View Full Version : Focus
Pages : 1 [2] 3 4 5 6
  1. Removing relays from 2001 fuse box
  2. inside rear door panel how to please
  3. Instrument Problem
  4. Stereo
  5. white smoke
  6. Focus 2000 ZX3: Alternator Problem?!?
  7. windows falling down
  8. 2002 Focus - Steering Column Locking Lever
  9. need info or help on short ram intake
  10. No low beams or fog lamps
  11. 2003 focus stalling in reverse
  12. focus lacks power
  13. 2006 2.0L engine vs old 2.0L
  14. No turn signal
  15. 2005 ford focus tranny problems and more
  16. 20 inch rims
  17. help!!!!!! Brakes are off I cant get the back on
  18. Inoperable power locks/ keyless entry
  19. 02 focus vibration in reverse.
  20. Belt Pulley
  21. Electrical or ignition switch?
  22. Chime won't shut off!!!
  23. Can the Ford car Manual be driven in "free gear"
  24. 00 focus won't start
  25. Increasing torque?
  26. '02 ZX5 Hard Shifting
  27. 05 focus air filter
  28. Help!! My 2000 ZX3 is making a weird clicking noise
  29. 2002 SE Possible Misfiring?
  30. 01 focus se cluth help!!!
  31. What's wrong with my 02 Focus
  32. Common Problems?
  33. 2007 trunk release issues
  34. Washer Fluid Pump
  35. hella projectors
  36. running rich
  37. 2000 Focus Steering Knuckle Question...
  38. Loud whine in right rear
  39. help!!!! bogging problems with focus
  40. 2001 Focus Zetec Engine Vibration
  41. focus air bag??
  42. I need help!
  43. spark plugs for 2005
  44. I need help or information.
  45. Ford Focus 2002
  46. Turbo Focus...
  47. intake manifold runner circuit code p1520
  48. One headlight working
  49. focus wont start
  50. 2005 Ford Focus Zetec Broken Locking Alloy Nut
  51. Ebay Coilovers
  52. 5.0L mustang engine in a 2000 focus
  53. Power Trunk
  54. Supercharging?
  55. vibration from hell
  56. Need to replace drivers side seat
  57. Drivers Side Door Chimes with no key in ignition and with headlights off & door open
  58. Turn signal blink frequency...
  59. Just Curious???
  60. windshield wiper arm removal?
  61. '05 fuel filter
  62. 2006 focus altinator
  63. horn location
  64. Repair Manual Recommendation
  65. Focus rally parts HELP!
  66. Car does not hold self on slope
  67. Blown engine fuse after AC is on for 30 minutes
  68. Rear axle nut size???
  69. which is better
  70. what typeof engine
  71. new cams
  72. 07 radio question
  73. Front Brake Procedure...Help!
  74. Zx2 Zetec and ZX3 Zetec
  75. 05 Zx3 Cel
  76. installing keyless entry
  77. Burning Rubber Smell
  78. engine number????????
  79. i want a tach
  80. Talk me in or talk me out...
  81. 2000 focus zts
  82. Should I buy a salvaged vehicle?
  83. i just bought 2000 focus zts
  84. Tranny Slippage Focus 02
  85. 2007 Cruise Control Question
  86. most dependable focus=??
  87. a/c not working right
  88. 2005 Ford Focus ST Sunroof troubles
  89. Tire troubles with 2005 ST FOCUS
  90. New-jack
  91. Looking for mods
  92. 02 Ford ZTS Electrical Problem
  93. 2000 Ford UnFOCUSed (Door Lock Problems)
  94. Problem with windshield wiper motor???
  95. 2002 Focus Cold Starting
  96. 2000 ford focus lx
  97. headlight harness???
  98. focus tranny swap
  99. 03 focus rear breaks
  100. thinking of getthing a 2001 foucus
  101. Rear Brake Adjusment on 2000 ZX3?
  102. 2003 rattles on driver side upon acceleration ALWAYS!!
  103. extended warranty
  104. 01 modified zetec losing power
  105. ford focus kona zx3 5speed tranmission mtx or igx???
  106. 2003 Focus needs new tranny
  107. Brights are stuck, help would be seriously appreciated.
  108. quiet performance exhaust
  109. 2003 Ford Focus Check Engine
  110. 01-Focus - Intermitent Hesitation
  111. i want specs!
  112. again....front brake problems 2003 zx3
  113. Check engine light...O2 sensor....Misfire?
  114. Urgent Help Needed
  115. Over Drive issue
  116. '07 Focus
  117. Rounded Oil Drain Bolt - Ford Focus 2005 SE ZX4
  118. 2003 Focus Won't Start Unless #1 & #2 Coil Switched
  119. Anyone Ever Change Serpentine Belt & Alternator 2000 Focus Zetech???????????
  120. electrical
  121. #@*$?()&^ auto-locking doors!
  122. Brake light stuck on
  123. 2000 Ford Focus Code PS10701
  124. I on cluster then my car stalls and goes again
  125. Anyone Know Or Have Pics Of Changing A Power Steering Pump Z Tech Engine?????????????
  126. Hesitation
  127. High idle at first...
  128. Starting problem
  129. 2000 ford focus z3 smog problem
  130. Any Ideas?
  131. 2003 focus 5 speed 2.3L please help
  132. For Sale Ford Focus Special Millenium Edition!
  133. Advice appreciated - 2002 Focus Wagon.
  134. 00 Focus ZX3 5spd Idle Problem
  135. Odd Problem
  136. high rpm?
  137. Projector headlight bulbs?
  138. 2007 Focus ZX3 S CD Player Removal
  139. 05 Focus vibration at highway speeds, did all I can, problem persists
  140. Thanks
  141. Focus trans cables won't come off!
  142. looking for an SVT
  143. Ford Focus 2000 Fuel Filter
  144. Timing Belt
  145. Keyless Entry Code Location
  146. 2001 Focus LX speedometer jumps like tachometer when reving motor
  147. possible bearing problem
  148. Ignition Problem!!
  149. Problems with locks /
  150. Is It Worth It?
  151. 02 focus need help
  152. electrical problem, 2000 Ford Focus won't start
  153. Focus Safety Defect Warranty Problem
  154. eletrical problem, no pc broken.....focus zts 2000.
  155. Ford Focus modified by Mattig Tuning
  156. help about pump of focus
  157. 2000 ZTS...lost key..deales charging $160.00 need option?????Is this true??
  158. engine oil light & clicking, but no start
  159. Clicking & Squeeking
  160. 2003 Focus 23,000 miles Engine light EVAP Emission?
  161. dooski
  162. Come Check out Rally at X Games 12 Aug. 3-6 in Los Angeles
  163. 06 ST 2.3l + AEM CAI??????
  164. Cruise control not working
  165. Digital Readouts
  166. Steeda intake install
  167. Installing led undercar lights /amps and speakers
  168. Removing rear brake drum dust cap
  169. I just bought an '05 ZX3 SE and I have a few questions.
  170. Trunk Latch problem
  171. Better to dye or paint your dashboard?
  172. Power Door Locks: 2000 Focus Se Wagon
  173. Front Wheel Noise
  174. 2000 Se Wagon Focus: Central Timer Module
  175. Stuck In Park & Stuck Key Dealer Says New Shifter Needed?? $300?????????????
  176. 2000 Focus, left side parking lights don't work
  177. Blaupunkt stereo problem
  178. focus wont start
  179. Ford Focus
  180. Ignition Switch Problem
  181. 00 focus se check engine light
  182. Anyone Know Where The Intake To Add Freon To Ac???
  183. Door Ajar Light
  184. Lock Or No dead Lock
  185. Looking at buying an 03 - ZTS sedan..
  186. problem with horn on 2003 ZX3
  187. Hole in firewall
  188. Another problem with the little piece of...
  189. CAI or Short ram intakes
  190. slips out of overdrive
  191. 00 Focus Spudders When Accelerating + CEL
  192. 4 12's
  193. Cooling Fan Switch?
  194. slow down shift
  195. MIL Light is On a 2001
  196. Replacing rear power window motor/regulator
  197. Drive Up Ramp - Clearance
  198. Engine Specs
  199. overdrive gear slips
  200. 2000 SE acceleration problem
  201. The Warranty
  202. 2000 focus key problem
  203. Help Car Problem PLEASE
  204. PCV Value
  205. 30K - Service for 2005 Ford Focus ZX4
  206. 2003 Focus ZX3 front brake noise
  207. Focus on Fritz
  208. 00 focus se
  209. boss monitor problem
  210. 02 LX, 5spd, vibration @ high speeds
  211. Transmission no overdrive
  212. 2004 Focus SE - 102,000 KM!!
  213. Small Vibration at 1500 RPMs
  214. CAI installation trouble!:banghead:
  215. Brake light is on
  216. 06 focus for sale
  217. ignition problem.. can you help me?
  218. Instal/Remove Doors
  219. 2000 Focus, Rough Idling in Signals and now P171 code appears
  220. After Market Exhaust worth it??
  221. Wierdest radio issue ever!
  222. Recommend or Not???
  223. Automatic Blinkers?
  224. ZX5 on Sedan
  225. Alloy wheels (oem)
  226. Front brake rotors/pads
  227. Diesel focus wont start
  228. Transmission type
  229. Problems with moon roof
  230. Need help with engine swap
  231. left rear turn signal
  232. Suggestions on Extended Warranty
  233. Other Belt On 2000 Focus Zetech Engine @@@@@@@@@@
  234. Keycode Radio
  235. 2006 focus belt noise?
  236. Trunk lock
  237. Easy Fix For Stuck Key
  238. Clicking Noises??
  239. Clicking Noises??
  240. intake install problem
  241. Electrical Gauges dying while car is running, eventually leading to the car dying
  242. Noisy Turn Signal / Flasher
  243. Mustang on Focus
  244. Manuel to Power Windows
  245. Switching Body Parts on Focus
  246. Transimission CLUNK in Cold start
  247. sticking ignition key
  248. Antifreeze leak? Advice requested
  249. Need help with Engine Mods.
  250. Trunk Lock
