View Full Version : '97+
Pages : 1 [2] 3 4
  1. Driver side headlamp.
  2. coolant leak
  3. Where are you people???
  4. resetting locks and alarm - '99 Passat
  5. Radiator Issues
  6. 2000 passat rear calipers?
  7. Power doesn't come from battery to eny part of the car
  8. Where are the spark plugs?
  9. alternator light
  10. Volkswagen Passat, Secondary Air System
  11. Help! Headlights & Daytime Running Lights Do Not Work
  12. 1999 Passat ABS fuses
  13. 97 GLX, opinions
  14. Passat Relaibility?
  15. 2002 GLX won't start!
  16. 2004 Passat Information display wrong country/language
  17. 1999 Passat Auto door lock
  18. 2003 Passat auto trans indicator lights
  19. battery
  20. 2005 engine light intermittent
  21. Confort Module & Plug
  22. Obtaining XM Radio ID number
  23. Timing Belt and Controll Arms.
  24. Looking at a 2000 1.8L turbo -your opinion please
  25. Where to buy parts for european '00 passat?
  26. gas smell
  27. Need help in making a decision.,,,PLEASE
  28. Keyless Remote Lock only unlocks Driver door.
  29. Check Engine and Coolant Lights
  30. 1.8t hessitation
  31. oil in coolant reservoir
  32. Good Mechanic Here?
  33. '97 Passat. Would 2003 headlamps fit?
  34. Dead Radio 2002 GLX
  35. Trade in water damaged 2001 Passat
  36. 2002 Passat up and ran hot! Help!!!!!
  37. 2002 Passat Alternator Install Bosch 120A
  38. HELP! Hazards not working
  39. How to remove the head lamp assembly?
  40. Minimum Volume Control '00 Passat GLS
  41. Jerky Acceleration '00 Passat GLS - Dangerous
  42. Gearboot+Knob
  43. 97' passat 2.0 in a 90' corrado
  44. turbo ?
  45. How do you change the Bulb on the rightside passenger Air Vent
  46. High-octane gasoline for 1.8T
  47. Clock, milometer keeps resetting
  48. Help! - 99 Passat won't start because Fuse #14 keeps blowing
  49. 1998 VW Passat Tranny Jerks! Problem with Tranny? or Engine?
  50. where I can buy purge valve
  51. Changing Spark Plugs VW Passat 2002
  52. air conditioning problem
  53. 2002 Passat GLX Wagon Crisis
  54. 2001 passat wagon can't open back latch
  55. 2000 Burning Crazy amounts of oil!
  56. Passat will not start.
  57. Lock doors - Windows go down!
  58. 2003 keys
  59. Passat Hitch....Advice?
  60. passat 99 windows problems
  61. Replacing passenger-side brake light bulb
  62. help please!!!
  63. 1999 Passat Instrumentation Cluster
  64. Shaky (Scary)
  65. 2000 Passat power window, locks don't work
  66. New 01 passat v6 Navigation
  67. 2002 passat won't start
  68. 1999 V6 Passat ABS/Brake Light
  69. About to do my brakes on my '99 Passat....
  70. Vag-com information
  71. 99 1.8t small coolant leak by oil filter
  72. 03 Passat dash keeps rattling, how can it be fixed?
  73. 99 Passat Warm Weather starting problem
  74. 02 Passat check engine light/sometimes wont' start
  75. Fog Lamps
  76. Molding
  77. 1.8L AEB Timing Issues..Timing Belt Off??? sorry post is a little lengthy
  78. Leaking Valve Covers ('99....2.8L V6)
  79. Need some help here.
  80. 2003 Passat 1.9TDI oil leak
  81. Upgrades
  82. 99 Passat 1.8t Tranny Oil
  83. Happy New Owner 99 1.8t GTL Passat ???
  84. 99 Passat Check Engine/Won't start
  85. Cam position sensor
  86. Front speakers
  87. 2001 Passat for Sale
  88. 1.8t AEB T-belt set points.
  89. Gamma multichanger wiring???
  90. 1997 PASSAT GLX VR6 - Headlamp Off, Foglights Off - 3.29.06
  91. steering rack id
  92. 97 passat glx steering whine
  93. 97 VW Passat Electrical Issue
  94. Just upgraded Intake
  95. Auto & tip shifts n gear, but car won't move
  96. ABS fault
  97. 1999 Passat V6 - Brake pulsation
  98. 1999 Passat V6 - 114,000 mi.
  99. 2005 Passat Alarm Disable Question
  100. 2005 Passat Alarm System Disabling
  101. tail lights(revisited)
  102. ABS/Break light off
  103. OBDII scanner
  104. Keyless Entry Question
  105. turbo doesn't work
  106. air intake
  107. tail lights??
  108. VW Passat engine siezure
  109. Airbag light
  110. Stuck Gear shift?
  111. Buzzing sound in dash and clock reset
  112. Gas smell, decreased mileage, check engine light
  113. changing brake calipers on a 98 passat
  114. anyone want to buy my 03 passat?
  115. 98"passat climate control, electric problem. PLS HELP
  116. Radio Problems - Blaupunkt Bolgna C50
  117. Aircon clicking sound
  118. Problem with Remote opening passenger/back doors
  119. Car sputters on acceleration
  120. Type of oil
  121. P1338
  122. 97 Passat wont take gas!
  123. 2000 passat fire issues?
  124. 2000 Passat ccomfort module
  125. 2004 Passat - Both Break lights go out but no fuse manual
  126. '98 passat 1.8t swap for '02?
  127. car shakes!! help!
  128. 2002 Passat crankshaft actuator sensor
  129. won't start after every fill up
  130. Help, Red spot on display
  131. passanger door wont open on 98 passat
  132. warm start problem
  133. Looking for performance shop in Orange County CA
  134. horsepower question
  135. 2002 Passat owner seeking advice
  136. ARE PASSAT ENGINES INTERFERENCE OR NON-iNTERFERENCE
  137. 01 Passat crashed, bought the 06 no questions
  138. 99 passat won't start
  139. Passat downshift bump
  140. 99 VW Passat With Factory Alarm Won,t Start
  141. 99 Passat Wgn Battery Dead
  142. Various problems 01 Passat - Which are Priority?
  143. Seeping Oil Seals
  144. 00 Passat V6(ATQ) 2.8l
  145. Brake 1999 passat
  146. Back door window
  147. 2000 passat wet floor board
  148. 2001 Passat and a Cupped Tire
  149. Updated Timing Belt Kit Questions...1.8L
  150. 01' Passat driver side door wont open from the inside
  151. 98 1.8 passat clicking engine
  152. Someone help me before I explode!
  153. 99 Passat 1.8T Oil Pan Change
  154. 99' Passat Warning lights no tach
  155. 99 1.8 wagon interior light stays on
  156. Urgent help needed, 98 Passat pass door window
  157. 1999 Passat V6 - Full Antenna Replacement
  158. turbo on on 03' passat?
  159. brake job cost?
  160. Extended Warranties?
  161. Fuel Door Release
  162. 98 Passat loosing power
  163. Trip Computer resets after 2 hours
  164. IPOD on My passat 1998
  165. No Turn Signal / Hazard Lights
  166. engine is dieing on every intersection
  167. brake pad changing trouble
  168. '02 PASSAT Trunk lock
  169. 2000 Passat
  170. adding satelite radio antenna
  171. '98 1.8L I4...possible broken timing belt? What else could go wrong?
  172. '00 misfires, check engine light after 80k service
  173. Type of Coolant?
  174. W8
  175. Dip stick
  176. 2003 passat 1.8
  177. Passat 1998 owner 's manual
  178. ~~Load Knock from TOP of Engine~~
  179. Technical bulletins
  180. Check engine light
  181. 97 vr6, loud top end?
  182. chirping sound from engine
  183. cd changer
  184. 02 Passat Power brake loss when cold?
  185. Alarm Problems
  186. 2000 Passat Horn Location
  187. Power loss and stalled on interstate
  188. 2006 TDI starting problem
  189. A.I.R. Pump Relay #323 Location 01' Passat
  190. Overly active ABS
  191. Euro tail lights
  192. Universal Oxygen Sensor Replacement
  193. 99 Passat GLX steering problems
  194. electrics prob draining battery - help
  195. Adjusting headlights on 2001.5 Passat
  196. Indicator Column change? Passat TDI 98 MY
  197. Need help w/ '00 Passat 4motion suspension
  198. 1999 Passat - Front Rt Caliper Locks Up
  199. 1998 Passat tie rod removal
  200. standard alarm in a passat
  201. control cruise
  202. 2006 Passat hesitation
  203. 2000 Rain leaking through the pollen filter
  204. Check engine light 2000 1.8T
  205. Tires worn too soon - 2000 1.8T Passat
  206. synthetic oil only & timing belt
  207. 2000 passat hood release
  208. misfire codes.
  209. F into C
  210. rear wiper and window cleaner problem on 99 passat wagon
  211. I'm stunned!!!
  212. Repair bill went from $275 to $1700 in less than a day
  213. altenator change
  214. exchanging a MAF sensor between years
  215. Loud clicking on right side
  216. Trunk Release
  217. Problems with Tiptronic after installing new battery
  218. Electrical problems
  219. 99' 1.8T Headlight Lense
  220. 2006 passat
  221. 2001 passat problems
  222. Tiptronic kick in transmission when downshift
  223. 99 Passat hood won't open
  224. harsh shifting.
  225. Check engine light
  226. possible starter problem
  227. door panel
  228. Sluggish Shifting Gears-99 Passat Automatic
  229. 1.8L turbo burns oil
  230. abs module test ?
  231. Passat Remote Battery Change/Reprograming
  232. Loss of engine power at 3k revs in '97 1.9 TDi
  233. 2000 Passat rear window regulator
  234. chipping a 2003 v6 30v 2.8 passat?
  235. reset airbag light
  236. Door Lock Activates a Pump/Motor
  237. Odd musty smell in my 97 Passat VR6
  238. check engine light
  239. Door lock switch?
  240. VW diesel engines/vehicles
  241. Removing Door Panel 99 Passat Wagon
  242. do your vaccum lines
  243. repairs help
  244. turn signals do not blink 2000 passat
  245. 01 1.8Lturbo, O2 sensor code
  246. Front end rattle
  247. replacing power mirror switch
  248. power steer fluid loss
  249. Radio Problem
  250. fuel pump secondary circuit??
