View Full Version : '97+
Pages : [1] 2 3 4
  1. wipers adjustment
  2. radiator and coolant question
  3. 2 1998 Passats B5 Variant in China: Pics
  4. Front Suspension Replaced 00 Passat
  5. Oil Pressure unit
  6. Water pump belt replacment
  7. 1999 VW Passat V6 2.8 overheating
  8. 2002 Passat code: P2096
  9. 99 V6 trany computer
  10. 2003 passat climate control issue
  11. Shaking steering wheel
  12. Question: 2003 with W8-sensor problem?
  13. emission workshop message
  14. looking for diagram for door window cable
  15. 1999 passat 2.8
  16. Tiptronic Help
  17. a/c recharge unsuccessful...what now
  18. 2000 passat hp gains
  19. 2001 Passat Instrument Cluster
  20. 05' Passat 2.5L inline 5 running rough HELP!
  21. 1997 passat radio problem
  22. 02 Passat 1.8t
  23. abs light on headlights turn off
  24. 1998 Passat Electrical Issues
  25. location of MAF on ATW 1.8T
  26. MAF sensor AUG/ATW vin?
  27. Need some advice on buying a 98 Passat
  28. limousime 1.9 TDI 1999 ventilator belt noise
  29. 99 Passat Radio Installation
  30. front and rear brakes
  31. 02 Passat 2.5 V6 TDI warning lights
  32. 2004 Passat Headlamp adjustment
  33. window problem
  34. 1999 volkswagen passat
  35. '00 Passat stalls/won't start
  36. 2004 TDI Passat Shudder on Acceleration
  37. ignition control module
  38. lots of wather in on passenger side carpet
  39. 02 Passat V6 4 Motion - - - low speed missing
  40. 2001 Motor Head needed
  41. PO118 - How Serious?
  42. Help
  43. Mass airflow sensor
  44. MAF rebuild?
  45. windshield wipers not working
  46. 2008 VW Passat 3.6 4motion
  47. 2002 Passat Oily water in intercooler
  48. Extreme Shaking and shuddering when hitting ~50 mph
  49. all gears selected/no tiptronic/no 5th gear
  50. 99 passat passanger window and lock
  51. Windshield Wipers Work but Store in Up Position
  52. Can ac pulley/clutch be replaced 99 passat
  53. 01 Passat no electrical at all
  54. 2002 Passat Timing belt
  55. ! inside triangle idiot light
  56. Replacing Head Lamp
  57. Windscreen And Side Wndows Mist Up Badly Help!!!
  58. No Heat or A/C
  59. 1
  60. Camshaft Alignment Tool 3391 & 3242
  61. P1128 Code Suggestions/Outter Door Handle Broken
  62. Help w/ changing the fuel filter on 99 Passat?
  63. Satelite radio out, warrenty past
  64. 2003 VW Passat Codes
  65. 2000 GLX 4Motion won't start
  66. Electrical problems; cruise, dash light, windshield wipers
  67. transmission problem
  68. alternator workshop?
  69. vibration problem
  70. Any help appreciated
  71. cooling problem
  72. which is better 1.8t, V6, w8?
  73. Why doesn't my cruise control work?
  74. Passat Door Locked
  75. Stereo Problems 99 Passat Glx
  76. Timing Belt Round 2
  77. Aux Colling Fan
  78. Tranny shifting problems
  79. 1999 passat no start
  80. 01 Passat Loud Humming Noise
  81. ABS/Brake Fault
  82. ABS/Brake Light , Fault 01200
  83. 2004 Passat Headlamp / Headlight Intermittent
  84. 97 Passat VR6 Secondary Air Injection Pump
  85. 99 Passat problems
  86. Fuse 13 and 14 keep blowing
  87. Info
  88. Emmissions Workshop, sound familiar?
  89. 97 Passat (b4)Transmission Mount (replace)
  90. 03 Passat Wagon Question(s)
  91. 1999 V6 Passat - stutters on accelleration
  92. 1999 V6 Passat - stutters on accelleration
  93. Passat oil issues again 2006
  94. 2006 Passat - Starting problems
  95. 98 passat 1.8 20v turbo
  96. 2003 Passat, 1.8L -bad engine, 125,000 Miles
  97. P0118 Fault Code Issues
  98. Too many issues.. Need a mechanic...
  99. Which OBD
  100. car won't start
  101. WTB - 99 Passat passenger side corner light
  102. Please Help!!
  103. 2007 volkswagen turbo-car keeps stalling
  104. Front turn signal light 2006 Passat
  105. Power Steering fluid.....
  106. Power Mirror issue
  107. 2001.5 VW Passat Mirror does not stop tilting up
  108. What's it worth?
  109. help w/04 passat headlights
  110. 1.8L Passat oil pan removal??
  111. passat scary drive
  112. 2001 Passat acceleration prob. (nub)
  113. 98 1.8 warm start problem
  114. Intermittent Brake Failure 01 Passat Estate
  115. Anyone know where I can find a w8 radiator online?
  116. 2002 VW passat GLX 4Motion
  117. Coolant light on
  118. headlights
  119. halfshaft replacement help???
  120. VW passat 2001.5 1.8T Cold start problem
  121. rear lights inop
  122. 02 Passat Hazard Flasher Clicks
  123. ABS control module 1998 vw passat gls 1.8L turbo
  124. Passat battery drain
  125. Considering 97 Passat 6cyl - Need Feedback
  126. Passat "Jolt" at crusing speeds?
  127. 02 Passat glove box
  128. Help in changing a bulb in A/C unit
  129. Vacuum sound on passenger side of engine
  130. Is there a difference between the air flow sensor and meter?
  131. Big problem plz help
  132. 2000 passat clutch fan wrench size
  133. Key/Lock problem
  134. 2000 Passat 2.8 no start/lock problem
  135. Anyone know the name for this piece
  136. Passat Alarm troubleshooting
  137. 99 Passat Passenger seat won't lock in position
  138. shudder and slipping tranny 99 passat
  139. 1999 passat problem
  140. Should I buy 2002 Passat W8
  141. 98 passat code 1136 and 0303
  142. frustrating diagnostic
  143. Onboard computer problems
  144. 99 passat break down on highway
  145. tiptronic bad
  146. Another Passat smell question
  147. 99 Passat, ran rough then wouldn't start
  148. Buying 2001.5 Passat GLX V6 - What to look for??
  149. electrical connector pin removal
  150. 2001 Passat. Check Engine Light
  151. No Power to AC- Steering Wheel controls, Stopped working while driving
  152. My trunk is heating up?
  153. 99 passat radio problems
  154. Passat Electronic Power Control (EPC) light
  155. 99 passat v6 - a/c not working - electrical???
  156. Slow or infrequent starting 98 Passat - HELP
  157. ac blows hot and cold air
  158. Strange radio behavior 2002 Passat
  159. Passat help
  160. POWER STEERING BELT TOO BIG HELP! 98 passat
  161. Turn signal turns off/won't work 2001 Passat
  162. Do 97 passat glx vr6's have sai?
  163. Vexing Electrical Problems - '02 Passat
  164. Passat SW 2001.5 Vacuum hoses
  165. Replacing a Passat battery?
  166. performance help
  167. 1999 Passat GLX 6 cyl.
  168. 1.8t sport passat 2001 mass air flow sensor problem
  169. code reader location
  170. 98 passat window regulator plastic piece
  171. 02 Passat - Passenger front/rear floor boards are wet!
  172. 02' Error code P0171
  173. Passat TDI
  174. Lower control arm
  175. 98 Passat random no start
  176. idling
  177. Oil pressure issue...Sludge, sensor or other?
  178. dump valve and boost gauge.....
  179. AC/Heater Fan dead except for fastest speed.
  180. Door lock problems
  181. 98 Passat 4cyl 1.8 not start Ple Help
  182. Turn signal, persistant clicking after signal is off
  183. 99 Passat Headlight Reminder
  184. Have a multifunction range switch for 99 1.8t if anyone is interested.
  185. how to fit a cam position sensor
  186. Thermostat housing
  187. Airbag fault
  188. 1999 1.8t passat start and clock problems
  189. Auto shifts hard like a manual
  190. 99 Passat Won't Start
  191. Coolant leak on 1.9 tdi
  192. Rings or Turbo?
  193. Power Output Stage or Ignition Control Module - which is it?
  194. lights
  195. 99 Passat GLS V6 -Will Not Start
  196. Reliable Mechanic
  197. rear drivers side window wont roll down. not motor.
  198. 2001 PASSAT suddenly will not start
  199. I Am Crying (really) Help.
  200. 1.8t Intercooler piping
  201. My engine dont start Help!!!
  202. What does this light mean?
  203. Ford Explorer Seat
  204. change front o2 sensor 2000 passat
  205. Gunk in interior light
  206. Headlight assembly replacement
  207. Auto aftermarket parts
  208. 2003 Sedan (GL vs. GLS vs. GLX)
  209. fuse index card??HELP
  210. Passat seatbelt
  211. 2001 Passat Timing Belt and Electrical Help Please
  212. 97 Passat Body Control Module (BCM)
  213. cruise control engaged by itself
  214. Windshield Wiper Fluid Alarm
  215. Engine speed sensor
  216. top speed
  217. 2001 Passat Instrument Cluster
  218. 99 Passat blown fuse short circuit, WONT START!!
  219. 01 passat
  220. how do i remove a radio/cass from a passat
  221. 2006 passat seat problem
  222. Cruise control issues
  223. premium gas
  224. VW Passat 3BG 2.8V6 Tuning
  225. 01 Passat v6 Secondary Air System
  226. VW Passat 1.9 TDi Oil Pressure & Turbo
  227. Oil Change Woes...
  228. Oil leak
  229. 2002 Passat Water in jack Well
  230. Coolant temperature
  231. 2002 B5.5 v6 starting problems - throttle body?
  232. How to clear the "Service" notice on display
  233. 3k passat 190047826032
  234. 2001.5 speed sensitive door locks overactive, help!
  235. 97 Passat GLX Electrical Problem
  236. 97 Passat GLX Electrical Problem
  237. V6 ICM and triptronic advantage
  238. Headlight Adjustment Passat 2002
  239. Troubleshooting Passat Cruise Control
  240. passat 2002 rattling noise when heating
  241. 2000 Passat - heater core
  242. 02 Passat Electrical Bug
  243. 2003 Passat Rear Brakes
  244. VW Passat stumbles while driving
  245. Transmission "Clunk" 2004 GLX V6
  246. 97 VW Passat fog lights
  247. Driver side headlamp.
  248. coolant leak
  249. Where are you people???
  250. resetting locks and alarm - '99 Passat
