View Full Version : ZX2
- Electrical issues after auto to manual transmission swap
- 2000 zx2 s/r throttle position sensor
- Question about selling a ZX2
- How do I remove heater hose?
- Axle stuck in wheel knuckle
- Head Gasket Issue, Need Advice
- squeal and ticking on startup
- Hesitation on acceleration - gears slipping?
- 2001 serpentine belt slips off
- Zx2 won't start...i've tried alot! Think you can help?
- 01 ZX2 timing belt
- 98 Manual Trans - Transmission Overhaul
- Runs Great COLD !
- Need Advice on a zx2....
- gas milage
- Gotta Problem.... No Start....Need some help/ideas...
- Poor gas mileage and no power
- Cracked head?
- No brake pressure
- 1998 zx2 coupe no brake lights
- Check Engine Light - P0125
- Another ccrm question
- Engine vibration when idle
- Tach, gas gauge, cruise control don't work.
- 99 Zx2 OBDII Problems
- Battery Light
- Cooling Fan
- ZX2 and EXP
- Cam Position Sensor, 00 ZX2
- Check engine light - not. 2000 ZX2
- emergency brake light comes on
- CCRM in 03 zx2
- Need ZX2 S/R info...
- Camshafts out of sync
- zx2 rough idle vibration
- I've got a strange misfire situation
- 1998 Zx2 Cruise Control Problems
- heater issue
- spark plugs
- radiator fan won't shut off!!!
- Any input welcome
- 2001 ZX2 shuts off
- Daytime Running Lights - stopped working
- Electrical short
- Mil on DTCS 302,303, with no drivability problems
- 01 ZX2 problem...
- 01 ZX2 huge oil leak
- 1998 zetec eng ?
- Died slowly from 70mph...
- 2000 zx2 auto trans question
- D.o.a
- Weird noise on back end when reversing
- check engine light on my zx2
- Need some info
- 99 zx2 dies, seems like alternator but it's been replaced
- 03 zx2, smells like raw fuel on exhaust side of engine
- water leak?
- Engine Won't Turn Off
- thermostat??
- Teamzx2
- 1999 ZX2 No Start Problem
- Oil burner fixed?
- 1999 ford escort ztec engine removal
- A/C Help!!!
- need help replacing cigarette lighter
- I need a constant control relay module !
- 2003 ZX2 Speedometer Problem
- 2002 ZX2 engine no spark need trouble shooting!
- How To: Reverse Flush Cooling System???
- Got air, fuel, but no fire... yep it won't start
- stereo in the zx2
- AC Question
- Car died. Battery? or Alternator?
- Replacing rear turning signal in 2000 ZX2
- ZX2 timing belt wants to walk off cam sprocket
- '02 zx2 problems...
- Where the heck is the speedometer cable at the tranny?
- ZX2 runs rough stalls when putting into gear.
- zx2 '98 engine question
- update on my sick zx2
- 98 escort zx2 question
- 2001 zx2 Fuel Filter Replacement
- 98 ZX2 cuts out when running and slowly dies
- 2000 excort zx2
- '98 zx2 5 speed tranny issues
- CamShaft sensor code
- 1998 ZX2 pvc valve location?
- '99 ZX2 dies when you press the brake
- S/R rear brakes
- Time for a rebuild / tune up.. need advice..
- need some advice
- 2002 ZX2 turbo?
- Missing something? bumper cover 2001
- where is the knock sensor
- idol pully
- Front wheel bearings
- stick rear wheel drive trans. swap?
- New ZX2 Owner
- VCT Replacement
- I have no heat and its 20 below zero
- car problem
- ZX2 Only runs on 3 cylinder at idle
- What all should be done with timing belt change?
- 98 ford escort rear end problems
- Power Steering Problem.............
- where to find parts
- 2000 ZX2 Cooling Fan Keeps Blowing Fuses
- 2000 ZX2 intermittently won't start
- Anyone else play with SCT?
- Surging then died
- 2000 zx2 s/r problem
- Trouble Starting
- Rear Defrost / Radio Problem
- 2000 ZX2 Alternator issues...
- Tire Choices
- speedometer/odometer cut in and out
- Manual Transaxle Fill Plug...?
- high revving vs speed
- 2001 ZX2 Battery Light
- my 2000 zx2 s/r is knocking- help
- 2 problems...are they related?
- Is it possible to use headers off of a Focus on a ZX2
- 1999 Zx2 Vct
- 99 ZX2 problem.
- soft plug heater
- Side Window Visors
- To all ZX2 owners: please help!!! parts missing after maintenance!
- check engine light, P0125
- P0301 and Stumble: 98 ZX2
- 2001 ZX2 Turbo?
- 2000 ZX2 cut off and won't start
- Question about service engine light
- I need help w/ cams
- Timing Belt Change
- 1999 Ford Escort ZX2 for sale - SoCal
- Need power steering help
- 2001 ZX2 oil pan removal
- 2000 ZX2 Won't start, possible electrical problem HELP!!
- A/C starts and stops (Please Help)
- Metal block with rubber?
- Howling / Whining ZX2 - Help :)
- 2002 zx2 advice?
- Engine Stuttering
- 2003 Zx2 Help!!!!!!!!!!!!!!!!!
- Do 2000 ZX2 have a IAT sensor
- Cylinder 4 Misfire
- A/C problem - 2000 ZX2
- Engine Problems!
- ZX2 Modifications!
- Guage Cluster Problem
- 1999 ZX2 horn gone wild...
- 2000 Escort ZX2 Tail light Socket installed incorrectly
- ‘98 ZX2 Error code P0113 IAT Sensor
- Struts Question
- 2001 ZX2 brakes...
- Feul injector removal
- zx2 universal spoiler / wing
- 98 zx2 hesitation coming off idle
- 2002 ZX2 Code Reading question
- Losing power when defrost is on????
- A/C bypass
- what version zetec engine is in my 98 zx2?
- How to get to the front speakers
- IAT Intake Air Temp Circuit
- '02 ZX2 Engine Cooling Issue
- 2000 ZX2 Engine RPM's High
- complete engine rebuild
- 98 Escort ZX2 stumbling and hesitating....making noise
- cat back/ header
- 2002 ZX2 A/C Fan
- maf
- gauge face ?
- Accelleration problem
- 99' ZX2 question?
- 98 Ford Escort ZX2 Alternator Question
- 2000 zx2 problem
- Pulsating Brakes
- zx2 fuel pump
- Where do I add clutch fluid?
- Water in headlights
- is a V-8 Possible
- ZX2 Parts
- AC System
- mod sites
- Power Steering Pump - How to replace???
- Catalytic converter=dead battery?
- Air Intake Mod
- lighting surge!
- Car seems to struggle starting up....
- Mtx
- Shocks
- Whistling
- power loss or lugging help
- Acceleration Problem
- rear disk breaks
- 98 ZX2 hesitates and stumbles
- Escort Zx2 intake
- 2002 Automatic Trans....
- tail lamp removal
- Cold air intake and exhaust?
- Speaker Cover/Side Pocket
- jump start went wrong
- VCT problems
- Changed Timing Belt Now Code P0340???
- Header Removal
- crank timing peg
- Elevation power difference...
- Adding Fog Lights to a 98 ZX2
- new parts ?
- would you buy zx2 again??
- computer went gofy sorry
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
- dash lights!
