Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Cavalier
> Cavalier Problem Diagnosis |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
98 Cavalier Z24 no start/ VATS problem
exhaust problem
ecm or not
99 Sunfire --Flashers/Turn Signals, Brake Lights, a......
Big Electrical Problem
Idle RPM'S?
No Vacuum
2004 Cavalier Check Engine Problems
1995 Cavalier 2.2L No start when damp or wet
Depressed
Car keeps stalling after installing sub and amp..
99 sunfire starting problems
chevy cavalier 95 not starting
Trouble Code P1133
98 Cavalier died on me!
Fuel Problem
95 cavalier runs hard from start
98 Cavalier NO-START, please help!!!
98 Cav with awful gas mileage
98 Cavalier with awful gas mileage
RE: 96 Cavalier issues with randomly not starting and stalling for the last 6 months
Check Engine Light.... no code??
Ignition Lock Cylinder
cpu/sensor??
Help
97 Cavi Will Not Start.. im stumped
2002 Z24 Check engine light
GM techs, HELP!! stubborn crank position sensor.
Fuel Problems on '96 Cav
speedometer drive gear
2005 Sunfire Power Window Problem
Odd Problems 97 2.2
1989 Cavalier Transmision shift
engine problem
firebird wont start
climate control lights????
Stick is actin kinda funny
Demobilizer (i think) issue
98 Cavalier replace ac evaporator HELP!!
Bah, i knew at 220k something would go wrong
95 chevy cavalier quad driver codes (i need help)
odb 2 code p0480
1997 Chevrolet Cavalier 2.2 alternator
2.2 question
96 Cavalier takes average 50 seconds to start
Dumpin Fuel, Won't Accelerate ??
'02 Cavalier- car idle surging w/AC on and trans in drive
97 Cavlier IAT Sensor Problem
Rear wheel bearing
97' Z24 cyl 2 and 3 missfire???
gas gage problem
94 cavalier dies while in drive and reverse
Changed my coolant
91 Cav has trouble starting/running
fuel pump
03 Cavalier Check Engine Emisiions Warning?
Help Oil Smells Like Gas???????
2000 Z24 spark plugs?
99 Cavalier surges (reverse surges)
Cavalier Low Fluid Light
Car wont turn on.
93 Cavailier RS Car cutting off an on.
94 Cavalier Possible Tranny Overheat
Can Someone Explain This
How do I go about doing this...
Oil? '00 Sunfire Removing engine part.
No lowbeams & a ticking noise?
Confused Help
Noises
Air lock in cooling system
1995 sunfire speedometer quit working
Omg WTF HELP!!!
Stereo Issue
http://www.automotiveforums.com/vbulletin/showthread.php?t=698762
Front End Clunk
2002 Sunfire 2.4 High idle Problem
anoying and maybe harmfull noise plz help
Confused.....01 cavalier
Speedometer issue
steering column removal
Went to change my oil today and almost cried...
Hid xeon headlights in 05 Cavalier
95 cavalier
No power to fuel pump 2002 Cavalier
Engine blown?? Video posted.....
Check Engine? Can I do this myself?
Can't Find the Coolant Leak? HELP Please
Can't Find the Coolant Leak HELP Please
igntion key cylinder lockup
DTC P0335 and P0341
99 cavalier dash warning lights stay on all the time
why does my cavalier jerk around 35mph
Car chugging/stalling/poor acceleration
rattling/squeaking noise
wheel humming
ABS Light...
another z24 that won't start...this one's different though
Fuel pump problems
??97 Cavalier Overheating/Died, Now won't start??
whats not wrong with my kia?
97 cavalier a/c problem
Hard time starting my car.
lock out selinoid
DTC P0440 update
Subtle Vibration in 03 Cav
Can anyone help????
Anyway to fix a noisy Lifter?
oil?!?!
Whats wrong now?!!?
headlight, cruise and fog light problem in 2003 nsunfire
Blown Engine?
My parking and tail lights stays on after car is off, HELP!
CanOBD2 Reader and my Cavalier
Vibrations at high speeds
Help!!!
Oil plug
05 Rear Seat came unlatched?!
spark plug denting
Limp Mode? I've searched
beam lights 1996 chevrolet cavalier
2002 a/c problems
Uhhh something bad is wrong, I need help fast!
How to remove the dipstick in a 99 cavalier
couple of problems
98 sunfire surges
95 cavalier buzzing noise in dash
help
no spark
Engine light and traction coontrol light on
199 cavalier brake bleed issue
3.1 motor ?
2004 Cavalier misfire and stalling
1990 2.2 5sp
where is vss located
1996 sunfire trans won't shift
2000 Cavalier intermittent light problem
1998 Cavalier LS headlight issue
2004 Cav Oil change
97 Sunfire Transmission Problems
2002 Cavalier Z24 rattling??
Sunfire '97 Estimate Diagnostic Costs
2001 z24 lil input
Hesitation During Acceleration
97 Z24 almost stalling during cold starts
power window problem
96 sunfire 2.2 frustratedbouttagagiveup
95 Cavalier, 2.2L Intermittent Starting Issues
97 sunfire abs light
auto tranny
Leaky IAC Valve and DTC P0440.
B&M Shiftplus stopped working.....
compression problems 1997 2.2
10mm plug wires and coil pack question.
Battery getting drained/alternator is fine
2000 Sunfire - Monsoon CD player no longer working
Extremely Stumped...Please Help Me!!!
92 Cav. overheated replaced thermostat now dies for no reason
96 Cavilier Clutch Question
Speedometer replacement - sticking
what can kill the charging system
passlock or something else?
1994 Cavalier Rs Air Conditioner issue!
Front end thumping
96 cavalier transmission woes
96 cavalier front wheel noise
lights aint goin off.........
03 Cavalier won't start - Please help...
acceleration noise & excessive fuel consumption
2000 Idle stumbles
Strut mount problem??
Doing a running vacuum test 95 cavalier
91 Cavalier 2.2l Heater issue?
hey guys i'm back.... and i need a new Alternator
cooling fan relay
Wheel locked up
1994 Cavalier trouble codes
1993 cav acting stupid
Bad miss
Rebuilt Transmission Vs. Used
code 32 EGR diagnosticSw ..Signaling incorrect
01 Cav code P0440
Problems with my 89' Cavalier
Looking for expert advice...
Rear defrost and rear speakers dont work when its cold outsi
97 Cavalier thermostat ?
sunfire theft system and service light on with dying battery
2.2l rs 97 Cavalier missfire
need help!!
A/C leak in 2000 model
How do I fix the Vents?
Theft light stays on, key will not start car?
Emissions problem?
hole in air intake
Idiling Problems?
surging idle and stalling
Turn signal shuts off headlights???
94 Cavalier Signals
03 Cavalier 2.2L loud clicking under valve cover.
New computer? help please
95 2.2L, A/C and heat only work on HIGH!
98 Cavalier Thermostat Problem?
sunfire misfiring
95 cavalier 2.2L running rough
idle problem
intentifing engine size
Car loosing coolant after over heat.
Where is the Blower Motor Relay / Blower Resistor located
Heater is going on and off ???
02 sensors and your miles
exaust manifold/pipe
sunfire temp gauge
sunfire gt 96 wont start
1995 sunfire--2.2...no heat and speedo is not working...HMMM??
2001 Sunfire cooling system
Now car won't start because I can't dearm alarm
Died in the middle of the road.
350K...might be toasted
90 Cav stalls/hesitates from idle
location of 95 cavalier Horn relay
No fan/heater
I Smell gas when idelling
99 cavalier trunk lock problem
idle problem
89 z24 bad torque converter questions
96 Chevy Cavalier NO HEAT HELP!
98 Cavalier Front Speakers
94 z24 cavalier tranny problem
Another Engine Boging question
2000 Sunfire electrical
Trip odometer quit working
Fuel Problem 2000 Cavalier
'93 Cavalier, revs on turns and quick stops
fuel injector replacement
Engine bogging?! Need HELP!!!
Strange noise when turning wheel
Question about my cavalier shaking
95 water pump gasket leak after change
dim headlights
Speedometer not working and smell antifreeze
97 2.2L ODB Error code p0440
97 Z24 Power Window problem....
04 Sunfire gauges
electrical problems????
'90 Cav, bogging, hesitating.
Overheating/Leaking Anti-freeze
Web
AF
