View Full Version : '97+
- 02 Passat error code P1296
- electric mirror switch replacement
- New Owner of '99 Passat 1.8T: Preventative Maintenance Suggestions??
- Idle & turbo problem?
- 97 Passat
- Failing Central locking and locked Fuel lid
- Check Engine light 99' Passat
- Spark plugs 99' Passat 1.8T
- 2004 Passat will not start
- 2000 1.8 whistle on cold start
- 2001 Passat 4motion - Intermitten Starting Trouble
- 2001 Passat CD changer
- 2000 passat door mechanism
- 2001 passat coolant loss
- parts for 99 passat
- where is the connector for the odometer for 99 passat
- 1999 Passat Thermostat Location
- 99 1.8T Spark Plugs
- 2002 Passat -Wont Start
- 2002 Passat Rear Brakes
- Headlamp Passenger Side/Passat 2000
- Replace heater core in a/c 99 1.8T
- 2004 1.8T Oil Pan and Drain Plug
- 1999 Passat battery/computer problem
- Needs Instructions On How To Change 2002 Outside Passenger Side Headlight?
- FS:1998 VW Passat 1.8T
- 99 Passat idles rough -- Please help
- Tiptronic "T" to a Top botton straight shifter?
- Parting out a 1991 VW Passat
- 2001 Passat - Rear Brakes
- 2002 passat allarm going off
- 1997 Passat GLX VR6 Woflsburg Window Motors
- 2002 Passat Oil Pressure Problem
- 98 1.8 Turbo Revving
- 2002 Fog-light Cracked
- 1997 Passat Glx Vr6 -thermo Housing Leak -07/28/04
- Passat 98 electrics cut out
- 2002 VW Passat 1.9 TDI with cold air draught around gearstick
- 2000 Passat Battery Change and Computer Reset
- 1999 Passat Interior Lights Broken!!
- 1999 Passat V6 -slight miss when idling.
- 2000 passat turbo tempature gage
- 98 passat gls for sale......
- REPAIR question, front end, 2003 Passat
- '98 1.8L Not Starting
- Turn signals not working....?
- 2003 Passat Fuel Filter/Brakes
- '00 Passat - loss of A/C, Fans, Wipers, Signals,
- problem with 2000 4motion electrics
- 04 passat tdi "whistling" noise
- 00_Passat Check Engine Light
- buy 2002 Passat? 95K
- 97 Passat Rear door not locking
- Location/Engine Coolant Sensor/Passat 2000
- 2002 Passat Rotors and Brakes
- Replacing flasher switch on 2001 Passat
- 98 VW Passat burning oil
- Should I Buy A Passat
- check engine light (98 Passat)
- popping while braking (98 Passat)
- 98 Passat Alarm
- 2002 V6 oil burning
- 98 Passat - Probs with Coolant Temp/Level Light
- Oil change in my '98 Passat?
- 98 passat 1.8t
- 2000 VW Passat failure!!!
- 99 Passat V6 strut/sway bar noise
- 2000 Passat won't start
- 2001 GLS 1.8t ABS light
- strange noise in 97 Passat GLX VR6 wagon
- 99 Passat Transmission issue
- 01 Passat Engine Light and Temp Gauge
- abs light on 97 passat wagon glx
- 99 Passat Items Needed
- '98 Passat spark plugs
- CD Stuck in '04 CD player -- anyone know how to unjam?
- 2001 passat
- 1998 passat shudder
- a/c recharge port on the '99 1.8T
- Emissions Workshop Tip for 2001 Passats with 1.8T engine
- 2000 Passat brake noise in reverse
- BMW headlights on 97 passat?
- timing belts 60000 mile and dealer mark up? (1999 wagon)
- Subwoofer in 2003 Passat Variant
- 2001 passat engine light
- Just Purchased Used V6 1997 Passat
- location of ignition module on 99 Passat 1.8?
- 97 B4 Passat day time running light concern?
- Urgent !! 2001 Passat Antitheft Alarm keeps going off
- 2000 Passat GLX 4 motion
- smell, fogged windows, in 2001 Passat V6
- Brakes Lock-up and will not Release - '99 Passat
- 97 Passat Temp Gauge Problem
- 97 Passat Power Window Problem
- Rattle in Trans or Wheel? 2002 Passat
- 2004 Passat Triptronic lurching
- 1997 Passat remote key
- 2000-2003 passat wagon rating
- 2001 VW Passat P0431/P0421 Catalyst problem
- im lookin for a 97 passat glx cup holder and a center cap
- 00 Passat Transmission Noise - Need Help
- 2001 Passat
- 99 Passat Battery and Remote Key
- 2002 VW Passat rear brakes
- 2002 Passat Specs
- 99 Passat 1.8 has anyone had this many probs???
- 1999 Passat V6 GLS For Sale
- 04 Passat Odometer Jump?
- 97 passat glx wagon tire size
- Car jerks when coasting
- looking for interior center air vents for a 2000 passat
- 1999 Passat Windshield Washer low light wont go off.
- Im looking to buy a 99+ Passat. What should I be looking for?
- Cold Weather Blues - 1999 Passat
- oil smell inside 2000 glx V-6
- Rear door probs 99 passat wagon
- '03 Wagon - Brake Noise, then Gone
- Pipe size for 1999 Passat
- 99 VR6 morning engine noise
- passat sport 03 throttle response
- 2001 passat warped rotors
- 1999 Passat 1.8T Timing Belt Maintenance Interval
- Creaking noise on 03 Passat
- APR 91 Octane chip for 2000 Passat
- bad smell from 1998 Passat V6
- Converting 2001 Petrol/Gas Passat to TDI engine?
- 99 1.8 turbo help
- Need TSB Text 99 Passat
- Need Advice on which car to buy; 1998 Passat v6 or 2000 Passat v4
- 1997 Passat Computer Chip?
- Passat 1.8T oil specifications
- 2003 Passat windsheild wiper blades
- 2000 Passat climate control problems
- '03 Passat GLX 4M Brakes coming on by themselves!
- Chipping a B5.5 2003 1.8T Passat
- 1999 Passat Brakes
- 2003 Passat GLX
- 2000 Passat Coolant Problem
- Tuning an 03 Passat 1.8T
- cruise control 97 Passat VR6
- Technical questions, troubleshooting etc.
- 2002 Passat V6 engine mods.
