View Full Version : '91 - '96
Pages : 1 2 [3] 4
  1. about a 91 jetta.
  2. 95 Jetta auto, won't shift past 3rd
  3. Wheels/Rims '88 vs '91 Jetta
  4. Start-up issues 95 Jetta III
  5. Cornering Issue
  6. Clutch Job
  7. dohc
  8. Bogs when you take off
  9. 95 Jetta - Revs rough at start up
  10. 94 Jetta timing belt
  11. Engine Light
  12. jetta spark problems
  13. 96 Jetta Starter Replacement Issues
  14. Brake rotors
  15. Wire harness for the speed sensor
  16. 91 JETTA gl 1.8 SHUTSOFF AND WON'T START UNTIL 10 MINUTES OR MORE LATER
  17. alarm
  18. OK...tell me what's up...
  19. Gas Pedal
  20. For Sale 96 Jetta GLX 61,800 miles $6495
  21. vr6
  22. aftermarket fogs
  23. !1991 to 1996 VOLKSWAGEN JETTA III MOTOR FOR SALE!
  24. transmission
  25. FS: 1991 Jetta, 69K Miles!!!
  26. 91 jetta 4 cyl diesel poss. thrwn rod
  27. snow tires
  28. Few mechanical ??"S
  29. 1994 jETTA !!!!!!!!!!!!!!!!!HELP NOW!!!!!!!!!
  30. Autotech Cold Air Intake
  31. Location of VAG 1551 diagnostic interface
  32. 96 jetta 1582 code
  33. Please Please Help Replaced Battery!!!
  34. headlights
  35. Trim on roof edge, 91 jetta
  36. 95 jetta window regulator replacement
  37. What would it cost to put a clutch in a 91 Jetta?
  38. Couple pics of my 96 jetta just bought
  39. FEW?"s on aftermarket stuff (need help)
  40. ticking noise while driving between 30-40mph
  41. What is normal operating temperature for Jetta III 2.0?
  42. 1991 Volkswagen Jetta TD Looking For Any Body Kits
  43. I can smell gas in my oil and it isnt running
  44. Weird noise-mechanical question
  45. '96 Jetta Starter Just Spinning - Engages After 20 Tries
  46. P0506 Fault Code MK3 Jetta Help!!!!!!!
  47. completely dead
  48. 96 jetta Lost All Power
  49. After Market Alarm install help. 1999 Jetta
  50. Air box lines?
  51. Busted Hose
  52. gear oil check 96jetta 2.0 GL
  53. 96 Jetta - strange electrical problem.
  54. Starting condition when wet
  55. 1999 (oldbody) Jetta Stalling out!!!!!!!HELP
  56. Backup switch on jetta'92
  57. MKIII Clutch
  58. plz help 1995 2.0 jetta
  59. Drive Cycle???
  60. Jetta Gauge problem
  61. Airbag light stays on
  62. 1995 jetta 2.0
  63. A couple questions about a 91 jetta turbo diesel
  64. want a mk3
  65. '96 jetta 2.0 No start condition, engine doesn't turn over
  66. water leaking in passenger front floorboard
  67. 93 Jetta Not Starting, Sounds Different
  68. 96 jetta engine change
  69. 94 jetta failed emissions need help
  70. 95 jetta 2.0 questions
  71. Big Silver Aluminum Thingy.........
  72. 92 Jetta New Alternator New Battery wont start still!!!!
  73. 92 Jetta intermittent miss/idle
  74. All 91-98 Jetta Parts For Sale!
  75. 95 jetta starting issue
  76. what grade of gas?
  77. stalling jetta
  78. aftermarket air filter
  79. '96 Jetta Bearing Vibration
  80. 95 Jetta III, idle+speedometer problems
  81. 94 Jetta electrical/starting problem
  82. 96 Front brake caliper removal
  83. CAr won't Start?????? Come here
  84. Starting problems and sputtering
  85. Start!!! you stupid CAR!!!
  86. Oil dipstick
  87. lights!!
  88. 1995 VW Jetta III GL
  89. moonroof/sunroof
  90. AC fuse
  91. Jetta Fuel problem
  92. fuel pump relay clicking
  93. v belt installation
  94. A/c
  95. replacing '96 jetta timing belt
  96. 96 jetta BIZARRE steering problem...please help
  97. 1992 volkswagon jetta
  98. 1994 Jetta Electrical Help Plz!
  99. 94 Jetta GL 2.0 Possible Fuel pump???
  100. Jetta '96 dead with a charged battery
  101. Attention Someone..
  102. 92 Jetta Starting Probs cont.
  103. Yet another Jetta wont start thread.
  104. 96 jetta starting problem
  105. 92 Jetta cv? bearing? noise
  106. hep me, hep me!!!!!!
  107. some questions abut 95 jetta gl
  108. 92 Jetta Cranks but won't fire
  109. 95' Jetta "tat-tat-tat-ect." noise?
  110. Fuel Filter?
  111. 96 Jetta 1582 1303 codes?
  112. 96 Jetta stalled now no start
  113. 96 Jetta Bogs Down No Power
  114. 92 Jetta Horn relay
  115. 92 Jetta GL Engine Fumes in cabin
  116. what seats fit
  117. 96 jetta clutch costs??
  118. 96 Jetta Auto Problems
  119. 95 jetta idle problem?/need help
  120. 95 Jetta power window problems
  121. 92 Jetta will not start
  122. 96 Jetta Gl Auto Tranny Problems! Help!
  123. 1996 Keyless Entry
  124. Aftermarket Clutches (ACT)
  125. electrical problems need help
  126. brakes
  127. 1994 jetta feul pump problem
  128. Tires
  129. 95 Jetta, few problems i need help with
  130. NEW kind of stereo / radio reset problem. help?!
  131. heeelp!!! Busted Jetta
  132. battery goes dead
  133. 91 Jetta wolfsburg For Sale
  134. jetta wont start
  135. 94' Jetta Electrical Short?
  136. 94' Jetta Auto Shifting Problems!?
  137. 95 M/T Speed sensor wiring
  138. Jetta Wiper problem
  139. stereo install??????
  140. How to Add More Power to Jetta III
  141. 95 Jetta III running lights don't turn off
  142. what does this mean?
  143. Oil
  144. Help!! '95 Jetta AT Rebuild problems.
  145. low computer ground
  146. Radio Issues
  147. Cluster lights out...please help
  148. 96 Jetta GLS needs camshaft position sensor
  149. 94 jetta auto tranny
  150. 94 Jetta GL tranny problems?
  151. 94 Jetta GL Oil pressure light keeps going off
  152. 1991 Jetta cooling problem
  153. Is my clutch going?
  154. engine problems
  155. 1992 jetta, replaced battery. radio says CODE?
  156. 96 Jetta Throttle Body Help!!!
  157. jetta III seats
  158. jetta III body kit
  159. Need help
  160. 95 jetta help please
  161. 95 Jetta GL FOR SALE $2150 NE Ohio
  162. posible electrical problem
  163. 92 VW Fox, starter does not crank
  164. 95 Jetta, alarm/starting issues
  165. Help - Need an Exhaust for 96 Jetta 2.0L
  166. No Spark And No Fuel
  167. Cluster lights not working
  168. 96 Jetta Power loss
  169. Broken Lock On Driver's Side
  170. 1.6 Diesel Golf/Jetta 92 Check oil pressure from filter housing,checks 85 PSI!!!!
  171. Should I Buy A Vag-com???
  172. 94 Jetta tranny problem
  173. power locks/windows have a mind of thier own
  174. 96 Jetta Knocking
  175. Passenger side control arm
  176. '95 Cold air intake
  177. Jumpy Idle
  178. body kit
  179. '95 Jetta clutch release
  180. Diesel :Pump problem?
  181. vw jetta doesn't start smooth with warm engine only
  182. 92 Jetta Brake losing pressure.
  183. '92 VW jetta Gl Ecu Trouble Code Retrieval
  184. 95 Jetta Acceleration/Power problem
  185. Motor
  186. Air bags gone but need way to install aftermarket steering wheel for race use?
  187. 93 Jetta starting problem
  188. Gas/oil mixture in my intake tube on my 8v?
  189. Headlight Adjustment
  190. Should I buy this '95 Jetta?
  191. 92 Jetta 8v...some questions...
  192. Need Help?
  193. Leaky MKIII Tails
  194. 96 Jetta GLS taillights always on?
  195. iPod
  196. radio
  197. Sensor On Tranny 96' Jetta Auto
  198. Fun Tune-up
  199. 94 Jetta Iii Gl Sunroof Not Working
  200. 99 Jetta Alarm
  201. 96' Jetta Auto Stalls
  202. My Alternator Is Making A Whineing Sound
  203. 96 jetta sputters when accelerating
  204. No turn signals
  205. loss of rpm, power stearing, then stalling
  206. 96 Jetta
  207. Code P0113 where do I begin?
  208. SPs
  209. Check Transmission -- Manual
  210. 96 Jetta 3
  211. 96' Jetta Gl Auto Stalls
  212. cold air intake
  213. 96 jetta
  214. 96 Jetta GLS stoplights alsways on-brake pedal switch OK
  215. MAF cleaning Procedure
  216. Corrado Spoiler
  217. Idle Air Control Valve
  218. 92 Jetta stalling when splashed underneath
  219. Water pump leaking, easy job to replace?
  220. !996 jetta can't start
  221. Vapor Canister
  222. motor swap
  223. 95 jetta loss of power
  224. Tires
  225. Tune Up?
  226. '96 Jetta 2.0 Turns over but won't start
  227. CD player
  228. 95 jetta wierd
  229. looking for aftermarket parts Gl/GLS/Vento/Trek/Gt
  230. 93 jetta gl
  231. Relay Layout
  232. 96' jetta gl acceleration loss
  233. Radio In Safe Mode
  234. 94 Jetta stalling problem
  235. V and Serpentine belts, 96 JEtta GL 2.0
  236. Where is the throttle valve?
  237. Ignition switch is toast
  238. 96 2.0 jetta won't start
  239. 96 Jetta GL Fuel pump fuse blows after 5 minutes
  240. 96 Jetta Hoses
  241. MK3 power mirror wiring diagram
  242. Rally Jetta!
  243. 1996 Jetta tranny swap questions
  244. stuck on starter removal 91 auto...
  245. 95 Jetta overheated today
  246. oil
  247. 1992 Jetta problems
  248. Fan won't stop (92 Jetta)
  249. heat shield
  250. Crank Sensor?
