  88. how to clean ABS sensors...?
  89. 97 Windstar... slew of problems
  90. Obtained fault codes P1512 and P1538
  91. Oil deposits in the thorttle body
  92. Coil Spring breaks, Free Replacement!
  93. Stalled on highway
  94. Windstar Gauges
  95. Front A/C warm Back A/C cold
  96. '97 Windstar GL ABS actuates rear brakes when stopping
  97. Please help
  98. 02 Windstar Autolock
  99. Engine/Tranny Vibration
  100. 2001 Windstar stalling!!
  101. car elec. cuts out
  102. 96 windstar electrical problem
  103. '99 Windstar Injectors
  104. amsoil?
  105. 2000 Windstar O2 sensor
  106. Brake light on and fuel pedal out of order after HG changed
  107. Front end clunking noise with ABS light on
  108. Driver window won't go up
  109. thoughts??
  110. Buying 00 windstar what to look for
  111. easy transmission fluid change
  112. Super hot air blowing from rear lower vents with ac on
  113. Vibration from Fan
  114. 99 windstar
  115. Coolant Drain for the '99 Windstar
  116. Air Filter and A/C
  117. 95 Windstar transmission slips from 3-2
  118. '99 windstar sel (3.8L) radiator cap?
  119. Drop in Fuel Mileage
  120. Hard Shift 1-2 in 99 Windstar
  121. Mercon V
  122. 1998 Windstar Dash Lights, Parking Lights, passenger window not Working
  123. 95 windstar 3.8 p0302 code
  124. 2000 Windstar won't start
  125. Alternator cable melted - how to replace
  126. 98 Battery/Alternator Issue?
  127. Note on ABS or wheel speed sensors
  128. Motor Mounts and Transmission mounts
  129. failed emission test/ p171 &174
  130. water leaking from under the engine area
  131. Slight squeeking noise from left front end 2000 windstar
  132. A/C Need recharging???
  133. '99 Windstar Brake Squeak
  134. 2003 P1406 code
  135. Spark Plugs
  136. 02 Windstar LX
  137. mysterious electrical outlet
  138. Belt Questions
  139. Windstar 2001 spare tire
  140. hidden "color-code"?
  141. '99 Windstar Front End Noise
  142. 2000 Windstar runs rough/Check Engine
  143. can additive make trans fluid Mercon V?
  144. 1999 windstar - tranny leaking?? help(94,000miles)
  145. '96 problem Code P1151
  146. code 0185 & airbag light on, dashboard vents
  147. AC Parts ///anyone parting out a 95-97?
  148. Windstar Code P0460
  149. Code 1156 ?
  150. windstar AC Problem
  151. Another Transmission Cooler Post
  152. brake emergency
  153. Floor Covers for Seat Mounting Openings
  154. What is this part???
  155. What is this part???
  156. How Bad Is the Windstar Tranny?
  157. ABS and TRAC OFF problems
  158. Leaking After 171 Fix
  159. SES light a No Show!
  160. High idle
  161. Transmission Filter
  162. Shifting to park drops RPMs
  163. 2001 Windstar Abs And Brake Light Goes On
  164. Dumb Question Prior to 0171/0174 Fix
  165. Strange Problems with ABS in 97 Windstar
  166. 98 windstar towing capacity
  167. abs diagnostic plug??
  168. Overfill you Tranny?
  169. Slipping between gears-2 trannies!
  170. 95 windstar air springs
  171. 3.8L 1999 Windstar Purchase Checklist
  172. 1999 Ford Windstar SEL Leaky PCV Tube
  173. 97 windstar tranny question
  174. How easy was the P0171/P0174 fix for you?
  175. 171/174 code fix issues
  176. Fixed Stuck Fuel Gauge
  177. 96 Windstar, can't put on new drum!
  178. P1401
  179. grinding sound then ABS light
  180. Instrument Cluster problem
  181. Rear Power Door Won't Close
  182. Coolant pipes
  183. 99 steering question
  184. A/C Hot and Cold
  185. Power Steering leak....help!
  186. Flashing CEL P1538 AND P1513
  187. 1999 Windstar Auto Sliding Door
  188. ABS light on and off with a "clunk"
  189. Opinions Needed: P0171/P0174 - Ebay Kits
  190. Gear Shifter Rattling
  191. Right rear turn signal
  192. 2001 Ford Windstar giving code 0183
  193. Tire Warning Indicator Light
  194. 2001 Windstar - Rough start, sometimes will not start at all
  195. ? Constant wobble sound, shake at high speed
  196. 95 Windstar a/c electrical
  197. Replacement brake pressure switch
  198. 2000 Windstar Won't Start, Gauges Flip, Lights Flash
  199. Cel P0156
  200. lamp out indicator--1999
  201. 98 Windstar Hard Brake Pedal
  202. Where is
  203. Oil in the intake and catch can
  204. like fingers on a blackboard
  205. 200 Windstar:Turning Steering Wheel Revs Engine & Idles @ high RPM
  206. ABS light and code on 99 windstar
  207. growling/moaning noise in 99
  208. 1998 Windstar Towing Package included what components?
  209. Stuck Fuel Gauge
  210. '98 Windstar IMRC P1537 P1538 P1513
  211. Suspect valve
  212. ignition (key)
  213. engine noise
  214. What is Best Brand AX4S Trans Overhaul Kit to buy ?
  215. ABS Comes on at 70 MPH - 98 windstar
  216. Rear AC Blowing hot air.
  217. No throttle response
  218. Drained Battery
  219. Door Ajar/Interior Light/Urgent Help!!!!!!!!!
  220. How to remove wiper arms
  221. 99 winny
  222. P0304 after restarting
  223. overdrive-wrong fluid?
  224. Auto sliding door & trunk
  225. Windstar FAQ's -- Let's Gather 'em Up!
  226. Update on windstar electrical problem
  227. ABS light and check engine light 2000 Windstar w/codes
  228. Intermittent dashboard Battery Light
  229. Transmission low to intermediate servo
  230. Completed mechanicals for P0171 - Do you need to perform WSB B26.2 PCM Update?
  231. '96 front coil springs
  232. Unusual question about fuel system
  233. sliding door cable
  234. 03 windstar trany
  235. 03 windstar trany
  236. I'm moving.
  237. 1999 Windstar LX Transmission goes "WHAM" into drive then nothing except reverse ??
  238. 95 Windstar Tranny- Just got codes, plz help!
  239. Windstar 99
  240. intermittent wipers
  241. abs power relay
  242. roof racks for 2002 windstar lx
  243. 1996 windstar stalling and not starting
  244. Champion spark plug: Copper plus vs Platinum
  245. Damage caused by constant battery drain?
  246. '99 Windstar AutoLocking
  247. 2000 Windstar side door lock
  248. How to program a keyless remote.
  249. abs light comes on after a couple of minutes
  250. 2001 vs 2003 wheel dia.?
