View Full Version : '91 - '96
Pages : 1 2 3 [4]
  1. help! car starts only with foot on gas
  2. 95 jetta lll check engine light under 3500 RPM
  3. need 96 Jetta help fasttt
  4. HELP!!! Dead car
  5. 92 jetta won't start
  6. advice on repairs
  7. How to remove door panel
  8. 96 Jetta brakes
  9. 96 Jetta stops working after 5mins
  10. '95 Jetta III GL won't start now
  11. 95 Jetta car alarm problems
  12. 94 Jetta Surges and spuders on acelleration
  13. Blinking Temp Light
  14. Heated Seats
  15. Signal Light
  16. single wiper at home modification..
  17. Starting Problems; 91 jetta.
  18. from 90 deisel to to 91 1.8 having tranny issues with cluth
  19. Turbo
  20. which muffler? [+pic]
  21. 95 Jetta III idle problem & missing once warm
  22. Help my jetta runs but lacks top end
  23. u-clamps that hold the front steering
  24. 96 Jetta Trek-CEL,Vacuum Prob??
  25. 1996 Jetta Trek Broken hood release cable
  26. '92 engine swap?
  27. 95 jetta stumbles going down the road
  28. 1994 jetta wiper problems
  29. dash lights
  30. broken glass
  31. 95 Jetta NO START!! Please HELP!!
  32. water engine
  33. pitted windshield
  34. help my 92 jetta wont run in the cold
  35. slipping clutch
  36. Help!!!
  37. Delayed start
  38. jetta new coil no spark
  39. Tricky Ignition
  40. Similar problem
  41. Technical questions, troubleshooting etc.
  42. 1996 Jetta GL 2.0 sputtering/slow getting into gear
  43. Clicking suspension
  44. 94 Jetta GL issues (oil pressure light, alarm, gear lights, locking mechanism)
  45. What's In Your Sound System In Your Jetta??
  46. 1995 Jetta III Celebration Edition (A) Acceleration Issues
  47. 91 Jetta crazy idle...please help!
  48. 91 Jetta crazy idle...please help!
  49. clutch went out! Help
  50. Trouble starting '96 Jetta...electrical problems?
  51. 95 Jetta manual window crank removal
  52. 95 jetta startup problems
  53. 95 Jetta injectors
  54. Jetta starting problems when wet
  55. 95 jetta diese heater fan problem
  56. 95 Jetta GLS fuse diagram and interior lights problem
  57. 95 GLS with power window problem
  58. 1995 Jetta 2.0
  59. 96 Jetta wont start
  60. 1996 Jetta Rough Idle / Stalling
  61. 1996 Jetta GLS - Ignition coil
  62. Coilover question for 92 jetta
  63. 1995 Jetta
  64. 91 Jetta loss of power at highway speeds
  65. 95 jetta III doors
  66. OBD-II on 95-Jetta
  67. OBD-II on 95-Jetta
  68. 95 Jetta Timing Belt ?
  69. (please help) 1995 Jetta - Reading the Check Engine Codes
  70. 96 Jetta Engine light flickers
  71. 94 GL Problem
  72. (HELP PLEASE) 1996 VW Jetta (ROUGH IDLE)
  73. PLease help ME.Does My 1992 Jetta Rear Seat fold Down?
  74. Rear speaker wiring in 96 Jetta GLS
  75. 95 manual trany fo a 91 golf gaz motor's trany
  76. 94 Jetta transmission problems after engine swap
  77. 1995 jetta throttle problems?,check engine light(how do you read codes)?
  78. 95 jetta oil light
  79. 95 jetta speedo dosent work
  80. 95 Jetta Idle problem
  81. 1995 Jetta Warning Light Question, should be easy!
  82. 1994 JettaIII GL intermittant no start/stall
  83. 96 Jetta Trek leak
  84. 95 jetta overheating like crazy
  85. 95 brake light switch
  86. 95' jetta IIIGL burned out compressor clutch
  87. 1996 Jetta 2.0 GL Brakes Suck
  88. 95-97 Jetta 2.0 8v Turbo Project
  89. 96 Jetta A/C not working
  90. 95 Jetta III Issues
  91. 94 Jetta alarm problem
  92. changing suspension in a 95 jetta gl
  93. Help with 1995 factory floor mat color
  94. 1996 VW Jetta Cooling fan?
  95. Is it worth my time? and what site has a variety of 93-98 jetta body kits???
  96. radio display on 95 Jetta
  97. 96 jetta leaking in car
  98. 94 Jetta ignition problem, please help!!
  99. 94 Jetta Ignit. Coil help
  100. 92 jetta wont start after running
  101. 95 Jetta GLII 2.0/4 cyl A/C quit
  102. 95 Jetta Tranny Q's
  103. 96 Jetta Starter prob?
  104. 95 jetta III GLS question
  105. 1996 jETTA SUNROOF MALFUNCTIONING
  106. 95 jetta intermittant hesitation
  107. 91 Jetta won't start after replacing timing belt.
  108. 1996 VW Jetta 2.O GLS-Electrical
  109. 96 Jetta GLS antenna base needed..
  110. 1994 Jetta Gls problems
  111. Cooling fan problems 96 Jetta
  112. 96 Jetta Heater Core Help
  113. will a3 (93-98) fenders and body kit fin on A2 jetta?
  114. 92 jetta..no spark
  115. 91 jetta won't start, beginner needs help
  116. '94 Jetta temp light
  117. 94 Jetta Gls 2.0 stalls on Hiway
  118. 1995 Jetta III GL cold start problems
  119. 1994 Jetta Sputter
  120. 96 Jetta GLS Speedo Problem
  121. 1996 Jetta "Engine Check Light"
  122. 1995 Jetta won't Start
  123. 92 Jetta A/C HELP!
  124. 95 jetta vr6
  125. 16V for '94 2.0L
  126. 1995 factory speakers
  127. 96 Dome Light
  128. 96 Jetta need kelp
  129. 1996 Jetta GLS Feaky Electrical......
  130. 96 jetta trek cruise control
  131. 96 Jetta starter trouble
  132. '96 Jetta Brakes
  133. 1991 MK2 Jetta ECOdiesel for sale
  134. 91 turbo diesel stalls (starving for fuel?)
  135. 96 jetta CEL...?
  136. exhaust jetta 96 TREK
  137. FS: 1991 Jetta ECOdeisel in AZ
  138. Odometer on 1996 Jetta
  139. 94 Jetta Check Engine Light
  140. jetta 96 wiring switch starter
  141. Major Problems On My 1996 Jetta Trek- Need Advice
  142. Idle Problem 1995 Jetta III
  143. 1991 Jetta
  144. my 94 jetta has no spark/no fuel
  145. 96 Jetta 2.0
  146. 94 Jetta possible electrical problem help!
  147. 96 Idle Problem
  148. 96 jetta trek
  149. 96 Jetta Gls Engine Light
  150. 96 jetta won't start (fuel pump problem?)
  151. '96 Jetta Mass Airflow Sensor
  152. Wiper prob on 96 Jetta
  153. Any advice on replacing coolant pipe? '94 VR6
  154. Need Info for 96 Jetta Head Board Removal
  155. 95 Jetta Misfiring With Warm Temps
  156. 1996 jetta radio antitheft code
  157. 1994jettahelllllp!
  158. stock stereo removal 96 jetta
  159. 96 Jetta/Passat Recall 02V256000 - WHDK
  160. Jetta 1994 Starting problems
  161. 95 jetta fuel pump trouble ???
  162. '96 Radio Display bad AND needs to be reprogrammed!
  163. '96 For Sale $2,500
  164. 91 Jetta temp light, clutch problems...I need advice
  165. just got a 1991 diesel!!!
  166. *96 Jetta CHECK ENGINE LIGHT ON*
  167. 1994 Jetta GL Sunroof
  168. 95' Jetta Problems
  169. Help! Stereo probs. in my '96
  170. 94 jetta III tranmission problems
  171. 94 jetta heater fan
  172. 92 Jetta two electrical problems
  173. 1992 Jetta eratic Idle, loss of power, runs to rich
  174. '96 Jetta Oil light/beeping wont stop!!
  175. installing a new head unit for a 1994 vw jetta
  176. 96 jetta power windows!!!
  177. 91 jetta Hole in firewall?
  178. question for the early 90's jetta owners
  179. 92 jetta worth it?
  180. Buying a 95-96 VR6. I need opinions.
  181. 95' Jetta OBDI system
  182. 1994 Jetta acceleration hesitation - Bogging Down
  183. 94 automatic trans. question
  184. 94 Jetta 3
  185. 95' jetta clutch
  186. 95' jetta starting problems
  187. 96 jetta problems
  188. 94 jetta 2.0 Wiring diagram
  189. Help with my 95 jetta
  190. 1996 jetta
  191. 92 Jeeta dies after starting
  192. Buy a '95 Jetta.. or not?
  193. 94 Jetta, automatic -- Towing Technique
  194. Jetta III 95 Auto Tranny Only drives in 3rd...
  195. '91 Jetta ecu
  196. 1995 jetta Gl III to vr6 swap
  197. 1992 Jetta stall problem solution
  198. 94 Jetta GL Dash Lights Not Working!!
  199. 1995 Jetta sunroof
  200. Jetta 92 dashlight and AC
  201. 94 with problems
  202. 96 VR6 OBDII 50K miles Motor 4Sale
  203. 91 Jetta Starting Problems -HELP!!!!
  204. Alternator Probs 96 jetta
  205. 1991 Diesel Jetta 2dr questions...
  206. 96' Vw
  207. 96 jetta automatic trans help!
  208. 1994 Jetta Check Engine Light!
  209. 1994 Jetta GLS Dashboard lights, radio and A/C fan won't work!
  210. 95 jetta check engine light codes
  211. What do you think about a '95 Jetta?
  212. Erratic idle in 1995 Jetta, help?
  213. Clutch slipping on 1995 Jetta
  214. Does 1995 Jetta have radiator resovore?
  215. mk3 faq/diy
  216. Transmission Removal on 96 Jetta 2.0
  217. 95 Jetta dual Headlight Conversion?
  218. Vw 91 Jetta Problem Please Help!!
  219. common 95 steering problem? help please
  220. '95 VW Jetta sunroof motor
  221. 94 GL stalling problems...
  222. 96 jetta fusable links
  223. 96 Jetta Trek Electrical Problems
  224. Performance mods for 1995 Jetta GL?
  225. Have to sell 96 Jetta
  226. 1995 Jetta
