Our Community is 705,000 Strong. Join Us.
View Full Version : '97 - '03
Pages : 1 2 3 4 5 [6] 7
  1. 2001 Jetta Blinker problem
  2. '97 Jetta Won't Start (not battery or starter)
  3. horse powers
  4. 97 jetta gls
  5. 2001 ABS light??
  6. Transmission Rebuild Kit
  7. 2000 Jetta - How to Change battery
  8. 99 VR6 Water pump Going?
  9. 98 Jetta GLX VR6
  10. 2002 TDI vibration/shuddering = timing belt?
  11. 1999 Jetta Wolfsburg
  12. Overheating
  13. Wanted
  14. Stereo Fuse
  15. Starter Not Working in COLD weather
  16. please please help me (98 jetta audio)
  17. 1999.5 jetta radio removal/install help
  18. Jetta IV Axle Replacement
  19. 1999.5 jetta aftermarket intake help
  20. jetta 2000 trunk light switch
  21. NO START - (Not Battery)
  22. 00 GLS-problems shifting into 1st, 3rd
  23. parking brake light stays on, headlights won't work!
  24. 1999.5 jetta 2.0.. pleaseeeee help
  25. RPMs varying - 1998 Jetta
  26. Remote and Key Help
  27. 99 "new" jetta has massive problems!
  28. 2001 Jetta TDI problem with check engine light
  29. 2000 jetta Drivetrain problem, ????
  30. 99 headlight replacement
  31. Turn Signal Problem
  32. Jetta 2000 Airbag Warning light on
  33. Source for online diagrams/parts fiche?
  34. How do I a change vw remote battery?
  35. transmission slams into gear
  36. A/c Ka Boom !
  37. tail lights for '97 Jetta
  38. Help!! Rear Light Wiring on 2001 Jetta
  39. 2000 VR6 Jetta-starting & light problems
  40. 2002 jetta radio stopped working
  41. 97 Jetta won't start
  42. Brake Lights & Fuses--2001 Jetta
  43. Door lock and unlocks while driving
  44. 2000 2.0L is it worth the $ to change to syn
  45. 97 Jetta Spark Plugs not fireing
  46. '98 Jetta GT won't start....
  47. 2000 jetta: brake warning light with beep
  48. 01 1.8T Jetta startup noise
  49. 98 Jetta Alarm system ... HELP!!
  50. 2000 jetta dying
  51. 2000 jetta making loud humming noise
  52. What is that smell????????????
  53. 1997 VW Jetta GLS Questions
  54. Lost engine or Clutch
  55. '97 Jetta won't start!
  56. '98 VW Jetta GLX VR6
  57. Jetta rear wheel bearings
  58. 98 GLS Heated Seats-which fuse?
  59. trip and clock keeps resetting???
  60. what is the 1.8t
  61. killing Jetta IV Auto locks?
  62. Out of my realm but am asking for help on behalf of someon else.
  63. Where is the Airbag spring unit located?
  64. Any way to find the key codes for a Mk III?
  65. Radio is now into "SAFE" mode
  66. brake noise when backing up
  67. automatic transmission - weird shifts
  68. valve train noise (clatter)
  69. intake noise (growl)
  70. thanks for not helping...you guys are the best
  71. 98 Jetta door lock problem
  72. Fuse Location
  73. Ordering parts
  74. Spark plug wires
  75. blinker
  76. Replacing the Monsoon head unit
  77. installing radio + rf modulator/1998 jetta
  78. *~engine mileage~*
  79. 98 valves or timing belt?
  80. Trouble shifting
  81. MK3 Jetta FOR SALE
  82. Technical questions, troubleshooting etc.
  83. Jetta RPM's running high. PLEASE HELP!!
  84. TDI Broken Timing Belt = Warped Cylinder?
  85. check engine lihgt problem
  86. Block Heater options 1999 mk IV
  87. Grease on Doors
  88. Rough Idle when raining 1999
  89. 98 Jetta passenger door won't open...
  90. Catback Question
  91. Remote Starter Help Please
  92. i hate my clutch
  93. Tuning up
  94. 2002 Jetta GLS Tiptronic Tranny Problem
  95. gas gauge and spedometer dropout
  96. 98 Jetta Starting Dilemma
  97. Jetta 2000 Radio Wiring with DVD question
  98. Help 2000 Jetta Running Through Gas Like There's No Tomorrow
  99. 98 Jetta electrical problems?
  100. VR6 01 Turbo??
  101. EMERGENCY HELP!!! 2002 jetta tail lights fuse
  102. 97 Jetta Starting Problem
  103. Jetta 99' Jerks after acceleration
  104. Check engine light 98 Jetta TDI
  105. cruse control wont set
  106. 2002 red Jetta GLS for sale VW certified
  107. I want to disable my alarm (97 Jetta GLS)
  108. 2001 Jetta VR6 Code issues.....
  109. Newbie, weird electrical problem Jetta 2000
  110. Timing Belt Jetta 99
  111. 2001 Jetta - Lower Body Dents
  112. 2001 Jetta shifting adjustment problem
  113. Jetta 97 2.0, wont start
  114. 2000 JettaGL Coolant light on when cold
  115. 1998 Jetta GLS alarm module
  116. 97 Jetta GL - Hard Start when Cold
  117. 2002 jetta electrical
  118. Noise from Oil Pump on 97 VR6??
  119. 2003 Power steering
  120. 97 Jetta Interior Lights
  121. 98 glx auto transmission
  122. 1998 Jetta starting problem.
  123. Catalytic Converter Problem Jetta 99
  124. 2002 1.8t jetta starting problems
  125. 97 Jetta GLS - Window Regulators
  126. 2001 Jetta GLS smells like a sewer
  127. 2000 Jetta fuel and performance problems
  128. Jetta 97 GLX ,engine rattle, need help
  129. 02 1.8T upgrades
  130. 2000 Jetta problems
  131. 98 jetta no rain start
  132. 98 US Jetta no start
  133. 98 Jetta issue with wipers and running/headlights
  134. wanna get a 97 VR6. good idea?
  135. 2003 GLS starting problems
  136. 01 jetta doesn't turn over, interior lights flash when trying
  137. 98 Jetta TDI Keeps Stalling
  138. WTB:Wiper Arm Assembly(99 Jetta)
  139. 2002 Jetta DRL disabling
  140. whats the top speed of a '98 vr6 jetta glx?
  141. Spark Plug Problem 99.5 jetta 2.0
  142. 97 jetta 2.0 want start ignition problems
  143. 97 Jetta GLS about to buy Need Advice Please
  144. '99 Jetta interior lighting Issue
  145. Help - strange (ringing bell) sound from my 2001 VR6 Jetta
  146. 200 Jetta:How to turn off check engine light
  147. 98 Jetta Clutch Issues(newbie)
  148. '02 Jetta Engine Codes - HELP
  149. 99 jetta rear door window removal
  150. 97 jette gls help Please
  151. Alarm light in 2000 jetta
  152. 99 Jetta How to remove cover to access wiper moto?r
  153. 98 jetta gt NO START
  154. Bucking/Hesitation Problem in 2002 Jetta GLS
  155. '01 Jetta Water Leak, Cabin, Passenger Side
  156. 2001 jetta 1.8T having engine probelms
  157. 2001 jetta exhaust manifold gasket
  158. 1997 Jetta GT automatic; worth it?
  159. Planning to buy a Jetta 99
  160. Jetta Battery Replacement '02
  161. 98 Jetta radio problem
  162. Performance upgrades 03 TDI Jetta
  163. 99 jetta vr6 tranny
  164. Jetta 2000 Starting problems
  165. 99 Jetta problem with coolant sensor
  166. Oil leak Problem on my jetta carat 1989
  167. Parting out a 99 Jetta
  168. 1997 Gt Stutters
  169. need a 97 jetta lll side skirt trim any for sale?
  170. 97 jetta cooling fans
  171. 2000 Jetta cd changer install
  172. 2001 Jetta 2.0: Check Engine Light and temp gauge
  173. switching shifter for my 2001 1.8t (manual)
  174. 2001 Jetta front Blinker
  175. removing 2002 Jetta door panels
  176. 1.8 8v to a 2.0 16v or a VR6
  177. upgrading stock 97 Jetta
  178. 2000 jetta alarm activates when I open door w/valet key
  179. 01 Jetta GLow Plug Light
  180. Torque Steering: 2001 Jetta
  181. 2000 1.8t wont start
  182. Headers for my 99 Jetta!!! pls help
  183. 2000 VR6 EPC light on, no brake lights, no cruise
  184. 1997 jetta gt Hesitations
  185. Turn signal clicker on '02 Jetta
  186. 00 Jetta crunching/creaking sound in front
  187. 2001 Jetta Seat Belts
  188. 97 jetta ingnition/starting problems....
  189. need big help with a 98 jetta
  190. 97 jetta gl door locks broken & alam going off... help!
  191. Power lock problem on 99 Jetta
  192. Just got 97 VR6, any suggestions for modifications?
  193. just got 99 need to know some stuff!!!
  194. 99's exhaust might have hole??
  195. 2000 Jetta manual
  196. 99 Jetta Won't Start When Wet!
  197. 2000 Jetta Blown Fuse, windows, trunk,sunroof, a/c
  198. performance upgrade for a 2.0 Jetta (2000)
  199. Changing Thermostat 1997 VW Passat
  200. Need some help on 97 jetta gls!!
  201. 1999 Jetta Camshaft Specs and ID NEEDED!
  202. 97 Jetta Fuse
  203. 97 door locks delay
  204. 97 Jetta GL Problems
  205. 98 Jetta Factory Radio Problems
  206. Jetta 2000 a/c fuse
  207. 2001 1.8T (Auto) acceleration problem
  208. 2002 vr6 Jetta glx coolant question
  209. 98 Jetta: Rattling/grinding sound
  210. 98 Jetta Cruise Control
  211. 98 Jetta 2.0 idle problems from A/C
  212. 2000 Jetta question
  213. 2000 Jetta engine drivebelt (serpentine)
  214. 99 jetta battery problems
  215. '02 Jetta: EPC Light
  216. 2001 Jetta GLX for sale
  217. 2001 VR6 Stress!!!
  218. 97 jetta- im new
  219. 1999 Jetta Speedometer Reads 10 MPH Slow
  220. 03 jetta rear window sounds
  221. lights for a 1998 jetta
  222. 1999 Jetta Door Panel
  223. jetta 2000 vr6
  224. 97 jetta products question
  225. 2000 Jetta hesitation at acceleration
  226. 2000 Jetta GL - Acceleration prob's in all gears
  227. 97 jetta have to press gas to start and idle problem
  228. 98 Jetta slow startinf
  229. new 03 vr6 24v
  230. I want to swap my 2.0l with a 1.8T, but I don't know where to start.
  231. 98 jetta... will not start
  232. 97 2.0L 8 valve upgrades
  233. 1.8t swap
  234. 2003 Jetta Speakers
  235. Help 97 jetta gl
  236. Thinking about buying 97 VR6
  237. 1999 Jetta: Armrest
  238. 98 GLX Idle Problem
  239. '97 Jetta won't start
  240. '99 Jetta TDI: Cutting Off
  241. 98 jetta problems
  242. window popped today. 00 jetta vr6
  243. 99 Jetta: overheating
  244. 98 GLX VR6 idling high adn fan turning on? ideas?
  245. 2000-2002 jetta wagon ratings
  246. 2000 Jetta Radio
  247. 98 Jetta: Water leakage
  248. 98 Jetta: Dome light
  249. '98 Jetta: Window regulator or motor?
  250. 2001 Jetta rear brakes
