View Full Version : '88 - '92
- 98 Passat
- 1992 passat wagon wont start
- 1992 passat 2.0 overheating
- radio cuts in and out when clutch depressed
- 92 passat possible ignition switch
- OIL Presure lamp flickering
- Clutch pedal gets stuck in my 91' Passat [140km]
- 3 Alternators and counting - 91 Passat
- My 91 Passat Brakes need HELP!!!!
- 1990-91-92-93-passat 2l 16v visdome needed- turn key and nothig
- 1990 Passat from Hell!
- how to change Ignition switch on VW Passat 1990
- 2002 2.0L Passat will not take its gas after gets warm
- Leaking oil...
- ignition switch removal?????1992
- 1991 Passat Stereo Removal and Installation
- 91 Passat problems !
- looking to buy - 91 gl
- 1992 Passat 1.8L G60 Syncro AWD
- Battery Connections
- Sunroof problems
- 91 Passat - Help!
- Passat 1992 Replace A/C Condenser
- switch control and air conditionning problem
- Engine Turns But Refuse to Start!
- is transmission problem ?
- passat problems
- 1992 Passat Jumpy Speedometer
- D) All of the above
- Ignition Key: I Need An Extra. Valeo Brand.
- Changing ignition switch on a Passat '92
- car quit while driving!
- 91 gl 16 valve does not turn over
- knocking at 3000 rpm
- spasticone help?
- My car loves the cold.
- cooling fan won't start
- 92 door lock problem
- Anyone know what this part is called?
- Scary (engine?) Noise!
- Aluminium kick sills
- 91 passat gl stuck in 3rd
- low clutch pedal on 91 Passat GL
- Speaker Grill Removal
- stalls when wet
- fuel pump
- New Stereo Power Wiring
- intake air temp sensor
- Relays
- rpm guage jumps
- Passat 91 overheating problem (where is the the run-on switch located?)
- Passat '92 with climatronic - problems
- flashing temp and oil LEDs
- dies with driving
- Dim Headlights
- Electrical Instrument Lights Out
- Oil-pressure lamp!
- 1990 Passat Fuel Pump Fuse Blowing
- Recourse for those with used VW's not under warranty
- No Spark. Starter Turns.
- FOR SALE Autotech Q-Chip for 2.0l 92 Passat
- 92 passat wont start
- Front Brake Pads for 1991 V.W. Passat
- How to replace dust/pollen (cabin), air, and fuel filters?
- fuel gauge 91 passat
- Remove ignition lock cylinder
- '91 passat wont turn over suddenly
- 1990 passat please help!
- Speedo Sensor
- VW Passat warning chime
- Fuel Pump Assembly 1992
- wiring diagram
- How to replace heater core in 91 passat??
- What problems are common?
- Tranny Slips and ideas?
- 91 tons of problems PLEASE HELP!
- timing belt 92 passat, 9A engine
- '91 passat - passenger electric window problems
- electrical problems!
- Erratic Idle, jerky when driving when foot lifted.
- passat won't hold charge
- My wipers are slowly dying. Help me!
- Camshaft sensor trouble code
- Brake pedal fade drop?
- clutch assembly squeel
- Automatic transmission problem
- battery dead?
- Crazy noise comming from dash area
- Big Problem! (maybe spark plug)
- fuel and drive train problems
- Strange idle problem
- Important Information for anyone with power problems
- Auto Tranny
- 91 vw passat electrical problem
- 88 model Passat Overheats
- 1990 Passat flood right at start up
- Please Help!!! I shot my self int the foot on this one (1992 passat wagon)
- eletrical problems with 1992 passat
- 1991 Passat GL Sometimes wont start
- 2000 passat seat control stuck
- No front sidelights with engine off
- electrical gremlins, where to look??
- PLEASE help with my 92 passat 2.0 auto
- 91 GT 16v stalling when warm
- looking at 92 passat gl
- 92 passat trans help
- Front End Rattling - Clicking - Shimmy
- '91 Passat - P/N Switch or Relay? HELP!
- coolant recovery tanks???
- 91 Passat - Fails emissions test...
- Automatic seatbelts are not cool!
- Transmission Problems
- 91 Passat - Tranny stuck in "sport" mode?
- Battery/Power is being killed! HELP!
- how do i change the lock barrel on my '92 passatt
- 1991 passat help!!!!
- 91-Passat GL WONT START
- Power Problems
- 91 Passat Rattling
- Changing the radio
- 91 Passat Charging problems????
- 92 2.0 16v At it again
- Knocking noise at dash and steering wheel
- '91 PASSAT starting problems
- Technical questions, troubleshooting etc.
- 92 VR6 dosen't start
- Head gasket 92 GL
- No Spark
- 91 passat stalls...help!
- 91 passat transmission??
- 92 Passat erratic stalling/rough running
- Engine Interchange years
- Interior Lights
- OIL Problem - Leaking from filter
- infant seats
- Alternator Belt Doesn't Like My 91 GL ~ HELP!!!
- 90 GL Passat wagon needs parts
- 92 Passat L Turbo Diesel won't start
- 1991 4 cyl opperating temp
- 1991 - Power locks
- 1992 Passat
- 1992 Passat vacuum hose connection
- 92 Passat, No power, air hissng sound
- 1991 - grinding noise from front when turning right
- 1991 Passat - no power
- 1991 4 cylinder overheating probelm
- 1991 Passat CD Player Battery Problem
- 91 Passat guage fuse blows constantly
- Passat 1991 transmission
- has ne 1 had stiff brakes on a 91 passat
- 91passat still giving break problems
- Trouble Codes 91 passat
- 91 Passat wont start, help!
- Passat 1991, automatic oil transmission color
- Passat 1991 drain the battery !!!
- Passat 91 overheats???
- 1991 starting problems after stalling
- 91 Vw Passat Limp Mode???
- Rough Idle on 92 Passat 16V
- Passat 91 Coolant steam inside the car
- 91 passat - replacing timing belt
- 91 passat gl over heats
- 91 Passat ABS Problems
- HELP HERE PLZZ!!!!!!!!!!! 1991 passat
- 92 passat alarm
- 92 passat gl: questions!!!
- Passat 91 rear brake problem
- 91 Passat auto tranny
- 91 Passat sunroof / no heat
- 91 passat GL heideberg radio
- '92 Passat gear shifting problem
- 1991 passat heater core
- 91 passat...looking for hospital or graveyard
- 90 passat wagon transmission
- 1990 passat for sale cheap as hell
- Passat 92 Gl Factory Alarm Problems
- 1992 Passat GL problems...
- VW Passat 1991 won't start
- 92 passat
- 91 passat 2.0L :Fine under engine load JERKY when not..
- 90 Passat Grill
- 1992 Passat G60 Syncro >>> good deal?? <<<
- Starter issues with 1990 Passat 2.0L (5spd manual)
- i need some advice on what to do with my 91 passat
Automotive Network, Inc., Copyright ©2021
