Grand Future Human-Grade Air-Dried Beef Dog Food
Automotive Forums Car Chat
Nissan
240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
> Technical
View Full Version :
Technical
Pages :
1
2
Power Steering Problem I think
grinding second and third
A/T problems
Can u get a transmission swap?
Recomendations????
gearbox oil for 180sx ca18?
180sx s15 conversion
Camshafts
s14 sr20 questions
Ca18det
fast blinker
Any thoughts on ebay clutches?
How NOT to treat someone looking for help
ka problem
89' 240sx engine noise at start up......
Tach Problem
help 240 wont rev high?????
240sx engine revving problems
for those who have done the RB swap
how to properly check you TPS sensor
spark plug wire pops out
Z32 MAF on throttle body(SR)
losing power in my s13 sr20det
Timing chain noise
86 4wd transmission questions
putting s14 auto tran in s13 auto car...
300ZX brakes
how do i read the ecu code?
car shaking?
Which engine swap??
What ECU for SR20DE
coilover noise
93 Nissan 240 shut off after start
HELP!!! S13 front conversion on 92 240sx fastback
timing and idle adjustment
Car doesnt idle too well...
OEM SPL / Ring Gears
180sx headlights wont open
s13 blacktop question
Greddy Racing down pipe for the SR20det...
Engine Management System
starter s13
dam car
soch p/s pump on sr20det
car won't start
S13 Wheels 101
offset
Turbo Kit Question
car is not starting
timing off?
Differential Tech.
Titanium vs. Stainless steel
sr20det s13 turbo engine needed!
What causes my top radiator hose to be like this...
SR20DET and drifting?
Thermostat in 91 ka24de
seized motor
Car wont start...
All Motord Ka
Got a tech question? Check here first!
non-HICAS to HICAS
sr20det
thanks
Turbo Literature?
HELP w/ KA24DE-T
limited slip on the 240sx
90 240sx frame troubles
Turbo Questions...
Ka24e auto to manual swap
89 240sx Engine Swaps???
Ground Problem
Changing tension rods
1984 200sx
Hedlamp won't retract
300ZX > 240SX
KA tranny in SR
Tranny removal problem
E-brake removal
Rear brakes?
sr20det turbo
runs good now but wont idle. at what RPM should i time it at?
automatic to manual
200sx/180sx/skyline
SR20DET TIMING - Which CAS mark? Which is #1 cylinder? Do i Time off of #1?
low oil pressure in 1992 240sx with ka
SR 20 S14 wiring
Energy Suspension...
SR20DET Won't Crank
s14 questions.... and updates
s13 engine swap
single cam KA not running right
is that all i need for the z32 caliper conversion???
sr20det specs
Brake lights stay on!
I am the FIRST
RB SWAP FAQ FROM UNSTABLE. GOT AN RB QUESTION? LOOK HERE FIRST!
Quality Real Meat Nutrition for Dogs:
Best Air Dried Dog Food
Real Beef Dog Food
Best Beef Dog Food
