View Full Version : '91 - '96
- 95 jetta bucking and hesitating
- 4 codes to fix
- Oil pressure warning in 95 jetta
- 94
- Jetta Mk Iii Rear Bumper Brackets!!!!!!!!!!
- Anyone up to the challenge?
- Reset computer?
- transmission problems help please
- Volkswagen Jetta MK III/ Golf 3 front bumper
- 96 Jetta, has spark,gas,compression - but no start
- Jetta is acting up. HELP!!
- German Guy Needs Help With His Us Jetta!!!
- Jetta 96 tranny and overheating problem.......Help please
- 96 Jetta Electrical Problem turn Signals/Brake lights
- Front Door Speaker Wires
- 94 Jetta Transmission Trouble
- 94 jetta transmission trouble
- 1994 hard start, hard idle
- jetta '96 gls starting problems. HELP........!!!!!!!!
- 96 Jetta DTC error code P1613
- I need a VR6 jetta real bad
- blinkers
- 92 jetta rotor cap clips
- Won't hot start!!
- 95 jetta gl wont start with key
- R-134a pressure on conversion
- 96 Jetta will only run while I spray carb cleaner
- Parts for sale
- 93 Jetta Starting Problems, Not a car person
- 94' VW JettaIII GL AT
- speedo/instrument cluster question
- 95 jetta --HELP !!!
- we need help please!! 96' jetta trek
- Thermostat replacement
- Interference engine?
- Location of ecu on 95 jetta gl
- 92 jetta with no spark
- '96 Jetta GL Clutch replacment...how difficult?
- 1996 Jetta A/C Loud
- 91 jetta gl ac problems
- Ignition Problem
- Looking for statistics on a 96 Jetta
- Gas guage inop....
- 94 Jetta, series of problems
- '92 Jetta-Timing belt change now high rev: HELP!!!
- 95 Jetta Radio
- Speaker Wiring.
- jetta 1.8 '92
- Location of cruise module - 96 Jetta
- Wanted:91-96 Jetta
- 96 Jetta A/C problems
- 95 Jetta relays and wiring nightmares. Please help.
- 96 Jetta alarm trouble
- noob: pics of my cars....
- 92 Jetta clutch
- 92 Jetta irregular idle
- 92 Jetta starter problem
- Oil leak
- help me help a friend shifting problems
- How do i get the crank handle off?
- 1995 Jetta VR6 Pouring Out Antifreeze...
- alram arming it's self after 2 minutes
- '96 Jetta TREK, Stereo Help
- Vibrations 96 Jetta
- where is OBD port on 1996 jetta 2.0?
- 96 Jetta Broken Door Latches
- Diverters for heater core box
- dash lights don't work. any ideas?
- upgrades for the 2.0
- Flowmaster muffler 50 series for 93-97 vw Jetta
- 91 jetta wont fire
- 96 Jetta, Can't find OBDll plug
- 94 GLS Won't Start
- 96 Jetta radio
- Oil light on 91 jetta
- blinkers stop working when i step on the brake
- seat belt light on?
- water in trunk
- 96 jetta III 2.0, whana go fast to the drags
- TPS Throtle Position Sensor
- Exhuast System-- I am replacing it
- 1994 antifreeze leaking
- will not crank
- How to get codes?
- 94 Jetta starting problems pls advise
- Window cables
- Vacuum Pump
- got my jetta but...
- Very longt time to lock Vento -93
- Corrado engine in a 95 jetta
- 96 starter
- 95 vr6 power loss
- 94 JETTA - electrical help needed!!
- Don't run without oil
- 94 jetta power windows
- honking horn dead battery
- clicking in reverse
- 96 jetta. Buzzing Hazard switch
- 95 jetta need expert help
- Performance
- 92' Jetta...I'm ready to fix it but I need your help
- '96 No power >40mph
- 96 jetta drum brakes
- is it worth getting a vr6 with manual trans in my 96 jetta
- ungo alarm system
- Stereo Codes
- Diesel 1994 Jetta GL NO-START
- just bought a 92 jetta
- 96 Jetta Cat. Conv. part #
- 96 jetta rain problems
- fan coming on too late / idle speed and shaking
- '92 Jetta's
- gas tank
- 2001 Jetta check coolant warning light
- '91 Jetta diesel overheating
- Need Direction - 95 jetta
- 1994 Jetta cranks but will not start update.
- 96 jetta 2.0 dummping to much gas at high rpm's
- tach/speedo intermitantly not working
- 91 Jetta 16V, bucking at low RPM
- car dont start in bad weather
- car alarm!!
- 94 volkswagon jetta
- 1995 vento
- 92 Jetta won't start wont' crank
- 96 jetta wont start, after extensive work
- tranny problems in 95 jetta III
- Heater core
- fuel injector cleaner
- Jetta Trek '96 idling high
- 96 Jetta Gls Electric Problem
- Hello BOSCHMANN
- 95 Jetta problems?
- Jetta Won't shut off
- 1994 jetta electrical
- MAF and Fuel Injectors
- 1992 Jetta - Idle and intermittent stumbling
- about to buy a 2.0 1996 jetta
- Sudden Valve Cover Leakage
- Ignition Coils
- 1991 jetta thermostat
- Fuel pump relay
- Help!! 96 jetta 2.0 no start problem
- Need help for '96 Jetta, 2.0L, with overheating problem.
- Newbie needs help with bucking '92 Jetta
- 95 Jetta intermittent run rough
- 95 Jetta-III Questions
- 95 Windshield Wiper Switch / MFA
- Jetta transmission conversion help
- VW tools??????
- 93 Jetta GL Relays
- Questions
- 94 jetta wipers stopped burnt smell in interior
- Help! 1996 Jetta won't start
- 96 Jetta Trek Starting Problems
- HELP - Can oil buildup in the intake/MAF/air cleaner cause rich running when cold?
- Problems w/the alarm 1996 Jetta
- 96 Jetta Stalling
- Tranny Linkage Cable
- Where to find aftermarket parts for a 96 jetta gls?
- 1996 Jetta Not Starting
- 1995 jetta electrical problem
- car won't start because of alarm
- mechanics in NYC Tristate
- Window Cables / Motor
- Fun upgrades
- '94 Jetta Fuel Consumption!
- '94 Jetta III Gl 2.0 5 spd problem
- Engine runs only 2 seconds
- 96 Trek horn
- 96 Jetta 2.0l GL emissions/blowing
- hesitation, bucking at slow speeds
- Anti theft code number
- ABS Light
- thermostat
- 1995 Jetta celebration
- Check engine light on/off
- ignition switch replacement
- vr6 tranny
- HELP!95 jetta won't start after small fire/mechanic ripped me off
- need advise on buying rims
- '95 JettaIII GL engine lock
- car with issues
- Jetta Check Engine Light Keeps coming back on
- Audio Question
- hopefully easy ? about seatbelt.
- transmission
- '99 Jetta GLS Alarm
- broken drive side lock
- Oil Light
- timing problems
- p0341 crank position sensor error
- Please Help with 96 Jetta starting Prblm...
- 94' Jetta Gl problem
- Radio code car is too old...
- Remote start wirings?
- '96 Jetta AT slow shifting
- Dashboard light
- 94 jetta overheatng
- car cranks but does not start
- Oil leak question???
- front end alignment
- can't start after changing battery
- 95 Jetta Starting Problem
- Ask Doug Tatham...?
- Recall Information
- Jetta Car Memory
- Motor Noise... Where's It Coming From?
- Aftermarket Spolier Installation
- Custom Sub box: 95 Jetta
- Priming Fuel Pump
- return breather residue
- Leaking Trunk
- 96 Jetta GL Front End Noise
- Engine Grinding Noise HELP!!
- leaking coolent
- 95 Jetta GL
- Car will not start...
- throttle position sensor 96 Jetta
- What in the world is this loud beeping?
- 96 Jetta TPS problem
- short ram intake
- radiator fans
- jetta wont start
- 96 jetta alarm on wont start
- grindin noise 96 jetta
- Fuel Injector Problem? Car Won't Start.
- question
- Fuel Filter Replacement
- cant figure it out?
- rpm
- 1.6L operating temp?/thermostat
- removing door panel 95 jetta auto window
- 95 Jetta No Wipers...(not a fuse)
- Leaking heater core
- 95 Jetta wont start
- gregory
- what's the best shop manual out there
- Power Steering
- Flsahing Temp light
- 91 Jetta Clutch
- Radio asks for CODE
- best place to buy parts.(online)
- installing new timing belt jetta gl diesel
- Noob Car Problem!
- about a 91 jetta.
