View Full Version : Focus
- Fuel Cap
- Has anyone swapped an engine?
- door wiring loom
- Digital Tachometer/Speedometer
- rear brakes
- Power folding hardtop?
- What can I expect from the base ZX-3 drivetrain?
- ANswered my own quetion!!!!
- Odometer/Trip Display Burnt Out? Rest of gauges fine
- Question about DTC from self test
- Whats the biggest size Rim you Can fit on a Zx3
- White powder on pos. post
- White powder on positive post
- first year svt question
- Focus bucking problem
- starting problems
- Dies at idle. Rough Idle. 2000 Focus
- Ford Focus Pos
- Quick Focus question
- Factoy CD player
- Focus Transmission Chirping
- 2003 Ford Focus Wagon Ignition Problem
- Where is Focus-Central?
- how do I bleed the clutch on 2000 focus
- bleed clutch on 2000 focus
- Official Focus RS Keyring
- Projector Headlights
- 2006 Ford Focus ZX4 ST
- 5speed o5 focus ST idling probs and check engine light
- Idle Motor
- Gage malfunction
- 06 street appearance package
- supercharger for ST
- need more brakes and grip....
- Installed wrong oil filter............
- economy?
- Radio Clock
- Tie Rod Help Please
- Modern Performance Clearance Stuff
- voltage regulator
- 2000 Focus Wont Crank
- battery died
- 2005 Focus power train
- 2003 ford focus running rich
- 2000 Ford Focus LE
- Svt swap or just tranny swap? Zx3
- Zetec head $95
- Zetec/SPI Throttle Body Swap
- tail light lens
- 6 disc changer won't play burnt cd's
- ford focus 2003 LX-key will not turn in switch
- Turn Signals whackin out
- Need more go go
- Center dash consol removal with a nut driver and a coat hanger
- funny smell
- Where does the clutch cable connect to?
- 2000 Focus Heater Control
- Dashboard Center Console Removal
- mystery all doors lock.
- question about the rs model
- does it happen to everyone at the same time?
- brake light switch?
- Engine Cuts Out
- 2002 ZTS will not idle
- Headlight Wiring
- This is why Ford sucks
- Cold startup, bit of a whine
- All-New Ford Focus RS WRC 06
- Clutch on 2000 Ford Focus wagon w/automatic
- Largest Size Tires
- '05 ZX4 Squeaky Wheels, Grinding Brakes
- High fuel pressure
- snow in the gas tank
- So thaaaaaat's what that is...
- any advice?
- Dash and console
- SPI...how much of a gain?
- Exhaust System
- Left turn signal not working
- 2000 Ford Focus zetech Rough Idle Cold but doesnt Stall sometimes Rough Idle at stops
- light weight windows
- head tourque specs?
- HELP!!I'm lost
- Strut Tower Brace
- two problems- related?
- Duratec 2.0 Turbo?
- engine swap
- 05 focus zx4 cd error
- 2000 Focus runs fine cold then judders and dies
- Turbo???
- auto trans leak '05 focus
- Door panel removel
- explain the zetec
- 2001 Ford Focus Horn
- clutch pedal, leaking inside vehicle
- Bent 16" rims
- Where is the auxiliary port in a 2005 Focus?
- 05 Focus Wheels
- "bumping" feeling in the clutch pedal
- Duratec or SVT
- Ford Fuckus rear window
- horrible idle on focus and check engine light
- top speed limiter removal
- Check engine light...Need help!!!!
- 2002 Focus SE (Sedan) Window Problems...Please Help!!!
- Car stalls when shifting into park or reverse too quickly
- Focus Won't Start
- Tach for my 2.3L duratec
- rear grease seal?
- Standard Trans Clutch Replacement...
- bodykit questions
- Help Me With My Bumper
- 03 svt focus shift cable slips off
- battery light issue...
- Suspension upgrade
- Fuel filter location?
- 2000 Ford Focus rough idle now stalls
- Bad TB position sensor - "need new TB" WHAT!?
- My car problems
- loud noise+vibration
- I've got a brain buster of a problem w/my zx3
- 2000 Died at low RPM
- Eibach Sportline
- 2004 Focus Power Locks, already there?
- funny noise from engine
- ZX5 transmission problems.
- FS: 02 Focus ZX3 (35K Miles, CLEAN!! 5Speed, LOW PRICE!!)
- SPI or Zetec?
- Lag In Acceleration
- Exhaust tip question
- Focus w/ Mustang Engine
- won't start, won't shift out of park
- My Duratec needs more power
- lowering
- Normal to SVT exhaust change
- Vibration in front-end
- Pirelli P6
- focus problem
- ZX3 electrical problems
- Zetec Flywheel
- Ford Racing Tachometer
- 2005 Ford Focus Radio Removal
- SOHC Performance Parts
- Factory Cluster Swap
- Not able to shift into 5th or Reverse
- brakes
- ZTW Wheel Nut Caps...Disappearing
- Horse Power???
- Cryo2
- just got my '03 ZX3...
- speakers
- 2000 Ford Focus SE
- ignition problem
- Idle Speed Control Valve (iscv)
- Wheel Bolt Patterns Question
- Focus Wheel Alignment...'Shims' Needed???
- 2002 Focus no power won' rev up, Code p1507
- focus vs 156
- Oh!! No!!???
- How to replace fan speed switch on 2000 Focus?
- focus upgrades?
- I hear all of these problems about the Focus...
- 02 Focus ZX3 FOR SALE!!!
- 2000 ZTS Altenator or Processor problem?
- transmission?
- Speed Kills
- FS- 03 ZX3 factory 16" rims
- Carbon fiber focus hood
- Back Door Windows
- civic killa
- Everyone with a 2005 focus read this.....
- I Bought A 2005 Ford P.o.s.!!!!!!!!
- Wanted to buy...
- Focus Limited for sale.
- Body kit install
- 2005 ZXW - unfortunately a lemon!
- Engine Swap?????
- Focus Overheats when A/C is off
- remote entry not working
- Focus Acronyms and codes
- weird sound from the read while using A/C
- what can be done to them
- 1996 Focus TDI smoking and whisteling
- where is the fule shut off valve and relay?
- nedd help with check engine light!
- Focus wiring diagram needed for grounds
- fuel pump or fuel injector problem
- check engine light
- problem with tranny
- how good is the focus really
- EGR valve? Need Help!!
- '05 Focus "noise"
- Hole In Firewall
- 2002 Focus ZX5 - 63Kmi // for sale
- ZTW Tire Follow Up
- ZTW Tires (Options?)
- engine light on??
- Major problems with 2000 Ford Focus SE at 48,000 miles.
- What's the total cost(All installed turbo)??
- 00 SE A/C Recharging
- 2000 SPI Auto Transmission Problems
- 2001 Focus Se 4 SALE
- What do you think is faster?
- funny sounds....
- kinda off topic but can u help me?
- Engine lopes when idling
- Focus ZX3 Overheating Problem
- Echeck!!!!
- Automotive Extended Warranties
- zetec turbo header?
- Focus fuel Pump.
- focus for VW corrado
- can xtra feature be added at the dealership?
- good car for noob drivers?
- Focus 1.8 petrol - battery charge light - intermittent
- Break in period?
- question for ALL of you
- no help on focus
- power power power
- puttering
- V8 conversion
- location of OBD2 port
- '02 ford focus zx5 2.0 dohc engine light problem
- Brake Lights, Door Handles, Trunk Release, Keys
- for sale:ground control coil-over kit extremely cheap!!!!!
- Halo Headlights
- Stoplight switch
- ZX-3 and ZX-5 the same size?
- friggen door handles
- car original stereo
- just a tip for anyone who wants to remove their alternator
- heres what i have 2 say
- 2000 Focus 2.0 SE Specs
- ORP help......
- electric problem
- 2000 Rumbling
- Transmission Grinding
- dyno?
- Engine Vibration
- PO125 error '01 Focus
- Focus 2.0L Zetec, mpg?
- whats wrong with my car?
- Adding A/C to 2003 Focus ZX3
- is it possible to do a 2.5 duratech swap?
- Focus SVT OEM Radio, HELP!
- Low speed miss or lurching
- for sale:ground control coil-over kit Best offer :)
