View Full Version : Focus
- Need Ford Transit Connect sub-forum
- Removing CDs from 2006 Focus CD player
- Fuel cut off inertal switch
- Check engine light
- Ford Focus zx3 relay
- Passenger compartment fuse panel
- 2002 focus rough idle problem solved !i originally
- 2001 Ford Focus zx3 luggage compartment does not open
- 03 Foucs no start
- focus 1999 1.4 zetec 5dr hatchback heater/blower
- 2000 focus started missing and sputtering
- Electrical Nightmare-Heater works rear wiper
- Ac issues
- 2003 ZX3...changing alternator
- Ford Focus coolant outlet feedback
- 2002 ford focus rough idle when at operating temp.
- Electrcial Accessories Issue
- Possible tranny issue?
- 2009 Focus SES Coupe spoiler
- Another problem.... are you suprised! :)
- New Problem! Are you shocked??!! :)
- New airintake, car turn off after a few seconds
- 2003 Ford Focus- Stalls when idle, rough idle
- 2007 head rest
- 2000 Focus LX hesitation when cold
- can I upsize to 60 sidewalls from 50?
- ZX3 AC Evaporator installation help
- ford focus computer
- 2003 Ford Focus code po171
- Dead on the Roadside
- 2003 belt chatter, rattle
- Focus 55 plate (uk) misfire
- 2000 Ford Focus SE ac & heat went out at same time!!!
- Exhaust
- 2002 Focus - Overcharging
- I removed my battery and now my car wont start
- coolant leak
- AC Help
- Please help me!!!
- 01 focus no spark in 1 cylinder
- Ford Focus 1.6 Zetec (Another Problem)
- Low RPM Missfire
- Focus ZX4 ST......Steel Rims Possible???
- alternator
- 2005 zx3
- 2005 ford focus zx3 alternator, drivers seat help, HELP
- 1999 focus 1.6 zetek problem
- Is my car safe to drive?
- Problem bleeding brakes
- new 09 coupe
- Very Rough Idle and no power
- 2002 SVT Focus Brake problem...
- Ford Focus stumble, erratic speedometer
- engine fail
- 2003 RFront caliper locking intermittently
- 2007 Focus ZX3 Turbo Build Thread
- 01 Focus Wagon Tranny and the (!) Yellow Light PROBLEM
- 2001 Focus dead at 83,000miles
- 2000 LX Focus High Revs!
- Tries everything and no solution
- Fkin focus
- 2000 Focus sluggish then won't start
- Focus paint code
- 2005 stalls and stalls and stalls...
- Should I buy a Focus
- please read!! need help..
- no fuel no spark
- 2005 ZX5 overdrive?
- Need advice on my 2002 focus zts
- Brake poping and Car shaking at high speeds..
- 02 focus DPFE sensor
- 2002 zx3 stalling
- Shift doesn't lock in Park
- 2002 Ford Focus- Alternator problems?
- Thinking about buying a focus
- 02' ZTS amp ground?!
- 2005 focus door mirror replacement
- 2002 focus fan not working
- I'm considering a Focus - what should I watch for?
- Need help with interior lights
- 2002 zts Brake poping?
- Won't start in cold?
- adding SYNC to a non-equipped car
- 2000 Ford Focus, Heater doesn't work
- 03 focus loses power while driving
- 2000 Focus rear
- '06 focus fuse box replacement
- Need to figure out spark plug cable positions
- Anti-theft
- Focus engine swap-
- two questions
- Coolant recomendation
- SPI swap
- Keyless entry
- 03 focus just won't start
- 2002 focus zx5
- 01 driver door lock won't unlock
- need help - trying to remove inner tie rod end
- Tag lights
- 2001 Focus stutter/misfire
- 2001 zx3 puttering
- 2008 Valve Body & Computer replaced??
- revving, flames
- Puttering from my 2002 Ford Focus
- 2008 Ford Focus
- 2.0(CVH) Escort engine-2.0SPI(CVH) Focus engine compatibility/swap/interchange?
- 2000 Ford Focus - blowing cold air
- 2005 focus zx3 reverse light switch
- 01' Focus revving then idling very low
- 03'ford focus air filter
- 01 focus vibration in the morning
- exhaust manifold heat shield problem
- 2002 Focus - sound front passenger wheel
- Simple Question - painting
- Interesting history of the Focus.
- Running Rough at idle and at speed
- focus ZX5 burn relay
- where I can buy a part shop for decorates ford focus in usa?
- how to adjust valves in SPI SOHC engine in ford focus
- 2005 Focus Bodykit Help !!!!
- 2005 Focus body kit help
- 2000 ford focus transmission
- 2004 focus air/fuel mixture problem!!!
- Check Out My Custom Gauges I Made
- Car Kit Help
- Profiles for Transmissions?
- The surprising truth about engine oil.
- HID Conversion and Halo LED lheadlights
- New tail light installation problem
- Bigger oil filter works fine.
- Melted Wiring? (Picture)
- Looking at Focus
- Customizing ZX5 Focus
- 2000 ZTS with OIL in the Air Filter
- 2004 Power Flicker Issue
- Where is the MAFS on 05 Focus DOHC 2.0 ZX3?
- 07 instrument cluster removal
- help !!!!!!!!!!!!!
- 2003 ZTW black spark plugs/misfire
- 05 Focus ZX3 SE 2.0 DOHC Auto Tranny
- how do i take off rear drums
- 01 Focus SE Wagon Problem
- 2000 focus,sohc,rough idle==
- Crunching breaks
- All in one function DVD player for Ford Focus
- my hell in SVT land
- coil spring safety issue
- what's a cooling fan bypass?
- Help!! Focus won't start after sound system installation
- 01' Focus with Zetec loosing antifreeze
- Ford Focus Vibration
- Ford Focus Crash - Ouch!!
- '05 ZX4 Tranny and Electical Dash Problems
- 2002 focus idle problem
- 2001 ford focus wont go in reverse
- 2001 Focus heater/ac unit
- 2003 zx5 good or bad ???==
- Someone wants to give me a 08 SES Focus
- 2003 ford focus ignition
- 02 Focus ZX3 - EGR Issues/Error Codes
- which part of your focus satisfies you most?
- 2001 Focus fuel problem
- 2001 Focus Idle Problem
- 07 Driver Air Bag
- SVT Focus Rear Brakes
- Lost power on Focus
- 2003 ford focus lx 93,000 miles
- looking for sites for performance parts
- P0750 Shift Solenoid No. 1 circuit
- Presentation of my Euro Ford Focus 2007.5
- Mushrooms in trunk
- 2003 Ford Focus ZTW stalls only when hot
- 2001 Focus On Air, wheels trade or sale Pics
- Turbo SVT Experience?
- 5W-30 ok?
- Possible steering or tie-rod problem?
- Good Intake
- Gold Starter NO START 4 beeps???
- Gas Cap & Check Engine Light
- 2005 Airbag Indicator
- gas cap light is on
- tire problems
- 2000 ford taurus front end squeaking
- What is this noise from my front end?
- High Pitch Whistle on '03 ZTW
- A simple pigtail is all I need.
- P2195 on 2003 focus
- Engine Fan only runs with A/C on
- 2000 inner tie rod
- Engine Light 2004 focus
- Front brake noise...
- Reliability of 2007 Focus
- Look to buy a 2001 focus wagon
- car alarm problems, help!
- focus shut down
- 2002 front brake issue...
- Grab Handles / Passenger Assist Handles
- Is ZTS and Zx3 engines?
- Rear Wheel Bearing Torque Question.
- shifter problem
- looking for 4x4 conversion
- 01 zx3 wiring harness
- From previous thead
- 2001 Ford Focus Radio
- Fordfocus 2003 ABS and Traction control light on
- Antifreeze on the driveway (strange spot?)
- focus key wont turn
- Can I install Cruise control in 07 zx3
- 2000 Focus ABS Light ON
- Aftermarket Radio Harness
- Intermittant problem wont go in or out of gear
- help diagnosing front end suspension problem.
- How to reprogramme Focus keys ?
- Flaming rag in gas tank fix?
- Right rear suspension dead?
- fan speed
- '07 rear brake squeal
- changing alternator
- hi lights w/working fog lights
- Water in intake
- Cyl 2 missfire code
- E-Brake Light
- Body sway in 2004 Focus
- Headlights dont work Brights do
- Dash and Parking lights out - 2001 ZX3
- how to change out alternator
- 2002 Focus "door ajar" light won't go off...
- Driver's Side Heated Seat Problem ('03 ZTW)
- Focus 05 Gas Pedal Stuck in the morning...
- Strange problem affecting DASH & TRANSMISSION ???
- Engine Replacement Cost
- 2007 focus se
- 07 Focus ZX3 vs 07 Cobalt???
- Swap SPI for Zetec?
- Help.x
- Rear Brakes: 2005 ZX4 Ford Focus
- question about my car
- Focus wont downshift...
- 2002 SVT?yes/no
- km to miles 07 focus zx4
- Considering an 03 Focus with 24k
- 2000 Focus Extreme Road Noise
- Engine Rattling noise
- Removing relays from 2001 fuse box
- inside rear door panel how to please
- Instrument Problem
- Stereo
- white smoke
- Focus 2000 ZX3: Alternator Problem?!?
- windows falling down
