View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16
  1. Overheating/Leaking Anti-freeze
  2. 1991 Z24 manual stalls
  3. 1999 Cavalier Mis Fire
  4. Fuel filter+ABS
  5. tack help....
  6. car is rev limiting at 3800
  7. Cavalier Charcoal Box
  8. 97 Cavalier Drum Brake Drag
  9. 1991 cavalier wagon issues
  10. 96 2.2L Cavy transmission....
  11. Could it be the timing belt?
  12. My car jumps
  13. Electric Windows Problems 96 Sunfire
  14. 97 Cavalier cold start problem
  15. Z24 2.4L engine swap
  16. 99 Cavalier Fuse Box
  17. 92 Electrical Problem..
  18. loss of power
  19. Bucking Cavalier
  20. 96 Cavalier wierd problem
  21. Cavalier RS 1992, accumulator battery type
  22. Belt problem...i think
  23. 97 Chevy Cavalier will turn over but will not start
  24. Checking/Adding Tranny Fluid, 97 Z24
  25. fuel/spark probs?
  26. adding new turn signal
  27. coolant river!?!?!?!?!
  28. 97 Sunfire skipping need help
  29. 95 cavalier timing chain
  30. 97 Sunfire - Starts runs for 2 sec, dies
  31. 89 Z24 Loss Of Oil Pressure
  32. still won't start...what next?
  33. front O2 sensor problem.
  34. Cruise control
  35. Many Problems...97 Z24...need help.
  36. How to remove the master cylinder.
  37. Temp Fluctuation while driving
  38. 96 Cavalier - Cranks, won't turn over unless with starter fluid
  39. Please help me Huge problem!!!
  40. Ideas
  41. Winter or Tinkerage?
  42. Engine Problem
  43. almost stalling, but not?
  44. PCM/ Engine Control Computer?
  45. How to tell if you have a head gasket problem
  46. slipping clutch/transmission?
  47. Blinker sound, no blinker on
  48. 91 cavalier
  49. new problem
  50. High pitched squeal
  51. Car wont turn over, and no power at all
  52. Now its just getting old
  53. Power Steering Pump
  54. Waterpump - Sunfire GT - anyone have manual?
  55. 98 Cav. Running Real Hot
  56. 98 Cav just died what could it be?
  57. trunk light not working
  58. Gas Leak
  59. Leaking Tires?
  60. Problems restarting after bad traffic
  61. New car, lots of little headaches.
  62. 1998 2.4l Auto cold acceleration problem
  63. ABS acting up
  64. Low Coolant - where is it going?
  65. Help 1997 Pontiac Sunfire...
  66. Please help with my '98 Sunfire
  67. Help!!!!!
  68. temperature guage stopped working
  69. clutch problem
  70. weird question
  71. CEL on... Need an O2 sensor
  72. an itty bitty problem. rough driving and power locks
  73. 97' Cavalier Help plz!
  74. 97' Cavalier Help plz!
  75. 97' Cavalier Help plz!
  76. 97' Cavalier Help plz!
  77. 2001 cavalier problems
  78. Help please -2000 caviler dies on highway
  79. 96 Cavalier overheating & wiring issues?!?!
  80. 2000 cav flickering problem need help
  81. low beams won't work...HELP
  82. Door Locks
  83. hard to start
  84. Noisey Fuel pump
  85. hard starting/anti theft the cause?
  86. Engine misfire?
  87. Aggravating car! I need help!
  88. chevrolet cavalier fuel pump problems
  89. Car starts...then stops..engine knocks..timing belt maybe?
  90. Replaced fuel pump but still no fuel?
  91. replacing 95 cav 2.2 l ohv water pump
  92. Coil Packs
  93. 89z24
  94. And the list continues....
  95. Car batteries Hydrometer went blank
  96. A/C comes on when heater turned to defrost
  97. strange grinding sound when starting!!!!
  98. Oil Burner
  99. starting cavalier
  100. crazy gauges
  101. CV Halfshaft
  102. Thump noise from front end
  103. 95 Cav Z24 stalling when hot
  104. 95 Cav Z24 stalling when hot
  105. 89 cavalier problem. help please :)
  106. Auto Tech 3.0
  107. HELP! Sunfire Rough idle/dies hard start
  108. How to replace alternator on 98 Z24?
  109. Two weeks later... ANOTHER mysterious problem!
  110. 1991 Chevy Calavier
  111. Electrical problem
  112. 2000 cavalier code B1001 - help please
  113. Idle problem after car was overheated
  114. 2.3 skipping problem
  115. Oil Filter for 2.2 L
  116. not starting
  117. instrument panel not working
  118. Oil cooler hose leak
  119. starting motor?...maybe?..click here and guess!!
  120. 02 Cav - radio stays on when door opens
  121. Gas leaking around fuel injector
  122. No spark from 1 plug wire
  123. Thank You...Thank You...Thank You...
  124. Lunchbox!
  125. Spark Plugs
  126. Bad Headlight Switch??
  127. Cv Joint
  128. Gas milage way too low
  129. changing a belt tensioner in a 94 chevy caviler
  130. Need new egr valve
  131. engine compatibility ???? HELP Blowen engine!!
  132. 96' Brake Problems also
  133. 1996 Cavalier Brakes
  134. 94 2.2 litre transmission problems
  135. 96 Cavalier will turn over but not start - HELP!
  136. How do I reset the engine computer?
  137. Slightly Low-High rpms and chaking. Please help
  138. 2000 z24 cavalier dim headlight
  139. 96 Cavalier no spark in #1 and 4 cyl!!!!!! 2.4L
  140. does my car TRULY need a fuel level sensor
  141. egr cleaning
  142. 98 sunfire wont start
  143. downshifting too late?
  144. crank shaft postioning sensor
  145. Engine Quit
  146. car takes long to start
  147. 2000 Pontiac Sunfire codes...
  148. Simple Vacuum question
  149. OverHeating
  150. airbag/seatbelt lights
  151. how many miles
  152. 97 Cavalier 2.2 Overheating
  153. alternator problems? or just a Screwed up car?
  154. 97 Sunfire wierd "knocking" sound???
  155. 97 pontiac clutch and shaking problems
  156. 97 Cavalier 2.2 - Rough Idle
  157. 99Sunfire 2.4L Automatic ~ Sounds like a Diesel
  158. 98 Sunfire Convertible Window switch
  159. Crank sensor location for a Cav. Z24 1995
  160. 01 Cavalier Z24 ABS
  161. bad clutch?
  162. '03 Cavalier headlight problem
  163. 96 Cavy VATS problem. TDM.
  164. 1989 Cavalier Z24 OVERHEATING LIKE MAD
  165. 2001 cavalier problem!
  166. Problem finding the proper brake line
  167. 2002 cav. anti lock break reset
  168. 01' Cavy will not start, please help!!!!!
  169. Big Problem
  170. 94 Trunk Release
  171. Small problem with a 99 Cavalier Z 24
  172. Radio and dash light issues
  173. 96 Cavalier Interior Light Problems
  174. Battery problem indicator keeps coming on
  175. 1993 Cavalier 2.2l No Start
  176. Annoying Engine Code..
  177. 97 Cavalier fuel lines
  178. 2000 Sunfire GT a/c
  179. 99 cavalier wont start
  180. Quick Questions about the Warning Lights
  181. extremely fast idle
  182. 2000 Sunfire Idle Problem
  183. transmission fluid check?
  184. Getting codes P0336..P0340...P0130
  185. power locks
  186. Temp Guage acting up.
  187. Where Do The Problems Lie With Cavaliers?
  188. in the process of finding the cause for my engine to be running on 3 cylinders.
  189. Chokes after use of accelorator
  190. High pitched engine noise
  191. Instrument Panel Probs--- long
  192. Low-Coolant Light on 2000 Cavalier when I shift from 3rd to 4th Gear only.
  193. rear defrost on 02 cavalier
  194. Problem With My Z24...acts Like Its About To Stall
  195. Lights dim, deck cuts out
  196. No Power to Starter
  197. 03 Cavalier 3rd Brake Light Out!
  198. 91 chevy cavalier rs loses power
  199. 2003 2.2L ecotech service light, ets, stall
  200. 2000 Sunfire not accelerating
  201. Cooling fan not working in 95 sunfire
  202. 2003 Sunfire headlight issue
  203. Problems in a 96 SunFire
  204. computer reprogram neccessary?
  205. 2001 New to me Cavalier
  206. Anit theft light is on
  207. loud noise HELP
  208. proper brake bleeding tech. for cavalier
  209. 2000 Sunfire No Brake Lights
  210. major brake problem
  211. 02'Sunfire
  212. 96 sunfire oil pan removal HELP!!!
  213. 96 cavalier starter/ignition
  214. please help 96 cavalier wont start
  215. 91 Cav 2.2 TBI, Serious Issues
  216. Help Please
  217. ETS check engine light on
  218. I Need Help
  219. 2002 Cavalier horn clicking??
  220. cavalier/sunfire won't start- fixed
  221. hell with it.
  222. Fuel Pressure Regulator
  223. Speedometer stopped working check light on?
  224. No light on my Odometer
  225. wierd popping noise
  226. need help please
  227. Blower Motor Works Intermittently
  228. 96 Sunfire - Engine Replacement?
  229. idles high rpm, smell gas, bad mpg = ???
  230. uggghh....brake issues
  231. New gas tank, new problem. 1996 2.2L Sunfire
  232. 98 sunfire stalling
  233. Fault code
  234. 97 2.4L Sunfire starting problems
  235. A/C clutch Sounds HELP!
  236. '94 Cavalier turn signal problem. Help!!
  237. Clutch Slave Cylinder
  238. 03 no start
  239. 96 Cavalier Charging Problem
  240. Sunroof problems....
  241. theft codes on 97 Sunfire
  242. 98 Sunfire - No Dim lights
  243. bypassing the ignition
  244. 98 z24 acceleration problem
  245. Idle and driving really rough.
  246. Rear Defroster not working
  247. "Theft System" light on
  248. 97' sunfire engine misfire
  249. How to Replace Radiator Cooling Fan
  250. 98 cavalier brake problem
