View Full Version : '93 - '96
- transmission
- for sale
- Blinker/Electrical problem
- 94 Passat GlX
- 93 passat vr6 fuel pump relay location
- 1995 vw passat vr6 was stalling now won't start.....
- '95 Passat FL power window problem
- 94 passat electric windows
- Rear Struts?????
- 96 Passat VR6
- 94 Passat High Running Temp, Hot weather performance.
- :banghead: :banghead: :banghead:
- Steering clunk
- check engine light wont read?
- Window stops 1cm before top - regulator??
- 1996 Passat V6 Fuel Problem
- i need some help anybody plz!! desperate here
- i wanna sell my 96 vr6!!!
- Master break cylinder
- 95 Passat Clutch Wont Return & No Heat
- 95' VW Passat sunroof issue!
- Changing 96 Passat headlight bulbs. *Help Please*
- Secondary Air Injection Pump Motor Needed Now
- 96 passat glow plus not comming on
- 93 vr6 auto - trans in limp mode?
- 1996 Passat TDI stalls then restarts - help
- Izzy
- thermostat location
- Question about transmission
- squeky breaks
- overheating....... alot when accelerating
- 95 gls vr6 sticky clutch
- Question about a 96 GLS
- 95 Passat fuel pump VR6
- Smok check / airbag warning light stay on
- ABS & brakes
- '96 Passat TDI: fuel lines keep breaking
- cruise control / check engine light
- 96' Passat GLX VR6. Key wont turn!
- Reading Codes in a VW 93 Passat
- 1996-1997 vr6 glx 5speed keeps blowing the fuse in the engine the #5
- Oxygen Sensors
- noise at 2100 rpm only
- How do you remove the fuel pump unit on a 95 vw passat?
- 93 Belt and Pulleys?
- steps to remove the fuel pump on 95 passat v6?
- Coolent leak
- 95 Vr6 Running Slow
- need help....leak?????
- 1995 Passat DTCs
- 97 passat not starting
- '96 Passat vr6 auto to manual trans swap
- A/C issues still...
- The interior of my Passat 95 is an oven
- A/C fuse location...please help!
- Removed radio now not starting?
- bent valves
- $1721 for a fuel pump? '96 diesel wagon
- 1996 passat VR6 GLX sluggish
- 1995 VW Passat GLX Sedan Alarm Problems
- '95 Passat trip computer/clock problems
- Brake Pads and Rotors - 95 GLX
- Passat seatbelts
- Steering wheel removal
- Which thermostat should I use???
- 95' Passat stalls when rad. blower fan kicks on
- A/C Woes in TEXAS!
- vw 1994 pasta bucking in reserve
- '95 passat VR6 starting problem
- 95' Passat VR6 Won't start
- Fuel Filter location in VW Passat 96
- 93 VR6 rough idle/acceleration when warm
- 93 Passat engine codes
- 96 passat vr6 oil leak
- 95 GLX VR6 - Wipers don't stay down
- Coolant leak 95 VR6 Passat
- heater hose question, 1996 passat glx vr6
- 96 GLX will not select 1-3 manually
- 95 vr6 left lowbeam quit HELP!!!!!!!1
- 1995 Passat vr6 vehicle speed sensor
- 96 passat idle speed control.
- Hazard/Turn Signal Problem
- Passat Has Become a Bucking Bronco
- what obd is my 95/96 passat estate
- fule pump fuse 93 passat
- 95 volkswagon passat v6 standard
- passt vr6 air box
- 93 Passat GLX VR6 POWER LOSS ABOVE 4K RPM
- 96' passat vr6 glx relays trouble!!!!
- multiple problems. need help. going insane.
- Windows not working!!!!
- 94 Passat Wagon V6 won't start
- fog light
- 93 Passat GLX, VR6 - 10A Fuse - Carburator keeps blowing
- h1/h1 headlights
- '96 GLX...coded keys?
- 1993 VW Passat GLX Radio HELP!
- Hole in oil pan
- door handle rod, not connected right
- 93 Passat Dies after it warms up
- 93 VR6 Transmission fluid
- Big Trouble No Solution? 94 VR6 GLX
- 1996 Passat GLS - Cruise control intermittent
- 1995 Passat fog lights
- Keepin on'
- Inner Tie Rod Tool
- Getting my computer to a "ready" state for smog check (long)
- Passat engine swap
- Front Doors Stick
- 1996 Passat GLX transmission
- Check Engine Light
- 96 passat front quarter panel removal
- Multi-function switch
- 93 Passat Ignition Wiring..*HELP*
- Porting And Polishing Services
- 95 Passat GLX VR6 ignition problem?
- Abs Module Problems Team .help!
- 94 Passat A/C Gremlins
- 96 GLX Trouble Starting
- 94 passat vr6 idling issues
- Battery or Alternator issue? (1996 Passat GLX)
- Dashboard warning lamps
- 1996 Passat stumbles, How to find intermittant fuel problem?
- 1996 'Check Engine Light'
- ABS Light On For Years 96 Passat GLX
- '93 GLX Automatic problems / swap info
- AC Condenser on '96 Passat
- ABS problems
- electrical problems
- pressure plate and clutch please
- fly wheel and pressure plate
- flywheel torque specs please
- Rear Window will not close
- Ignition Switch Removal On 95 Passat
- odometer LCD readout
- additional dash light
- CV drive axles
- how to connect rechargeable torch
- Trans on 1995 vr6 glx wagon
- ignition problem
- 94 Passat. Starter?
- wiper noise
- 95 Passat-Used-What's the deal with the Relays
- Turning off daytime safety lights.
- speedometer stopped working
- 93 GLX 4dr AT
- Trailer Hitch for b3
- OBD not ready
- 96 passat rattle at strat up
- brakes?!?!?
- airbag light on
- Please review - '91 VW Passat Wagon GL
- brake pedal is pumping ????
- 94 passat- fog light, heat, AC questions
- 93 Passat VR6 only passenger door locks all doors
- 93 Passat VR6 A/C, melted dials
- 96 Passat TDI window jerks upon closing
- smoke out of the vents
- 1994 Passat VR6 Starting Problems
- Passat Turbo Diesel (not TDi) starting trouble
- Power Windows & Door locks. weird problem
- rain problem
- '93 Passat VR6 GLX Wagon
- Passat electrical problem fan /wiper /lights
- 95 GLX TD/STD Fuse #21 problems "this is a more detailed thread" 2 of 2
- 94 Passat VR6 ECM relay location
- 94 Passat VR6
- how do i get a better look at passat gauges
- Passat gauge problem I REALLY NEED HELP
- vr6 computer code
- fan selector
- auto trans fluid
- factory alarm on 96 passat
- Car Parts
- 96 Passat gauges
- Can't find door handles for 95 Passat V6
- 1996 Passat Fan/Blower: Vicious Cycle!
- Passat 97 GLX VR6 Transmission
- Obd-ii
- gas smell in 96 passat
- Clutch Pedal
- Rear window defogger no working
- Brake pedal remains depressed on 93 vr6
- Electic Windows
- 96 b4 Steering Wheel Removal
- Rear Break Lights (PLEASE HELP)
- 95 passat vr6 glx nothing but problems
- Passenger rear footwell drenched!
- check light
- new to vw board, questions 96 Passat vr6
- help in "Exhaust pressure sensor circuit malfunction"
- TDI Glow Plug Relay Location
- OBII code p470-71
- door locks
- 96 VR6 Passat Emissions (Boschmann?)
- hex bolt size
- manufacture alarm
- flashing water temp light
- Cleaning the injectors
- Auto Tranny problems
- 95 Passat - Heater Core?
- Technical questions, troubleshooting etc.
- 1995 Passat Engine Swap, starter doesnt crank, please help!!!
- 1995 Passat Auto w/Transmission Fluid in Coolant ???
- 96camry 4 cyl 102K miles low oil pressure
- Passat fuse location
- clock and tripometer go to zero
- Headlight bulb replacement
- 95 Passat VR6 tranny
- 1995 Glx Vr6
- Overheating Problem!
- camshaft position censor 96 passat
- '96 Passat Idle
- rear window switch
- 1995 Passat Yellowed (Dulled) Headlights
- 95 Passat 2.0L stalling problem
- Metal VR6 Coolant Pipes
- 94/95 passat 1.9cl td relays in main beam..
- 1994 passat-overheating and misfiring
- '96 Throttle Body and 2 Oxygen Sensors
- E-Brake Adjustment 96 Passat
- '94 GLX - Clutch pedal goes all the way to the floor!
- how to replace radiator on 95 Passat?
- Exhaust Help Needed..93 VR6 Wagon
- 1996 AC Warms-up
- 93 VR6 Need info to remove front nose..
- Rear view mirror removal - '94 Passat
- HELP removing door panels - '94 Passat
- changing break pad's on a 95 passat wagon
- ´93 VR6 cruise control doesnt work
- ´93 VR6 weird hydraulics (clutch) problem
- 1996 Passat TDI stalls at speed
- 1994 Passat Heater Blower Controls
- 1996 passat r6 glx door handles wont open
- Best Way To Sell 96 Vr6 As Parts Car
- '96 CD changer installation
- 95 engine temp light
- 96 Passat A/C Problem
- 96 VR6 Cold Start
- 1996 passat electrical problem
- 1995 GLX V6 repair manual sources?
- 95 passat GLX V6-ignition/electrical problems
- 95 passat GLX V6-AC lines cold but not in car??
- where thermostat located on 95 Passat VR6
- 96 passat starting problems
- '94 Passat Wagon - internal leak - need help!
- 1995 Passat Parts?
