View Full Version : Older Pickups
Pages : 1 [2]
  1. losing clutch fluid
  2. 98 frontier P1148 code help
  3. '95 King Cab needs frame work
  4. '95 King Cab needs frame work
  5. '95 King Cab needs frame work
  6. fuel pump
  7. 1994 Pickup underhood to 87 body
  8. oil weight
  9. 3.0 v6 Ignition and ECU available
  10. Lookin for body
  11. 84 parts swap!
  12. 1987 Pickup (is it fixable)
  13. Swapping to a Holley 2300, What vacuum do I really need?
  14. 1993 Nissan Pick-up wont start!!
  15. 1995 Nissan Pick-Up won't start
  16. WTB Hardbody Z24i Transmission
  17. Fuel Temp & IAT sensor locations
  18. 95 Pickup intermitten clutch slipping
  19. 83 Nissan truck Z24 needs new carb
  20. Reading codes how to
  21. 4cyl suddenly died...stolen cat conv!
  22. Need some direction
  23. v6 in hardbody the same as v6 in 300zx??
  24. Did I total my truck?
  25. 1984 Nissan failed Co2 Emissions (barely)
  26. 96 Nissan Pickup XE fuel problem?
  27. 94 nissan pickup loses all power and shuts down...
  28. Replacing U-joints in 93 4x4 p/u?
  29. 1995 kA24E engine (nissan pick up)
  30. '86 Tranny problems
  31. 1988 Z24 has uneven idle
  32. Need help with lighting for instrument cluster
  33. air conditioning problem
  34. wont start no spark.
  35. my 86 720 pickup truck
  36. 88 pickup 2wd Stereo ?
  37. neeeddd heeelppp!!!!!
  38. MAF sensor 1995 xe pick up KA24E Nissan
  39. radio
  40. 92 4cyc stumbles
  41. 1995 kA24E check engine light
  42. 87 nissan windshield
  43. 1987 nissan pickup parts
  44. v6 swap
  45. turn signals help!!!
  46. 1988 4x4 making noise HELP!
  47. turn signal
  48. Carrier bearing/U joints - do it myself???
  49. MAF/throttle body swap?
  50. 89 Problem
  51. 93 hardbody fuel leak
  52. 95 nissan 3.0 v6 newbie
  53. Parts for sale
  54. bags?
  55. 4th alternator 97 pup
  56. no power to tbi @6 pin connector plug.
  57. 86 hardbody stalling
  58. Help!
  59. 87 2.4 early over rev cant figure out
  60. 94 Nissan Hardbody Fuel Filter Location
  61. 91 p\u needs rear shaft any other parts fit?
  62. 85 Nissan Truck (no fuel)
  63. Nissan 95 loosing power
  64. No Break Lights ,Signal lights,
  65. GAS mileage went down HELP HELP
  66. 95 Nissan Hard Body Truck
  67. problem with cab heat & fluctuating temp gauge
  68. noob needs help!!!!!
  69. s13 trans in a hardbody???
  70. Phantom, Info?
  71. Transmission needed
  72. What other head fits on 2.4l a nissan pickup
  73. 97 4x4 pickup ABS/Brake lamps on ???
  74. 89 Nissan pickup fuel pump
  75. nissan wannabe
  76. 89 rust problem????
  77. Have Fuel Have Fire But No Start 95 truck
  78. Help
  79. 96 pickup
  80. changing carpet
  81. Blinker/Signal problem. any ideas?
  82. 1991 Nissan 2.4L 2wd Auto Transmission on ebay for cheap,Listing ends in a few hours!
  83. adjustable thermostat, 1987 Nissan p.u. hardbody/Z24 engine
  84. 95 XE pickup horn problem
  85. 94 Nissan P/U Manual Trans Fluid
  86. 94 Truck Blower Motor Relay Location
  87. Nissan Truck Instrument Panel
  88. 97 xe Check Engine light
  89. 1995 4x4 pickup
  90. ECU problems
  91. swapage
  92. 94 D21 Body kit
  93. 90 nissan pickup wont start
  94. need a camper shell for 86 Nissan 4x4
  95. 96 center support bearing
  96. 95 auto no reverse?
  97. Engine miss/shaking when engine is started
  98. Radeator's (spelling idc right now)
  99. 1988 door removal
  100. Need some help PLEASE!
  101. wild tachometer
  102. 1984 Pickup/manual Steering To Power Steering Conversion!!!!!
  103. Engine Mount's
  104. Need help with head gaskett...
  105. 1993 power steering pressure hose
  106. 1991 Nissan crank but will not start sometimes
  107. Manual transmission question?
  108. Big tires on hardbody?
  109. Nissan Pickup Distributor FOR SALE
  110. 86 power train schematic?
  111. sr20ve
  112. truck worth the work?
  113. 1991 Maxima
  114. 1991 Nissan pickup alternator
  115. 92 nissan p/u truck parts
  116. '96 Nissan XE-V6 Timing Mark
  117. timing problem
  118. 240sx in a 1985 720 pickup
  119. 97 4x4 exhaust bolts broke off,help please
  120. '95 4X4 gas saver?
  121. Engine Model Number
  122. 1993 2.4 High Idle
  123. audio wiring diagram
  124. 1992 Nissan 4x4 truck problem
  125. no dim lights on my 88 pick-up
  126. Used motor?
  127. navigator rims
  128. 93 pickup with antifreeze in the oil
  129. engine swap info please help?
  130. barely "turns over" then starts - what is it?
  131. 87 4x4 questions
  132. for sale cheap!!
  133. 94 2x Manual Transmission Grinding in 2nd & 3rd
  134. Parking Brake
  135. First Time Nissan Owner
  136. fuel gage problem
  137. HELP!!! Motor swap??
  138. 87 nissan pick up
  139. 96 Nissan pickup has problem with water
  140. 94 V6 Pickup, Need New Engine, Best Place to Buy?
  141. 94 Pickup, Rear End Clunk
  142. unknown truck noise in hot weather!!!
  143. ECU Pin diagram
  144. Brake lights
  145. '95 Nissan P/u cranks but won't start. *Z24 engine
  146. Spark Plugs for '89 4 banger hardbody 2WD?
  147. may get an 89
  148. 87 pickup cranks but won't start
  149. Replacing 94 Nissan Ignition Switch
  150. 88 2wd engine swap help please
  151. 94 Pickup Starter Location and Removal
  152. 87 Nissan 4x4 suspension
  153. '89 Z24i engine stalling
  154. thermostat
  155. Removing transmission.
  156. 94 Nissan Pickup Won't Start
  157. No fuel flow: '95 Nissan pickup
  158. Truck makes a clunking noise...
  159. Tps
  160. 91 nissan truck
  161. grinding noise upon startup
  162. rattling noise
  163. center support driveshaft bearing.......
  164. ABS light
  165. Rear axle ratio...
  166. 93 4X4 front wheel bearing repair
  167. new 2.4 engine
