View Full Version : '91 - '96
- Aftermarket Spolier Installation
- Custom Sub box: 95 Jetta
- Priming Fuel Pump
- return breather residue
- Leaking Trunk
- 96 Jetta GL Front End Noise
- Engine Grinding Noise HELP!!
- leaking coolent
- 95 Jetta GL
- Car will not start...
- throttle position sensor 96 Jetta
- What in the world is this loud beeping?
- 96 Jetta TPS problem
- short ram intake
- radiator fans
- jetta wont start
- 96 jetta alarm on wont start
- grindin noise 96 jetta
- Fuel Injector Problem? Car Won't Start.
- question
- Fuel Filter Replacement
- cant figure it out?
- rpm
- 1.6L operating temp?/thermostat
- removing door panel 95 jetta auto window
- 95 Jetta No Wipers...(not a fuse)
- Leaking heater core
- 95 Jetta wont start
- gregory
- what's the best shop manual out there
- Power Steering
- Flsahing Temp light
- 91 Jetta Clutch
- Radio asks for CODE
- best place to buy parts.(online)
- installing new timing belt jetta gl diesel
- Noob Car Problem!
- about a 91 jetta.
- 95 Jetta auto, won't shift past 3rd
- Wheels/Rims '88 vs '91 Jetta
- Start-up issues 95 Jetta III
- Cornering Issue
- Clutch Job
- dohc
- Bogs when you take off
- 95 Jetta - Revs rough at start up
- 94 Jetta timing belt
- Engine Light
- jetta spark problems
- 96 Jetta Starter Replacement Issues
- Brake rotors
- Wire harness for the speed sensor
- 91 JETTA gl 1.8 SHUTSOFF AND WON'T START UNTIL 10 MINUTES OR MORE LATER
- alarm
- OK...tell me what's up...
- Gas Pedal
- For Sale 96 Jetta GLX 61,800 miles $6495
- vr6
- aftermarket fogs
- !1991 to 1996 VOLKSWAGEN JETTA III MOTOR FOR SALE!
- transmission
- FS: 1991 Jetta, 69K Miles!!!
- 91 jetta 4 cyl diesel poss. thrwn rod
- snow tires
- Few mechanical ??"S
- 1994 jETTA !!!!!!!!!!!!!!!!!HELP NOW!!!!!!!!!
- Autotech Cold Air Intake
- Location of VAG 1551 diagnostic interface
- 96 jetta 1582 code
- Please Please Help Replaced Battery!!!
- headlights
- Trim on roof edge, 91 jetta
- 95 jetta window regulator replacement
- What would it cost to put a clutch in a 91 Jetta?
- Couple pics of my 96 jetta just bought
- FEW?"s on aftermarket stuff (need help)
- ticking noise while driving between 30-40mph
- What is normal operating temperature for Jetta III 2.0?
- 1991 Volkswagen Jetta TD Looking For Any Body Kits
- I can smell gas in my oil and it isnt running
- Weird noise-mechanical question
- '96 Jetta Starter Just Spinning - Engages After 20 Tries
- P0506 Fault Code MK3 Jetta Help!!!!!!!
- completely dead
- 96 jetta Lost All Power
- After Market Alarm install help. 1999 Jetta
- Air box lines?
- Busted Hose
- gear oil check 96jetta 2.0 GL
- 96 Jetta - strange electrical problem.
- Starting condition when wet
- 1999 (oldbody) Jetta Stalling out!!!!!!!HELP
- Backup switch on jetta'92
- MKIII Clutch
- plz help 1995 2.0 jetta
- Drive Cycle???
- Jetta Gauge problem
- Airbag light stays on
- 1995 jetta 2.0
- A couple questions about a 91 jetta turbo diesel
- want a mk3
- '96 jetta 2.0 No start condition, engine doesn't turn over
- water leaking in passenger front floorboard
- 93 Jetta Not Starting, Sounds Different
- 96 jetta engine change
- 94 jetta failed emissions need help
- 95 jetta 2.0 questions
- Big Silver Aluminum Thingy.........
- 92 Jetta New Alternator New Battery wont start still!!!!
- 92 Jetta intermittent miss/idle
- All 91-98 Jetta Parts For Sale!
- 95 jetta starting issue
- what grade of gas?
- stalling jetta
- aftermarket air filter
- '96 Jetta Bearing Vibration
- 95 Jetta III, idle+speedometer problems
- 94 Jetta electrical/starting problem
- 96 Front brake caliper removal
- CAr won't Start?????? Come here
- Starting problems and sputtering
- Start!!! you stupid CAR!!!
- Oil dipstick
- lights!!
- 1995 VW Jetta III GL
- moonroof/sunroof
- AC fuse
- Jetta Fuel problem
- fuel pump relay clicking
- v belt installation
- A/c
- replacing '96 jetta timing belt
- 96 jetta BIZARRE steering problem...please help
- 1992 volkswagon jetta
- 1994 Jetta Electrical Help Plz!
- 94 Jetta GL 2.0 Possible Fuel pump???
- Jetta '96 dead with a charged battery
- Attention Someone..
- 92 Jetta Starting Probs cont.
- Yet another Jetta wont start thread.
- 96 jetta starting problem
- 92 Jetta cv? bearing? noise
- hep me, hep me!!!!!!
- some questions abut 95 jetta gl
- 92 Jetta Cranks but won't fire
- 95' Jetta "tat-tat-tat-ect." noise?
- Fuel Filter?
- 96 Jetta 1582 1303 codes?
- 96 Jetta stalled now no start
- 96 Jetta Bogs Down No Power
- 92 Jetta Horn relay
- 92 Jetta GL Engine Fumes in cabin
- what seats fit
- 96 jetta clutch costs??
- 96 Jetta Auto Problems
- 95 jetta idle problem?/need help
- 95 Jetta power window problems
- 92 Jetta will not start
- 96 Jetta Gl Auto Tranny Problems! Help!
- 1996 Keyless Entry
- Aftermarket Clutches (ACT)
- electrical problems need help
- brakes
- 1994 jetta feul pump problem
- Tires
- 95 Jetta, few problems i need help with
- NEW kind of stereo / radio reset problem. help?!
- heeelp!!! Busted Jetta
- battery goes dead
- 91 Jetta wolfsburg For Sale
- jetta wont start
- 94' Jetta Electrical Short?
- 94' Jetta Auto Shifting Problems!?
- 95 M/T Speed sensor wiring
- Jetta Wiper problem
- stereo install??????
- How to Add More Power to Jetta III
- 95 Jetta III running lights don't turn off
- what does this mean?
- Oil
- Help!! '95 Jetta AT Rebuild problems.
- low computer ground
- Radio Issues
- Cluster lights out...please help
- 96 Jetta GLS needs camshaft position sensor
- 94 jetta auto tranny
- 94 Jetta GL tranny problems?
- 94 Jetta GL Oil pressure light keeps going off
- 1991 Jetta cooling problem
- Is my clutch going?
- engine problems
- 1992 jetta, replaced battery. radio says CODE?
- 96 Jetta Throttle Body Help!!!
- jetta III seats
- jetta III body kit
- Need help
- 95 jetta help please
- 95 Jetta GL FOR SALE $2150 NE Ohio
- posible electrical problem
- 92 VW Fox, starter does not crank
- 95 Jetta, alarm/starting issues
- Help - Need an Exhaust for 96 Jetta 2.0L
- No Spark And No Fuel
- Cluster lights not working
- 96 Jetta Power loss
- Broken Lock On Driver's Side
- 1.6 Diesel Golf/Jetta 92 Check oil pressure from filter housing,checks 85 PSI!!!!
- Should I Buy A Vag-com???
- 94 Jetta tranny problem
- power locks/windows have a mind of thier own
- 96 Jetta Knocking
- Passenger side control arm
- '95 Cold air intake
- Jumpy Idle
- body kit
- '95 Jetta clutch release
- Diesel :Pump problem?
- vw jetta doesn't start smooth with warm engine only
- 92 Jetta Brake losing pressure.
- '92 VW jetta Gl Ecu Trouble Code Retrieval
- 95 Jetta Acceleration/Power problem
- Motor
- Air bags gone but need way to install aftermarket steering wheel for race use?
- 93 Jetta starting problem
- Gas/oil mixture in my intake tube on my 8v?
- Headlight Adjustment
- Should I buy this '95 Jetta?
- 92 Jetta 8v...some questions...
- Need Help?
- Leaky MKIII Tails
- 96 Jetta GLS taillights always on?
- iPod
- radio
- Sensor On Tranny 96' Jetta Auto
- Fun Tune-up
- 94 Jetta Iii Gl Sunroof Not Working
- 99 Jetta Alarm
- 96' Jetta Auto Stalls
- My Alternator Is Making A Whineing Sound
- 96 jetta sputters when accelerating
- No turn signals
- loss of rpm, power stearing, then stalling
- 96 Jetta
- Code P0113 where do I begin?
- SPs
- Check Transmission -- Manual
- 96 Jetta 3
- 96' Jetta Gl Auto Stalls
- cold air intake
- 96 jetta
