View Full Version : '97+
- o2 sensor, CEL
- Steering rack question
- oil/transmission fluid
- ABS MODULE TEAM! hELP guys
- gas level, check engine, emission
- Another problem!!!
- Throttle position sensor
- Oil Smell
- passat 1.9tdi loads of vibration on start and white smoke.
- Heated seats
- 99 1.8 turbo LOTS of Probs! HELP!!!!!
- Vibration on Acceleration?
- CD changes "No Magazine" message
- IS 1998 passat wagon is turbo bad?????
- conversion of F to C on Climate Control
- Clunk While Breaking/Accelerating (99 Wagon)
- Turbo for passat
- wiring code
- Alternative suspension found, need advise and need reliable transmission control
- 99 series passat
- Turbo (or lack thereof) question
- Passat wont unlock and alarm sounds please help
- Oil in coolant overflow??
- Bad Cruse Control
- 1998 Passat Needs New Engine
- immobilizer system
- 2000 Passat Driver Door Alignment
- Code Reader Scaner Connector
- 1999 1.8T Passat and OBD codes
- Passat V6 4 Motion won't start
- vr6 parts?
- noise around 40mph
- 1999 Passat 1.8, problems with the Turbo
- 99 Passat Losing coolant
- Air Filter Baffle
- turns over but wont start
- 1998 Passat??
- 2000 Passat 1.8T Automatic Shifting Problem (Tiptronic)
- DTC 18223 , P1815 What does it mean?
- Passat 2002 - Brake Lights out! Replaced 2 bulbs
- Transmission Module Issue...not sure?
- Headliner replacement?
- '03 VW Passat V6-Tiptronic?
- Blue Smoke!
- upper strut brace
- Brake pulsation
- Trustworthy mechanic in Stamford, CT area
- Exhaust Emmisions Warning Light
- Preformance Issues With 98 Passat 1.8t
- Emblem
- Factory alarm issues
- 2001.5 Passat question
- headlight adjustment?
- 97' passat Vr6 GLX... Weird noises
- vw dealership misleading customers
- Help! The dog ate my dashboard!
- Passat V6 (in Eurovan) stalls/idles rough
- Wanted Passat TDI
- 1999 V6 Passat Belt Squeling
- 2000 being returned to dealer...Need advise....and FAST!!!!!
- passenger airbag N 131
- aeb 1.8t stock starting problem please help
- passenger airbag
- trans oil level
- help trouble codes p1136, p1250, p1475!!!
- Looking for 02 Passat fuse panel diagram
- Cylinder 3 misfire issue
- 97 passat driver door problems
- Have i "lost" my chip-tuning during service?!!?
- Fuel Cap stuck and no gas !
- girlfriend's 98 passat is totaled...should she buy it back and fix it?
- tiptronic "bump shift" quit working
- Passat TDI PD 130 judder / shudder
- 99 passat window and door lock problem
- Passat B4 VR6 exhaust options
- ABS relays/Location?
- Airbag light on
- Oil leak? Please help!
- replacing oil pump
- CAM Adjustment
- Side Marker Lights
- Passat 2001 water leaking in
- cam chain noise or valve noise?
- 2000 Passat 1.8t P0411
- 01' Passat Won't start
- Steal my car!!!
- Hi, need advice on maintenance and cost..
- 97 passat-vr6. trans.problem.
- Problems with the 1.8t :( need help
- 98 1.8 turbo
- Comfort Control Module Location
- 1998 Passat Electrical Issues
- 97 Keyless Entry
- 99 Passat Sputtering then dying
- 99 Passat - Break-light is on and head lights won't come on
- Keyless remote reprogramming
- first time driving a passat
- Oil Leak - Cam seal replacement
- Malfunction Indicator Light
- '98 Passat Won't Start
- cd changer check magazine error
- Monsoon sound system problem
- New '97 Passat GLX vr6 owner- Questions
- Thinking of buying a Passat!
- 98 Passat TDI's exist?
- Passat error code 411
- 99 passat 1.8t abs/break lights problem
- No start after engine dies
- 2000 passat temp gauge
- 2001 Passat battery or electrical problem
- 98 Passat Electrical Problems
- 2001.5 Horn won't work
- 99 Passat floor mats
- loud noise when turning
- Drivers door panel
- I need 1998 passat 1.8t keyless entry directions please
- 2001 Passat 4-Motion Wagon 3 Repair Questions
- AM/FM Stereo
- Air conditioner blows fan motor fuse
- weird electrical problem - one for the books!
- 2000 Passat - Sounds like an exhaust leak but not sure
- Lead for cd changer
- Air intakes 99 passat
- 2001 Passat turn signals don't work
- Remove Dashboard for cd changer!!??
- 99 Passat STEERING PROBLEMS!
- 17'' on 99 passat
- Synthetic Oil REQUIRED for Turbo Passats?
- 2003 1.8 Liter Turbo Passat Temp Gauge
- 2003 1.8 Liter Turbo Passat Power Steering Fluid
- 2003 1.8 Liter Turbo Passat Spark Plugs
- 2003 1.8 Liter Turbo Passat Brake Fluid
- 2003 1.8 Liter Turbo Passat Rear Brake Pads
- Oil Pressure
- how good are fuel injector cleaners
- Headlight Washer or are they Sprayers???
- Replacing starter
- rear passenger door wont open
- computer codes
- Fan Pulley?
- Check Engine Light comes on when Low Octane Fuel Added?
- Fuse Question!!
- i just bought a new passat...
- grrr....noise problems
- Wheels, Tires, Air Intakes......
- I guess no one know??? READ PLEASE!
- Rear passenger footwells are wet
- Boschmann....ANYONE!
- Does ANYONE know???
- need 02 passat engine
- Help on 00 - 02,03
- passat inner tierod change
- is there a big difference in power with the vr6 gti n passat
- Antenna amplifier problem?
- Passat Skid Plate. HELP!!!
- 2001.5 Headlight Switch/Harness Installation
- Brake dust problems anyone?
- No Oil Pressure
- Blown Turbo? Please help!!
- 97 passat 1.8t 20v high emissions and fluctuating rev counter
- Location of air filter on '99 V6???
- Experiences with 6-yr old 1998 VW Passat
- Passat 2003 ABS/ESP/battery problems
- Lock for wagon rear hatch won't open
- A Passat 1.8T 2002 noise when started
- Car Manual.
- Audi TT turbo
- 99 Passat-Water Leaking in from under dead pedal
- Boot / Trunk won't shut
- Dumb question - 2002 Passat headlight housing removal
- test driving 99 passat tommorrow... what to look for?
- Gas Cap?
- White Smoke?
- 2000 VW Passat code P1128
- TDI motor oil, does only the dealer have it
- 2004 Wheels
- Engine Movement
- Cat, PCV hose & differential
- wind noise
- Hp Racing Evo 18x8 of 18x9 Hypersilver LIght or Dark 5x112 Beautiful
- loss of power and a/c display flashes/blower fuse blows
- Check Engine light with P0421 ...???
- radio code???
- '05 Passat, Thinking about buying, asking for opinions
- Suspension Survey
- what to do if timing belt broke ???
- PASSAT 1.8 20v
- No wipers, brake or turn signal light
- Code P301-304
- Dead Interior Lights
- 02 Passat noise from wheel well
- Transmisson?
- Chronic overheating after turbo swap!
- 98 won't turn over :(
- Clock and trip odometer display
- rough start
- Possible Memory Seat malfunction?!
- 03 PASSAT; trunk lock alarm always on
- New Enthusiast
- 1998 Passat 1.8T No Start No Fire?
- 98 Passat 1.8T elec and engine issues
- 99 Passat Wagon 1.8T - running lean
- transmission locked out
- Brake Malfunction
- 2004 Passat potential remote starter problems
- Brake Pad light - intermittent
- Help! '03 Passat cold start problem
- 2003 Passat GLX will not start
- Rough idle/starts bad
- replaced battery in 97 Passat: won't start, alarm lights no horn going off
- passat only starts when it feels like it
- Multifunction Switch problem after major service
- How to change Passat 2002 Fog lights
- Temp Indicator and Oil press wire
- knocking sound in driver side wheel well
- Help with CLimate Control lights
- '99 Passat v6 won't start
- Glove Compartment lock not working
- Error Code P1423
- tire noise-tie-rod?
- 2000 V6 an interference motor?
- 2002 Passat - Dead Remote
- new passat q's
- so were ????
- slapping noise on start of 2000 V6
- Changing ECU on 2000 Passat
- Wipers, Turn Signals, Fan, Headlights OUT/ Brake light ON
- question for Boschmann
- Problem with Passat
- 1999 Passat won't start
- Help me diagnose this Passat please
- Follow up - PASSAT - No Turbo till 3000rpm then.... look out!
- Idle problem at stop
- DTC P0411 - What does it mean
- Faded skirt trim 2001 Passat
- 99 Passat Turbo 1.8 Ck Engine
- 1999 Passat Trunk Light
- passat 1.8t 1999
- New member concern list
- passat 1.8turbo
- 2001 Passat Engine Appears Flooded
- Passat Cambelt
- 1997 VW Passat Wagon GLX-NOISY ENGINE
- new stock stereo- different year
- 1997 passat V6
- 97 Passat heater core
- 99 passat autom trans shift problems, cold or hot
- O4 passat brakes shimmer
- 1998 Passat tie rod ends??
- 99 Passat - Should I replace both brake pads & rotors?
