View Full Version : '97 - '03
- How much HP can I get out of my VR6 VW Jetta
- power problems
- 97 VW Jetta Horn HOnks intermittently
- obdII software downloads for pc's
- brakes hissing?
- '99 Fan Switch Removal
- Starts & runs for 2 or 3 secs then dies.
- 1999 Jetta Wolfsburg
- 02 Jetta Catalytic problem
- 97 Jetta New timing belt stripped
- Services engines light Blinking 97 VR6
- '97 Jetta
- 98 Jetta feels like it's sliding when I turn HELP
- 01 jetta automatic one touch window
- 01 jetta 1.8t overheating
- manual transmission filler plug
- 1999 Jetta P0440 p0422
- 2000 Jetta
- 1997 Jetta Won't Start... Pls help!!!
- 03' Jetta w/ Issues w/ Intermittent flickering dashboard lights.Need advice!
- 1997 Jetta starting issue
- Posessed radio!
- Cold air intake splash guard?
- 97` jetta runs bad with alternator plugged in
- help! on 2002 1.8t buying issue
- Battery Drain Issues
- wiper problem
- 2002 Volkswagon Jetta
- 02 Jetta 1.8t Running very hot
- 1998 VR6 wont restart hot
- Camshaft Position Sensor out of sequence
- 01 Jetta TDI stuck in park
- 97 Jetta wont move! HELP!
- 2001 jette vr6 ac compressor
- each year something messes up on ac, need info
- speedometer
- 1997 GLI VR6 acting all sorts of stupid... help?
- Looking to buy 99.5 Jetta
- 97 jetta wont start
- 2003 Jetta temp gauge
- 99 jetta overheating
- ac compressor on 1999 jetta
- 01 jetta 1.8t,cel PO172 too rich,help
- strut bearing
- Cooling System 2003 Jetta
- Problems.. 98 Jetta doesn't start after rain, power loss, hesitation, no radio
- 1.8turbo replacement help
- wheels rims
- 2000 jetta crank sensor location
- major studdering and wont rev up
- need help code 1426
- 01 jetta reverse problem
- engine problems
- Help with 1997 jetta trek please!
- 03 jetta primary coil malfu.
- 98 jetta 2.0 M/T stalls 3500-4200 RPM
- 09 Jetta Gt getting hot
- overheating,
- Jetta Turbo Removal
- tranny trouble
- oil for jetta 1.8t
- 1997 Jetta Trek Fog Lights
- jetta 1.8t
- 1999 Jetta (automatic)Trouble Starting
- longtime lurker first time poster...help(real bad idle)
- 97 jetta gl only starts when pushed
- Fuel pump retaining ring?
- Gas gauge!!
- '97 Jetta Trek Oil Light Issues
- 2003 Jetta cooland light(red) on
- How do I identify the difference between a GL and GLS 200 Jetta?
- 99 trunk wont open
- '00 jetta..engine light...computer not working!!!
- Oxygen Sensor Problems
- Loose struts 2000 Jetta GLS 2.0....more gremlins!
- 2000 Jetta GLS 2.0 coolant loss.
- motor shaking at low regime (cold and warm motor)
- Jetta Turbo whine
- Looking For A Coil Over Kit For Reasonable Price
- 2nd Gear loss of power
- Low beams stopped working - at once
- 03' GLI #1 cylinder Misfire
- 97 jetta running out of coolant
- 98 Jetta TDI Headlight/Blower/Wiper Failure
- CODE P0103 Please Help ME!!!
- 02 VW Jetta 1.8T water pump problems
- o3' Jetta Starting Problem
- 97 jetta GT wont start
- 2003 jetta temp gauge
- 98 GLS Power window problems
- 99 jetta 1.9 tdi
- Relay Identification 2001 Jetta VR6
- trans problem
- 2001 jetta 1.8t epc light problems
- my engine light came on!!
- driver door, 2000 vr6
- 2000 Jetta Strange Window Problem
- 1997 Jetta - unpredictable starting especially when wet
- 2000 vr6 cooling fans not working, HELP
- 1997 jetta hard starting?
- AC question
- 2003 jetta GLS factory stereo to aftermarket stereo question
- 03 jetta cruise control
- 2003 Jetta 2.0 poss. no overdrive
- 2003 Jetta Headlight problem.
- Cruise control, Instrument cluster 97 Jetta
- 2000 Jetta brake lights stuck on!
- 2001 Jetta- rear tires feel chocked
- 1997 Jetta Alarm Issue
- 2003 Jetta 1.8T overheating
- '97 Jetta blowing out oil filter gasket
- Anyone know where is the lock-up solenoid on 98 Jetta?
- Transmission Troubles
- Serpentine Belt on a Jetta V6
- How many lugs on an '01 Jetta?
- Pls. help. '97 Jetta Low Oil Pressure
- 99 jetta stuck in park
- 1999 Jetta oil pan and ignition replacement
- 99.5 jetta (p0748,P0763,p0768)
- Exhaust Manifold Gasket
- HELP- 2001 Jetta engine misfire
- 2001 Jetta Radio Upgrade Question
- 02 jetta 2.0 turbo...
- '02 Jetta TDI - MIL light and code 1705A
- 99 Jetta front window
- '99 Crankshaft Problems (simple question, please help!)
- 2003 Jetta can't shift out of park
- Bora V5 Engine oil mistakenly put in coolant reservoir.
- 1999 VR6 RPMing high??
- 2000 VR6 Keyless entry, Windows, and dome lights dead
- Aftermarket/DIY Questions 1999 Jetta Wolfsburgh 2.0L
- '01 Jetta Dash light problems
- Disabling the front blinker.
- Basic aftermarket Stereo Install question...
- Speaker static
- help w/ the jetta "curse"
- electric water pump
- my 2000 jetta makes a lound screaching sort of noise everytime i start it.....
- 97 jetta front end ?
- 97 Jetta wont start
- Jetta 99 GL 2.0L Transmition Stick Problem
- engine won't crank after locking keys in car
- 2000 Jetta GLS problem, please help!
- '03 jetta 1.8t rough running first started
- Jetta Mk4 (or most everyother car) Headlight restoration project
- 2000 Jetta Engine Scream
- 1997 jetta "trek" starting problems?
- 02 Jetta GLS W/57K issues
- '99 Jetta Alarm problems
- 2003 fuel pump?
- 1999 Jetta GL lens filler panel
- 97 Jetta, Brake lights shorting post-accident
- Help replacing Engine Speed Sensor 1999 2.0l
- 98 jetta electric problems
- 97 jetta trek running sluggish
- CD Player on 2003 Jetta Wagon GL 2.00
- How to reset an airbag light for 97 jetta GL
- Jetta 02 1.8T
- 98 Jetta 2.0, Coolant light question
- lug nuts
- 97' Jetta Starter
- 97 jetta 5 spd trans pushrod bushing
- 2003 1.8t Lost Power Suddenly
- 1997 Vw Jetta 2.0 Coolant Flow
- All you Jetta Guru's Please Help
- 2000 VR6 jetta/bora edition
- Buying a jetta
- Engine oil
- looking for vw sdi parts
- 2002 vw jetta 1.8 turbo
- Cold engine = stalls Hot engine = rough idle
- timing setting on a vw jetta 2003 ALH
- 98 Jetta CEL
- 2001 Jetta RPM Fluctuating
- i want my jetta turbo
- MIL Light On
- Engine speed suddenly drops-code P1580?
- Interior Question! can't find anywhere!!
- 99 Vw Jetta Bodykit Bumper
- monsoon stereo
- Volkswagen Exhaust
- 2002 Jetta GLS transmission problems
- 1998 VW Jetta TDI idles rough
- Jetta Rally Car
- Passenger door wont open!!!
- Electric Problem,computer,ignition????
- Trans computer change?
- Radio Installation Problem
- 97 Jetta GL - Battery can't keep a charge?
- 2000 Jetta Code P0341
- 98 jetta airbag sensor location?
- '02 Jetta 1.8T front end shake
- 1999 VW JETTA Trans problem
- Somethings wrong here!!!
- my blinker is going crazy
- major problem with an 01 Jetta
- 2002 Jetta
- auxiliary input...?
- car alarms
- 97 jetta starter... same part for manual & automatic?
- 2003 BLACK TINTED LIGHTS help
- Distrbutor Cap Retention clip problem
- help
- top brake light affected by main light switch
- Power Window/Door lock Problems 99.5 Jetta
- boostin my GF VR6
- 98 Jetta III GLX Transmission Issues
- Need help identifying part 02 Jetta
- Conic air flow filter
- strap a turbo on a Mk4 2.0L GLS?
- 1999.5 GLS Clutch Slipping
- ASR light flashing
- vr6 coolant temp sensor location
- Aeg/aba?
- 02 Jetta TDI - won't start
- ashtray/aux power light needs replaced???
- Need web site that will show tires and rims on vehicle
- 2002 Jetta VR6 - Engine Code
- 2000 Jetta Overheats!
- Window regulators on the 97 vento
- No juice to ignition or power windows
- 2000 Jetta remote fuel filler door won't latch.
- HELP! major problems with my jetta.. what should i do?
- 97 Jetta Check Battery
- 2002 Jetta 77K miles Engine fails
- 2000 2.0 timing tensioner old or new style
- 01 jetta engine problem
- 2003 volkswagen jetta vr6 12valve 1/4 mile stock?
- NEUSPEED chip ????
- jetta lighting
- 99 (New Body) Jetta Stalling problem.. No Check engine light.
- Trunk latch problem
- '98 VW Jetta GL
- What do i need to do?
- new turbo or Blow-off valve and intercooler?
- CD Changer
- 01 JETTA 1.8T - Stalls @ stops
- 97 Jetta GLX WON'T START!!! Alarm issues???
- 1999 Jetta Vr6 Radio Question???
- Intermittent Radio
- 2000 Jetta Radiator Removal
- Rear Brakes
- 2001 Jetta TDI A/C problem
- 2000 jetta w/ code 1582
- 99.5 jetta cooling fans inoperative
- Psycho Temp Gauge
- Remote
- Jetta 2000 1.8T no forward or reverse when hot
- '99 Jetta III Idle Adaptation at Limit
