Our Community is 662,000 Strong. Join Us.
View Full Version : Equinox
  1. Need help! Is this a good deal?!
  2. H20 in headlights
  3. Lighters
  4. wiring diagram
  5. 05 Equinox C0041
  6. 2005 equinox shifting hard
  7. Change clock
  8. Intermitten rough idle after braking - 2007 Equinox 3.4L
  9. 2011 Chev Equinox - Losing Power & Poor MPG
  10. radio problems
  11. 2007 Equinox losing brake fluid
  12. 05 Chev Equinox problems starting at times
  13. speaker size
  14. head light adjustment
  15. 2007 Equinox
  16. 05' ignition question
  17. Bad thermostat or coolant temp sensor?
  18. ABS Speed Sensor/Wheel Vibration
  19. 2006 Chev Equinox Hesitation at 55km
  20. Equinox Hesitating at 55km
  21. 20s
  22. 2011 Equinox poor mpg hwy!
  23. Irritated 68
  24. Heater Quit
  25. Cruise control not working
  26. 2006 equinox cruise won't work
  27. just bought a 2006. any things to look out for?
  28. Check Engine Light.....
  29. Tire replacement
  30. 2010 Equinox door pillar cover replacement
  31. 06 Equinox rear wheel hub
  32. 06 Wheel Speed Sensor
  33. VVVVVV Sound When Driving....
  34. 2005 A/C blows cold only at cruising speed
  35. 2009 Equinox AC
  36. Ticking Noise
  37. A/C not working
  38. Equinox code P0054
  39. Upper Strut bearing pop sound?
  40. 2005 Equinox Cooling fans stuck on
  41. 2005 Equinox just a bad year, or what?
  42. Horrible Front End Noise When Cold???
  43. 2008 Equinox Sport DRL Off???
  44. Outside thermometer available?
  45. Save a noob!
  46. Equinox windshield wiper blades
  47. DRL indicator light
  48. 2005 ABS question
  49. FSM for 2005
  50. 2006 Equinox Stereo/Auxilary
  51. No Heat 2006 Equinox
  52. Headlight Bulb Question
  53. Steel Wheels
  54. 4 banger
  55. Struggles to Start
  56. 2005 Equinox
  57. DRL / Auto lamp sensor
  58. 2005 Equinox Cooling fan
  59. Stabilitrak Problem....anyone else
  60. Service engine soon light on.
  61. 08' eq
  62. egr update please help
  63. grinding/heavy vibration from front wheels
  64. EGR pipe
  65. Aftermarket!
  66. '08 Equinox Sport w/3.6L engine
  67. 2005 AWD Vibration
  68. 2005 Equinox Dead! Until jumped then fine
  69. security light staying on?
  70. Wind Noise!
  71. clicking noise coming from under dash on 2005 chevy equinox L S
  72. Equinox mechanical parts
  73. onstar backpu battery
  74. clunking noise from drivetrain
  75. Just got my Equinox 2 days ago and shes not playing MP3's! help!!
  76. 2008 Equinox trailer hitch suggestion
  77. 235/60R17 LRR tires
  78. 2000-2005 3.4 engine
  79. Ignition keeps getting stuck
  80. Thinking of Buying a 2008 Equinox
  81. 05 Equinox - noise while turning the wheel
  82. ENGINE SWAP! 2005 Equinox LT 3.4 with 2008 Impala 3.9!! Will it work??
  83. Drivers Side Door trim
  84. Dent repair issue
  85. Heater fan control
  86. Take 2005 dash apart.
  87. Equinox rattle
  88. Tire Pressure Monitor Reprogramming
  89. Key for Equinox
  90. tailgate wiper repair
  91. DRL not working
  92. seats
  93. Transmission Service
  94. keyless entry not working at times
  95. '05 Equinox w/98,400 miles -SMART or DUMB?
  96. Am Radio Reception
  97. 2005 MP3 Radio
  98. Steering Wheel Lock
  99. swishing noise
  100. swishing noise
  101. Changing Headlights
  102. Hard to remove key?
  103. Equinox owner satisfaction
  104. iat sensor
  105. Bad Ebrake Design
  106. Who Makes A 3rd Brake Light Cover For The Equinox?!?!?!?
  107. How to change the passenger air comparment filter?
  108. Trouble starting
  109. towing with equinox
  110. HWY mpg
  111. Equinox AWD on the beach
  112. class II radio?
  113. moonroof visor
  114. Highway RPM's
  115. Key sticks in ignition?
  116. Keyless Remote Programming Instructions for 2005 Equinox
  117. Evap silonoid
  118. Interior cleaning
  119. DRL turn off
  120. So, when does the Lemon Law take affect?
  121. Radio installation instruction needed
  122. Sputtering
  123. Equinox Interior Fading/chipping
  124. Calling All Chevy Lovers
  125. Equinox front end noise??
  126. Should I buy an Equinox???
  127. Socal: Looking for a Equinox to test fit, will pay $200!
  128. What is "Service Vehicle Soon Light"?
  129. 05 Equinox
  130. Can Equinox jump start another car?
  131. 3.4 motor is it the only choice?
  132. Gas milege with 05 Equinox
  133. Equinox First Post
