View Full Version : '97 - '03
- What Year was TDI introduced???
- smell of gas under the car's bonnet
- 2001 jetta vr6 auto repairable/for parts
- Loping Idle/CEL Mystery
- Sweet Smell after driving 98 jetta vr6
- 1999 Jetta wolfsberg 4 banger ( clean just modified )
- Considering Purchase
- looking for TDI
- Jette 2000 GLX licence plate lights
- 98 jetta gl good deal or lemon?
- Misfiring at idle and driving and throws a CEL
- Rear Bearings
- diesel engine
- 00 Jetta VR6 for sale
- 2001 Jetta Engine Swap
- idle problem
- Forsale: gren jetta spoiler
- wet tail light 97
- 2001 Jetta needs help.
- 2002 Jetta For Sale - 2 liter, New Bearings, New Clutch
- Rear brakes 2001 jetta
- jetta ac
- Aftermarket part webpage for 98 glx vr6??
- Too hard for vw techs, nobody knows how to change shiftlock solenoid
- how to change gearshift solenoid on automatic 98 jetta??
- CAT Problem
- 97 Jetta GLS
- New Appearance
- 02 1.8T Check Engine CODE 0133
- 97 jetta no start, any ideas, please help.
- need some nozzles for my TDI
- Gas Cap** HELP ME!!
- Frozen Door locks?
- 1.6 bora won't start
- (small leak)
- Low idle after starter replacement?
- throttle body 99 jetta..please help
- 01 jetta diagnostic problems
- check engine sign 01 jetta
- Idle problems after taking on H2O
- DOH!!!!Wiring? Alarm engages while driving
- Wiring? Alarm engages while driving
- 97 jetta rough idle
- p0420 after new cat, o2, and maf
- car won't start.....think it's the alarm
- 03 Jetta Black Needs Mirror
- Another 97 Jetta no start
- Dashboard lighting
- no tail lights
- jetta wont start in cold
- 99' jetta 2.0L GLS engine light on
- How do I fix: Error P1116 O2 Sensor Heater Circ.,Bank1-Sensor1 Open
- Error P1116 O2 Sensor Heater Circ.,Bank1-Sensor1 Open
- 00 Jetta radio no power
- Tranmission fluid change time
- License Plate Bolts
- Wheel Bearing
- can anyone help me
- New owner needs help
- 1997 jetta "trek" window problem
- 1997 jetta "trek"
- Transmission Swap
- Heating and Air Control Light OUT
- 97jetta Won't Start
- headlights
- Exhaust smell in cabin
- window out of track
- 00 vr6, grinding noise in reverse
- airbag light on
- My Car is having serious problems someone please help!!!
- What size socket to remove CV shaft???
- 2000 GLX epc light and engine workshop message
- trouble code
- only fiberglass body kits for the jetta?
- 99 won't start, now cuts out
- VW Bora 2002 - EPC light?
- turbo 2.0
- VW Jetta GLS Alarm
- Water Leak, Drivers side 02 Jetta
- Side Mirror Fuse
- Winter tread for 1997 Jetta Gls 2.0 automatic
- alarm light and head light problems
- Help, I keep replacing the same parts
- '02 Jetta 1.8T Transmission Problems
- 97 jetta power loss
- lowering 2 inches?
- 1998 Jetta GL
- service manual?
- Timing belt
- Need your opinion
- Best Jetta 4 Making HP and TQ ?
- 98 Jetta door speakers
- problem with 2000 stopping while driving
- power windows in 99 jetta
- TDI has a knock
- Jetta has to go asap.
- I love my car "but"
- 2000 Jetta 2.0 Camshaft Position Sensor
- 99 Jetta hesitates 1st start of day
- Timing Belt Question
- headlight dimensions
- How to chirp the tires
- 2003 front brakes- any comments
- Fan will not work.
- Mystery - need help starting Jetta
- Slow power windows
- 97 jetta gl fuse problem
- Trouble with my door lock.
- rattling sound when accelerating
- Jetta must go!!!!!!
- 2002 Jetta Stereo Head Unit Replacement
- Most Mileage On An AEG Coded Engine.
- water leaking out of exhaust pipe
- Wolfsbourg for sale!
- E-Brake problems
- 99.5 manual tranny problems
- Broken Passenger Mirror
- 2000 Jetts coolant temp sensor
- Check engine light question
- VW bora brake pedal travel
- Hi everyone..first time posting, problem w/ jetta
- 2003 1.8T mods
- 98 Jetta diagnostic code p0422
- 97 Jetta VR6 Misfiring
- 03' Jetta VR6 for sale
- 2001 Passat Garage Door Opner
- Cooling Fans 97Jetta GT HELP!!!
- front door speaker problems (multiple)
- Removing head rest(serious)
- '99 jetta water temp light flashing
- knocking sound
- 1999-2000 Jetta's
- ignition wire ?s
- 2000 Alternator Removal
- 1998 Electical/Horn Issue
- shifting at high rpms
- Dash light
- p1255 ect sensor
- 97 Jetta won't start, I have spark though
- Having problems finding...
- reverse gear blues
- Have i been ripped off? PLZ HELP
- Timing OFF?
- Need Jetta Advice
- Timing Belt
- Lightning Bolt Warning?
- 2002 Jetta Temp Sensor
- timing belt
- 2001 brake pad light
- Performance clutches
- tail light / bulb is out 2002 Jetta
- PLease Help MEEE!!!!!!!!!!!! jetta 97
- Something slipped down behind my dashboard - help
- 2nd gear not engaging sometimes
- VW Jetta A/C problem
- check engine light
- Clunking sound when turning steering wheel
- fan control module test ?
- 01 Wolfsbourg Jetta for sale!!
- 01 TDI, Problem with Reverse
- Major Alarm Issue
- 97 Jetta Transmission Problems
- 97 Jetta Jazz transmission issue
- 99 vw jetta rpm's
- jetta overheating
- BOV on automatic?
- Springs and Wheels
- 1999 Jetta (old body) P0506 Fault code
- 2000 jetta overheating
- any ideas??
- can I put a 1989 1.8L in a 1998 jeta 2.0
- P0411 error code
- 00 vr6 air fuel problem
- Audi S4 Engine Swap??
- Dash and Alarm Electrical Problems
- 97 Jetta quits running
- 1997 VW Jetta 2.0 engine question
- lighting questions.
- 02 Jetta Transmission
- buying 96-98 jetta....what to look for?
- Turbo kits
- What in the hell
- 2002 jetta radio woes
- turn signal clicking
- 97 Diesel has "hit the wall"
- '01 GLS 2.0 Problems
- 1997 VW Jetta GLS Valve pan gasket
- VW diesel engines/vehicles
- key replacements
- Timing belt time!
- 97 jetta Fan takes long time to run
- AC Fan Switch only works on high
- Clearing CEL Code causing aftermarket stereo to stop working properley - Help!
- Changing the oil in a 2003 Jetta
- '98 Jetta will not run
- CV joint and Wheel Berring
- Jetta 2.0 GLS or Jetta 1.8T
- K&N AIR FILTERS
- P0506 Fault Code MK3 Jetta Help!!!!!
- Brake Master Cylinder Q: Is It Safe To...
- key replacement
- Abs Module Team. Help Guys!
- After Market Alarm install Help 1999 Jetta
- 2002 Jetta GLS jerks hard when comming to a stop.
- 1999.5 Jetta GLS
- Chip for 98 GLX
- 98 Jetta GLX wont start
- Stuck in 4th Gear
- 1997 Jetta Speedometer going out
- 2000 Jetta EPC?!!?
- 99 scratched winshield
- trunk wont open
- 1999 Jetta (old Body) STALLING OUT!!!!!HELP
- jetta headlamp & tail light installation
- Drivers side door switch
- 00 Jetta Glx Vr6 Show Car Lots Of Mods Low Miles Like New Immaculate Condition...
- Door lock Electrical connector removal
- AC problem 2000 VR6
- noise from belt area
- A bit of a water leak 2001 Jetta
- 98 Jetta GLS DS power window dropped
- I need some help
- transmission shifting weird
- jetta question
- '01 Jetta - Check Engine Light
- 2000 jetta cd player error
- Suspension / Springs Noise -
- clutch feels really loose
- 99 jetta overheating
- wolfsburg edition jetta
- Transmission not shifting like it should
- dome light and blinkers?
- Damsel in Distress '99 Jetta bogs down
- Over heating
- 2000 Jetta Radio Code
- Coolant Leak
- car dies out when driving
- making the 2.0L fly
- Replacing Headlight
- Squeeky rattle when clutch is engaging
- exhaust tone
- FS: 01' JETTA GLS $8,000 o.b.o.
- 02 Jetta 1.8T - When A/C on, clunk, powerloss, sometimes stalls
- blinker madness
- CD/tape failure
- stuck in park
- 1997 Jetta CEL
- stick shift question
- Help error 0411
