View Full Version : Cavalier Problem Diagnosis
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
  1. Starter relay wiring?
  2. 2002 CD Player won't shut off
  3. '97 Cavalier 2.4 - lifters or oil pump?
  4. Possible tranny leak?
  5. 95 chevy cavi z24 2.3l -- misfire/wont turn over
  6. stalling problem [please help :)
  7. 91 Cavalier ECM Fuse
  8. Oil light help
  9. 02 Sensor Heater Circuit Malfunction ????
  10. replaced 97 2.4 with 2000 2.4 no power to interior
  11. 97 Cav questions
  12. Clicking noise
  13. Oil Light lit on 97 Sunfire 2.2
  14. need help with a major pain in my ass
  15. crazy problem in my 2.2l bet you cant figure this one out
  16. 1993 cavalier rs fuel pump relay location
  17. what years fit 1999 z24
  18. Help no head lights!!!!!!
  19. radio problem
  20. car keeps making clicking sound
  21. Rear engine seal leak?
  22. Fuel pump relay grinding
  23. Passlock 1 Bypass
  24. Anybody ever align a door on 95+ Cavy?
  25. Cooling fan 98' 2.4L
  26. No fan operation-98 cavalier 2.2
  27. 97 Cavalier- Stalling Problem
  28. 97 Cav with unknown "issues"
  29. Brake problem?
  30. Any help would be great!!! 1997 Sunfire 2.2L
  31. 90 cavalier,a/c issue
  32. 2.4 Quad 4 NAME THAT NOISE!
  33. 97 Cavalier antilock issues
  34. Could you have a look at this condition?
  35. left inner tie rod
  36. 97 cavalier cooling fan
  37. 2004 Sunfire quit running
  38. Could I bypass the AC compressor in a 2001 cavalier
  39. Sunfire stalls
  40. Car won't accelerate in drive
  41. will these interchange ??
  42. 2005 cavalier oil pan
  43. will these interchange??
  44. Vacuum Leak near Power Steering Resivoir
  45. Trans will not shift into reverse
  46. 1998 cavalier drl relay switch
  47. 97 sunfire clutch slave bleeding
  48. 96 Z24 Cavalier clutch slipping
  49. 98 sunfire cutting out/ stalling
  50. 1998 Cavalier Overheating
  51. 96 2.4 starter
  52. 98 cavi probs
  53. 2000 cavalier z24
  54. replacing 95 Cavalier brake lines
  55. heater only works on high
  56. idle speed
  57. Engine Coolant leak (2001 Cavalier)
  58. clanging noiw
  59. 03 Sunfire problem, need help!
  60. 99 chevy cavilier z24 2.4 liter engine problems
  61. 1999 pontiac sunfire serpentine belt repalcement
  62. 02 Dash Display
  63. '96 2.4L Runs After a Charge, Then Dies Out
  64. Will not start.
  65. Over Cooling issue....
  66. 00 2,2l sunfire fuel problem
  67. Simple question
  68. 05 cavalier low beams & drl's quit
  69. Brake line has no pressure on drivers side
  70. Cavalier CD Player says "LOC"
  71. Odor when blowing air from outside
  72. Changing fuel pump. connection ???
  73. car wouldn't start (electrical problem)
  74. 1992 3.1 Liter Z24 Cavalier
  75. 1996 Chevy Cavalier running rough even after tune up
  76. Chevy Cavalier 2001 Cooling System Problem
  77. 2001 Chevy Cavalier Coolant System Problem
  78. wiring help
  79. Serpentine Belt Problem
  80. driving lights switch help
  81. 1998 Z24 Quad 4 Head swap
  82. 1996 Chevy Cavalier No Spark
  83. 2000 Cavalier service light on
  84. 2000 2.4 Cavalier Stalling Issues
  85. 2000 2.4 Stalling Issues
  86. Changing bulb in 3rd brake light
  87. 92 cavalier 3.1 won't idle and will die
  88. 04 Cavy Wheel Hub Sensor
  89. '96 Z-24 - Starter and Alternator just installed, now it just turns and turns
  90. 04 cavalier miises or jerks
  91. 2002 Chevrolet Cavalier I trying to replace the drivers side front wheel bearing hub
  92. Tranny help
  93. car won't stay running
  94. No Codes, No Start ... 1999 Sunfire
  95. 2000 Cavalier A/C compressor
  96. headlight problem
  97. 2002 Chevrolet Cavalier 2.2L SFI OHV I am hearing grinding noises from the front end
  98. 03 Cavalier, abs, trac off and brake lights on
  99. 98 z24 caviler won't start
  100. 2000 cavalier metal grinding belt
  101. 1998 Cavalier Z24 About to give up! I can't figure it out... Sputters & Shakes...
  102. changing torque converter lock-up point???
  103. Jiffy Lube oil change - now my car is dead. HELP!!! :(
  104. Hub Bolt
  105. 97 cavalier Died 178K
  106. tire/brake/suspension
  107. drl issues and more please help
  108. 98' Cav failed DEQ (emissions), crank and cam sensor codes.
  109. 02 cavy headlight conversion
  110. '98 Cavalier mystery problems...
  111. Cruise Control Sticks
  112. Help Me Diagnose - 2000 Cavalier -Misfire - Trac Off
  113. 1995 Cavalier Ignition Problems
  114. Power Steering Problems - 2002 Chev Cavalier
  115. 1996 Chevy Cavalier No Start
  116. 98 Cav. a/c / refrigerant problem
  117. transmission oil
  118. Cost to install 2001 Cavalier engine?
  119. 1998 Cavalier Z24 2.4 Quad4 THIS CAR IS REALLY MESSED UP! Water coming out firewall!
  120. 99 z24 hesitates and stalls
  121. Won't start unless I pull the fuel pump relay
  122. cavalier flooding
  123. 2000 2.2 bi fuel wont start
  124. 02 cavalier
  125. 1998 Cavalier: What a ride this is becoming!
  126. Just Keeping this car running.
  127. Drivers Seat Soaked
  128. Idling Problem
  129. 1992 cavalier crank sensor question
  130. Brake noise...clicking
  131. Weird brake!!!
  132. Theft light
  133. Not sure why I can't get my 3.1 to run. (Need some outside Ideas)
  134. E brake
  135. my 04 cavalier wont start and has no power
  136. 99 Cav getting hot!
  137. 02 cavalier a/c makes engine rev/no cold air
  138. 1991 cavalier LIGHT PANEL ON DECK LID? DONT WORK?
  139. z24 LIP 2003-2005?
  140. 04 Cavalier E-Brake doesn't release?
  141. surging while driving
  142. 98 cavalier 2.2
  143. Ignition Key
  144. 98 z24 problems
  145. 99 sunfire gt 2.4l tc a/t FUEL LINE REPLACEMENT
  146. 98 cav 2.2L A/C and engine problems?
  147. Issues with squeaking tires.
  148. P0171 too lean bank 1
  149. 1996 Chevy Caviler Smokes, missfires, and has oil in air intake box.
  150. 99 Cavalier ABS Light on
  151. 99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK
  152. 98 cavalier stalls
  153. 93 chevy cavalier
  154. 2.2 oil pan gasket
  155. ok heres one for ya I NEED HELP!!!!
  156. 96 2.2L crank/no start...keep reading
  157. Help with Air Conditioning Compressor
  158. obd codes 96 cavalier
  159. '98 repeating electrical problem (fuel line)
  160. ac in 98 cavalier
  161. 2004 overheating
  162. 97 CAVALIER blinks really fast
  163. 03 cavalier help -> W. VIDEO
  164. Accelerating/turning noise
  165. sounds like it wants to back fire
  166. 2003 cavalier growling noise
  167. 1996 z24
  168. ECM QUESTION for a 1994 Cavalier
  169. e brake
  170. 01 Cavalier, Fuel Line Schrader Valve Location?
  171. Good Site to get Codes, OBD2
  172. 2003 Cavalier fuel gauge problem
  173. 2004 chevy cavilier
  174. 95 Cavalier shimmy at Highway speed
  175. '91 Cav, 140000km, hesitates on acceleration up to 30km/hr
  176. 2003 cavalier HID help.
  177. 2003 cavalier help. Cluster gauges.
  178. 02 cavalier 2.2 ecotec HELP
  179. 2001 sputtering in drive
  180. AC issues
  181. 97 cav tranny issues
  182. help 2000 Z24 acting stupid
  183. Check Engine Light- Code 25
  184. cav. sutting off while driving
  185. Max AC Clicking/Tach Problem
  186. Wet floors-2002 4 door Cavalier
  187. Fuel Gage
  188. '03 Cavalier with slight ticking (Lifter? Timing? Tensioner?)
  189. Strange Radiator Fan Problem? Help?
  190. Air Conditioning Problems
  191. Horrible sound
  192. code P0325
  193. 96 cavy wont start
  194. timing & head Q's
  195. "97 Cavalier 2.2 slow start, & code 440 issues
  196. 99 Sunfire - Need help - 2 Problems....
  197. 1998 Pontiac Sunfire - No dash lights
  198. 99 Cav - Switch from non cruise to cruise?
  199. cavalier 99 cooling fan
  200. 94 problems
  201. 04 Cavalier Troubleshooting
  202. drl (daytime running lights)
  203. engine light comes on
  204. Engine and Transmission Compatibility Issues
  205. 97 sunfire clutch leak
  206. 94 cavalier stalls
  207. Decided to rebuild my engine
  208. 97 sunfire (2.4lt twin cam) serpentine route
  209. adding a/c
  210. Changed brake pads now trac off light and brake warning light stay on
  211. 1996 cavalier 2.2 shocks
  212. 2002 Cavalier - Oil in Air Intake
  213. 92 cav crankshaft sensor
  214. 1998 Sunfire 2.2 troubles
  215. 2000 Cavalier just died. Won't stay running
  216. P0440 Evap system problem
  217. Engine dies while going down the road
  218. 1992 Z24 3.1 Can't get the timing set back right....(MY FAULT)
  219. 2004 cavalier, only cranks and code reader wont read?
  220. What do you think about the Mitchell1 Website for manuals?
  221. Premature brake wear?
  222. Wheel Bearings
  223. 2.3 Tapping loud
  224. My 2002 Cavalier LS 4 Door Coupe
  225. stalls when put in gear
  226. 1998 2.2 L Sunfire overheats
  227. 99 cavalier 2.2 guage cluster goin crazy
  228. I don't want to spend a ton
  229. Stalls and studders
  230. Bad parts at Auto Zone??
  231. 2000 Cavalier Vent Flow Problem
  232. Aftermarket cd problems
  233. 2002 chevy cav err message on radio?
  234. Transmission Problem?
  235. Tips for starter modification
  236. Any other way to read the engine codes?
  237. Sounds like a LAwnmower, Help!
  238. 96 Sunfire 2.2L Misfire after new Batt. & Alternaotr
  239. Overheating and surging idle 99 z24
  240. no cooling fan
  241. power window limit switch
  242. check engine light
  243. 2002 Z24 Cavalier - won't start...sometimes...
  244. Electrical or just a pain?
  245. '97 cav 2.2 stalling
  246. horn button
  247. 1998 2.2L quit running
  248. 2002 Cavalier A/C and Radiator Fan Not Functioning
  249. 2000 Z24 dome light will not go out
  250. 93 cav 2.2 emissions control??
