Our Community is 705,000 Strong. Join Us.
View Full Version : '91 - '96
Pages : [1] 2 3 4 5
  1. Jetta'01 Auto Turbo with SO MANY problems/codes!
  2. Car runs poorly when hot.
  3. 1996 jetta jerks after drivin for awhil
  4. 92 Jetta won't start HELP!!
  5. Check engine light on , help
  6. Starting problem
  7. questions..Coil & Distributer-Cap
  8. 96 Jetta ...Starting Problems
  9. Jetta tail lights not getting power
  10. 96 Jetta transmission whistle?
  11. 1996 Jetta. Hard Check engine light
  12. P1580 Code
  13. 1996 Jetta Vibrates in Reverse
  14. 94 Jetta only Goes Forward in Reverse
  15. 91' jetta installing electric window kit
  16. 95 jetta celebration edition
  17. Gears Slipping Out at Speed
  18. 92 jetta with idle problems when clutch is in, and acceleration issues
  19. part questions
  20. 92 Jetta Dash Issues
  21. Check Engine Light won't read/vacume leak
  22. Wheel Bearings
  23. Need help on air intake install
  24. water temp light blinking
  25. the famous "wont start" problem
  26. Need help with aftermarket component speaker install.
  27. problem with 94 jetta
  28. 92 Jetta 1.8
  29. Transmission speed sensor, don't have a clue.
  30. Abs question
  31. Alternator question, simple but don't know what's up.
  32. 92 jetta breaking alternator belts
  33. No Start After Timing Belt Change
  34. Distributor Bracket and O2 Wiring
  35. 94 Jetta fuel problem, no power to pump relay
  36. 94 glx Need help identifying parts
  37. code P1582 any ideas?
  38. AFS servicing on 92?
  39. 96 Jetta GLS, 2.0L - burning coolant?
  40. Instrument Cluster Tricks..
  41. Disable DRLs?
  42. 95 jetta windshield wipers won't stop
  43. Anyone know about fuseboxes?
  44. Checking CEL Codes
  45. OEM Alarm System
  46. 96 Jetta engine lacks power. Fuel pump?
  47. 96 Jetta fuse box sparked and smoked. Now problems. Plz Help.
  48. 96 Jetta not getting fuel
  49. 96 Jetta stalling out
  50. Originally a Radiator Fan Problem, Now Car Won't Start
  51. Fuses or relay problem.
  52. Heater leaks anti freeze. how do i aproach it?
  53. 1994 jetta 2.0 stalling out
  54. 1996 Jetta overheating..no coolant loss?
  55. 94 jetta2.0 no spark cel on
  56. 95 Jetta bog down
  57. 94JettaGL heat-related bogging/hesitation
  58. How to put the starter back.
  59. Help quick. 96 Jetta wont start. Seems like electricity problem
  60. 96 jetta, runs rough with alternator plugged in, unplugged its great.
  61. If your clutch pedal ever goes to the floor
  62. 91 Jetta Glow Plugs
  63. Clicking when decelerate
  64. 91 jetta 1.8 liter starts and dies about 3 secs later
  65. 1995 Jetta VR6 won't start.. HELP!!!
  66. 94 Jetta GL Crank, won't start, reading code 1-0-0-2!!!
  67. 1994 Jetta III won't start
  68. 95 Jetta GL AWD conversion kit
  69. 95 Jetta Gas Gauge Problem
  70. 91 jetta gli intermittent lossofpower
  71. 1991 vw jetta
  72. 91 jetta sparks on plugs only when turn key to on
  73. Electrics flickered, engine backfired, no start
  74. radio speaker not working
  75. Vw Mk3 2.0 Vw
  76. leak down test
  77. coolant in valve cover, what to do?
  78. 1995 2.2 jetta gls
  79. heater core, engine problem, smoke plz help
  80. 96 jetta trek won't fire.....results...fyi...comments?
  81. 96 jetta trek 2.0 won't fire...what i know so far...please
  82. OBD 2 codes need help
  83. 96 Jetta with 2.0 5sp Oil everywhere
  84. Sunroof Electrical 95 Jetta
  85. 92 VW Jetta;starting/running problem
  86. 95 vr jetta
  87. problems starting
  88. 1994 Jetta alarm problems Please HELP!!
  89. 85-92 Jetta, golf service manual
  90. Delayed start when warm
  91. 1996 jetta gls, auto trans cross reference or convering to 5 speed(hard to do??)
  92. Turn the key, get no crank... Power to everything else...
  93. '91 Jetta Performance Ideas?
  94. 96 jetta dies on acceleration
  95. Big fule consumption and jerks at higher speed/Rpm.
  96. jetta 96 GLS no spark plz need help
  97. idol control valve 1994 jetta 2.0
  98. 1996 Jetta Tranny problem
  99. vento heater problems
  100. 94Jetta wipers&Fan stop when wet
  101. '94 VW Jetta III unknown part name
  102. Big Fuel Cons. and hard to start I need Advise
  103. 1994 Jetta III stuttering/bumping 35+ MPH
  104. 95' jetta auto not shifting properly revs high
  105. wipers stay on
  106. 91 Jetta 1.8 died. Scrapping
  107. 94 jetta-Blink Code 4431?
  108. 96 Jetta Won't Start, Smells like Gas
  109. my 96 jetta is getting too much fuel
  110. Noise from trunk
  111. A/C o-rings
  112. 1992 gas Jetta engine problems.
  113. heater core inlet pipe cracked
  114. 1996 Jetta GL clutch
  115. 94 jetta w/ replaced motor...
  116. Replaced Starter in 96 Jetta. Still won't crank
  117. Jetta Trunk Leak 1992
  118. 94 Jetta Shifter
  119. 1995 VW Engine Replacement/Overhaul?
  120. 92 jetta 1.8 SOHC questions
  121. 93 Jetta/Vento (UK) overheating
  122. I cant get my dash out 92 Jetta
  123. 92 Jetta 1.8L not starting
  124. 96 jetta 2l code p0135
  125. Alt. problems
  126. 96 Jetta Wont start n either do i
  127. 96 jetta
  128. 96 jetta pops out of reverse
  129. 96 jetta gets "engine smell' in cabin
  130. 91 jetta diesel timing belt
  131. 1991 jetta timing marks
  132. 1991 jetta timing broke, replaced now won't start!
  133. 94 jetta 2.0 hall sender help
  134. MK2 starting problem
  135. Clutch adjustment
  136. EVAP system and ODB code ?
  137. 94 Head lights
  138. 95 Jetta Key gets stuck
  139. head bolts
  140. 1994 jetta engine 2.0
  141. 94 jetta no start
  142. 1994 jetta mutiple problems and no start
  143. my wreck
  144. Brakes
  145. Spark plug wires.
  146. 95 Jetta Blower Motor
  147. 96 Jetta OBD2 102 and 510
  148. Have 3 blink codes on a 94 jetta..help please
  149. Vehcile speed sensor
  150. '92 gas jetta accelerates fine, jerks at 2800-3200rpm
  151. 91 jetta needs to be timed
  152. oxygen sensor location 96 jetta b1s1...
  153. Broken timing belt, interference engine--mechanical novice here
  154. '91 Jetta...idling high.
  155. 95 Jetta III (Need Help)
  156. Jetta service manual
  157. intermitent emission light
  158. 96 Jetta Airbag Light is on, need HELP !!
  159. 91 Jetta Overheats & NO Dashlights
  160. timing belt constantly breaks
  161. 96 vw jetta vr6 temp light on and smoke coming from a/c vents
  162. 95'jetta stalls in gear when starting up
  163. Somebody Help About To Junk This Car.
  164. I drive my kids...please help.
  165. Help: 95' Jetta Engine oil leak
  166. Gear ratio on 91 jetta GL
  167. 94 Jetta 3 Coil burnt wire?????
  168. 96 jetta stumble when accelerate, any ideas
  169. 92 jetta starts then stops right away
  170. 95 Jetta With idle and oil light problem
  171. Clutch? problem on 91 jetta GL
  172. problems with 96 jetta gl volkswagon alarm
  173. can i turbo my 92 jetta?
  174. 96 jetta
  175. Obdii Code 0440 , 0137
  176. Need Some Answers Please!!!
  177. Need Some major help!!
  178. 1992 Jetta Oil Alarm Buzzer
  179. 95 jetta no spark
  180. 95 jetta dash board
  181. 95 jetta dash board
  182. fuel pump fuse
  183. 96 Jetta Power Locks
  184. 95 jetta Idling Problem!
  185. '96 Idle Problems when A/C is on
  186. Thermostat
  187. Jetta Refrigerant Recharge: Please Help
  188. 1995 Jetta overheating
  189. car won't start ? ignition
  190. Obd Ii P0341
  191. 96 GLX Cruise Control Problems
  192. 1995 Jetta Blower Motor
  193. Trouble after some repairs. Doug help me!
  194. Jetta wolf cranks but wont start
  195. Transmission cv flange removal
  196. jetta
  197. Need help on my 96 jetta VR4 (manual)
  198. lost of power 95 jetta
  199. help!
  200. 96 Vw Jetta
  201. 1995 jetta 2.0
  202. fuel pump gone bad?
  203. 96 jetta gls trouble idling and running
  204. 96 jetta 2.0 normal operating temp
  205. 95 jetta III manual
  206. Oil indicator light
  207. Fuel Pressure Test Point?
  208. 96 Jetta Help!
  209. Torquing the head bolts...
  210. 96 Jetta Hiccups when driving and stalls when starting, sometimes...
  211. Looking for new I.P. and injectors 94 1.9TD
  212. intrument cluster help
  213. i got a problem
  214. help!91 automatic 3 speed jetta doesnt shift into third gear
  215. Smoke from steering column on 96 GL
  216. 92 Jetta front end noise
  217. 92 Jetta vapor locking?
  218. 2.0 Jetta Timing Belt?? Cam Position Sensor code.. And car wont start!! Help!!
  219. Clutch jumping
  220. 1996 Jetta GLS rear speaker replacement
  221. 1994 Jetta GLS Electrical Problems!
  222. 96 Jetta losing acceleration
  223. Rough Idle Cold Start. Help!
  224. 96 jetta vr6
  225. 96 Jetta - Blow by
  226. 96 Jetta, Is dead..HELP!!
  227. 92 GL problems
  228. 95 Jetta sensor temperature light
  229. 95 Jetta-PLEASE HELP-Loud Pop When Started in Cold Weather
  230. '95 Jetta 2.0 check engine light, no codes
  231. Oil Pressure Light & Beeping Sound...
  232. MK2 and MK3
  233. Adjusting Diesel Injection Pump
  234. Where is the programming button?
  235. 95 jetta runs rich on first start up
  236. looking for Wings West 4 piece lip kit!!!!!
  237. Help... 96 jetta won't shut off
  238. Jerking Jetta!!!!
  239. 94 Jetta GL- Heater Core!!!
  240. 96 Jetta alarm help!
  241. Auto aftermarket parts
  242. Reuse of bearing?
  243. No Spark/No Fuel Tried Everything
  244. 94 jetta gear shift indicator light in dash will not go on
  245. '94 Jetta -- Shakes & Shutters
  246. spark plug removal
  247. 94 Jetta III GL antenna
  248. Check engine light/oil light
  249. Reprogramming radio
  250. Help
