View Full Version : '83 - '90
- 85 jetta 1.8 idle control motor question
- Fuel gauge troubleshooting
- intermittent low power on 91 gli 16v
- 87 Jetta GL Wolfsburg
- 88 gli
- 88 Jetta starts, idles rough, but no accelerator response
- 87 Jetta hesitation on acceleration
- Spark Problem
- 86 jetta diesel
- 1985 VW Jetta oil problem
- I Have Problem..Won,t start when is Hot
- OBD plug location
- a/c recharge
- Idle And Start problem
- ignition switch change
- Hall Effect Switch Testing?
- '90 Jetta Carat Wolfsburg Edetion Sensor?
- Jetta won't start
- Oil Alarm
- 89 jetta starts hard sometimes
- short vs long shifter
- Jetta '89 random power loss
- i need diagram for a jetta 87 hose vacum sistem
- 88 Jetta not getting fuel
- wipers don't work
- timing gear cover
- 87jettawork
- 89 jetta rpms drop
- Jetta just turns off O.o
- 1986 VW Jetta GL 5 speed, Starts then Stalls
- Leaky dipstick
- Help! 85 Vw Jetta!
- 86 diesel jetta The car runs strong, but has an idle problem ( ok if the glo-plug is
- slight problem
- 90 Fuel pump gone bad
- replacing the clutch
- 86 jetta reverse problem and more
- Pimp my Jetta?!
- My stupid blinkers.....
- '88 Jetta Slalom
- Over-heating Engine
- 1990 Jetta losing power
- jetta diagram
- 88 jetta, overheating
- body kit questions
- 83 Jetta Alternator problem!!
- dashboard removal
- outside door handle question
- help! Shift linkage
- 85 VW JEtta Turbo Diesel For sale
- Water Pump???
- Brother got an 87 Wolfsburg Jetta...trouble starting
- I need help
- 87 Jetta Won't Start
- 1986 Jetta Very High Idle
- Confused and frustrated with my 85 Jetta
- 1990 Jetta 4000 rpms at 70 mph
- starting problems
- air conditioning
- i need help with my 90 jetta
- Help Identifying Part, Please
- 1990 jetta issue
- 85 jetta wont idle
- 85 turbocharged jetta won't run
- 1989 vw jetta not turning over
- 1985 jetta fuel problem
- 88 GLI possible engine lock
- timing belt change intervals
- Maybe a unique problem:
- Horn Goes Off on My 88 VW Jetta GLI
- Can I swap an 87 trans to a 89 engine????
- Seats for '89 Jetta?
- 90 Jetta blows oil out the dipstick tube
- 89 jetta huge problem ?
- 88 Jetta parts
- 1990 jetta won't start
- 87 Jetta interior door panel needs to come off
- computer wiring for sandrail
- tune up parts for sale
- Help Radio won't work
- Burning oil
- 90 Jetta GLI Idle?
- I Need Help
- diesel
- cannot select right gears on my '88 Jetta
- 1990 Jetta 1.8 Ltr. Overheating in Rain
- Parts for sale, MK2 - g60/8v
- Alternator Pulley Alignment
- 1986 VW gli wont turnover
- '89 Jetta manual transmission problem
- Rear door stuck/locked shut
- want a mk2
- 85 jetta won't start
- 1986 jetta problem need help!!!!
- Engine Swap
- '85 Diesel Jetta with White smoke
- 1987 Jetta cranks but won't start
- Jetta Brake Problems
- 86 jetta gli O2 sensor light
- 1987 jetta gl steering wheel movement
- supposed oil pressure problem
- 1987 jetta gl speedometer / odometer not working
- Help! My new (old) Jetta died!
- oil pressure sending unit....
- 1983 jetta 1.6l tdi blinker hazard reverse light prob
- 86 GL bucks and kicks
- 89 Jetta idling at 3000rpm
- what seats fit????
- 86 jetta GL turbo diesel, timing belt/oil pump?
- 86 jetta door panel
- oil spewing out and lots of smoke
- 86 jetta gli "dying"
- missing piece 1984 jetta
- fuel problems with a 89 jetta
- 90 1.8 L Gl
- chugging, stalling and clicking, please help!
- '85 jetta running VERY rough!!
- 89 Jetta noisy when changing gears
- My Car Won't Startup without a Jump
- Fuel Problem
- fuel distribuitor question
- Jetta Engine Codes
- 89 gli wont start sometimes
- seat belt lock-out
- Diesel Or Turbo Diesel?
- 88 jetta, no reverse, all else works fine
- trunk leaks
- Help! 1989 Jetta won't start!
- 85 Jetta modifying
- starter interchangeable??
- What colour should we paint our '86 Jettas?
- 87 Jetta Electrical problem
- 85 Diesel Jetta wont start all of sudden in cold
- 89 diesel hard starting
- 1990 Jetta sqeaky belt problem.. HELP!!
- 86 Jetta Carat Defrost Problem
- Technical questions, troubleshooting etc.
- Parting 90 JETTA!!!!!!
- 85 Jetta Diesel Starting Problem (Electrical?)
- 1988 Gli 16v
- Timing specs on 1990 Jetta, help!
- 90 Jetta doesn't like the rain
- 89 Jetta GLI Question
- 1989 Jetta Diagnostic Codes?
- My 89 2 Door Jetta
- Clutch problems 87 Jetta
- 1988 Jetta
- 1988 Jetta Door Hinge
- front spoiler for 85 jetta
- 88 VW Jetta GLI - starting problems
- grill conversions for an 85 jetta
- 88 Jetta GL for sale.
- 90 jetta dying when i press on clutch!
- 90 jetta gli intermittent problem
- 90 Jetta intermittent problem
- Want to Rebuild Seats in 89 Jetta
- 86 Jetta engine temp problem
- Running problem with 89 GLI
- 1987 VW Jetta GLI
- 86 Diesel Jetta Fuel Pump Location
- 86 turbo diesel wont start
- '89 Jetta
- 1988 Jetta fuel pump noise ,stalling
- 1989 5 sp trans fluid change question
- NEED 84 jetta gti front stock springs
- 84 Porsche 911 firing problem
- where do i get a chip for a 1985 jetta
- Help!!! 87 Jetta Starting Problems
- 90 VW Jetta Power windows
- need 1986 GTi Cylinder Head
- 1988 Jetta no spark
- Silver 88 VW Convertible For Sale
- Is a 88 Jetta worth modifying?
- 1990 jetta wont run
- 90 Jetta low oil light/buzzer
- 1988 Jetta - Leaking windows
- 90 Jetta 1.8L rough idle
- My '90 cranks but won't start
- wut to do for mass hp for a 1985 jetta with 100hp
- 88 jetta no fuel
- 1989 Jetta running problems
- love my car. 85 jetta, needs work, have some questions
- 88 Vw jetta with manual window problems
- 1990 jetta radio problem
- 1988 Jetta cold start
- 88 jetta engine rattle
- 1990 Jetta mysterious rattle
- vr6 into 89 jetta
- 1990 jetta overheating
- 1987 Jetta low speed hesitation and bucking
- 1989 Jetta - Reading Engine Codes
- 87 jetta gl fuel dis
- 85 Turbo Diesel starting problems
- high revs out of 88 1.8L
- 89 Jetta Parts and Accessories
- 1990 Jetta axle noise problem.. please help.
- 89 Jetta Woflsburg - Starting Trouble
- 86 jetta bucks like a wild horse then dies!!!
- 89 Jetta jerks & misses -air flow sensor?
- 90 Jetta engine
- # of 86 Jetta GL Fuel Pumps
- 86 Jetta GL - Fuel Pump Relay Purpose?
- Fuel Pump Relay 'crackling', 88' GLI 16v
- 87 jetta loping idle in drive
- 89 diesel pressurizing coolant resevoir
- 85 jetta dying
- 85 Jetta pings
- Help deciding clutch for 88 GLi
- 1990 Jetta I just bought.
- 84 Jetta GLi dash wiring
- 1987 Jetta Radiator Fan Runs
- 84 Gli
- My 86' Jetta Wont Start. It will turn over but wont catch.
- 90 jetta stalling when clutch is in
- 84 jetta
- 89 jetta Prob.
- vr6 engine swap for '87 GLI 16v...possible?
- 1989 wolfsburg editon jetta 1.8t
