View Full Version : '91 - '96
Pages : [1] 2 3 4
  1. 96 Jetta GLS, 2.0L - burning coolant?
  2. Instrument Cluster Tricks..
  3. Disable DRLs?
  4. 95 jetta windshield wipers won't stop
  5. Anyone know about fuseboxes?
  6. Checking CEL Codes
  7. OEM Alarm System
  8. 96 Jetta engine lacks power. Fuel pump?
  9. 96 Jetta fuse box sparked and smoked. Now problems. Plz Help.
  10. 96 Jetta not getting fuel
  11. 96 Jetta stalling out
  12. Originally a Radiator Fan Problem, Now Car Won't Start
  13. Fuses or relay problem.
  14. Heater leaks anti freeze. how do i aproach it?
  15. 1994 jetta 2.0 stalling out
  16. 1996 Jetta overheating..no coolant loss?
  17. 94 jetta2.0 no spark cel on
  18. 95 Jetta bog down
  19. 94JettaGL heat-related bogging/hesitation
  20. How to put the starter back.
  21. Help quick. 96 Jetta wont start. Seems like electricity problem
  22. 96 jetta, runs rough with alternator plugged in, unplugged its great.
  23. If your clutch pedal ever goes to the floor
  24. 91 Jetta Glow Plugs
  25. Clicking when decelerate
  26. 91 jetta 1.8 liter starts and dies about 3 secs later
  27. 1995 Jetta VR6 won't start.. HELP!!!
  28. 94 Jetta GL Crank, won't start, reading code 1-0-0-2!!!
  29. 1994 Jetta III won't start
  30. 95 Jetta GL AWD conversion kit
  31. 95 Jetta Gas Gauge Problem
  32. 91 jetta gli intermittent lossofpower
  33. 1991 vw jetta
  34. 91 jetta sparks on plugs only when turn key to on
  35. Electrics flickered, engine backfired, no start
  36. radio speaker not working
  37. Vw Mk3 2.0 Vw
  38. leak down test
  39. coolant in valve cover, what to do?
  40. 1995 2.2 jetta gls
  41. heater core, engine problem, smoke plz help
  42. 96 jetta trek won't fire.....results...fyi...comments?
  43. 96 jetta trek 2.0 won't fire...what i know so far...please
  44. OBD 2 codes need help
  45. 96 Jetta with 2.0 5sp Oil everywhere
  46. Sunroof Electrical 95 Jetta
  47. 92 VW Jetta;starting/running problem
  48. 95 vr jetta
  49. problems starting
  50. 1994 Jetta alarm problems Please HELP!!
  51. 85-92 Jetta, golf service manual
  52. Delayed start when warm
  53. 1996 jetta gls, auto trans cross reference or convering to 5 speed(hard to do??)
  54. Turn the key, get no crank... Power to everything else...
  55. '91 Jetta Performance Ideas?
  56. 96 jetta dies on acceleration
  57. Big fule consumption and jerks at higher speed/Rpm.
  58. jetta 96 GLS no spark plz need help
  59. idol control valve 1994 jetta 2.0
  60. 1996 Jetta Tranny problem
  61. vento heater problems
  62. 94Jetta wipers&Fan stop when wet
  63. '94 VW Jetta III unknown part name
  64. Big Fuel Cons. and hard to start I need Advise
  65. 1994 Jetta III stuttering/bumping 35+ MPH
  66. 95' jetta auto not shifting properly revs high
  67. wipers stay on
  68. 91 Jetta 1.8 died. Scrapping
  69. 94 jetta-Blink Code 4431?
  70. 96 Jetta Won't Start, Smells like Gas
  71. my 96 jetta is getting too much fuel
  72. Noise from trunk
  73. A/C o-rings
  74. 1992 gas Jetta engine problems.
  75. heater core inlet pipe cracked
  76. 1996 Jetta GL clutch
  77. 94 jetta w/ replaced motor...
  78. Replaced Starter in 96 Jetta. Still won't crank
  79. Jetta Trunk Leak 1992
  80. 94 Jetta Shifter
  81. 1995 VW Engine Replacement/Overhaul?
  82. 92 jetta 1.8 SOHC questions
  83. 93 Jetta/Vento (UK) overheating
  84. I cant get my dash out 92 Jetta
  85. 92 Jetta 1.8L not starting
  86. 96 jetta 2l code p0135
  87. Alt. problems
  88. 96 Jetta Wont start n either do i
  89. 96 jetta
  90. 96 jetta pops out of reverse
  91. 96 jetta gets "engine smell' in cabin
  92. 91 jetta diesel timing belt
  93. 1991 jetta timing marks
  94. 1991 jetta timing broke, replaced now won't start!
  95. 94 jetta 2.0 hall sender help
  96. MK2 starting problem
  97. Clutch adjustment
  98. EVAP system and ODB code ?
  99. 94 Head lights
  100. 95 Jetta Key gets stuck
  101. head bolts
  102. 1994 jetta engine 2.0
  103. 94 jetta no start
  104. 1994 jetta mutiple problems and no start
  105. my wreck
  106. Brakes
  107. Spark plug wires.
  108. 95 Jetta Blower Motor
  109. 96 Jetta OBD2 102 and 510
  110. Have 3 blink codes on a 94 jetta..help please
  111. Vehcile speed sensor
  112. '92 gas jetta accelerates fine, jerks at 2800-3200rpm
  113. 91 jetta needs to be timed
  114. oxygen sensor location 96 jetta b1s1...
  115. Broken timing belt, interference engine--mechanical novice here
  116. '91 Jetta...idling high.
  117. 95 Jetta III (Need Help)
  118. Jetta service manual
  119. intermitent emission light
  120. 96 Jetta Airbag Light is on, need HELP !!
  121. 91 Jetta Overheats & NO Dashlights
  122. timing belt constantly breaks
  123. 96 vw jetta vr6 temp light on and smoke coming from a/c vents
  124. 95'jetta stalls in gear when starting up
  125. Somebody Help About To Junk This Car.
  126. I drive my kids...please help.
  127. Help: 95' Jetta Engine oil leak
  128. Gear ratio on 91 jetta GL
  129. 94 Jetta 3 Coil burnt wire?????
  130. 96 jetta stumble when accelerate, any ideas
  131. 92 jetta starts then stops right away
  132. 95 Jetta With idle and oil light problem
  133. Clutch? problem on 91 jetta GL
  134. problems with 96 jetta gl volkswagon alarm
  135. can i turbo my 92 jetta?
  136. 96 jetta
  137. Obdii Code 0440 , 0137
  138. Need Some Answers Please!!!
  139. Need Some major help!!
  140. 1992 Jetta Oil Alarm Buzzer
  141. 95 jetta no spark
  142. 95 jetta dash board
  143. 95 jetta dash board
  144. fuel pump fuse
  145. 96 Jetta Power Locks
  146. 95 jetta Idling Problem!
  147. '96 Idle Problems when A/C is on
  148. Thermostat
  149. Jetta Refrigerant Recharge: Please Help
  150. 1995 Jetta overheating
  151. car won't start ? ignition
  152. Obd Ii P0341
  153. 96 GLX Cruise Control Problems
  154. 1995 Jetta Blower Motor
  155. Trouble after some repairs. Doug help me!
  156. Jetta wolf cranks but wont start
  157. Transmission cv flange removal
  158. jetta
  159. Need help on my 96 jetta VR4 (manual)
  160. lost of power 95 jetta
  161. help!
  162. 96 Vw Jetta
  163. 1995 jetta 2.0
  164. fuel pump gone bad?
  165. 96 jetta gls trouble idling and running
  166. 96 jetta 2.0 normal operating temp
  167. 95 jetta III manual
  168. Oil indicator light
  169. Fuel Pressure Test Point?
  170. 96 Jetta Help!
  171. Torquing the head bolts...
  172. 96 Jetta Hiccups when driving and stalls when starting, sometimes...
  173. Looking for new I.P. and injectors 94 1.9TD
  174. intrument cluster help
  175. i got a problem
  176. help!91 automatic 3 speed jetta doesnt shift into third gear
  177. Smoke from steering column on 96 GL
  178. 92 Jetta front end noise
  179. 92 Jetta vapor locking?
  180. 2.0 Jetta Timing Belt?? Cam Position Sensor code.. And car wont start!! Help!!
  181. Clutch jumping
  182. 1996 Jetta GLS rear speaker replacement
  183. 1994 Jetta GLS Electrical Problems!
  184. 96 Jetta losing acceleration
  185. Rough Idle Cold Start. Help!
  186. 96 jetta vr6
  187. 96 Jetta - Blow by
  188. 96 Jetta, Is dead..HELP!!
  189. 92 GL problems
  190. 95 Jetta sensor temperature light
  191. 95 Jetta-PLEASE HELP-Loud Pop When Started in Cold Weather
  192. '95 Jetta 2.0 check engine light, no codes
  193. Oil Pressure Light & Beeping Sound...
  194. MK2 and MK3
  195. Adjusting Diesel Injection Pump
  196. Where is the programming button?
  197. 95 jetta runs rich on first start up
  198. looking for Wings West 4 piece lip kit!!!!!
  199. Help... 96 jetta won't shut off
  200. Jerking Jetta!!!!
  201. 94 Jetta GL- Heater Core!!!
  202. 96 Jetta alarm help!
  203. Auto aftermarket parts
  204. Reuse of bearing?
  205. No Spark/No Fuel Tried Everything
  206. 94 jetta gear shift indicator light in dash will not go on
  207. '94 Jetta -- Shakes & Shutters
  208. spark plug removal
  209. 94 Jetta III GL antenna
  210. Check engine light/oil light
  211. Reprogramming radio
  212. Help
  213. Help
  214. Distributor Cap Keeps Carboning Up
  215. 92 Jetta starter issues Version 2.0
  216. check engine light
  217. 95 jetta transmission shift problems
  218. Engine Build!
  219. Head removal
  220. No Heat :(
  221. Speedo and Tach
  222. 1994 Jeta III
  223. Need Help!
  224. MkIII Jetta Auto Trans
  225. Valve Cover gasket
  226. FYI on blinker problem
  227. car buying help sought
  228. 94 jetta stereo wiring
  229. 96 Jetta GL clutch cable
  230. lights flickering
  231. 96 jetta problem????
  232. 1991 jetta idle issue?
  233. 1996 jetta starting problems
  234. NA left fog light cover - help!!!!
  235. coolant leaking.....
  236. Cruise Control Problems
  237. Misfires - 2000 Jetta
  238. torque steer
  239. Transmission Problems
  240. Transmission Selector Lever Display will not light up
  241. Transmission problems!!!!!!!!!
  242. 95 jetta jerking need help!
  243. Selling shot 96 Jetta III GLS, needs engine
  244. exhaust bolts--catalytic converter
  245. just got a jetta and got a couple problems
  246. Head foglight and side markers
  247. 95 Jetta III Not Starting
  248. Jetta window/alarm
  249. 93 Jetta stuttering while driving and sometimes gas smell
  250. Runnin rich
